15 Oct 2025 06:03
Replied by tommylight on topic LinuxCNC v2.9.6 Released
Category: LinuxCNC Announcements
Shortly after the release of 2.9.5 it was
noticed that a fix for a graphics bug in Gmoccapy had resulted in the
Axis touch-off dialog box no-longer working for non-zero entries.
I've been refraining from commenting on this till now, but i have to, i would absolutely prohibit changing anything that affects Axis GUI in any way, shape or form, from other GUI's or anything else.
Axis is and should remain bullet proof, that is the main reason i use it on all my machines (over 40 by now).
Destroying basic functionality on Axis to fix something already broken in GmoccaPy is plain absurdity.
I can absolutely understand if it was a mistake, but from a bit of reading it does not seem to.
I really hope i am wrong...
  • Hakan
  • Hakan
15 Oct 2025 05:38
Replied by Hakan on topic Ohmic sensing with IPTM-60
Category: Show Your Stuff
Recorded the voltage between tip and work piece during some 5 minutes. Was cutting a bunch of small holes.
They all look like this one, with some variation.
This was on a dry work piece. There is a clear voltage drop, somewhat slow, delayed recovery.
Triggered contact condition was a one-cycle voltage drop of 5 Volts.
  • unknown
  • unknown
15 Oct 2025 05:12 - 15 Oct 2025 22:50
fixing "raspi firmware" errors on the official amd64 ISO
Category: Installing LinuxCNC
Quick Update.
Using "Trixie" branch from here; salsa.debian.org/live-team/live-build/-/...rixie?ref_type=heads
I built a live-build package on a machine running Bookworm from the above repo. Installed the built package and was able to successfully build a Linuxcnc ISO without the raspi-firmware. As noted above hostmot2 firmwares are installed, a test run of Axis with the default gcode produced no errors, apart from latency due to being run in a virtual machine.
Building live-build packages from the above sources also works for building ISO on Linux Mint 22.1 Xia.
The goal would be to pin Linuxcnc to 2.9.4 during the ISO creation, as there seems to be a few issues reported by users with either the 2.9.5 or 2.9.6 branch.
  • Aciera
  • Aciera's Avatar
15 Oct 2025 05:10
Replied by Aciera on topic Glade Hal Meter Spindle Speed -> postgui
Category: GladeVCP
try changing
net Spindelrpm =>  gladevcp.Spindel <= spindle.0.speed-out
to
  • Aciera
  • Aciera's Avatar
  • vibram
  • vibram
15 Oct 2025 04:57
Replied by vibram on topic Lathe : 2nd turret over limit switch
I tried to do it correctly so I wired them as normally closed. I have 2 limit switches on the axis and this one is also my home switch.
If I follow your advice then I need to revert everything to have the other LS as HS. This is not an issue to be honest, just thinking about the consequences.
  • richcolvin
  • richcolvin's Avatar
15 Oct 2025 03:52
Replied by richcolvin on topic M19 for Indexing a Spindle using Stepper Motors
Thank you Peter.  I reviewed the link you provided, but is there a document or manual which describes how to set this up?
  • PCW
  • PCW's Avatar
15 Oct 2025 03:02
Replied by PCW on topic LinuxCNC installation + 7I96S
That indicates a Ethernet latency issue.
What does the command
sudo chrt 99 ping -i .001 -q -c 60000 192.168.1.121
report?
(the command will run for one minute then print statistics)
  • jmp97
  • jmp97
15 Oct 2025 02:45
Replied by jmp97 on topic LinuxCNC installation + 7I96S
When I move the engines after a while, I get this error.
I can't figure out what the problem is. The connection seems to be fine.
  • COFHAL
  • COFHAL
15 Oct 2025 02:08
PP problem versions 2.9.5 and 2.9.6 was created by COFHAL
I installed both versions 2.9.5 and 2.9.6 and both have the same problem with the parallel port. I have an MPG configured with a C10 and in version 2.9.4 it works perfectly, but in either of these last two versions it doesn't. When running LCN you can see with the hal that the parallel port is indeed loaded on the pins, but none of the functions programmed in the MPG work. I went back to 2.9.4 and the MPG works again.
  • RLA
  • RLA
15 Oct 2025 00:50
Replied by RLA on topic AC Servo change to run
Thanks to each for reply's...Going to get back to that in a day or so so will likely struggle a bit...but that is the way it works!
15 Oct 2025 00:19
Replied by tommylight on topic Injection molding
Injection molding
Category: CNC Machines
LinuxCNC can do all that, and much more, but it is much better to use a micro controller for that task, usually PLC, but you can make your own PLC just search for "arduino PLC" or "ESP32 PLC" .
15 Oct 2025 00:12 - 15 Oct 2025 00:17
M1xx: Controlling Relays (solenoids) from within axis MDI
@LangdonS,
what are you replying to ?
And might i add: why?
Edit,
OK i found it.
  • unknown
  • unknown
15 Oct 2025 00:02
Replied by unknown on topic Injection molding
Injection molding
There's an example of an electronic gearbox for a lathe, no gcode, just a custom GUI and some HAL connections.
Probably not a lot that you can use, but an example of what you can do.
My guess would be as long as you can get the data into linuxcnc and output any control values based on the input you should be fine. This would probably require some custom HAL written components to operate on the data and apply the output required. Oh yeah and maybe a gui.
The absolute simplest example I can think of is the parallel port tester, doesn't have any kinematics, but does allow you to control outputs and read the state of inputs.
Just throwing this out there.
MRO is another example. Maybe this could be a starting point, just start be reading data and displaying it, once you have that nailed, you could start with some simple HAL components to manipulate your data.
linuxcnc.org/docs/html/gui/mdro.html
Not an exact implementation but kind a simple example of what is achievable.
No doubt Andy will have a better idea and contradict everything Ive said, as he's way way more knowledgeable.
  • PCW
  • PCW's Avatar
14 Oct 2025 23:12
Replied by PCW on topic 6th axis for ATC
6th axis for ATC
As long as the axis is only controlled by gcode (with no direct display/control from the GUI)
it should work.
You will have to do some hand editing of the hal file to add
the additional joints/axis and kinematics specifier.
Displaying 12301 - 12315 out of 13405 results.
Time to create page: 2.060 seconds
