  • JT
  • JT's Avatar
10 Oct 2025 21:11 - 10 Oct 2025 21:12
Replied by JT on topic User interface
User interface
For startup Axis is as solid as you can get, as soon as you want something more suited to your machine and work flow then Flex GUI is the best because you can have what ever you want and what ever screen size you want. Other GUI's you have to use what the programmer wants you to use.
JT
  • Digger011
  • Digger011
10 Oct 2025 21:05
Replied by Digger011 on topic Strugling with installation
Category: Installing LinuxCNC
This is what I have a problem with after installing from LinuxCNC install image linux_2.9.4-amd64.hybrid
Is this correct?
  • andypugh
  • andypugh's Avatar
10 Oct 2025 21:02
Replied by andypugh on topic Set GPIOś via Halshow
Category: HAL
 Can i create new buttons in Linuxcnc?
Yes, but there are many ways to do it and the best choice will depend on the GUI you are using and your requirements.
Most of the GUIs support VCPs:
linuxcnc.org/docs/stable/html/ and see "Virtual Control Panels"
Some GUIs allow customisation inside the main window too.
  • andypugh
  • andypugh's Avatar
10 Oct 2025 20:51
  • Dragan
  • Dragan
10 Oct 2025 20:45
NEW BUILD, need help with e-stop in tklinuxcnc
Category: Basic Configuration
gui is launching i cant move the stepper with arrows because i am locked and i can not turn the machine on
  • PCW
  • PCW's Avatar
10 Oct 2025 20:41
Are you saying the GUI never launches?
  • andypugh
  • andypugh's Avatar
10 Oct 2025 20:38
Controlling spindle using python scripts and Modbus TCP
import linuxcnc and hal into the Python script, then create HAL pins to receive the spindle commands from HAL.
Load the Python script at load-time with a "loadusr" command in the HAL.
  • Dragan
  • Dragan
10 Oct 2025 20:37
c@raspberrypi:~/linuxcnc/configs/microcarve$ LINUXCNC - 2.9.6
Machine configuration directory is '/home/cnc/linuxcnc/configs/microcarve'
Machine configuration file is 'microcarve.ini'
Starting LinuxCNC...
Note: Using POSIX realtime
Found file(REL): ./microcarve.hal
task: main loop took 0.100768 seconds
task: main loop took 0.113741 seconds
task: main loop took 0.140260 seconds
this is what i get running it from commandline. task: main loop ........
  • andypugh
  • andypugh's Avatar
10 Oct 2025 20:34
Replied by andypugh on topic Axis configuration not fully working on 2.9.6
Category: AXIS
Can you report this problem on the issue tracker?
github.com/LinuxCNC/linuxcnc/issues
  • PCW
  • PCW's Avatar
10 Oct 2025 20:30 - 10 Oct 2025 20:32
if this:
net estop-loop =>iocontrol.0.user-enable-out
net estop-loop => iocontrol.0.emc-enable-in
does not work, it's most likely because you have
estop-loop connected to another pin in the hal file.
Starting LinuxCNC from the command line will show the actual error.
  • andypugh
  • andypugh's Avatar
10 Oct 2025 20:27
Replied by andypugh on topic XHC-WHB04B-04 Got it working
it's almost like multiprocess welders, unless you drop some serious money, you're compromising.
Off-topic but I am impressed with the multiprocess welder at my local Hackspace. It allows you to keep both MIG and TIG torches permanently connected and has separate gas input spigots for each process gas.
You are not wrong about the "serious money" part, though.
parweld.com/product/xtm211di/
(#notsponsored :-) )
  • Dragan
  • Dragan
10 Oct 2025 20:19
axis not working over vnc in my setup,
this is resulting in tklinuxcnc not starting, maybe its working with older software versions.
  • andypugh
  • andypugh's Avatar
10 Oct 2025 20:16
Replied by andypugh on topic NEW BUILD, need help with e-stop in tklinuxcnc
Oh, and why tklinuxcnc? There's nothing wrong with it, but it's rather outmoded and hasn't had a lot of developer attention for a while.
  • andypugh
  • andypugh's Avatar
10 Oct 2025 20:10
net estop-out =>iocontrol.0.user-enable-out
net estop-in => iocontrol.0.emc-enable-in
I think these need to be the same signal name to work as described. Try:
(note that the signal name is nothing special, there is no significance in changing it to loop, other than clarity. The important thing is that it should be the same name on both lines)
  • andypugh
  • andypugh's Avatar
10 Oct 2025 20:06
Replied by andypugh on topic Strugling with installation
Is this with the LinuxCNC install image?
Displaying 12511 - 12525 out of 13403 results.
Time to create page: 2.283 seconds
