  • unknown
  • unknown
05 Oct 2025 06:16
Undefined Reference to hal_export_funct Linker Error in LinuxCNC HAL Component
Category: Installing LinuxCNC
Is there any reason you can not use halcompile to build your component. As that is the "traditional" way to build components outside of the build process.
  • unknown
  • unknown
05 Oct 2025 06:12
Replied by unknown on topic 7i76eu connection issues
Not entirely clear about what you are trying to say.
Please attach any images to your post. So until you attach an image I can't comment on the boot issue.
You shouldn't be assigning 127.0.0.1 to any interface that requires traffic to go to another computer or device on a network. That address is traditionally used for "internal use only". Or the "local host".
The IP of your computer and the IP of the mesa card must not be the same. It's like having 2 houses on the same street having the same number.
10.10.10 could be considered the street name, the last number is the house number.
Pick ,say 10.10.10.11 for your PC.
  • takgu
  • takgu
05 Oct 2025 06:02
Hello,I am encountering a persistent linker error while building a HAL component for LinuxCNC, despite correctly identifying the location of the required function. I would appreciate any assistance from members who have experience using
hal_export_funct
. 1. The Problem I am trying to link my component, but the build fails with an "undefined reference" error for a HAL API function. 2. The Setup and Findings ItemDetailsInitial Linker Option
-L/lib -llinuxcnchal
Error Message
undefined reference to hal_export_funct
Source of ErrorI confirmed that the function
hal_export_funct
is not defined in
liblinuxcnchal.so
.Function LocationI found that
hal_export_funct
is defined in the real-time library:
/rtlib/hal_lib.so
.Attempted FixI updated the linker options in my build system (a
.pro
file using qmake) to include both libraries:
and
-L/rtlib -lhal_lib
.Resulting ErrorThe linker now reports that it cannot find the
-lhal_lib
library.
Sheets로 내보내기 3. The Core Issue The linker path to the directory (
/rtlib
) is accurate, and the library file (
hal_lib.so
) containing the function is confirmed to exist there. However, the build system or linker seems unable to successfully link
-lhal_lib
.Could this issue be related to:
  1. A specific linker flag order required for real-time libraries?
  2. A misunderstanding of how the HAL and RTAPI libraries should be linked together (especially since
    hal_init
    is present in both
    liblinuxcnchal.so
    and
    hal_lib.so
  3. An incorrect way to specify the library name (
    -l
    ) when using an absolute path or a custom library path (
    -L
    ) in the build system?
Any guidance on how to correctly force the linker to recognize and use
hal_lib.so
for
hal_export_funct
would be greatly appreciated.Thank you.
  • Ayden25
  • Ayden25
05 Oct 2025 05:31
7i76eu connection issues was created by Ayden25
I switched w13 and w14 as the instructions declare and I am still getting 127.0.0.1 in either default and eprom.At any rate I am getting a error on boot www.facebook.com/share/p/1BkDAYUf7Q/Fb post with the image of my error. I changed the ip of the pc to match the 127.0.0.1 to match what people are doing with 10.10.10.10 but still no luck any thoughts cant find any eu specific info or a 7i76eu specific profile on linux cnc.
  • unknown
  • unknown
05 Oct 2025 00:12
Replied by unknown on topic Installing LAN driver for RealTek 8111H
I would still fix the raspi thing, it'll bite later on.
And the kernel supplied RealTek drivers aren't the best.
  • cmorley
  • cmorley
04 Oct 2025 23:18
Replied by cmorley on topic Change camera resolution Qtdragon?
Category: Qtvcp
Are you talking of the resolution of the camera or the size of the window?
There is no built in way to set camera resolution but you can scale the window.
linuxcnc.org/docs/devel/html/gui/qtdragon.html#_camview_tab
  • Digger011
  • Digger011
04 Oct 2025 22:58
Replied by Digger011 on topic Installing LAN driver for RealTek 8111H
It looks like the error is on my side. Lan adapter was disabled in BIOS. After enabling it, Lan connected to network using live installation.
Thank you guys for all your support and suggestions.
M
  • Hakan
  • Hakan
04 Oct 2025 22:57
Replied by Hakan on topic CiA 402 in 1.15.0
CiA 402 in 1.15.0
Category: EtherCAT
Yeah it is a bit tricky this one. The basic_cia402 device is a very capable device, but as usual with ethercat one need to know everything in advance.
The documentation github.com/linuxcnc-ethercat/linuxcnc-et...umentation/cia402.md outlines many details and mentions the modParams, with which one can enable and disable features of the drive.
The first error is about sdo 0x6060 and 0x607c, and in the doc one can see what they do.
Your drives don't have those features is my assumption, or not enabled. You need to get rid of all,those sdo download problems.
Anyway, what you should do is take the output of the command "lcec_configgen"
which will have a long list of modParams and select those you are going to use and your drive has.
Not so easy to enable/disable right but give it a go.
Also, errors from ethercat generally goes into syslog, you can see them with the command "sudo dmesg" the last maybe 20 lines are the importqnt.
04 Oct 2025 21:34
Replied by tommylight on topic Hypertherm hsd130 interface
Category: Plasma & Laser
Also, do you mean one 1Mohm/2w on each wire for a total of 2 resistors or two 1Mohm/2w on each wire for a total 4 resistors?
1 resistor on each wire, two in total.
So my advice on wiring on the rectifier wont work as this seems to be an SCR controlled rectifier, but there is hope, wire resistors to the big terminals on the picture on the left side, use a DVM to find the torch and clamp connections, clamp will be positive and torch will be negative but you have to remove the torch cap to check as the outer torch nozzle is not connected to any of those.
Are the high voltage/high frequency parts on the other side of that metal wall?
04 Oct 2025 21:26
Replied by tommylight on topic CiA 402 in 1.15.0
CiA 402 in 1.15.0
Category: EtherCAT
From your error report:
./cia402.hal:16: insmod for lcec failed, returned -1
HAL: ERROR: pin 'lcec.0.3.out-01' not found
But that pin is not in your attached hal nor xml file, so wrong files maybe ???
  • bassti
  • bassti
04 Oct 2025 19:11
ATC - Servo, Analog, Carousel was created by bassti
Hello,
I got some trouble - with my ATC
Problem:
ATC wont align to the right pocket number
Homing works not correct
The ATC has one INI to find Pocket 1
A servo drives the magazin but i cant use the index for homing because the in comes several times per magazin rev.
my questions:
1. is it possible with the carousel comp to drive these ATC ?
2. if the first answer is yes - can anyone help me finding the errors in my config?
Thanks, bassti
  • ckuecker
  • ckuecker
04 Oct 2025 19:08
EasyProbe buttons not moving axes was created by ckuecker
I installed EasyProbe on my gantry mill running AXIS. The probe signal works, the manual zero buttons and the G54 - G59.3 buttons work.
None of the probe motion buttons work.
Any ideas on how to troubleshoot this would be appreciated!
  • MatthiasCNC
  • MatthiasCNC
04 Oct 2025 19:04 - 04 Oct 2025 19:05
Replied by MatthiasCNC on topic CiA 402 in 1.15.0
CiA 402 in 1.15.0
Category: EtherCAT
Hello,
I am new to LinuxCNC. I am trying to get a Festo CMMT-AS-C2-3A-EC-S1 to work via Ethercat with the CiA402. Unfortunately, I keep getting error messages when I start it up and have no idea what the problem could be.
Error message when starting up.
Debug file information:
Note: Using POSIX realtime
Failed to execute SDO upload: Input/output error
LCEC: slave 0.yaxis: Failed to execute SDO upload (0x6060:0x00, error -5, abort_code 00000000)
Failed to execute SDO download: Input/output error
LCEC: slave 0.zaxis: Failed to execute SDO download (0x607c:0x00, size 4, byte0=1, error -5, abort_code 00000000)
LinuxCNC Ethercat crashed with signal 11
-- STACK TRACE START
0    /usr/lib/linuxcnc/modules/lcec.so(+0xfc8c) [0x7ff70e4ddc8c]
1    /lib/x86_64-linux-gnu/libc.so.6(+0x3c050) [0x7ff70f2f7050]
2    /lib/x86_64-linux-gnu/libc.so.6(+0xa9d76) [0x7ff70f364d76]
3    /usr/lib/linuxcnc/modules/motmod.so(+0xd9b8) [0x7ff70e6309b8]
4    /usr/lib/linuxcnc/modules/motmod.so(+0xd5ad) [0x7ff70e6305ad]
5    /usr/lib/linuxcnc/modules/motmod.so(+0xd2c3) [0x7ff70e6302c3]
6    /usr/lib/linuxcnc/modules/motmod.so(+0x4a46) [0x7ff70e627a46]
7    /usr/bin/rtapi_app(rtapi_print_msg+0xbf) [0x558ee0026f2f]
8    /usr/lib/linuxcnc/modules/lcec.so(+0x11e94) [0x7ff70e4dfe94]
9    /usr/lib/linuxcnc/modules/lcec.so(+0x1316d) [0x7ff70e4e116d]
10    /usr/lib/linuxcnc/modules/lcec.so(rtapi_app_main+0x348) [0x7ff70e4dee76]
11    /usr/bin/rtapi_app(+0xbd67) [0x558ee0029d67]
12    /usr/bin/rtapi_app(+0xc6be) [0x558ee002a6be]
13    /usr/bin/rtapi_app(+0xccbc) [0x558ee002acbc]
14    /usr/bin/rtapi_app(+0x7a04) [0x558ee0025a04]
15    /usr/bin/rtapi_app(main+0x70f) [0x558ee002548f]
16    /lib/x86_64-linux-gnu/libc.so.6(+0x2724a) [0x7ff70f2e224a]
17    /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0x85) [0x7ff70f2e2305]
18    /usr/bin/rtapi_app(_start+0x21) [0x558ee00258f1]
-- STACK TRACE END
./cia402.hal:16: waitpid failed /usr/bin/rtapi_app lcec
./cia402.hal:16: /usr/bin/rtapi_app exited without becoming ready
shutdown.hal:2: unlink failed
2648
Stopping realtime threads
Unloading hal components
Waited 3 seconds for master.  giving up.
lcec: not loaded
<commandline>:0: exit value: 255
<commandline>:0: rmmod failed, returned -1
motmod: not loaded
trivkins: not loaded
homemod: not loaded
tpmod: not loaded
<commandline>:0: unloadrt failed
I have attached my hal, ini, and xml files below. Does anyone have any idea what I have configured incorrectly?
Thank you.
  • chrischan
  • chrischan
04 Oct 2025 18:45
Replied by chrischan on topic Probe screen v2 - malfunction?
Hey guys
I have similar problem.
When hitting page up or page down button, the z axis starts moving until the end stops. And only stops moving if probe sensor is touched or esc button.
Why does the probe screen behaves that way?
is it possible to remove this function?
I started to read the different py files, but didn't find a clue to this problem.
Displaying 12856 - 12870 out of 13402 results.
Time to create page: 1.006 seconds
