  • Aciera
  • Aciera's Avatar
23 Sep 2025 13:22 - 23 Sep 2025 13:31
Setting up kinematics for my Ballscrew articulated B-axis
Category: Basic Configuration
Personally I would suggest tp use the .comp format:
linuxcnc.org/docs/2.9/html/man/man9/userkins.9.html
But regardless,
Forward kinematic uses the joint positions to calculate the cartesian coordinate positions
Inverse kinematic uses the cartesian coordinate positions (ie the position commands of the motion planner) to calculate the joint positions (ie basically the commands that get sent to your motor drives)
One needs to be the mathematical inverse of the other (otherwise the values will run off and you will get limit violation errors)
  • RobotMatic
  • RobotMatic's Avatar
23 Sep 2025 12:06
Replied by RobotMatic on topic 7i76E Spindle configuration
Category: PnCConf Wizard
I was able to check the connection yesterday, you were right, [GND pulse - dir -] I had them bridged. !!
I always connected them, I understand that it's wrong! I like to learn because the board can get burned with this connection. I thought that the ground from both the driver and the board should be connected.
thank you!!!
  • alangibson
  • alangibson
23 Sep 2025 11:38
Replied by alangibson on topic No underspeed with temporary material
Category: Plasmac
I just checked and I was actually on LinuxCNC 2.9.4. QtPlasmaC version is v2.9-238.315. Is that version effected by the bug you mentioned? I'm going to assume so since the gcode works for you.
I've also just deployed a new version of MetalHeadCAM to metalheadcam.alan-gibson.workers.dev/. I'd really appreciate your feedback on it as I'm specifically targeting QtPlasmaC.
The basic workflow is:
- Click the hamburger menu and then Tools so you can add your tool parameters
- Import a DXF file on the Import stage
- Skip the Edit stage for now as it doesn't do much yet
- Click the topmost Apply button on the Prepare stage
- Add operations to parts and shape chains on the Program stage, making sure to select what you want to cut in the Apply To dropdown.
- Simulate the program on the Simulate stage or just skip it
- Download gcode on the Export stage
  • alangibson
  • alangibson
23 Sep 2025 11:33
MetalHeadCAM: dxf2gcode and Inkscape gcode plugin replacement
Category: Plasmac
Hi All,
I've just released an update that provides improved lead in/out support. Any feedback is of course appreciated.
  • cmorley
  • cmorley
23 Sep 2025 11:18
QtVCP Cannot Connect Message Dialog Box Hal Pin
Category: Qtvcp
qtdragon.probe-error pin is an I/O pin not an input pin.
I'll have to think more on the best way to add external error checking/handling.
It's a problem spot for linuxcnc.
  • Gautham
  • Gautham
23 Sep 2025 04:53 - 23 Sep 2025 09:21
Ok, sorry for the images. Anyway, I performed all the math on Google Sheets, so you can enter the B-axis position on the ball screw, and it will provide you with the spindle angle, the tooltip x-offset, and the tooltip z-offset. The range of travel for the B-axis is 0 to 305mm. You can enter this in cell Y11, and it will spit out the results. I have also illustrated the drawings better here so that hopefully you can understand. Here is the link . I have looked at the Kinematics tutorial on the website, but I just learn better if I can see someone do a working example. After hours of reading that with Gemini helping with some of the explanations, I don't know how to start writing the code. Anyway, from the tutorial I posted earlier, there is an image of this person's kinematicsInverse function, which I will insert below.
From what I've understood, the job of this function is to understand the required tool tip movement and spit out the number of steps each axis motor needs to make, correct? If that is correct, I should be able to modify the trigonometry here to accommodate my ballscrew articulated B-axis and get this going, hopefully. Because his setup also has an XYZAB setup similar to mine.
  • unknown
  • unknown
23 Sep 2025 02:34
Replied by unknown on topic New install on previously working system
Category: Installing LinuxCNC
If your're running a mes card there is no need to test with a base thread. Servo thread is all that is needed.
Usual advice, turn off power saving, anything that attempts to change clock speed in the BIOS, also turn off hyper threading if that is an option, for a 4 coremachine you might get some relief from isolcpus=2,3
It may help to supply some details regarding the machine you're using.
  • royka
  • royka
23 Sep 2025 01:05
Potential All-in-One Single Board Computers
RADXA Cuby A7Z
radxa.com/products/cubie/a7z/
SoCAllwinner A733 CPU2x Arm® Cortex®-A76 up to 2.0GHz6x Arm® Cortex®‑A55 up to 1.8GHz1x Alibaba RISC-V XuanTie E902 up to 200MHz
GPIO40-Pin GPIO Header with I2C / SPI / PWM / I2S etc
MCU: RISC-V E902 (200MHz) Coprocessor, Real-time tasks and low power management
Unfortunately I didn't see documentation yet
  • ckuecker
  • ckuecker
23 Sep 2025 00:24
EasyProbe error was created by ckuecker
EasyProbe error
Category: pyVCP
I'm trying to get EasyProbe running on my mill. I had an older version running, but am having problems with the probe signal.
The report file shows: Probe_postgui.hal:14: Pin 'hm2_7i96s.0.gpio.040.in_not' was already linked to signal 'probe-in'
Probe_postgui.hal has:
Probe signal and LED control (see readme.md)
# dbounce_probe.in must be linked to the probe tool input of the interface card
setp  dbounce_probe.delay      [PROBE]DEBOUNCE_TIME
setp  xor_probe.in0            [PROBE]PROBE_SWITCH
net   probe-raw                dbounce_probe.in             <=    hm2_7i96s.0.gpio.040.in_not
net   probe-switch             dbounce_probe.out            =>    xor_probe.in1
net   probe-signal             xor_probe.out                =>    motion.probe-input pyvcp.probe_led
I can't find any other instances of probe_in. Where might it be?
  • ckuecker
  • ckuecker
22 Sep 2025 23:14
Replied by ckuecker on topic New install on previously working system
That got me up - but now I've got "Unexpected realtime delay on task 0 with period 1000000"
Latency test gives 60624 ns jitter on the servo thread and 70111 ns jitter on the base thread.
  • Clark222
  • Clark222
22 Sep 2025 23:12
Replied by Clark222 on topic QtDragonHD tool sensor help for a maker space
Category: Qtvcp
I've been using Linuxcnc for the past 5-6 years (I use to be Clark22 but I got locked out).   More accurately, I've been making baby steps towards getting my cnc to work properly before taking an extended break (build the machine and get it moving, stop for a long break, get the spindle working properly, take a break, get endstops working then take a break ......).  The last big step was getting the spring probe and edge probe to play nicely with each other and then to get the auto tool change and updated tool.table working.  I've don't tend to ask for help but rather keep plugging at it until I get it figured out.  The past month has been going around and around, but today I finally got it working.  I've seen you ask for people to test out the probe_routine.py and the versa_probe.ui and I wanted to let you know that I got it working today and I really like how it's doing.  I have a lot more testing on it to make sure it's actually working but after a month the tool.tbl finally updates.  For anyone else wanting to try these out there's on part that was causing a lot of confusion for me.  the python_probe.py goes in the /usr/lib/python3/dist-packages/qtvcp/widgets/probe_routines.py directory and the versa_probe.ui goes in the /usr/share/qtvcp/widgets_ui directory.  For some reason I had the versa_probe.us in the first directory (who knows how it ended up in there). I thought clarifying that might help somebody.
  • snowgoer540
  • snowgoer540's Avatar
22 Sep 2025 23:02
Replied by snowgoer540 on topic No underspeed with temporary material
Category: Plasmac
That is not really helpful, need to know the QtPlasmaC version in the window's header.
For what it's worth, I ran your G-Code on v2.10-009.071, it runs fine.
I added a feature in 2.10 that changes the "VEL:" label to show when a reduction is present. In this case, the line read "VEL@60%: 1020"
  • tightmopedman9
  • tightmopedman9
22 Sep 2025 22:29 - 22 Sep 2025 22:30
Replied by tightmopedman9 on topic QtVCP Cannot Connect Message Dialog Box Hal Pin
Category: Qtvcp
It's a program that's intended to pause machine motion (halui.program.pause) anytime the wireless probe controller detects an error (hm2_5i25.0.7i84.0.2.input-24 == 1).
It creates a few HAL pins, one of them being: c.newpin("show-message",hal.HAL_BIT, hal.HAL_OUT) # -> qtdragon.probe-error
I added code to the probe_routines.py file which will set motion.digital-out-02 anytime the probe is in motion (through the MDI command 'M65 P02').
I've been working on the best way to implement error handling while a wireless probe is in motion. I initially tried setting HAL pins directly by patching the probe_routines.py file, but I couldn't get that to work. I then tried tying the same QTDragon dialog to motion.digital-out-00 and then sending a 'G64 P00' in the probe_routines.py before any probe movement. This didn't work as well - I got the same 'HAL: ERROR: signal 'probe-error-msg' already has output pin'. Also, since 'ACTION.CALL_MDI' pauses the UI, I don't think that this method would have worked anyways.
Currently, I have rudimentary error handling implemented by checking a digital input tied to the probe error output before the start of any probe motion (all within probe_routines.py). The subroutine will wait up to 5 seconds for the error to be handled, and will abort if there is no resolution. I tried adding a user interaction dialog box into this routine but I wasn't ever able to display a message to the user while the routine was active. Another issue with this approach is that the subroutine won't halt motion if the probe errors out after a MDI command has been sent, but before the probe has finished its motion.
The idea behind the newest implementation is that anytime the probe is in motion and an error is detected, machine motion will be paused, the user will be prompted for intervention and upon clearing the fault, the routine will resume.
Until fairly recently, I was using probe basic with .ngc files for all the subroutines. I updated and switch to QTDragon, at which point I tried (unsuccessfully) moving over my probe error handling to the python based probe routines.
If there is a different implementation you could think of, I'd love to hear it. I haven't been able to find a solution that's already been implemented.
  • unknown
  • unknown
22 Sep 2025 21:46
Replied by unknown on topic Linear Move Exceeds Lower Limit
Might have helped if you mentioned this to begin with. You really wasted a lot of people's time not giving the whole story.
  • scsmith1451
  • scsmith1451's Avatar
22 Sep 2025 21:24
Replied by scsmith1451 on topic Linear Move Exceeds Lower Limit
Out of frustration, I removed the o<word> declarations from the file and loaded the file as a normal g-code program. It worked correctly, start to finish. What ever was happening, mysteriously evaporated.
Thanks for your input and consideration.
Displaying 13291 - 13305 out of 13406 results.
Time to create page: 1.030 seconds
