  • Hakan
  • Hakan
19 Aug 2025 07:53
EtherCAT RC Servo Motor & PWM Output Interface Board
Category: Show Your Stuff
Where do you see this board being used?
Haven't seen much use for RC servos in linuxcnc.
Is it in robotics maybe?
  • meister
  • meister
19 Aug 2025 07:42
Exactly, and now I also have an original mesa board with which I was able to create a board file and test the whole thing.
  • unknown
  • unknown
19 Aug 2025 07:21
So basically you're supporting Mesa hardware, something I mentioned along time ago, which the Spartan6 hardware I added to the repo basically is, 7c81 ish clone.
  • rodw
  • rodw's Avatar
19 Aug 2025 07:20
Replied by rodw on topic pc for linuxcnc using ethercad and Mesa
8 gb will be fine. SSD whatever you want but mostly I've used from 64gb to 256 gb
  • rodw
  • rodw's Avatar
19 Aug 2025 07:18
Replied by rodw on topic ARE YOU KIDDING ME YOUTUBE !!!
8.7 TB free here.
You should be able to install a gitlab at home too. docs.gitlab.com/install/docker/ then you could clone what you want into your trpo
  • meister
  • meister
19 Aug 2025 07:15
I am getting this right, the W5500 acts as an Ethernet bridge ?
Yes
So this should also work with the 7I90HD in spi mode ?
7I90HD should work with small changes
Or any Mesa SPI firmware (custom) like something I've put together ?
No,
This has nothing to do with the Mesa gateware/firmware; RIO runs on Mesa hardware here.
Mesa gateware does not support W5500 modules.
  • rodw
  • rodw's Avatar
19 Aug 2025 07:12
Compleatly off line Voron image possible ?
Category: Additive Manufacturing
After 15 years of google drive, and running a Synology NAS, I have moved to on site (at home) for all my emails and web sites. But I started using cloudflare for dns. Should I do that?
  • unknown
  • unknown
19 Aug 2025 07:09
  • rodw
  • rodw's Avatar
19 Aug 2025 07:05
Replied by rodw on topic Carousel ATC setup on Probe Basic
Category: QtPyVCP
The standard qtpyvcp is not pi5 compatible, it requires a special build, this is likely why you're having issues. I don't use pi so I'm not the best source of help, I think rodw has a deb file build available, maybe he will chime in.
No can't help. QTPYVCP would need to support the Pi5 in its repository. Installing Debian 13 on the Pi might now be a solution but they don't seem to offer a img for the pi5.
  • besriworld
  • besriworld
19 Aug 2025 06:04
Replied by besriworld on topic Mini wannabe datron build
Category: CNC Machines
Great job. It just looks like a drawing :).
How much did it cost to make that blue part?
  • Daan96
  • Daan96
19 Aug 2025 05:57
Building a 3-axis plasma table with mesa 7i96s, THCad-2 and nema23 steppers
I've decided to immediately apply a 1:3 reduction ratio, which translates to 25mm (15T) or 20mm (12T) of displacement per revolution.
I want to listen to the advice of  rodw and  tommylight :)
This will change the design somewhat. I think I'll place the linear guide directly on the underside of the tubes to reduce contamination.
Slowly, all the parts are arriving, and I've started welding the table. Unfortunately, I have limited time :(
  • emresensoy
  • emresensoy
19 Aug 2025 05:47
EtherCAT Isolated Digital & Analog IO Board
– ETHERCAT DIGITAL & ANALOG IO BOARD
– 12x ISOLATED DIGITAL OUTPUT
– 12x ISOLATED DIGITAL INPUT
– 4x ISOLATED 0-10V ANALOG OUTPUT
– 4x ISOLATED 0-10V ANALOG INPUT
– 24VDC SUPPLY
www.egerobotics.com/ethercat-digital-analog-io-board
  • emresensoy
  • emresensoy
19 Aug 2025 05:45
EtherCAT Incremental Encoder Interface Board
– ETHERCAT ENCODER INTERFACE
– 2x ENCODER CAN BE CONNECTED SAME TIME
– 1 DIFFERENTIAL LINE DRIVER ENCODER INPUT(5V)
– 1 TOTEM POLE ENCODER INPUT (5-24V)
– 24VDC SUPPLY www.egerobotics.com/ethercat-encoder-interface
  • meister
  • meister
19 Aug 2025 05:15 - 19 Aug 2025 05:16
There is now support for a Mesa board: eusurplus.com/index.php?route=product/product&product_id=131
It can be used via RPI over SPI and over Ethernet via W5500
There are also developments in the new configuration front end, but it is still far from complete.
PS: Many thanks to EUSurplus for their support!
Best regards, Olli
  • ant0ny
  • ant0ny
19 Aug 2025 04:22 - 19 Aug 2025 06:15
Stepper motors running rough after re install
Category: Basic Configuration
Tommy,
Oh ok... I still have my working 2.7 install... yeah lean't long ago to always keeps what is working.
I'll do the 2.7 install on the new computer and see if that works and it runs smooth.
UPDATE:
2.7 hates my Z420 Workstation... installs but runs slow and when I setup and Launch Linuxcnc program the window is blank with "no file" in the top title.
My old machine is a HP xw4600 Workstation and it runs Linuxcnc great but I thought I would "future proof" my setup with something "less old".
2.9 runs fine on the Z420 but just not usable with the way it runs the stepper motors.
Displaying 13486 - 13500 out of 14171 results.
Time to create page: 1.164 seconds
