  • Chris91
  • Chris91
10 Aug 2025 18:59 - 10 Aug 2025 19:00
Starthilfe Retrofit ISEL CPM4030 MESA7i95T+7i83
Category: Deutsch
So that's how it is?
# Axis: X Joint: 0 Output: 0
# PID Setup
setp pid.x.Pgain [JOINT_0](P)
setp pid.x.Igain [JOINT_0](I)
setp pid.x.Dgain [JOINT_0](D)
setp pid.x.bias [JOINT_0](BIAS)
setp pid.x.FF0 [JOINT_0](FF0)
setp pid.x.FF1 [JOINT_0](FF1)
setp pid.x.FF2 [JOINT_0](FF2)
setp pid.x.deadband [JOINT_0](DEADBAND)
setp pid.x.maxoutput [JOINT_0](MAX_OUTPUT)
setp pid.x.error-previous-target True
# limit stepgen velocity corrections caused by position feedback jitter
setp pid.x.maxerror [JOINT_0](MAX_ERROR)
# joint-0 enable chain
net joint-0-index-enable <=> pid.x.index-enable
net joint-0-index-enable <=> joint.0.index-enable
net joint-0-enable <= joint.0.amp-enable-out
net joint-0-enable => pid.x.enable
# Enable Stepgen
net joint-0-enable => hm2_7i95.0.7i83.0.0.analogena0
# Joint 0 Step Generator Settings
setp hm2_[MESA](BOARD).0.stepgen.00.dirsetup [JOINT_0](DIRSETUP)
setp hm2_[MESA](BOARD).0.stepgen.00.dirhold [JOINT_0](DIRHOLD)
setp hm2_[MESA](BOARD).0.stepgen.00.steplen [JOINT_0](STEPLEN)
setp hm2_[MESA](BOARD).0.stepgen.00.stepspace [JOINT_0](STEPSPACE)
setp hm2_[MESA](BOARD).0.stepgen.00.position-scale [JOINT_0](SCALE)
setp hm2_[MESA](BOARD).0.stepgen.00.maxvel [JOINT_0](STEPGEN_MAX_VEL)
setp hm2_[MESA](BOARD).0.stepgen.00.maxaccel [JOINT_0](STEPGEN_MAX_ACC)
setp hm2_[MESA](BOARD).0.stepgen.00.step_type 0
setp hm2_[MESA](BOARD).0.stepgen.00.control-type 1
# position command and feedback
net joint-0-pos-cmd <= joint.0.motor-pos-cmd
net joint-0-pos-cmd => pid.x.command
net joint-0-pos-fb <= hm2_[MESA](BOARD).0.stepgen.00.position-fb
net joint-0-pos-fb => joint.0.motor-pos-fb
net joint-0-pos-fb => pid.x.feedback
# PID Output
net joint.0.output <= pid.x.output
net joint.0.output => hm2_[MESA](BOARD).0.stepgen.00.velocity-cmd
# net joint.0.output => hm2_7i95.0.7i83.0.0.analogout0
  • probotix
  • probotix
10 Aug 2025 18:14 - 10 Aug 2025 18:15
@mBender
Where you at in Florida? How can I contact you?
JCLPCB delivered my self made PCB board. Testing ongoing. I had to order 5 boards. If anyone is interested in one, I have a few spares. Located in the Florida USA.
  • andypugh
  • andypugh's Avatar
  • andypugh
  • andypugh's Avatar
10 Aug 2025 17:01
Replied by andypugh on topic LiCHUAN A5 AC Servo Fine tunning
I would first reduce the acceleration in the INI and see if that makes a difference, just because that is quick and easy. (and you know exactly what you have changed, which might not be the case with tuning software).
That's probably not the final solution, but it may help narrow-down the problem description.
  • andypugh
  • andypugh's Avatar
10 Aug 2025 16:53
New member from Germany - CNC retrofit of a Leinen FM1
Yes, you are right, the tacho signal can be connected directly to the DC motor amplifier. I have only one amplifier for the 3 axes. So I can run them only in sequence.
Is this one of those systems that can only move one axis at a time?
  • Hartwig
  • Hartwig
10 Aug 2025 16:49
Hi Andy,
thanks a lot for your response. I will try it and buy the recommended MESA Board.
I hope, I will find out how to interpret the inputs (TTL ?) from the Heidenhain EXEs.
Is there any chance to get connected to the LinuxCNC developer in Münster?
Best regards
Hartwig
  • andypugh
  • andypugh's Avatar
10 Aug 2025 16:49
Replied by andypugh on topic M66 keeps waiting
M66 keeps waiting
Category: G&M Codes
Thanks for the replies. I guess updating Linux and LinuxCNC is the only option left.
Note that I don't actually expect that to fix this issue.
Can you attach your HAL files(s)?
  • andypugh
  • andypugh's Avatar
  • andypugh
  • andypugh's Avatar
10 Aug 2025 16:07
Replied by andypugh on topic how to make M7 (mist on) generate step pulses
Category: G&M Codes
I don't normally recommend PyVCP as it is not very flexible, but in this case it is probably a good choice.
linuxcnc.org/docs/stable/html/gui/pyvcp.html
The example panel in section 4.1 is very close, you would just swap the bar for a slider, and connect to stepgen.4.velocity-cmd instead of the spindle speed.
  • cakeslob
  • cakeslob
10 Aug 2025 15:55
Advice sought...getting started with Remora/Linuxcnc
its easier if you use the threads we have stickied at the top.
unless the chip is a good clone, we dont support the GD line of clones. the lowcost hardware that will be the least trouble are the ones listed on the docs
  • andypugh
  • andypugh's Avatar
10 Aug 2025 15:53
You _probably_ don't need to take the tachos to LinuxCNC.
Typically the tachos connect only to the servo drives to feed back velocity, and the analogue voltage input from the controller sends a velocity command based on position feedback from the glass scales.
The Leinien FM1 looks like a lovely little thing.
An all-in-one solution from Mesa would be: store.mesanet.com/index.php?route=produc...id=397&search=analog
But there might be cheaper options (for example 6i24 + 7i33TA) but the 7i97T ethernet option will work with just about any supported computer, including the Raspberry Pi.
Other options exist. EtherCAT, Pico PPMC for example.
One of the LinuxCNC developers lives in Münster, I think.
  • ihavenofish
  • ihavenofish
10 Aug 2025 15:40 - 10 Aug 2025 15:41
Replied by ihavenofish on topic Mini wannabe datron build
Category: CNC Machines
Fleshing out the rest of the bits.
Found a nicer cheap 21" touch panel on waveshare, seems like it would work well as a vertical panel with qtdragon
  • Hartwig
  • Hartwig
10 Aug 2025 15:38
Heidenhain EXE610 - which MESA board would be needed to connect 4 of them?
Category: Driver Boards
Dear members,
a simple question. I hope, that somebody knows the answer and responds.
I would like to connect 3 Heidenhain glas scales LS303  and 1 Heidenhain rotary sensor ROD450 via the EXEs.
Thanks a lot in advance and best regards
Hartwig
  • mikeT
  • mikeT's Avatar
10 Aug 2025 15:34
Category: G&M Codes
Can you help with how to control the flow rate from a virtual slider pot on the AXIS virtual control panel.
Mike
10 Aug 2025 15:15
Replied by tommylight on topic Retrofitting a MAHO MH500W '89-'90 with hand-feed
But I'm more of a software / mechanical guy, so any advice would help :D
- DO IT!!!
- a lot of reading
- never wire everything and hope it just works, it won't
- do everything step by step, especially wiring and testing the electronics
- ask, ask, and ask again, we are here to help as much as humanly possible
Displaying 13906 - 13920 out of 14178 results.
Time to create page: 0.572 seconds
