  • meister
  • meister
20 Jun 2025 08:51
Replied by meister on topic EasyCAT Arduino shield
Category: EtherCAT
wow, I've had the EtherCat click board lying around for over a year :)
My problem the whole time was that I didn't have Windows and didn't want to use one.
Now I have found a way to do everything under Linux, i.e. create EEProm from the XML and also flash it via EtherCat, all without TwinCat.
In the meantime I can put my desired config on the LAN9252 and read and write all values via lowlevel spi driver.
only one step is missing to adapt the RIO interface over EtherCat :)
  • endian
  • endian's Avatar
20 Jun 2025 08:06
Replied by endian on topic Fanuc-Style Toolchange
Hello gentelmen,
how is it with the manual tool change...
I have sometime issue with precision after tool change +-0.01mm with OWT grinded tool post fixtures with manual toolchange .hal stuff.. I noticed that in the default tool table for lathe is not the waer offsets .. I can switch on them by
LATHE_WEAR_OFFSETS = 1
where I can define them for the each tool separately
And then add the the remapping ?
Then I will need to change T1 G43 to T01XX in the postprocessor I think ..
Thanks,
Regards
  • NT4Boy
  • NT4Boy
20 Jun 2025 07:55 - 20 Jun 2025 07:56
Replied by NT4Boy on topic HURCO KMB-1 Control Update
Category: Milling Machines
I'm still addressing some old school electronics that needed updating in the VFD, so turned my attention back to the override potentiometers.
When the spindle runs and I read the pot via the 3.3volt Analogue pin 7i92.0.7i71.0.2.input_03, there is a notable hunting in the spindle speed. Not much, but it just doesn't sound steady.
This is down I think to the ADC hopping between bits which is also normal.
I looked at the original Hurco control use of the pots and how the analogue values were read, and note that the conversion to digital was done in a 12 bit ADC. so the increment between bits is tiny in comparison.
In the 7i73 manual. it states:
"OPERATION
ANALOG INPUTS
Inputs 0 through 7 can read analog signal values however only inputs 0 through 3 are supported for analog input by available interface modes. Analog inputs have a range of 0 to 3.3V. Normal resolution is 8 bits. All bits are readable as digital inputs. Note: analog inputs are only accessible in some software modes."
Does this mean I could configure an analogue input to use a increased resolution of 12 bits?
If so How would I do that?
  • mohbakh
  • mohbakh
20 Jun 2025 07:50
Leadshine EL7-EC400N ethercat error 818
Category: EtherCAT
Hello everyone,
I'm new to the forum, I just bought two Leadshine EL7-EC400N ethercat driver servo with Leadshine ELM1 AC servo motor 400W to start my new cnc projects.
I installed linuxcnc-ethercat following @Rodw's Ethercat installation from repositories documentation and i created a .ini config lithe axis with two axis X Z, and a hal file and ethercath-conf.xml, but every time I start linuxcnc I get an error 818,
My question is whether the Leadshine EL7-EC400N is compatible with linuxcnc or not?
and also I'm wondering if there's anyone who can help me or give me a minimum configuration (.ini, .hal, .xml) file to make the motor start and get past error 818?
I used rodw's configuration
github.com/rodw-au/linuxcnc_leadshine_EL8/tree/main
  • Aciera
  • Aciera's Avatar
20 Jun 2025 07:37
Replied by Aciera on topic Reposition Preview grid.
Category: Basic Configuration
not sure what you mean by "the position marker's start". A screenshot with an arrow might give us a clearer picture of what you are trying to achieve.
  • meister
  • meister
20 Jun 2025 07:12 - 20 Jun 2025 07:12
here i can also show the structure of the frames or the rio.v:
this is the 'top' verilog module, the main module:
github.com/multigcs/riocore/blob/dev/doc...ngbob/Gateware/rio.v
there is a block in which the RX frames are split into individual 'output signals':
    // PC -> FPGA (330 + FILL)
    // assign header_rx = {rx_data[327:320], rx_data[335:328], rx_data[343:336], rx_data[351:344]};
    assign VAROUT128_MODBUS0_TXDATA = {rx_data[199:192], rx_data[207:200], rx_data[215:208], rx_data[223:216], rx_data[231:224], rx_data[239:232], rx_data[247:240], rx_data[255:248], rx_data[263:256], rx_data[271:264], rx_data[279:272], rx_data[287:280], rx_data[295:288], rx_data[303:296], rx_data[311:304], rx_data[319:312]};
    assign VAROUT32_PWMOUT0_DTY = {rx_data[167:160], rx_data[175:168], rx_data[183:176], rx_data[191:184]};
    assign VAROUT32_STEPDIR0_VELOCITY = {rx_data[135:128], rx_data[143:136], rx_data[151:144], rx_data[159:152]};
    assign VAROUT32_STEPDIR1_VELOCITY = {rx_data[103:96], rx_data[111:104], rx_data[119:112], rx_data[127:120]};
    assign VAROUT32_STEPDIR2_VELOCITY = {rx_data[71:64], rx_data[79:72], rx_data[87:80], rx_data[95:88]};
    assign VAROUT32_STEPDIR3_VELOCITY = {rx_data[39:32], rx_data[47:40], rx_data[55:48], rx_data[63:56]};
    assign VAROUT1_WLED0_0_GREEN = {rx_data[31]};
    assign VAROUT1_WLED0_0_BLUE = {rx_data[30]};
    assign VAROUT1_WLED0_0_RED = {rx_data[29]};
    assign VAROUT1_BITOUT0_BIT = {rx_data[28]};
    assign VAROUT1_BITOUT1_BIT = {rx_data[27]};
    assign VAROUT1_PWMOUT0_ENABLE = {rx_data[26]};
    assign VAROUT1_STEPDIR0_ENABLE = {rx_data[25]};
    assign VAROUT1_STEPDIR1_ENABLE = {rx_data[24]};
    assign VAROUT1_STEPDIR2_ENABLE = {rx_data[23]};
    assign VAROUT1_STEPDIR3_ENABLE = {rx_data[22]};
    // assign FILL = rx_data[21:0];
and a block in which the ‘input signals’ are assembled to the TX frame:
    // FPGA -> PC (349 + FILL)
    assign tx_data = {
        header_tx[7:0], header_tx[15:8], header_tx[23:16], header_tx[31:24],
        timestamp[7:0], timestamp[15:8], timestamp[23:16], timestamp[31:24],
        MULTIPLEXED_INPUT_VALUE[7:0], MULTIPLEXED_INPUT_VALUE[15:8],
        MULTIPLEXED_INPUT_ID[7:0],
        VARIN128_MODBUS0_RXDATA[7:0], VARIN128_MODBUS0_RXDATA[15:8], VARIN128_MODBUS0_RXDATA[23:16], VARIN128_MODBUS0_RXDATA[31:24], VARIN128_MODBUS0_RXDATA[39:32], VARIN128_MODBUS0_RXDATA[47:40], VARIN128_MODBUS0_RXDATA[55:48], VARIN128_MODBUS0_RXDATA[63:56], VARIN128_MODBUS0_RXDATA[71:64], VARIN128_MODBUS0_RXDATA[79:72], VARIN128_MODBUS0_RXDATA[87:80], VARIN128_MODBUS0_RXDATA[95:88], VARIN128_MODBUS0_RXDATA[103:96], VARIN128_MODBUS0_RXDATA[111:104], VARIN128_MODBUS0_RXDATA[119:112], VARIN128_MODBUS0_RXDATA[127:120],
        VARIN32_STEPDIR0_POSITION[7:0], VARIN32_STEPDIR0_POSITION[15:8], VARIN32_STEPDIR0_POSITION[23:16], VARIN32_STEPDIR0_POSITION[31:24],
        VARIN32_STEPDIR1_POSITION[7:0], VARIN32_STEPDIR1_POSITION[15:8], VARIN32_STEPDIR1_POSITION[23:16], VARIN32_STEPDIR1_POSITION[31:24],
        VARIN32_STEPDIR2_POSITION[7:0], VARIN32_STEPDIR2_POSITION[15:8], VARIN32_STEPDIR2_POSITION[23:16], VARIN32_STEPDIR2_POSITION[31:24],
        VARIN32_STEPDIR3_POSITION[7:0], VARIN32_STEPDIR3_POSITION[15:8], VARIN32_STEPDIR3_POSITION[23:16], VARIN32_STEPDIR3_POSITION[31:24],
        VARIN1_BITIN0_BIT,
        VARIN1_BITIN1_BIT,
        VARIN1_BITIN2_BIT,
        VARIN1_BITIN3_BIT,
        VARIN1_BITIN4_BIT,
        3'd0
in the case of the Tangbob, the two frames ‘rx_data’ and ‘tx_data’ are passed to the w5500 module, which then takes care of the data exchange with the host computer:
    w5500 #(
        .MAC_ADDR({8'hAA, 8'hAF, 8'hFA, 8'hCC, 8'hE3, 8'h1C}),
        .IP_ADDR({8'd192, 8'd168, 8'd10, 8'd194}),
        .NET_MASK({8'd255, 8'd255, 8'd255, 8'd0}),
        .GW_ADDR({8'd192, 8'd168, 8'd10, 8'd1}),
        .PORT(2390),
        .BUFFER_SIZE(BUFFER_SIZE),
        .MSGID(32'h74697277),
        .DIVIDER(0)
    ) w55000 (
        .clk(sysclk),
        .mosi(PINOUT_W55000_MOSI_RAW),
        .miso(PININ_W55000_MISO),
        .sclk(PINOUT_W55000_SCLK_RAW),
        .sel(PINOUT_W55000_SEL_RAW),
        .intr(1'd0),
        .rx_data(rx_data),
        .tx_data(tx_data),
        .sync(INTERFACE_SYNC)
Now let's take a look at the signals from one of the Stepdir module instances:
the input/output signals have the following naming scheme: VAR[DIRECTION][SIZE]_[MODULE_INSTANCE]_[SIGNALNAME]
* VAROUT32_STEPDIR0_VELOCITY : a 32 bit output value for the specified velocity (steprate)
* VAROUT1_STEPDIR0_ENABLE : a 1 bit output value to activate the stepper (enable signal)
* VARIN32_STEPDIR0_POSITION : a 32 bit input value to return the current position (step counter)
    stepdir #(
        .PULSE_LEN(108),
        .DIR_DELAY(18)
    ) stepdir0 (
        .clk(sysclk),
        .step(PINOUT_STEPDIR0_STEP_RAW),
        .dir(PINOUT_STEPDIR0_DIR_RAW),
        .velocity(VAROUT32_STEPDIR0_VELOCITY),
        .enable(VAROUT1_STEPDIR0_ENABLE & ~ERROR),
        .position(VARIN32_STEPDIR0_POSITION)
the pin signals have the following naming scheme: PIN[DIRECTION]_[MODULE_INSTANCE]_[PINNAME]
however, they can also have suffixes, such as. _RAW / _INVERTED / _DEBOUNCED / ...
this is due to the modifiers pipeline that can be configured for each pin.
  • Neiji_msk
  • Neiji_msk
20 Jun 2025 06:24 - 20 Jun 2025 06:46
Errors when searching for axis origins was created by Neiji_msk
Hi guys, I have a question, when I turn on LinuxCNC drivers with absolute encoders, they make a delay to search for the machine zeros, accordingly, if I turn on the CNC before they find the beginning, a bunch of errors appear, is it possible to make some kind of delay when turning on until the driver finds the beginning? thanks
  • meister
  • meister
20 Jun 2025 06:22
Here is an output from the generator using the Tangbob configuration as an example:
github.com/multigcs/riocore/tree/dev/doc/example-output/Tangbob
and here is a kind of documentation of the generated gateware:
www.multixmedia.org/Tangbob-Gateware/
  • Johnnysacalu
  • Johnnysacalu
20 Jun 2025 05:44
Replied by Johnnysacalu on topic Lo ejes dejaron de moverse
7i96s
  • Johnnysacalu
  • Johnnysacalu
20 Jun 2025 05:31
Perdon 7i96s
  • Kieran
  • Kieran
20 Jun 2025 05:08
Do I need a better PC? was created by Kieran
Category: EtherCAT
ok, sometimes when I run my Ethercat servos, they sound like they have bad bearings/run rough. Restarting linuxcnc sometimes solves it and they run buttery smooth. I've also gotten a warning unexpected realtime delay. Im guessing Its because Im running the cheapest HP pavilion desktop junk(runs off a little wall wart and has the smallest cooling fan on a 1x1" cpu heat sink. :D
Anything I should look for when buying a proper motherboard for ethercat linuxcnc?
  • Kieran
  • Kieran
20 Jun 2025 03:58 - 20 Jun 2025 04:02
Replied by Kieran on topic Getting Ebay 2.6kw ethercat kit going.
Category: EtherCAT
well I reRan lcec_configgen and got a different reading on slave IDX 2 not sure why. I was able to fart around with the XML and get the servo going. it about jumped off my bench. she's a ripper.
working XML snippet for the Ebay servo/ DVS P200SE drive.
Warning: Spoiler!
20 Jun 2025 00:39
Replied by tommylight on topic Plasma hit count
Plasma hit count
Category: Plasmac
  • TheTinkeringMechanic1
20 Jun 2025 00:20 - 20 Jun 2025 01:36
Reposition Preview grid. was created by TheTinkeringMechanic1
I believe I have just about everything I need figured out on our double gang grinder CNC lathe conversion as far as operation goes.. The only thing I have yet to figure is altering the position of the where the marker starts on the preview grid. I would really like to have the plot marker in preview to be in the middle of the X on the grid. Tool offset and home offset have had zero change to the position marker's start on the grid.
Thanks in advance.
  • aabtech
  • aabtech's Avatar
19 Jun 2025 23:51
Plasma hit count was created by aabtech
Plasma hit count
Category: Plasmac
Hi, I work as a CNC Plasma Beam line Operator and any time I change consumables I have to reset the number of hit of the plasma to zero and as is cutting it count the number of hit, and know how long the consumables last and to change them can't we do the same thing to QtPlasmaC.
Displaying 14776 - 14790 out of 15360 results.
Time to create page: 3.845 seconds
