  • pgf
  • pgf
16 Jun 2025 19:39
M6 shuts off spindle, but no UI confirmation, and program doesn't pause
Category: Basic Configuration
I broke a brand new (happily inexpensive!) bit today.  Right after program start, the spindle shut down, and the work kept going.  I hit E-stop, but not in time.
The culprit was code generated by kirimoto, which contained an M6 for an initial tool change.  I missed it when configuring kirimoto -- that M6 shouldn't have been there -- but even so, it should have paused.
It's reproducible -- M6 shuts down the spindle, but the program keeps going.
I use hal_manualtoolchange, set up pretty much by the book:
#  ---manual tool change signals---
net tool-change-request    <= iocontrol.0.tool-change
net tool-change-confirmed  => iocontrol.0.tool-changed
net tool-number            <= iocontrol.0.tool-prep-number
#  ---Use external manual tool change dialog---
net tool-change-request    =>  hal_manualtoolchange.change
net tool-change-confirmed  <=  hal_manualtoolchange.changed
net tool-number            =>  hal_manualtoolchange.number
#  ---ignore tool prepare requests---
net tool-prepare-loopback   iocontrol.0.tool-prepare      =>  iocontrol.0.tool-prepared
The only mention of tools in the .ini is "TOOL_TABLE = tool.tbl" in EMCIO.
I ran halshow, watching the hal_manualtoolchange pins, and the ioctrontrol tool-* pins.  The iocontrol.0.tool-prepare/prepared loopback flashes on briefly when I hit M6, but that's the only change I can see.  (I didn't use halscope.)
Any ideas?  Am I missing some config?
  • Beovoxo
  • Beovoxo
16 Jun 2025 16:37 - 16 Jun 2025 16:37
Replied by Beovoxo on topic Deckel FP4A Retrofit
Category: Milling Machines
Got the right color :) RAL6011
  • JT
  • JT's Avatar
16 Jun 2025 15:56
Replied by JT on topic Flex GUI 1.2.1 Released
Category: Flex GUI
Here's a video of adding images to pushbuttons should be similar for labels.
JT
  • my1987toyota
  • my1987toyota's Avatar
16 Jun 2025 15:27 - 02 Jul 2025 10:25
Replied by my1987toyota on topic Linux vs Windows value
Any Government that supports / allows Windows OS and especially it's servers in there country.
  • scotth
  • scotth
16 Jun 2025 15:05
Replied by scotth on topic Linux vs Windows value
What government??
  • SebastianM
  • SebastianM
16 Jun 2025 14:48
Replied by SebastianM on topic Email Notification?
Email Notification?
Category: Forum Questions
When I write a reply I always tick the box “check this box to be notified of replies to this topic”, but I just don’t get any emails.
  • my1987toyota
16 Jun 2025 14:15
The Windows 11 slogan should be " We aren't spying for the Government honest."
  • PCW
  • PCW's Avatar
16 Jun 2025 13:46
Replied by PCW on topic Rote LED
Rote LED
Category: Deutsch
60000 packets transmitted, 59992 received, +8 errors, 0.0133333% packet loss, time 60099ms
rtt min/avg/max/mdev = 0.048/0.133/6.074/0.075 ms, pipe 9
Not good
What host hardware do you have (CPU and Ethernet chip)?
16 Jun 2025 12:37
Replied by tommylight on topic Email Notification?
Email Notification?
You have to subscribe. Its not automatic
It was for any topic you replied to or started. And you could subscribe to any topic manually.
No idea if that is the case now as i get e-mails for every post.
16 Jun 2025 12:34
Email Notification?
Ok. Guess if they work for you they work for everyone.
I did not say that.
  • rodw
  • rodw's Avatar
16 Jun 2025 12:18
Replied by rodw on topic Email Notification?
Email Notification?
  • rodw
  • rodw's Avatar
16 Jun 2025 12:12
Replied by rodw on topic Linux vs Windows value
I've been forced to use Windows again recently. Scarlett Solo Sound card supported natively in Linux needed a driver install and then it would fail every second start. I did manage to install an old Office license key after a forced upgrade, several restarts, a hang and attempts  to wean me off Chrome! Now I am on Win 11 so excited :(
  • Jens23
  • Jens23
16 Jun 2025 12:12
Replied by Jens23 on topic LinuxCNC and Beckhoff AX5000 servo drives
Category: EtherCAT
Did you ever get a Beckhoff AX5xxx vfd and got it running? I am looking for something I can work with but there isn't really that much about these vfds and linuxcnc ethercat out there.
  • rodw
  • rodw's Avatar
16 Jun 2025 12:05
Linuxcnc 2.9.2 and 2.93 images for Raspberry Pi 4b & 5
Category: Installing LinuxCNC
You should be able to set up auto login the same way it is done with an x86 machine as its the OS you are logging into
  • meister
  • meister
16 Jun 2025 11:56
Replied by meister on topic Modbus T3D Servo Treiber
Category: Deutsch
und wenn du P-076 einfach versuchst zu schreiben sobald du eine andere geschwindigkeit nutzen möchtest ?
Displaying 14956 - 14970 out of 15371 results.
Time to create page: 3.671 seconds
