  • andypugh
  • andypugh's Avatar
10 Jun 2025 13:24
Replied by andypugh on topic Tool in spindle memory
This sounds like a question for the ProbeBasic forum section.
  • andypugh
  • andypugh's Avatar
10 Jun 2025 13:17 - 10 Jun 2025 13:23
Replied by andypugh on topic Lathe Macros
Lathe Macros
Category: Other User Interfaces
Most of the stuff is in Github: github.com/andypugh/LatheMacros
The images are all in the .svg file as different layers.
The fusion 360 models that the SVG files came from might have moved with a change in how Autodesk store data.
The various models are here:
a360.co/43OnIFj
I made the SVG layers by creating a shaded isometric drawing of each component then exporting the drawing to SVG.
  • jg
  • jg
10 Jun 2025 12:23
Replied by jg on topic Mesa 7i92T - compiling firmware
Category: Driver Boards
vmt. Can confirm that your fixed firmware works for me and that I can compile functional f/w by making the file substitution back to wordpr.vhd.
Cheers.
  • mario0701
  • mario0701
10 Jun 2025 08:50
  • meister
  • meister
10 Jun 2025 07:36
yes, the advantage over shiftreg is that the evaluation of e.g. encoders is already carried out on the external fpga and only the finished values are transferred
  • michaeln
  • michaeln
10 Jun 2025 06:57
Replied by michaeln on topic 24 Volt Ausgänge?
24 Volt Ausgänge?
Category: Deutsch
... oder über die Konfiguratoren pncconf oder mesact (github.com/jethornton/mesact) mal das Grundgerüst erstellen lassen und dann editieren.
  • dg9mdr
  • dg9mdr
10 Jun 2025 06:46
Replied by dg9mdr on topic 24 Volt Ausgänge?
24 Volt Ausgänge?
Category: Deutsch
in der ini die Karte eintragen:
[HMOT]
CARD0=hm2_7i96s.0
dann kannst in der Halshow unter:
Pins
hm1_7196s
die entsprechenden Pinnamen einsehen und ansehen/beobachten
diese kannst du dann in der Hal setzen, z.B.:
# --- Maschine on ---
net machine-is-enabled => [HMOT](CARD0).ssr.00.out-00
# --- SPINDLE-ENABLE ---
net spindle-enable => [HMOT](CARD0).ssr.00.out-01
  • Edi_48
  • Edi_48
10 Jun 2025 06:03
Replied by Edi_48 on topic 24 Volt Ausgänge?
24 Volt Ausgänge?
Category: Deutsch
Danke für das Schema, jetzt bräuchte ich noch die Einträge in der Hal
  • flipzip
  • flipzip
10 Jun 2025 05:37
E-Stop Line Number was created by flipzip
E-Stop Line Number
Is there a way to indicated what G_Code line you were on after an E-Stop press in QTDragon? Just goes back to 1.
  • flipzip
  • flipzip
10 Jun 2025 04:23
  • rbobey1989
  • rbobey1989's Avatar
10 Jun 2025 04:21
Tunning PID Loop, encoder on the linear axis, not on the motor shaft
Hello Tommylight, your approach is very accurate. Starting from the values ​​you propose, I was able to make relatively smooth movements. I would only highlight the need to lower the D = 0.001-0.005 a little more, since the motor emits vibration with the proposed range of values. Regards and thanks.
10 Jun 2025 00:40
Linuxcnc 2.4.5 with Ubuntu 10.04 , Terminated with Error!
Post the error logs here so we can have a look.
Especially the Debug part...
  • dunnitagain
  • dunnitagain
09 Jun 2025 23:57
Hello , Newb here. Just bought 2 , very nice Bridgeport and Jet mill retrofits , with Microkentics Steppers and PICO Universal Stepper cards , from the estate of a friend. Machines are very nicely built.
They sat idle since 2013, the Cmos batteries were dead . Ive been working on the .ini file of the Jet mill , to correct the homing sequence.
Everything was great , fixed the Z Axis homing . Powered down the control to plug the A axis in . Now on power up , it will not load Linuxcnc 2.4.5.
Is there a way to decode the error message , to see what i need to change, to return functionality ?
   The computers are bare bones machines, no network capabilities , just USB.
             Where can I look , or were do I Start ?
  • tar_san
  • tar_san
09 Jun 2025 23:21 - 10 Jun 2025 06:03
Replied by tar_san on topic Problems with Lichuan Ethercat servo drive
Category: EtherCAT
Thank you. I tried both V1.04 and V1.11.
But I couldn't make servo drive move in LinuxCNC main screen.
I didn't see any error on screen,  but servo drivers didn't become "Servo On" state when I pushed "PowerOn"
Where do I need to check ? ( I used to use another tiny LinuxCNC system and machine , but it was stepper.., I used step conf. )
Do I have to set some servo parameter from switches on servo driver ?
( No load is connected to servo motors for now. )
Servo Driver Panel shows "20ry" (2 is blinking.)
I tried both V1.11 and V1.04 and this configuration,
forum.linuxcnc.org/ethercat/52341-proble...rive?start=60#304887
I have 3 sets of Lichuan Servo (Driver+Motor), I want to use them as XYZ CNC.
Displaying 15211 - 15225 out of 15386 results.
Time to create page: 0.700 seconds
