  • cmorley
  • cmorley
16 May 2025 14:26
Replied by cmorley on topic Error in tool_offsetview.py
Category: Qtvcp
I did push some work to fix an error I found.
  • knipknap
  • knipknap
16 May 2025 14:19 - 16 May 2025 14:24
MESA 7i76E burning out issue was created by knipknap
Category: Driver Boards
A while ago, my MESA 7i76E broke; one channel just stopped working. I wrote about that here . I then found someone who repaired the card, after which the machine ran fine for half a year. He said he "replaced the resistor network" of the channel.
Today, the exact same issue appeared again. Joint 2 stopped working and after a restart it worked for a minute and went away again. This is exactly the behavior I saw last time.
This time though I was better prepared and had a spare 7i76E ready to replace the other one. After replacing it the machine ran fine - but after an hour the new card displays the same behavior, too! Clearly something is going on that breaks this channel... sometimes.
What would you do to diagnose this? Replace the JMC servo (with the built in controller) and hope for the best?
  • sajurcaju
  • sajurcaju
16 May 2025 13:43
[SOLVED] New wifi card causes second parallel port to stop working
I remembered there is a wifi PCIe card (different brand) in my desktop which won't be missed. I put it in the CNC computer and now it all works.
I also did a latency test. This is with 5 glxgears plus YouTube running a psychedelic video, plus streaming from my RPi camera. Pretty much the same as I had back in March.
In addition to my machine config described in the first post, my graphics card is a Radeon Firepro V5800.
Thanks for the comments,
Steve
  • cmorley
  • cmorley
16 May 2025 13:14
Category: Qtvcp
Can you give more detail of the load problem?
I'm guessing you want it to autoload at startup?
set_style is old code from a slightly different version.
IIRC if you use it then you can't override the style with the style editor.
Here are some of the things you can change from the style sheet editor:
MacroTab CustomButton{
    width: 20px;
    height: 40px;
MacroTab QPushButton {
    width: 80px;
    height: 40px;
MacroTab QLabel {
    font: 24pt "Lato Heavy";
TouchSpinBox  LineEdit {
    font: 12pt "Lato Heavy";
TouchSpinBox  QPushButton {
    width: 60px;
    height: 100px;
I think it needs a way to change styles per macro as it's hard to get sizes to work with different macros.
If there is interest I can develop it more.
16 May 2025 13:04
Replied by tommylight on topic Issues installing LinuxCNC
Category: Installing LinuxCNC
Check the "accessories" submenu for LinuxCNC stuff, sometimes they end up there.
  • unknown
  • unknown
16 May 2025 12:46
Replied by unknown on topic Need guidence to improve latency and speed
Category: Basic Configuration
Mesa is definitely the way to go. It "future proofs" your setup. Swapping machines is easy, latency is less of an issue. If your current machine goes "poof" getting back & running is a simple task.
Tho it really depends on your budget....shipping to the Southern Hemisphere is brutal.
The easiest way, to prevent a total rewire is grab a 7i92T and that can plug into your existing parallel port breakout boards (or more correctly the breakout boards cab plug into the 7i92T). That'll get you going, later if you really feel the need a 7i76 can be plugged into the 7i92T.
I'm running a 7i92,7i76, another card for extra Smart Serial ports an analog smart serial card for the spindle and a 7i73 for the pendant.......Hasn't missed a beat in all the years I've been using them. Worked fine on the dual core J3355B system I used for a bit. Asrock J3355B-ITX. Upgraded to a system with a smaller foot print
Regarding isolating cores, from the dark spells I've read it would seem to isolate the cores on the same die, well that was the recommendations for Intel.
  • besi99
  • besi99
16 May 2025 12:35
Replied by besi99 on topic Issues installing LinuxCNC
Man I definetly need to take some sleep....
It definetly did something this time. Thanks for youre help guys. I was ready to just go back to Estlcam and windows haha.
If I go to Applications -> CNC there are only two options there is Documentation and G-Code Quick Reference. There is no LinuxCNC application does that mean somthing went wrong with the installation? I did a restart same thing.
  • JeGl
  • JeGl
16 May 2025 12:34
Wer sitzt in München bzw. im Münchner Süden?
Category: Deutsch
Hallo Joe,
ich bin aus München und habe auch ein 4060 mit Parellelport. Wäre sehr interessiert für so ein Treffen. Auch privat zum Austausch, wenn du Interesse hast kannst du mich anschreiben.
Gruß Jerry
  • npostma
  • npostma's Avatar
16 May 2025 11:50 - 16 May 2025 11:53
Replied by npostma on topic Need guidence to improve latency and speed
Hi Todd,
Thanks for your response — I’ll definitely give that a try, as it feels like my last resort with this current setup.
I've already disabled everything I possibly could in the BIOS. The only things I haven't touched yet are the memory timings and voltages. If this doesn’t work either, I’m honestly not sure what else is left to tweak.
I'm also considering switching to a Mesa card, possibly the 7i76EU, but I have zero experience with Mesa hardware. I’ll need to figure out whether it will work with my three DM542A stepper drivers, and also with my VFD, which is currently controlled over USB using: `loadusr -Wn vfd hy_vfd -n vfd -d /dev/ttyUSB0 -p none -r 9600`
Things i disabled next to the obvious, like settings for fixed clock speeds (fclock 1066, bclock 1000) disabling power management and disabling hardware that is not being used (BT, Wireless, serial, audio, fancontrol (disabled fixed on 100%)):
BIOS Settings (set to Disabled):
SMT / Hyperthreading
→ Disables logical cores to reduce cache sharing and latency spikes
C1E, C6, and other C-States
→ Prevents the CPU from entering sleep states, ensuring consistent timing
Streaming Stores Control
→ Avoids aggressive memory write optimizations that can disrupt real-time behavior
DRAM Scrub Time
→ Turns off background memory error checking to avoid unexpected memory bus usage
GMI Encryption Control
→ Disables inter-chiplet encryption on Infinity Fabric to reduce overhead and latency
XGMI TXEQ Mode
→ Prevents signal equalization tuning that could introduce instability or variability
DRAM Map Intervention
→ Disables memory remapping logic that can introduce unpredictable latency
DF Sync Flood Propagation
→ Prevents error broadcasts across chiplets, reducing the chance of system-wide stalls
16 May 2025 11:06
home and besnik are in the wrong places again and Downloads starts with upper case D. Linux is case sensitive so D and d are not the same.
Copy and paste from here:
cd /home/besnik/Downloads
sudo chmod +x  /home/besnik/Downloads/linuxcnc-install.sh
./linuxcnc-install.sh
  • Todd Zuercher
  • Todd Zuercher's Avatar
16 May 2025 11:01
Replied by Todd Zuercher on topic Issues installing LinuxCNC
You had the directory tree order wrong. You typed "cd home/besnik/downloads/" and it needs to be "cd besnik/home/Downloads/". Also Linux is case sensitive so the capitol leter "D" is also important.
  • Todd Zuercher
16 May 2025 10:36
Replied by Todd Zuercher on topic Need guidence to improve latency and speed
Keep playing with different combinations of cores isolated using isolcpus till you find what gives you the best result. Your Ryzen has 6 of them to choose from, I'd test different combinations of 1, 2, and 3 cores isolated, like 1,3,5 or 3,4,5 or 0,1,2, or 4,5, or 0,1...
  • low-blip
  • low-blip
16 May 2025 10:30 - 27 May 2025 11:38
Actual position and Commanded position differ, using cia402 [SOLVED]
I'm very new to LinuxCNC, and using a CNC machine custom built and configured by someone else. Running into some errors that none of us could figure out, help would be very very appreciated.
We are using cia402 and ethercat to run a 9-axis system, including xyz and 6 rotation axis. We noticed that the actual and commanded positions of the xyz axes are always off by a factor of 80 , e.g. if we send the Gcode to move X axis by 10mm, it moves by 10mm, the commanded position is 10, but the 'actual position' is 0.125. We can still run .ngc files, they do exactly what we expect them to do, but at the end we get motor position error on these three axes.
We've tried increasing the FERROR and MIN_FERROR in the .ini file
[AXIS_X]
MIN_LIMIT         = -5
MAX_LIMIT         = 395
MAX_VELOCITY         = 500
MAX_ACCELERATION     = 250
[JOINT_0]
TYPE             = LINEAR
MAX_VELOCITY         = 500
FERROR             = 200
MIN_FERROR         = 50
MIN_LIMIT         = -1
MAX_LIMIT         = 1200
HOME            = 0
HOME_OFFSET        = 0
HOME_SEQUENCE        = 1
HOME_IGNORE_LIMITS    = YES
# nach github.com/dbraun1981/hal-cia402/blob/main/README.md
HOME_SEARCH_VEL     = 5.0
HOME_LATCH_VEL         = -2
HOME_FINAL_VEL        = 1
HOME_USE_INDEX    = FALSE
 .hal:
loadrt [KINS]KINEMATICS
loadusr -W lcec_conf ECOMODUL_ethercat_conf.xml
loadrt lcec
loadrt cia402 count=9
# Functions servo-thread
addf lcec.read-all servo-thread
addf cia402.0.read-all servo-thread
addf cia402.1.read-all servo-thread
addf cia402.2.read-all servo-thread
addf motion-controller servo-thread #########################################
#nets
net emc-enable => iocontrol.0.emc-enable-in
sets emc-enable 1 #config
#testing Werte für pos-scale fehlen
#x
setp cia402.0.csp-mode 1
setp cia402.0.pos-scale 8000
#y
setp cia402.1.csp-mode 1
setp cia402.1.pos-scale 8000
#z
setp cia402.2.csp-mode 1
setp cia402.2.pos-scale 8000 ...
#from servo(ethercat) to cia402 net x-statusword      lcec.0.8Axis.xcia-statusword => cia402.0.statusword
net x-opmode-display  lcec.0.8Axis.xopmode-display => cia402.0.opmode-display
net x-drv-act-pos     lcec.0.8Axis.xactual-position => cia402.0.drv-actual-position net y-statusword      lcec.0.8Axis.ycia-statusword => cia402.1.statusword
net y-opmode-display  lcec.0.8Axis.yopmode-display => cia402.1.opmode-display
net y-drv-act-pos     lcec.0.8Axis.yactual-position => cia402.1.drv-actual-position  net z-statusword      lcec.0.8Axis.zcia-statusword => cia402.2.statusword
net z-opmode-display  lcec.0.8Axis.zopmode-display => cia402.2.opmode-display
net z-drv-act-pos     lcec.0.8Axis.zactual-position => cia402.2.drv-actual-position
#from cia402 to servo(ethercat) net x-controlword         cia402.0.controlword     => lcec.0.8Axis.xcia-controlword
net x-modes-of-operation  cia402.0.opmode     => lcec.0.8Axis.xopmode
net x-drv-target-pos      cia402.0.drv-target-position   => lcec.0.8Axis.xtarget-position net y-controlword         cia402.1.controlword     => lcec.0.8Axis.ycia-controlword
net y-modes-of-operation  cia402.1.opmode     => lcec.0.8Axis.yopmode
net y-drv-target-pos      cia402.1.drv-target-position   => lcec.0.8Axis.ytarget-position net z-controlword         cia402.2.controlword     => lcec.0.8Axis.zcia-controlword
net z-modes-of-operation  cia402.2.opmode     => lcec.0.8Axis.zopmode
net z-drv-target-pos      cia402.2.drv-target-position   => lcec.0.8Axis.ztarget-position
#from motion to cia
net x-enable    <= joint.0.amp-enable-out => cia402.0.enable
net x-amp-fault => joint.0.amp-fault-in   <= cia402.0.drv-fault
net x-pos-cmd   <= joint.0.motor-pos-cmd  => cia402.0.pos-cmd
net x-pos-fb    => joint.0.motor-pos-fb   <= cia402.0.pos-fb net y-enable    <= joint.1.amp-enable-out => cia402.1.enable
net y-amp-fault => joint.1.amp-fault-in   <= cia402.1.drv-fault
net y-pos-cmd   <= joint.1.motor-pos-cmd  => cia402.1.pos-cmd
net y-pos-fb    => joint.1.motor-pos-fb   <= cia402.1.pos-fb net z-enable    <= joint.2.amp-enable-out => cia402.2.enable
net z-amp-fault => joint.2.amp-fault-in   <= cia402.2.drv-fault
net z-pos-cmd   <= joint.2.motor-pos-cmd  => cia402.2.pos-cmd
net z-pos-fb    => joint.2.motor-pos-fb   <= cia402.2.pos-fb
  • besi99
  • besi99
16 May 2025 10:01
Okay thats a good tip that thoose commands are wrong. I found thoose commands on the forum.I tried the commands with the order you told. But I still get the same error. I took some pics maybe they help.
Thanks for trying to help me :)
- Shume flm per ndhime
  • alangibson
  • alangibson
16 May 2025 09:03
Ohmic probe aborts immediately was created by alangibson
Category: Plasmac
Hello all. I've got an odd problem with ohmic probing that recently cropped up.
When I tap the Ohmic Probe button in QtPlasmaC, probing immediately aborts without moving the Z axis. Normally I would assume that the ohmic sensing circuit is always closed for some reason, but it's definitely not that.
halscope shows that the ohmic sense feedback pin is never activated. The ohmic enable pin is however correctly activated.
I've verified that the relay on my breakout board closes when ohmic probing is activated. If I connect the ohmic sense wire directly to the table, probing again immediately aborts and the ohmic sense pin is correctly activated. I've also verified that the relay that closes when the sense circuit is closed is not activated.
Z axis is homed. It correctly probes when using only the float switch.
So my question is: what can cause a situation where ohmic probing aborts no matter if the sense pin is active or not?
Displaying 15481 - 15495 out of 17073 results.
Time to create page: 1.333 seconds
