  • youngyaper
  • youngyaper
15 May 2025 16:17
linux cnc keeps bending shortcutting to the next line.
I have an issue that im sure some of you know the solution. It seems linuxCNC/ AXIS processor  instead of completing a move to a coordinate begins moving to the next coordinate creating a curve/ bend toolpath between the two points, almost like a shortcut. It does this only from an X or Y cordinate to a Z and vise versa, but not from an X to Y coordinate. Please help !! thanks.
  • PasstScho
  • PasstScho
15 May 2025 16:02
Replied by PasstScho on topic mesa 7i73 4x8 keypad problems on KEY8 input
Category: Driver Boards
Great news!
I also tried more modern versions of the MPLAB X IDE, are not able to properly read the original hex format.
Well actually those editors are reading it correctly. Data after the End-Of-File should not exist. A good Editor should just say sth. like "can't open file - wrong entry" or "do you want to ignore the error?"....
The Editor/Programmer PCW is reading does not read it correctly as it ignores the EOF Entry without saying so.
Wikipedia says:
 :00000001FF   End Of File: Must occur exactly once per file in the last record of the file.
But well - the initial problem is solved and I don't think I will put effort in fixing Microchip's tools or Toolchains.
@PCW: Please keep the EOF bug in mind whenever you send hex files made by the same toolchain.
Thank you for the fixed firmware!
  • Milkof
  • Milkof
15 May 2025 16:00
Mesa 7I96 + Stepper online CL86T Wiring connections
 Hello everyone,
I wanted to ask a favour of some more experienced users than myself.
I am making the electronics with the 7I96 and the CL86T drives, the connections for the motor management I managed to connect.
Now I am missing the limit switches e-stop and Z-Finder, could you kindly check on the attached diagram if the connections are correct?
Milko
15 May 2025 15:43
Why does it seem like everyone here is Australian?
I am not in Australia.
I do like Australia, with all the creatures that can kill people easily, mostly because of people.
  • DarkPhoinix
  • DarkPhoinix
15 May 2025 14:46
Replied by DarkPhoinix on topic [SOLVED]linuxcnc Latency test ambiguous results
Today i try a new MB with HDMI exit! The youtube video test is DUMP!
Try stress test + glxgear for your system dont lose time!
  • kubes
  • kubes
15 May 2025 14:19
Replied by kubes on topic Show your screens
Show your screens
Category: QtPyVCP
@ anfänger
Nice work on the update to probe_basic.  The status tab is perfect!  I see this is an older post, but maybe you can share the update or some notes on how you made it.  I want to create something very similar.  Newbie here and not sure where to start.
  • SteepLearningCurve
15 May 2025 14:16
Replied by SteepLearningCurve on topic None of the axis are moving - using mesa 7i92t with 7i76u
Category: Basic Configuration
Hi All
Yes, the W4 jumper on the 7i92t was down, and it is now up.
The linuxcnc config loads,  the inputs also work , and there is also movement on the motors :)
A very very big thank you, to the knowledgeable folks on this forum, for sharing your valuable time, wisdom, and knowledge with me, it is greatly appreciated.
As a person new to Linuxcnc , there are so many things that we don't know.
Be braver than me, post a question sooner than I did.
(For folks reading this post in the future, the wiring currently is differential, and seems to be working fine).
  • DarkPhoinix
  • DarkPhoinix
15 May 2025 14:01 - 15 May 2025 14:04
Replied by DarkPhoinix on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
Warning: Spoiler!
Thanks for reply,
I have set 12800 and testing some gcode only with Y working.
I don't want to cause problems when all the stepper and spindle are physically working.
  • PCW
  • PCW's Avatar
15 May 2025 13:50
Replied by PCW on topic Question on Servo analog output scaling
Yes, unless you set the analog scale so that it equals
the velocity in machine units per second at 10V, (and FF1 ==1.000),
You will need to tune FF1 using halscope.
Here is a long thread about this tuning:
forum.linuxcnc.org/10-advanced-configura...to-example-mesa-7i77
  • cmorley
  • cmorley
15 May 2025 12:30 - 16 May 2025 13:14
Replied by cmorley on topic Error in tool_offsetview.py
Category: Qtvcp
You bet. I will look at it as soon as I can.
  • cmorley
  • cmorley
15 May 2025 12:25
Replied by cmorley on topic Manual Toolchange + Abs Z Probe (QtDragon)
Category: Qtvcp
Can you post the changes you made?
  • Esaber
  • Esaber
15 May 2025 12:16
Replied by Esaber on topic Esab Ultrarex UXD-P2000 Upgrade Project
Category: Plasma & Laser
Hi Tommy. Thanks for the instructions. Will let you know how it goes.
  • buergi
  • buergi
15 May 2025 12:14
Replied by buergi on topic mesa 7i73 4x8 keypad problems on KEY8 input
Today I managed to modify the hex file as proposed above by removing the EOF lines are sorting the sections. This way I succeeded flashing and all buttons of the matrix keyboard are now finally working. Thanks Peter for the firmware.
I really wonder why all the tools, I also tried more modern versions of the MPLAB X IDE, are not able to properly read the original hex format.
  • JT
  • JT's Avatar
15 May 2025 11:31
Best practice for installing custom Python packages in LinuxCNC?
Why not just build a deb and install your package?
github.com/jethornton/simple-deb
github.com/jethornton/simple-pyqt5-deb
Or if you're using Flex GUI you can just add it to your ini and it gets imported.
gnipsel.com/linuxcnc/flexgui/python.html
JT
  • unknown
  • unknown
15 May 2025 09:24
Replied by unknown on topic Combined MESA board order for Australia.
Yeah sorry about that mate.
Shipping is a killer to Down Under. I've used shipito as a forwarder and gotten good value on previous occasions.
I've previously used a Spartan 6 Dev board\Colorlight board (spartan 6 based ones are hard to find now) as a smart serial card based on Mesa's 7i90 hostmot2 firmware. Unfortunately it only supports digital I\O and 4 encoders for use as hand wheels. No analogue nor keyboard functions and not quite as compact as the 7i73.
Displaying 15526 - 15540 out of 17073 results.
Time to create page: 3.041 seconds
