- matn1
- matn1
06 May 2025 11:33
Replied by matn1 on topic Linuxcnc & the Raspberry Pi (4 & 5) Official Images Only!!!
Category: Installing LinuxCNC
Good day,
Adding a voice here as I think I saw another user having this issue: RPI5 with a 7i96, and after some time I get a solid red INIT light on the mesa card, and obviously at that point have to reset the card to continue. I cant make heads or tails of this just yet, but it might be related to idle. It may be specific to the 7i96 given the other poster also commented on that. I have 7i76EU on its way so will be able to test this and post back whether I experience anything similar. Currently the Mesa is on a 5v3A wall plug, and the RPI5 uses a somewhat official USBC RPI wall plug.
- jochen91
- jochen91
06 May 2025 10:39
Replied by jochen91 on topic Planning to Retrofit a Mazak Integrex200Y Mill-Turn Machine
I thought a little bit about it and came to the conclusion, that most of the functionality of the Millturn would be covered with the following G-codes:
G68.1/G69.1
G368/G369
G400
G490 (I think, I could do that myself by replacing the G code with a custom M code in the PP)
Do you think you could support me on more time ?
Kind regards,
Jochen
G68.1/G69.1
G368/G369
G400
Kind regards,
Jochen
- DarkPhoinix
- DarkPhoinix
06 May 2025 10:09 - 06 May 2025 10:24
First of all thank you so much for your interest in the problems of all of us newbies. And yes I can't speak English at all, I only understand a few technical words as the little I know was learned by myself. I'm sure that the things you wrote in the following posts will solve all my problems even future ones and I will keep these posts as documentation.
I have one last question, is there a specific post of remora? Could you kindly link because I thought it was this post here! Thanks again infinitely!!!
a little help links for NVEM RT1052 pins1 NVEM RT1052 pins2
Replied by DarkPhoinix on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
Warning: Spoiler!Alright its starting to look like the inmates are running the asylum. Everyone just hold on for a moment, breath in and out, and cool our heads. I know english or linuxcnc isnt everyones first language, but it looks like everyone is working off each others confusion, and you guys are spiraling out. I think there are some core concepts we arent all understanding completely. Its clear that you guys are smart people, so lets hold on for a moment and regroup, and always read the manual. If you atre getting frustrated, just start from page one and read. If there are things getting lost in translation on the documents, letting us know would be great, and we can change some of the wording. I know the docs arent perfect, but the core concepts are the same for the whole of remora.
Also, if its a remora specific question, it is best to ask in the thread. remora isnt really a big wide linuxcnc thing, it makes it harder to find your thread.
- hermann1976
06 May 2025 10:09
Replied by hermann1976 on topic Ein Neuling sucht Hilfe
Category: Deutsch
Hallo Hans, bei deinem ersten Post - meitest du Hartberg in Österreich - Stmk? Falls ja, bin aus Rohrbach a.d.L.
Eventuell könnten wir uns gegenseitig etwas helfen.
lg Hermann
lg Hermann
- aDm1N
06 May 2025 09:51 - 06 May 2025 12:14
Replied by aDm1N on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
Where can I find an example of how to connect and integrate a handwheel (MPG)? Is it possible with Remora to use both a handwheel and an encoder for the spindle, or is only one of the two possible?
The background is that I drive the spindle with an AC servo, and this should be controlled via step/dir as a C axis. In the Gcode, the spindle should then work as a C axis, depending on the call, or rotate as a spindle. For the C axis to function correctly, not only the index must be evaluated, but also the angle via A/B.
EStop tested on NVEM board, works with mushroom button. In the GUI, EStop can be released and the machine started if the switch is not pressed. If it is pressed afterwards, the machine goes back into EStop.
Thanks to the "stupid" AI, I now seem to have managed to get a command to be issued on Joint2 with G0 C10 or with an M3 S300.
#External e-stop (fault) on NVEM v5 input.
loadrt estop_latch
addf estop-latch.0 servo-thread
net estop-loopout iocontrol.0.emc-enable-in <= estop-latch.0.ok-out
net user-enable-out iocontrol.0.user-enable-out => remora.enable
net estop-loopin remora.status => estop-latch.0.ok-in => estop-latch.0.reset
net estop-reset iocontrol.0.user-request-enable => remora.reset
net remote-estp estop-latch.0.fault-in <= remora.input.04
Edit* - cekaa
06 May 2025 08:29
Replied by cekaa on topic Ls L7nh CİA402 servo Drive ethercat op and preop problems
Category: EtherCAT
ini hall and xml file adedd
- Spyderbreath
06 May 2025 08:18
Replied by Spyderbreath on topic free CADCAM
free CADCAM
Category: CAD CAM
Wow, something I actually know something about on this forum.
For anyone wanting to explore FreeCAD I would highly recommend using the latest development versions. There are nightly builds available through a ppa but I personally would (and do) opt for the near weekly builds of the AppImages from here - github.com/FreeCAD/FreeCAD-Bundle/releases/tag/weekly-builds - Linux, Mac and Window$. No worries about dependences and if any given build has a showstopper bug, you can still have the last weeks to keep going until the next build that will, 99% of the time have that bug fixed. Lots of advanced and more complete features keep showing up. Especially in the CAM workbench.
FreeCAD is my daily driver and unlike this LinuxCNC stuff, I took to FreeCAD like a duck to water. I personally find it very easy to use but I know I am amoung only a few that do. There are a vast number of vids on youtube and a forum every bit as active as this one to help get you started.
For the money, you won't beat it, and before you know, you will be knocking out parts left and right.
- cekaa
06 May 2025 08:16
Category: EtherCAT
cnc@debian:~$ ethercat slaves
0 0:0 PREOP E L7NH - Standard EtherCAT drive(CoE,EoE,FoE)
1 0:1 OP + L7NH - Standard EtherCAT drive(CoE,EoE,FoE)
2 0:2 OP + L7NH - Standard EtherCAT drive(CoE,EoE,FoE)
0 0:0 OP + L7NH - Standard EtherCAT drive(CoE,EoE,FoE)
0 0:0 PREOP + L7NH - Standard EtherCAT drive(CoE,EoE,FoE)
cnc@debian:~$
ethercat slaves -v
cnc@debian:~$ ethercat slaves -v
=== Master 0, Slave 0 ===
Device: Main
State: OP
Flag: +
Identity:
Vendor Id: 0x00007595
Product code: 0x00010001
Revision number: 0x00000001
Serial number: 0x00000000
DL information:
FMMU bit operation: no
Distributed clocks: yes, 64 bit
DC system time transmission delay: 0 ns
Port Type Link Loop Signal NextSlave RxTime [ns] Diff [ns] NextDc [ns]
0 MII up open yes - 2788414231 0 0
1 MII up open yes 1 2788417151 2920 720
2 N/A down closed no - - - -
3 N/A down closed no - - - -
Mailboxes:
Bootstrap RX: 0x0000/0, TX: 0x0000/0
Standard RX: 0x1000/128, TX: 0x1400/128
Supported protocols: EoE, CoE, FoE
General:
Group: ServoDrive
Image name: DRIVE
Order number: L7NH - Standard EtherCAT drive
Device name: L7NH - Standard EtherCAT drive(CoE,EoE,FoE)
CoE details:
Enable SDO: yes
Enable SDO Info: yes
Enable PDO Assign: yes
Enable PDO Configuration: yes
Enable Upload at startup: no
Enable SDO complete access: yes
Flags:
Enable SafeOp: yes
Enable notLRW: yes
Current consumption: 0 mA
=== Master 0, Slave 1 ===
Device: Main
State: OP
Flag: +
Identity:
DL information:
DC system time transmission delay: 720 ns
0 MII up open yes 0 2898738888 0 720
1 MII up open yes 2 2898740368 1480 740
Mailboxes:
General:
Group: ServoDrive
Image name: DRIVE
CoE details:
Enable SDO: yes
Flags:
Enable SafeOp: yes
Enable notLRW: yes
=== Master 0, Slave 2 ===
Device: Main
State: OP
Flag: +
Identity:
DL information:
DC system time transmission delay: 1460 ns
0 MII up open yes 1 2768192999 0 740
1 MII down closed no - - - -
Mailboxes:
General:
Group: ServoDrive
Image name: DRIVE
CoE details:
Enable SDO: yes
Flags:
Enable SafeOp: yes
Enable notLRW: yes
cnc@debian:~$
sudo dmesg
cnc@debian:~$ sudo dmesg -C
[sudo] password for cnc:
[ 136.638023] EtherCAT ERROR 0-1: AL status message 0x0032: "PLL error".
[ 136.640259] EtherCAT 0-1: Acknowledged state SAFEOP.
[ 136.664315] EtherCAT WARNING 0-1: Other mailbox protocol response for eoe0s1.
[ 136.696316] EtherCAT WARNING 0-1: Other mailbox protocol response for eoe0s1.
[ 137.046021] EtherCAT ERROR 0-2: AL status message 0x0032: "PLL error".
[ 137.048223] EtherCAT 0-2: Acknowledged state SAFEOP.
[ 137.096340] EtherCAT ERROR 0-2: Mailbox error response received - Unknown error reply code 0x0000.
[ 137.096347] EtherCAT WARNING 0-2: Invalid mailbox response for eoe0s2.
[ 137.128322] EtherCAT WARNING 0-2: Other mailbox protocol response for eoe0s2.
[ 137.452212] EtherCAT 0: Slave states on main device: SAFEOP, OP + ERROR.
[ 137.461022] EtherCAT ERROR 0-0: AL status message 0x0032: "PLL error".
[ 137.463020] EtherCAT 0-0: Acknowledged state SAFEOP.
[ 137.540312] EtherCAT WARNING 0-0: Other mailbox protocol response for eoe0s0.
[ 142.548211] EtherCAT WARNING 0-0: Slave did not sync after 5000 ms.
[ 142.888220] EtherCAT 0: Slave states on main device: OP.
[ 189.704214] EtherCAT 0: Slave states on main device: SAFEOP, OP + ERROR.
[ 189.734024] EtherCAT ERROR 0-2: AL status message 0x0032: "PLL error".
[ 189.736022] EtherCAT 0-2: Acknowledged state SAFEOP.
[ 189.768320] EtherCAT WARNING 0-2: Other mailbox protocol response for eoe0s2.
[ 189.820332] EtherCAT ERROR 0-2: Mailbox error response received - Unknown error reply code 0x0000.
[ 189.820338] EtherCAT WARNING 0-2: Invalid mailbox response for eoe0s2.
[ 190.146022] EtherCAT ERROR 0-0: AL status message 0x0032: "PLL error".
[ 190.148223] EtherCAT 0-0: Acknowledged state SAFEOP.
[ 190.184313] EtherCAT WARNING 0-0: Other mailbox protocol response for eoe0s0.
[ 190.200317] EtherCAT WARNING 0-0: Other mailbox protocol response for eoe0s0.
[ 190.232315] EtherCAT ERROR 0-0: Mailbox error response received - Unknown error reply code 0x0000.
[ 190.232320] EtherCAT WARNING 0-0: Invalid mailbox response for eoe0s0.
[ 195.229022] EtherCAT WARNING 0-0: Slave did not sync after 5000 ms.
[ 195.550023] EtherCAT ERROR 0-1: AL status message 0x0032: "PLL error".
[ 195.552216] EtherCAT 0-1: Acknowledged state SAFEOP.
[ 195.636321] EtherCAT ERROR 0-1: Reception of CoE download response failed:
[ 195.636320] EtherCAT WARNING 0-1: Other mailbox protocol response for eoe0s1.
[ 195.636325] No response.
[ 195.636327] EtherCAT WARNING 0-1: Failed to set number of assigned PDOs of SM3.
[ 195.636328] EtherCAT WARNING 0-1: Currently assigned PDOs: (none). PDOs to assign: 0x1A00
[ 195.636332] EtherCAT WARNING 0-1: PDO configuration failed.
[ 195.964216] EtherCAT 0: Slave states on main device: OP.
cnc@debian:~$
ethercat pdos -v
cnc@debian:~$ ethercat pdos -v
SM0: PhysAddr 0x1000, DefaultSize 128, ControlRegister 0x26, Enable 1
SM1: PhysAddr 0x1400, DefaultSize 128, ControlRegister 0x22, Enable 1
SM2: PhysAddr 0x1800, DefaultSize 12, ControlRegister 0x64, Enable 0
RxPDO 0x1600 ""
PDO entry 0x6040:00, 16 bit, ""
PDO entry 0x607a:00, 32 bit, ""
PDO entry 0x60ff:00, 32 bit, ""
PDO entry 0x6071:00, 16 bit, ""
PDO entry 0x60b8:00, 16 bit, ""
PDO entry 0x6060:00, 8 bit, ""
SM3: PhysAddr 0x1c00, DefaultSize 20, ControlRegister 0x20, Enable 0
TxPDO 0x1a00 "1st Transmit PDO Mapping"
PDO entry 0x6041:00, 16 bit, ""
PDO entry 0x6064:00, 32 bit, ""
PDO entry 0x606c:00, 32 bit, ""
PDO entry 0x6077:00, 16 bit, ""
PDO entry 0x60b9:00, 16 bit, ""
PDO entry 0x6061:00, 8 bit, ""
PDO entry 0x60ba:00, 32 bit, ""
PDO entry 0x603f:00, 16 bit, ""
PDO entry 0x60fd:00, 32 bit, ""
RxPDO 0x1600 "1st Receive PDO Mapping"
cnc@debian:~$
ethercat cstruct
cnc@debian:~$ ethercat cstruct
/* Master 0, Slave 0, "L7NH - Standard EtherCAT drive"
* Vendor ID: 0x00007595
* Product code: 0x00010001
* Revision number: 0x00000001
ec_pdo_entry_info_t slave_0_pdo_entries[] = {
{0x6040, 0x00, 16},
{0x607a, 0x00, 32},
{0x60ff, 0x00, 32},
{0x6071, 0x00, 16},
{0x60b8, 0x00, 16},
{0x6060, 0x00, 8},
{0x6041, 0x00, 16},
{0x6064, 0x00, 32},
{0x606c, 0x00, 32},
{0x6077, 0x00, 16},
{0x60b9, 0x00, 16},
{0x6061, 0x00, 8},
{0x60ba, 0x00, 32},
{0x603f, 0x00, 16},
{0x60fd, 0x00, 32},
ec_pdo_info_t slave_0_pdos[] = {
{0x1600, 6, slave_0_pdo_entries + 0},
{0x1a00, 9, slave_0_pdo_entries + 6}, /* 1st Transmit PDO Mapping */
ec_sync_info_t slave_0_syncs[] = {
{0, EC_DIR_OUTPUT, 0, NULL, EC_WD_DISABLE},
{1, EC_DIR_INPUT, 0, NULL, EC_WD_DISABLE},
{2, EC_DIR_OUTPUT, 1, slave_0_pdos + 0, EC_WD_ENABLE},
{3, EC_DIR_INPUT, 1, slave_0_pdos + 1, EC_WD_DISABLE},
{0xff}
/* Master 0, Slave 1, "L7NH - Standard EtherCAT drive"
ec_pdo_entry_info_t slave_1_pdo_entries[] = {
{0x6040, 0x00, 16},
{0x607a, 0x00, 32},
{0x60ff, 0x00, 32},
{0x6071, 0x00, 16},
{0x60b8, 0x00, 16},
{0x6060, 0x00, 8},
{0x6041, 0x00, 16},
{0x6064, 0x00, 32},
{0x606c, 0x00, 32},
{0x6077, 0x00, 16},
{0x60b9, 0x00, 16},
{0x6061, 0x00, 8},
{0x60ba, 0x00, 32},
{0x603f, 0x00, 16},
{0x60fd, 0x00, 32},
ec_pdo_info_t slave_1_pdos[] = {
{0x1600, 6, slave_1_pdo_entries + 0}, /* 1st Receive PDO Mapping */
{0x1a00, 9, slave_1_pdo_entries + 6}, /* 1st Transmit PDO Mapping */
ec_sync_info_t slave_1_syncs[] = {
{2, EC_DIR_OUTPUT, 1, slave_1_pdos + 0, EC_WD_ENABLE},
{3, EC_DIR_INPUT, 1, slave_1_pdos + 1, EC_WD_DISABLE},
{0xff}
/* Master 0, Slave 2, "L7NH - Standard EtherCAT drive"
ec_pdo_entry_info_t slave_2_pdo_entries[] = {
{0x6040, 0x00, 16},
{0x607a, 0x00, 32},
{0x60ff, 0x00, 32},
{0x6071, 0x00, 16},
{0x60b8, 0x00, 16},
{0x6060, 0x00, 8},
{0x6041, 0x00, 16},
{0x6064, 0x00, 32},
{0x606c, 0x00, 32},
{0x6077, 0x00, 16},
{0x60b9, 0x00, 16},
{0x6061, 0x00, 8},
{0x60ba, 0x00, 32},
{0x603f, 0x00, 16},
{0x60fd, 0x00, 32},
ec_pdo_info_t slave_2_pdos[] = {
{0x1600, 6, slave_2_pdo_entries + 0}, /* 1st Receive PDO Mapping */
{0x1a00, 9, slave_2_pdo_entries + 6}, /* 1st Transmit PDO Mapping */
ec_sync_info_t slave_2_syncs[] = {
{2, EC_DIR_OUTPUT, 1, slave_2_pdos + 0, EC_WD_ENABLE},
{3, EC_DIR_INPUT, 1, slave_2_pdos + 1, EC_WD_DISABLE},
{0xff}
cnc@debian:~$
cnc@debian:~$
ethercat slaves -v
Device: Main
State: OP
Flag: +
Identity:
DL information:
Mailboxes:
General:
Group: ServoDrive
Image name: DRIVE
CoE details:
Enable SDO: yes
Flags:
Enable SafeOp: yes
Enable notLRW: yes
Device: Main
State: OP
Flag: +
Identity:
DL information:
Mailboxes:
General:
Group: ServoDrive
Image name: DRIVE
CoE details:
Enable SDO: yes
Flags:
Enable SafeOp: yes
Enable notLRW: yes
Device: Main
State: OP
Flag: +
Identity:
DL information:
Mailboxes:
General:
Group: ServoDrive
Image name: DRIVE
CoE details:
Enable SDO: yes
Flags:
Enable SafeOp: yes
Enable notLRW: yes
cnc@debian:~$
sudo dmesg
cnc@debian:~$
ethercat pdos -v
RxPDO 0x1600 ""
cnc@debian:~$
ethercat cstruct
{0x6040, 0x00, 16},
{0x607a, 0x00, 32},
{0x60ff, 0x00, 32},
{0x6071, 0x00, 16},
{0x60b8, 0x00, 16},
{0x6060, 0x00, 8},
{0x6041, 0x00, 16},
{0x6064, 0x00, 32},
{0x606c, 0x00, 32},
{0x6077, 0x00, 16},
{0x60b9, 0x00, 16},
{0x6061, 0x00, 8},
{0x60ba, 0x00, 32},
{0x603f, 0x00, 16},
{0x60fd, 0x00, 32},
{0xff}
{0x6040, 0x00, 16},
{0x607a, 0x00, 32},
{0x60ff, 0x00, 32},
{0x6071, 0x00, 16},
{0x60b8, 0x00, 16},
{0x6060, 0x00, 8},
{0x6041, 0x00, 16},
{0x6064, 0x00, 32},
{0x606c, 0x00, 32},
{0x6077, 0x00, 16},
{0x60b9, 0x00, 16},
{0x6061, 0x00, 8},
{0x60ba, 0x00, 32},
{0x603f, 0x00, 16},
{0x60fd, 0x00, 32},
{0xff}
{0x6040, 0x00, 16},
{0x607a, 0x00, 32},
{0x60ff, 0x00, 32},
{0x6071, 0x00, 16},
{0x60b8, 0x00, 16},
{0x6060, 0x00, 8},
{0x6041, 0x00, 16},
{0x6064, 0x00, 32},
{0x606c, 0x00, 32},
{0x6077, 0x00, 16},
{0x60b9, 0x00, 16},
{0x6061, 0x00, 8},
{0x60ba, 0x00, 32},
{0x603f, 0x00, 16},
{0x60fd, 0x00, 32},
{0xff}
cnc@debian:~$
- cekaa
06 May 2025 07:57 - 06 May 2025 08:19
Ls L7nh CİA402 servo Drive ethercat op and preop problems was created by cekaa
Category: EtherCAT
I am a beginner in linuxcnc ethercat I am waiting for your help
.4 Chinese drivers work without any problems in the same system operating modeLs servo ????? op problemsethercat slaves ?????????
I couldn't find the reason why it was switching to op mode and not switching to it.I am adding demesg and other outputs that you can askI couldn't find the reason for this, I would be very happy if you could help me. I bought 10 of these servo motors, but I couldn't solve the problem of whether it was connected or not.
cnc@debian:~$
cnc@debian:~$
- Spyderbreath
06 May 2025 06:52 - 06 May 2025 07:17
Replied by Spyderbreath on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
I tried to enter the estop from tuxcnc above and got this error.
I attached my hal and ini files. Does this mean I can only have the watchdog or the estop latch but not both?
*Edit*
I have just tried the estop latch with the tuxcnc code with the watchdog commented out and after fixing the typo in the last line where it starts out - net remote-estp ... - it is missing the o in estop. That error is in the attached hal, didn't catch it befor attaching. It works, exactly one time, by opening the circuit and thats all she wrote. reconnecting the circuit and can not reset the estop and power back on the machine without closing down and restarting the gui.
Note: Using POSIX realtime
./remora-ec500.hal:60: Pin 'iocontrol.0.emc-enable-in' was already linked to signal 'remora-status'
3295
Stopping realtime threads
Unloading hal components
Note: Using POSIX realtimeI attached my hal and ini files. Does this mean I can only have the watchdog or the estop latch but not both?
*Edit*
- hermann1976
06 May 2025 06:50
Replied by hermann1976 on topic Change Tool Offsets after editing the Tool Table
Category: Gmoccapy
Thank you for your answer.
The tool length transfer also works with G43 and is also applied to the loaded tool after a change in the tool table. However, the tool diameter is not transferred. The data is only transferred when explicitly unloading or when switching to another tool and then back to the changed tool using the M61 Q? button. Unfortunately, only M61 Q? doesn't work because I get a message saying the tool is already in the spindle.
Can I somehow initiate the diameter change?
I think I have a different understanding of tool length. Fundamentally, machining can only be performed with a measured tool with a specific length. Therefore, tool length compensation should always be active. Which is why I can't understand why there is a G49 in the "on_abort" subroutine. If I have to abort the program, the tool length is set to 0, which leads to errors when calling the program again if there is no explicit G43 in the program. I removed the G49 from the "on_abort" macro program.
So, for me, the tool length should always be active.
- Spyderbreath
06 May 2025 06:12
Thank you cakeslob for these posts. I went back and read the Remona manual again from the start and I did discover something I didn't know before and that is the included estop stuff at the beginning of the sample .hal is a coms watchdog and testing it by unplugging the ethernet cable triggers the estop. Shiny, I can understand the function of that part. How or why, cluless, but what it does is clear.
But you asked if there were any questions, and yes there are.
I'll start with a single line from the tuxcnc example above.
1. estop-loopout - where did that come from? Did a search "estop-loopout" site:https://linuxcnc.org/docs and got 0 returns, same with a search of the Remora doc site, 0 results.
2. estop-latch - this did return some results - linuxcnc.org/docs/html/man/man9/estop_latch.9.html but I do not see any connection there that would lead me to come up with those words being placed where they are in the example. How would one know to put that there?
3. <= and => - What do these mean? Do they denote the direction flow of data or signals, do they stand for less than and equal to and equal to and greater than or is it something else and why are they needed and what determines where they go? Is this explained somewhere?
To be truthful, maybe I should be looking for someone to hire that can do all this complex coding and programing for me as it seems far and beyond my ability with my learning handicap.
For the moment, I'll keep trying and hack away at it bit by bit. To much time invested to round file it all now, but please feel free to tell me to go pound sand when I become to much of a burden. I won't feel bad, happens all the time when I am confronted with this kind of complex programing.
net estop-loopout iocontrol.0.emc-enable-in <= estop-latch.0.ok-out1. estop-loopout - where did that come from? Did a search "estop-loopout" site:https://linuxcnc.org/docs and got 0 returns, same with a search of the Remora doc site, 0 results.
- rbobey1989
06 May 2025 05:48
EL2502 and EL2535 PWM Ethercat BECKHOFF Modules was created by rbobey1989
Category: EtherCAT
Hi everyone, I've started to experiment with Ethercat and Beckhoff modules along with LinuxCNC. I have to say that it was easy to use the generic driver and get up and running. I've used some input/output modules, encoders, and analog outputs, for example the 2809, 1809, 5151, and 4032.
I was thinking about using modules with PWM outputs, and to my surprise, I saw that they are not included in the drivers (correct me if I'm wrong). I could try coding a specific driver, for example, for the 2502 and 2535 modules. Although if someone has already done it, perhaps it could save me some time.
The truth is that being able to use Beckhoff industrial modules with LinuxCNC has great hardware advantages, as interfacing with servo amplifiers, encoders, etc. is very simple. I've done some things with Remora and the RT1052 firmware, in which I've developed some encoder and PWM modules, but I always run into interface problems, especially with industrial modules. Obviously, compared to Beckhoff, this solution is much more economical.
Well, I hope for some answers, guys, about the EL2502 and EL2535 PWM modules. If anyone has developed something and wants to share it, I'd appreciate it in advance. Best regards.
06 May 2025 05:13
Replied by PCW on topic soft limit error after x homing, does not home y
If the homing direct does not change, then it's likely the you did not
change the correct ini constant (or perhaps there is another error in
the ini file homing constants or perhaps home switch operation)
I don't think you can eliminate the soft limits issue unless you get the
MIN_LIMIT and MAX_LIMIT setup properly (MIN_LIMIT < MAX_LIMIT)
It may also be the you have the hardware directions reversed, this you can
fix by inverting the direction pin or changing the sign of the joint SCALE
ini constant. (say 4000 to -4000)
- koch777
- koch777
06 May 2025 05:08 - 06 May 2025 05:11
Replied by koch777 on topic Troubles with Mesa 7I76EU + 7I76U(P1) + 7I89(P2)
Category: Driver Boards
Working like a charm.
Thank you very much Peter!
P.S.
Damn self-made DB25 cables. Firmware initially didn't make any difference. Apparently cables on P1 and P2 were backward. Reversed both DB25 connectors and now I see both 7I76 and 7I89 and encoders are working. These Mesa cards seem to be very robust, even all wrong signals on all the wrong pins didn't make them go dead.
P.S.
Time to create page: 0.768 seconds
