  • Grotius
  • Grotius's Avatar
24 Apr 2025 07:45
Replied by Grotius on topic LinuxCNC S-Curve Accelerations
@Pcw,
Thanks for your effort. Not everything is installed by the makefile.
I think you need to look at the ./installer file, wich install's locally :
libclothoid3d
libscurve
segment.h is part off libclothoid3d and is installed in /usr/local/include
Then finally there is done a ldconfig.
I hope it works for you then.
  • Aciera
  • Aciera's Avatar
24 Apr 2025 07:00
Planning to Retrofit a Mazak Integrex200Y Mill-Turn Machine
Also i saw, that in the Identity Mode the Axis soft limits work fine, but in TCP-Mode the maschine runs into the joint hard limits.
For non trivial kinematics proper limit checking prior to execution time is currently not possible because the planner is totally ignorant of custom kinematics. Your best option would be to check for limit violations in cam or running your gcode in a simulation configuration.
Limit checking does work during execution (ie when the joint position actually exceeds the limit) but that will cause an immediate (emergency) stop.
Sometimes it may even be necessary to loosen axes limits to be able to reach the full work space.
  • Mr. Mass
  • Mr. Mass's Avatar
24 Apr 2025 06:01
qtdragon mod was created by Mr. Mass
qtdragon mod
Category: Qtvcp
Trying to modify qtdragon a bit and add hal pins for slides. Found an example on the forum for analog, but I need to do for encoders. Tried to redo the code, at first glance everything seems ok, values change, sliders react. But the problem appears if we change the value by encoder, say by 50%, then press the button 100%, and if after that we reduce the value by encoder again, it immediately jumps to 40% (I specified a step of 10%). As far as I understand the problem is that absolute values are used, but it is necessary to use relative values. But I am completely stuck on how to implement it in the code.
  • Thayloreing
  • Thayloreing
23 Apr 2025 23:56
Replied by Thayloreing on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
Good evening everyone, I'm having a problem, I don't know where I'm going wrong, I do the ST Linkv2 procedure and it does everything right, but it doesn't appear as a unit on the PC, when I go to connect it to the PC with pyocd it doesn't find the ST Link, I've already bought 3 different ST Links and all 3 do the same thing, I don't know if my pyocd installation is wrong or not, I've redone the installation several times, I don't know where the problem is.
  • Chef_2
  • Chef_2
23 Apr 2025 22:39
Umstieg auf LinuxCNC mit RaspberryPi4
Category: Deutsch
Servus,
ich spiele schon länger mit dem Gedanken, auf LinuxCNC umzusteigen... jetzt habe ich gesehen, dass es das auch für den Pi4 gibt.... umsobesser :D
Die erste Frage ist nun aber, welche Steuerungsplatine sollte man hinter dem Raspi nutzen ? Aktuell habe ich Mach3... aber das mit der Echtzeit und alter gefällt mir nicht mehr!
Wer hat hier Tips für die Hardware zusammenstellug ? Handrad sollte auch noch her!
  • rodw
  • rodw's Avatar
23 Apr 2025 21:17
Replied by rodw on topic LinuxCNC S-Curve Accelerations
Hi Rod,
The Cia-402 i have seen the source code. It does not much.
It sends and recieves position, velocity, torque  trough a can protocol?
Yes, the cia402 protocol defines a state machine to turn on a machine using a standard control word and a status word confirming current machine state. The attached PDF is a good summary
There are also a loosely defined  set of PDOs
What we really need is a component that just defines the turn on sequence and then a seperate homemod for drive homing. It may be possible to do the turn on in the homemod so there is only one module but it might then sit outside the hal lcec Ethercat loop so it may run one servo thread cycle behind.
  • HansU
  • HansU's Avatar
23 Apr 2025 20:53 - 23 Apr 2025 20:53
Replied by HansU on topic Gmoccapy Modal Display
Category: Gmoccapy
The issue has been reported here: github.com/LinuxCNC/linuxcnc/issues/2753
  • Salrodri
  • Salrodri
23 Apr 2025 20:22
Replied by Salrodri on topic Tool changer
Tool changer
Category: O Codes (subroutines) and NGCGUI
Hi Andy,
I have been working on this ATC over 3 moths now. So far I released the magic smoke of two mesa cards, but the retrofit must continue.
Thank you for creating this component, It has tough me a lot in regards how linuxcnc and a CNC machine works.
It does makes more sense driving the ATC with G-code.
I discarded this idea, because you mention that carousel component was not designed to be used as an axis.
I guess we can scratch that lol
How would you go about it driving the ATC with G-code?
would you have a bunch of if statements?
for example:
if M6T1 then G53 G0 A2 (and the rest of the operations)
if M6T2 then G53 G0 A3 (and the rest of the operations)
Would I have to update the iocontrol with G-code every time the tool changes?
I have a lot of respect and admiration of your work.
is truly an honor that you respond to my question.
Thank you,
  • jochen91
  • jochen91
23 Apr 2025 20:19
Hi Aciera,
sorry for reply a bit late. I was on vaccation. Thank you so so much for this incredible help! I downloaded it and played i bit arround and it looks realy good.
I changed the travel limits for the B-Axis, because the head can swivel from "looking" left and right into the z direction. This caused some trouble. I need to spend more time with it to know what needs to be "polished".
I hope in find time during the weekend to dig myself further into your example. Thanks again for the amazing help!
Kind regards,
Jochen
  • andypugh
  • andypugh's Avatar
23 Apr 2025 19:25
Replied by andypugh on topic Tool changer
Tool changer
Alternatively this might be one case where it makes sense to define the toolchanger as an axis and drive it from pure G-code.
  • andypugh
  • andypugh's Avatar
23 Apr 2025 19:23
Tool changer
Well, one thing I can tell you is that I never imagined that a toolchanger like that existed when I created the carousel component :-)
It's a neat idea, actually, I quite like the design.
You could maybe set the carousel.0.rev-pulse to some value, but to be honest I don't think that would work properly, as it assumes that the motor is allowed to slip against a hard stop, and that's not going to work in counts mode.
I think that one way to do what you want would be to add a mux2 to switch the velocity command.
Change
net car-vel carousel.0.motor-vel => hm2_[MESA](BOARD).0.stepgen.03.velocity-cmd
loadrt mux2
loadrt pid
net car-vel carousel.0.motor-vel => mux2.0.in1
net park-vel pid.0.out => mux2.0.in0
net switched-vel mux2.0.out => hm2_[MESA](BOARD).0.stepgen.03.velocity-cmd
net car-enable mux2.0.sel
Then set up (and tune) the PID to park the changer and hold it there.
A better option might be to modify the carousel.comp to add an extra park state in the state machine. Do you have any familiarity with C code?
  • tiagounderground
  • tiagounderground
23 Apr 2025 18:49 - 23 Apr 2025 18:51
Replied by tiagounderground on topic LinuxCNC S-Curve Accelerations
Hi Tia,
I don't know why it won't run with cia-402.
We have more users with the same problem.
However the cia-402 source code does nothing with acceleration. Only torque, vel, pos.
Is there a alternative to the cia-402?
if you want to access my machine remotely i can give you access
  • PCW
  • PCW's Avatar
23 Apr 2025 18:26
Replied by PCW on topic LinuxCNC S-Curve Accelerations
Tried to compile but got this:
In file included from emc/planner/curve.h:14,
                 from emc/planner/feed.h:15,
                 from emc/planner/feed.c:12:
emc/planner/emcmot_segment.h:27:10: fatal error: segment.h: No such file or directory
   27 | #include "segment.h"
  • Grotius
  • Grotius's Avatar
23 Apr 2025 17:57
Hi Tia,
  • emresensoy
  • emresensoy
23 Apr 2025 17:41
Replied by emresensoy on topic EtherCAT Servo cannot set to OP state
Category: EtherCAT
nothing but something:D
Displaying 16696 - 16710 out of 17176 results.
Time to create page: 0.648 seconds
