  • aDm1N
  • aDm1N's Avatar
15 Apr 2025 16:34
Replied by aDm1N on topic ChatGPT LinuxCNC Assistent
Category: Configuration Tools
The link for the same Page.
I tested all of the public file services offered; some of the alleged URLs were not assigned; a private FTP server or cloud was allegedly tested positive, but no data arrived.
  • heaven
  • heaven
15 Apr 2025 15:55
Replied by heaven on topic duplicate component name "usergenserkins"
I  just reseted my pc and it worked, weird  . Thanks anyway
  • Aciera
  • Aciera's Avatar
15 Apr 2025 15:36
Replied by Aciera on topic duplicate component name "usergenserkins"
Just tried on a locally built version of master, seems to kind of work:
  • heaven
  • heaven
15 Apr 2025 15:22 - 15 Apr 2025 15:24
Yes, it is. In lcnc 2.8 i can run it by typing "genserkins" (not halrun) in terminal, but from 2.9 it seperated to ugenserkins.c and no longer work. I'm trying to add base and tool transform for this module.
  • notJamesLee
  • notJamesLee
15 Apr 2025 15:18
Replied by notJamesLee on topic Determining Angular Scale - Help w/ Microsteps
update.
I took the motor out just to see if i could get it to reliably spin one revolution. With all the dip switches set to default that number is 1600. And i think i just had a brain blast because switching to the 1600 doesn't change it.
Also conveniently 1600 / 3.12 (the pulley ratio) is 533.3333 pretty close to the 540 number,.
I am going to throw it back together and verify.
  • notJamesLee
  • notJamesLee
15 Apr 2025 14:59
Changing from F to 0 the output changes. The motor shaft is shaking as it doesnt have enough torque to spin the pulley. This is true until i get to 8. On 8 it comes alive and spins as it has been. The output seems to improve as i move past 8 but i have no data to confirm this.
I have the debug cord but once i get into the menus i have no idea what i am looking for.
  • Grotius
  • Grotius's Avatar
15 Apr 2025 14:30
Replied by Grotius on topic LinuxCNC S-Curve Accelerations
HI Rod,
A tester send me this :
Debian 10 : jitter max 45200
Debian 12:jitter max 29000
Debian13:jitter max 522000
Ir looks very bad.
  • MiRu
  • MiRu
15 Apr 2025 14:14 - 15 Apr 2025 14:16
Replied by MiRu on topic MPG error
MPG error
Attachment not found
My files
  • gardenweazel
  • gardenweazel's Avatar
15 Apr 2025 14:13
Replied by gardenweazel on topic Inconsistent values from Versaprobe
Category: Qtvcp
Thanks for your reply!
Indeed there is something clearly incorrect. I'm not sure that it's in code or documentation or a combination of both.
I've tried numerous times to fix this without success. I think that it goes without saying that if it's not working properly,
it should probably be removed. It's very annoying.
15 Apr 2025 13:47
Replied by tommylight on topic asd-a2 e delta homing
Category: EtherCAT
Moved the double post here as it had files attached.
Please refrain from double posting.
Thank you.
  • Aciera
  • Aciera's Avatar
15 Apr 2025 13:31
Replied by Aciera on topic asd-a2 e delta homing
Category: EtherCAT
@mehdidadash
No double posting please.
  • pgf
  • pgf
15 Apr 2025 13:22
Replied by pgf on topic WebGUI
WebGUI
Category: Other User Interfaces
Any more progress on this? It's a great idea.
  • Aciera
  • Aciera's Avatar
15 Apr 2025 13:15 - 15 Apr 2025 13:17
When i try run usergenserkins in terminal by typing genserkins to test something
I'm not exactly sure what that means but looking at this note at the beginning of 'ugenserkins.c' makes me think that you might be trying to use something that is likely no longer working:
* !!! Declining usage
* !!! This userspace program was been separated from the original
* !!! genserkins.c as part of refactoring kinematics for
* !!! switchkins support. The userspace program has not been
* !!! updated since 2009 (commit 1939285758) and correct
* !!! functioning in its current state is doubtful.
* Description: ugenserkins.c
* Test program (originally part of genserkins.c)
* License GPL Version 2
  • Kriek
  • Kriek
15 Apr 2025 13:05
Replied by Kriek on topic Tool in spindle memory
I have also implemented random toolchanger on my lathe. It works to remember the right tool in the machine. A problem that have occured quite a few times is that when I update tool offsets the tool number in use changes.
For instance, tool 7 is in use and I update tool 3's offset in the tool table. Save, reread, reload. Then tool 7 becomes tool 11 or 12. Well, some other random tool number. I could not deduce a specific pattern so far and it does not happen every time.
  • andypugh
  • andypugh's Avatar
15 Apr 2025 13:05
Replied by andypugh on topic CNC doesn't work with new update
Are you sure that you were on 2.8.2? The big update was 2.8.x to 2.8.x
(but I don't think that the update script changes it's warning depending on the actual versions)
[TRAJ] AXES has always been there, so I am not sure what the updater has done to make it apparently disappear. Do you perhaps now have _two_ [TRAJ] sections in the INI?
Displaying 17206 - 17220 out of 17243 results.
Time to create page: 0.367 seconds
