  • bigmactx
  • bigmactx's Avatar
04 Mar 2025 22:55
Replied by bigmactx on topic LinuxCNC 2.10 build
LinuxCNC 2.10 build
Category: Installing LinuxCNC
Quick update and correction.
It seems that changing the Makefile.inc isn't necessary as it gets rebuilt as part of the run.
So looking at ./debian/configure I see the option for no documents is 'no-docs' and this works.
./debian/configure no-docs
dpkg-buildpackage -b -uc
-b option doesn't seem to matter.
I'll do some more digging into the fortify issue to see if I can find a better solution and to understand the DEBUG question lingering in my miind.
Cheers
  • Hakan
  • Hakan
04 Mar 2025 22:49 - 04 Mar 2025 22:50
Replied by Hakan on topic Ethercat linuxcnc not seeing any slaves
Category: EtherCAT
Link down. Did you customize /etc/ethercat.conf ?
  • ihavenofish
  • ihavenofish
04 Mar 2025 22:46 - 04 Mar 2025 22:48
Replied by ihavenofish on topic Ethercat linuxcnc not seeing any slaves
Category: EtherCAT
from ethercat master.... seems maybe its not working at the network card level. What did i break? haha
Master0
Phase: Waiting for device(s)...
Active: no
Slaves: 0
Ethernet devices:
Main: 00:23:24:3e:1b:ba (waiting...)
Link: DOWN
Tx frames: 0
Tx bytes: 0
Rx frames: 0
Rx bytes: 0
Tx errors: 0
Tx frame rate [1/s]: 0 0 0
Tx rate [KByte/s]: 0.0 0.0 0.0
Rx frame rate [1/s]: 0 0 0
Rx rate [KByte/s]: 0.0 0.0 0.0
Common:
Tx frames: 0
Tx bytes: 0
Rx frames: 0
Rx bytes: 0
Lost frames: 0
Loss rate [1/s]: 0 0 0
Frame loss [%]: 0.0 0.0 0.0
Distributed clocks:
Reference clock: None
DC reference time: 0
Application time: 0
2000-01-01 00:00:00.000000000
  • Hakan
  • Hakan
04 Mar 2025 22:39
Category: EtherCAT
Try
ethercat master
ethercat slaves
sudo dmesg
  • ihavenofish
  • ihavenofish
04 Mar 2025 22:37
Ethercat linuxcnc not seeing any slaves was created by ihavenofish
Category: EtherCAT
So, I installed linuxcnc fresh, then began the ethercat install per instruction thread. It *seems* to have worked, but there are no slaves displayed when I type ethercat slaves...
So, for sanity I went into twincat, and it DOES scan the servo drives, however it triggers a communication error of wrong data type. I wonder if the 2 are related and something is set wrong on the drives.
Servos drives are omron R88D
Any thoughts on what may be wrong here?
  • JohnnyCNC
  • JohnnyCNC's Avatar
04 Mar 2025 22:29
Replied by JohnnyCNC on topic Work with probe
Work with probe
Category: Basic Configuration
Glad you got it. I'm using Basic Probe with QTDragon_HD. There is also Probe_Basic and Versa Probe which I think is what you are using. It looks like you are using the GMOCCAPY UI.
  • PCW
  • PCW's Avatar
04 Mar 2025 22:05
Should I just suck it up and buy a good stepper driver?
Category: Driver Boards
All standard MOSFETs have inherent "body" diodes which will function as flybacks
though typically Schottky diodes are added to reduce voltage drop and hence power
dissipation.
  • Daz
  • Daz
04 Mar 2025 22:04 - 04 Mar 2025 22:17
Replied by Daz on topic Work with probe
Work with probe
Found it! And at the end, it was a simple option to tick.
While I was analysing the macro, I came across this lovely if statement:
;Check for refinement measurement
O7 if [#<_hal[probe.chk_use_fine]> GT 0]
And after checking the screen, here it is: "Use refinement measurement". After checking the option, there is a second probing action at probing velocity. Problem solved!
  • Bjornstabo
  • Bjornstabo
04 Mar 2025 22:04
Replied by Bjornstabo on topic Plasmac Post Processors
Category: Plasmac
I am having the same problem with "Radius to end of arc differs from radius to start" with a +90% error rate, using the fusion 360 post. I am able to post out some parts that will run and some that dont. All of theese have previosly been run with no issues on a Mach3 plasma with the same cut settings. Files 1001 and 1005 runs fine. But not 1002 and 1006? Any idea on how to fix this?
  • Daz
  • Daz
04 Mar 2025 21:46
Work with probe
OK, I think I now understand how the macros are structured. Here is the main macro responsible for probing. I am now trying to understand it and debug it. Any help is much appreciated :)
File Name: _psng_probe.ngc
File Size:5 KB
  • bigmactx
  • bigmactx's Avatar
04 Mar 2025 21:36
LinuxCNC 2.10 build
So I found a quick fix for the _FORTIFY_SOURCE errors which is ok specifically for me at least to now but not a good fix for the project.
In the src directory is Makefile line 255:
original line DEBUG := $(DEBUG) -g -Wall -D_FORTIFY_SOURCE=2
modified line DEBUG := $(DEBUG) -g -Wall
in the Makefile.inc file line 114:
original line CPPFLAGS = -Wdate-time -D_FORTIFY_SOURCE=3
modified line CPPFLAGS = -Wdate-time
As I mentioned, this would not be an acceptable fix for generalized distribution as buffer overruns and other security features provided by _FORTIFY_SOURCE are important. It does however get me going for now just fine.
Now I'll dig into the manpage issue with "\S" and see if I can find a workaround for that. Documentation is always a good thing to have.
Thanks to all for help and suggestions.
  • ErwinCNC
  • ErwinCNC
04 Mar 2025 21:23
Installation 2.9.4 Debian Bookworm Preempt-RT ISO // Probleme
Category: Deutsch
Hallo Fraes Paul,
zu 2
bin ebenfalls nur Anfänger in dem Thema habe die letzten Wochen aber einige Zeit mit dem Thema Latenz verbracht.
Vermutlich kennst du die Latenz Videos von TooTall18T?
Hast du deinen Latenz Test unter Last gemacht? Video im Hintergrund, ein paar drehende Zahnräder (glxgears), Fenstergröße mit der Maus langsam ändern, ...
das hatte bei mir einen relativ großen Einfluss im Sinne von schlechteren Latenzwerten.
Mit den Hinweisen aus den Videos habe ich die Latenz deutlich verbessern können aber leider kommt immer noch ab und an die Watchdog Meldung
Grüße Erwin
  • Daz
  • Daz
04 Mar 2025 21:08 - 04 Mar 2025 21:10
Work with probe
Thanks for this. I have added the debounce function but it didn't didn't fix the problem. I am going to keep it as it looks like a good practice.
I don't have the settings you have in the ini file. However, the probe screen I am using has a separate file, "probe_screen.pref", where it keeps the preferences. Nothing seems to be missing.
I have checked the input signal in Halshow, and I can see the signal is going ON on the first approach at search velocity, but I don't see a second signal at probing velocity. The program just concludes the measurement and uses the value from the search velocity.
I am starting to think it is some kind of bug in a macro, but if that is the case, I am sure others would experience it as well.
I am using the probe screen v2.9 from this git repository:
github.com/verser-git/probe_screen_v2.9
Here are my settings for the probe screen and a macro to measure X- position (I hope it is the correct one). Perhaps someone can spot what is wrong:
####Config file#####
[DEFAULT]
chk_signal_delay = False
ps_signal_delay = 1.5
chk_use_fine = False
chk_error_signal = False
chk_auto_rott = False
ps_offs_angle = 0.0
chk_set_zero = False
chk_arm_enable = False
enbl_remap_m6 = True
ps_metric_mode = True
ps_searchvel = 100.0
ps_probevel = 10.0
ps_z_clearance = 4.0
ps_probe_max = 15.0
ps_probe_latch = 10.0
ps_probe_diam = 1.915
ps_xy_clearance = 5.0
ps_edge_length = 5.0
ps_offs_x = 0.07874015748031495
ps_offs_y = 0.079
ps_offs_z = 19.38
ps_arm_delta_x = 0.0
ps_arm_delta_y = 0.0
setterheight = -23.7225
blockheight = -71.445
#### Example Macro ####
o<psng_xminus> sub
; BEGIN PSNG PREAMBLE
M73 ; Save and autorestore model states. This will be used only in case of error, otherwise we will invalidate it.
o<_psng_modal_save> call
o<_psng_hook> call [6]
; END PSNG PREAMBLE
; Save starting X position
#<x>=#<_x>
; Ensure we're in G90 / absolute mode
G90
; Probe X Minus
o<_psng_probe_x> call [-#<_hal[probe.ps_probe_max]>]
O1 if [#<_value> EQ -1]
M72 ; Restore modal state
(ABORT, Probe already tripped when starting G38.3 move)
O1 else if [#<_value> EQ -2]
(ABORT, Probe failed to make contact with workpiece)
O1 else if [#<_value> EQ -3]
(ABORT, Probe failed to make contact without ERR signal)
O1 endif
; Move back to starting X position
G1 X#<x> F#<_ini[TOOLSENSOR]RAPID_SPEED>
; BEGIN PSNG POSTAMBLE
M71 ; Invalidate Modal Autorestore
o<_psng_modal_restore> call
; END PSNG POSTAMBLE
o<psng_xminus> endsub
M2
  • Hakan
  • Hakan
04 Mar 2025 20:39
Issue with OP Entry Delay and Failures in LinuxCNC + EtherCAT System
Category: EtherCAT
If you look at the diagnostic outputs using "sudo dmesg" on the two systems, does that give a clue to what can be the issue?
EtherCAT master puts out some info there.
  • PCW
  • PCW's Avatar
04 Mar 2025 20:22 - 04 Mar 2025 20:23
Running a Mesa PCI card through a PCIe to PCI adaptor?
The card would not be detected if in backwards
(Though the power supply pins might cause some issues)
I can just send you  6I24-16
(The -16 is big enough for any LinuxCNC config)
Displaying 18256 - 18270 out of 18599 results.
Time to create page: 0.524 seconds
