  • bananun
  • bananun
01 Feb 2025 08:24 - 01 Feb 2025 08:28
Ethercat installation from repositories - how to step by step
Category: EtherCAT
Sorry, my bad! I should have waited until I had access to the machine so I could post more info about the issue. This is what goes wrong for me with the latest RPi5 image. I've attached the full "log" as well. Is there any other data I can attach to assist? Thank you for your help in advance, I greatly appreciate it!
dpkg: dependency problems prevent configuration of ethercat-master:
 ethercat-master depends on ethercat-dkms; however:
  Package ethercat-dkms is not configured yet.
dpkg: error processing package ethercat-master (--configure):
 dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of linuxcnc-ethercat:
 linuxcnc-ethercat depends on etherlabmaster | ethercat-master; however:
  Package etherlabmaster is not installed.
  Package ethercat-master is not configured yet.
dpkg: error processing package linuxcnc-ethercat (--configure):
Processing triggers for desktop-file-utils (0.26-1) ...
Processing triggers for libc-bin (2.36-9+deb12u9) ...
Processing triggers for man-db (2.11.2-2) ...
Processing triggers for mailcap (3.70+nmu1) ...
Errors were encountered while processing:
 ethercat-dkms
 ethercat-master
 linuxcnc-ethercat
E: Sub-process /usr/bin/dpkg returned an error code (1)
  • cmorley
  • cmorley
01 Feb 2025 08:09
Replied by cmorley on topic qtdragon additonal buttons
Category: Qtvcp
Ok try this both files must be in the folder I described before.
pan/rotate button works and G5x button now will select the DRO to reflect the current user offsets.
As for the REF button - is it that the drop down menu is too small ? It can be enlarged.
Or the Ref button could be changed to just call the calculator for setting the axis (no drop down menu)
(for future reference, this mod is for 2.9 qtdragon_hd)
  • bananun
  • bananun
01 Feb 2025 08:00 - 01 Feb 2025 08:42
Replied by bananun on topic RPi5 Test images
RPi5 Test images
Category: Installing LinuxCNC
Sorry for the lack of info from my side, but I get the same issue with balena etcher fyi, not that it matters apparently since it's not the latest image any more
  • Aciera
  • Aciera's Avatar
01 Feb 2025 07:45
Replied by Aciera on topic caxis.comp - How to freewheel axis/spindle?
Category: HAL
As you don't want to unhome during gcode execution you might want to try a python component and use
self.command.unhome(joint)
That is what the guis use, which seems to work just fine.
  • Boogie
  • Boogie
01 Feb 2025 07:45
Replied by Boogie on topic The blacksmith's plasma table
Category: Plasma & Laser
@polskleforgeron - czesc, jak sie mozna z Toba skontaktowac? Chcialbym pogadac o tym stahlwerku - mam ta plazme od dluzszego czasu w pudle i w koncu musze to zaczac uzywac, a utknalem na etapie podlaczenia tego do linuxcnc.
Sorry guys,
just need to get in touch with polskleforgeron.
  • rodw
  • rodw's Avatar
01 Feb 2025 07:37
Custom PC build for my brothers company and more
Category: Show Your Stuff
(no Rod, your PC does not have 20 cores, Intel lied to you ... and the rest of the world, Atom cores are not worth a dime).
Hey all I care about is I see that count when compiling kernels and things ... rather quickly,.....
  • rodw
  • rodw's Avatar
01 Feb 2025 07:34
Replied by rodw on topic good day to all (in some gtp languages)
Snow here disappear in few days from top of mountain because wind .... so not sky with skins ..... than return and go .... but can done some little peaks .... tomorrow try again but snow is heavy now .... I hope in an other perfect day. Hello Toma!
Phew! the snow disappeared here too when the temperature hit 40.5 degrees C last week.
  • rodw
  • rodw's Avatar
01 Feb 2025 07:26
The dumification of humanity through internet
I have no idea how us Aussies should spell it after that!
Edit: Seems it was Silicon in the 70s when I last encountered the periodic table
I suspect Tommy lives in a pocket of the world who ignored the change in the 1800's
  • rodw
  • rodw's Avatar
01 Feb 2025 07:18
Homing an axis moves away from home switch!
Category: StepConf Wizard
It works now!
Is there some sort of step-by-step beginner's guide or something?
for I = 1 to 10
  read homing configutation docs
  have a play
endif
You might get after 8 iterations :)
  • rodw
  • rodw's Avatar
01 Feb 2025 07:13
Replied by rodw on topic Brilliant Bambu Lab
Brilliant Bambu Lab
There are some 3rd party replacement consoles for Bambu labs that might revert it to open source. While since I looked
  • rodw
  • rodw's Avatar
01 Feb 2025 07:00
Replied by rodw on topic Fusion 360 Win 10 EOL
Category: CAD CAM
Used to do that on a weekly basis when I was installing playground equipment, the supplier would ship all the stuff up not powder coated and we'd spend time packing it all and shipping it off to the powder coaters then doing all the nutserts. Man there was a lot of double handling.
That sounds familiar. I add a  fold in there too. Then package into a kit and label the bag. They look alright when done. This one was fully outsourced and they painted after nutserting but they look so much nicer if the nutsert goes in later.
  • rodw
  • rodw's Avatar
01 Feb 2025 06:49
Category: EtherCAT
I suspect the issue is that the Ethercat libraries are not supported on the 6.12 kernel
If you:
1. Only post once, not three times
2. show the output of the error, we might be able to help further.
  • rodw
  • rodw's Avatar
01 Feb 2025 06:44
Replied by rodw on topic RPi5 Test images
RPi5 Test images
 Only reason I wanted to try this image is since I'm not able to install ethercat on the latest one...
I would have thought cornholio would have included the ethercat repos. But you could use the provided script in a sticky in the Ethercat section that should work
  • Martin.L
  • Martin.L
01 Feb 2025 06:21
Replied by Martin.L on topic StepperOnline A6 Servo
Category: EtherCAT
Hey guys, I'm on the same boat, have you try the autotune software? I really don't get how it works, i can just start the inertia auto tuning and obtain the inertia number. How it's working for you?
01 Feb 2025 06:21
Replied by Cant do this anymore bye all on topic RPi5 Test images
RPi5 Test images
I give up.
Displaying 18616 - 18630 out of 21684 results.
Time to create page: 0.432 seconds
