  • PCW
  • PCW's Avatar
14 Jan 2025 17:02
Error problem hm2 7i96s 7i77 analogout scalemax not found ?
Category: HAL
Note, you can get a better idea of sserial channel --> 7I77 assignments with:
mesaflash --device 7i96s --addr 10.10.10.10 --dbname3 7i77 --readhmid
  • langdons
  • langdons's Avatar
14 Jan 2025 17:01
Replied by langdons on topic Homing an axis moves away from home switch!
Category: StepConf Wizard
I have a separate home switch for each axis.
Each home switch has its own wire leading to the beakout board.
Each home switch is also the minumum limit switch.
I also have maximum limit switches that are all wired in parallel.
  • programador
  • programador's Avatar
14 Jan 2025 17:00
Category: HAL
This error appeared when I took the data generated by PNCConf to try to include part of it in the programming code of the machine that I am already developing. But while I was waiting for your answer, I had the idea of ​​creating a new file through the basic PNCConf and gradually including the code of the machine under development. In this code, it is accepting the "analogout scalemax". I will leave it attached in case anyone needs a basic initial code for 7i96s with 7i77. I will try this method. Thank you for your attention, Mr. PCW.
File Name: Z3.hal
File Size:8 KB
File Name: Z3.ini
File Size:3 KB
  • PCW
  • PCW's Avatar
14 Jan 2025 16:58
Category: HAL
Look, like you have the channel number wrong for the analog 7I77 section
(its channel 1 not 0)
  • PCW
  • PCW's Avatar
14 Jan 2025 16:53
Replied by PCW on topic 7I96S With RS485 Servo Drivers
Category: Driver Boards
Yes, you need the appropriate D connector for CN1
  • programador
14 Jan 2025 16:44
Category: HAL
Yes, the 7i96s board has been updated, attached readhmid and bin files.
File Name: 7i96s_7i77d.rar
File Size:295 KB
File Name: 7i96s.txt
File Size:8 KB
14 Jan 2025 16:30
Replied by Cant do this anymore bye all on topic Linuxcnc 2.9.2 and 2.93 images for Raspberry Pi 4b & 5
Category: Installing LinuxCNC
Goto the linuxcnc home page.
  • mindstormmaster1
  • mindstormmaster1
14 Jan 2025 16:26
Replied by mindstormmaster1 on topic 7I96S With RS485 Servo Drivers
So I just need a DB breakout cord and then I can wire it like that and the driver will automatically take care of everything else like making sure it made it to the correct position automatically?
  • Ehsan_R
  • Ehsan_R
14 Jan 2025 16:25
How to call a python script in gcode was created by Ehsan_R
I want to create a python script that generates 12 non-repeating random numbers every time the gcode file is run and then stores these numbers in variables that can be used in the rest of the gcode.
It is also necessary to save the values ​​of these variables in a file and to be able to see them in the graphical interface to avoid creating a string of duplicate numbers.
  • PCW
  • PCW's Avatar
14 Jan 2025 16:13
For step/dir mode it's just:
Step+  --> Pulse+
Step-   --> Pulse-
Dir+   --> Sign+
Dir-     --> Sign-
  • mindstormmaster1
  • mindstormmaster1
14 Jan 2025 16:03
7I96S With RS485 Servo Drivers was created by mindstormmaster1
Hey! I'm working to convert my mill from Mach3 and open loop steppers to LinuxCNC and AC Servo motors.
I would like to use the Mesa 7I96S card along with these motors and drivers.
www.omc-stepperonline.com/a6-series-1000...67-a6-rs1000h2a1-m17
From the Mesa manual, it looks like it should be possible to use these stepper drivers, but I wonder if someone could confirm that they will work together. There doesn't seem to be a ton of information about wiring the 7I96S. I mostly see examples where Step +/- and Dir +/- are used. However, that does not seem to be as common with modern servo motor drivers. Would a different card be easier to find documentation for?
  • Aciera
  • Aciera's Avatar
14 Jan 2025 15:55 - 14 Jan 2025 16:05
Replied by Aciera on topic LCNC 2.10 - Ask for AUTOMATIC_G43
Category: Gmoccapy
Not every user used to the old behavior that switches to 2.10 is going to use the update script. The point is that EVERY user that starts Gmoccapy the first time in 2.10 gets the notice.
The popup needs a checkbox with "do not show again" and after clicking the message ist gone for ever.
Sounds good to me. The state of whether to show the message or not would be stored in the .pref file I suppose.
However I don't have the time to figure out the popup with the checkbox right now so if somebody knows how to do that then please go ahead.
thanks
  • zz912
  • zz912's Avatar
14 Jan 2025 15:42
Replied by zz912 on topic LCNC 2.10 - Ask for AUTOMATIC_G43
Category: Gmoccapy
Does this update script exist? What does it do and how does it work?
  • PopBang
  • PopBang
14 Jan 2025 15:39
Where do I find a current link to download the 2.9.3 image for Pi 5?
  • PCW
  • PCW's Avatar
14 Jan 2025 15:19
Category: HAL
Has the 7I96S been programmed with 7i96s_7i77d.bin firmware?
Displaying 19861 - 19875 out of 21712 results.
Time to create page: 0.341 seconds
