  • Becksvill
  • Becksvill
08 Aug 2026 05:15
Replied by Becksvill on topic Conversational CAD CAM
Category: O Codes (subroutines) and NGCGUI
Hey Tuxcnc
just wanted to message back here and explain some of the reasons for the tool wear remap t0101 etc
On almost all commerical cnc controllers (fagor fanuc mazak misubishi semiens heidenhain (also Pathpilot which is sort of a commerical version of linuxcnc)  you can change a offset to account for the tool wearing or machining cutting slightly the wrong size over time or part to part.  usually you have a option where you can just change the value by 0.05 or something and it changes the size the machine cuts a bit.  if you only use T1 m6 g43 then you have to adjust the actual tool geometry offset.  which if you have boring bars and also turning tools can be like 300mm different.  if you muck up your maths here or make a typo.  i been there and done it then the next time you run the machine it crashes.  and then also if you have a unskilled operator on the machine it's even worse.  anyway all these issues are good reasons to have some way to make only small changes to the tool size.  the T0101 remap is not the best way i could be quite happy with just t1m6 also if there is a good way to include wear offsets but i haven't seen one so i use the remap that chris morley made years ago.  I have a production lathe that would have made 50,000 parts now and wear offsets are essential in my opinion.
I can probably change the cycles to output only T1m6g43 once i am finished if you want it.  though your solution you showed seems to work.
cheers becksvill
  • hitchhiker
  • hitchhiker
08 Aug 2026 02:47
Replied by hitchhiker on topic PUMA 200 Robotarm and some Hal/INI issues
Ah i think i understand what you mean.
The model stays in a different position as the seted dh paramters ? Because i rotate the hand axis ( all 3) and the main tower.
Dh parameters= real positon/ angles
Vismach model = not build by dh paramters.
Or what do you mean?
The dh parameters i set are the parameters i get from right hand ruled cs. Possible i do it wrong. Because .. if i home over my sharpie marks the arm is in this position:
Joint 1 0 ( about 140 +- to the mechanical limits)
Joint 2 0 (90 deg to tower.. means parallel to base)
Joint 3 0 ( 90 deg to joint 2... means parallel to tower)
Joint 4 0 ( mid position +- 320)
Joint 5 0 ( mid position +-125)up and down same direction as joint 2 and 3
Joint 6 0 (mid position +- 280) left right same as joint 4
The values of A and D i get from the drawing
The Alphas i get from right hand rule cs.. and the signs for the A and D values i get with the alpha stuff.
And the angles after homing i checked with a digital pritractor... and the scales i checked with 90 deg moves looking to the digital protractor.
  • automata
  • automata
08 Aug 2026 00:37
Replied by automata on topic LinuxCNC S-Curve Accelerations
Hi grandixximo,
We really appreciate your dedication to solve the jerk limiting trajectory planner issue.
Can you share the update on any git repo to get wider community feedback started?
Looking for to testing the new fixes.
-automata
  • viewsat
  • viewsat
07 Aug 2026 20:49
Because I'm busy with work, I'll do testing when I have time.
  • MaHa
  • MaHa
07 Aug 2026 17:50
Replied by MaHa on topic Ver 10 NEW install
Ver 10 NEW install
I was able to reproduce this in a virtualbox test-installation. After entering a wrong name/passw  i was locked out. This solution gave me access again. And after that procedure, even entering the password wrong once, did'nt lock me out. Just enter correct password and login.
after this popup
Press the e key to open the boot parameter editor
Warning: Spoiler!
  • snowgoer540
  • snowgoer540's Avatar
  • 5280
  • 5280
07 Aug 2026 14:59
Replied by 5280 on topic Ver 10 NEW install
Ver 10 NEW install
Good thought but its a laptop an older Dell no video card other than built in Video
don't know if it matters but password login error screen says... "your password is incorrect try again" cancel / log in boxes ...... nothing else and the same thing over and over when entering the password. I was super careful in the setup of these areas during setup
Tks
  • MarkoPolo
  • MarkoPolo
07 Aug 2026 13:46
Replied by MarkoPolo on topic Error in tool_offsetview.py
Category: Qtvcp
Hi Cmorley
I've tested it some more, and I don't need to touch "def external_offset_state_changed(self, data):"; it works fine without any changes. I don't know why I had the problem before, but the stop button is still a problem.
To stop the spindle, I have to press stop a second time.
  • tuxcnc
  • tuxcnc
07 Aug 2026 12:34
Replied by tuxcnc on topic Ver 10 NEW install
Ver 10 NEW install
cant get past name and password screen yet.
If you see GRUB but after only blank screen, this may be graphic card issue. In this case try apply nomodeset kernel parameter at grub screen (there are many tutorials on internet).
  • 5280
  • 5280
07 Aug 2026 12:09
Ver 10 NEW install
Thanks 4 the info
but I have not been able to get to the terminal yet
have done 4-5 fresh install of the OS. they all hang up at the same place name and password screen
  • hitchhiker
  • hitchhiker
07 Aug 2026 12:01
Yes i use free ai to generate the single moduls of the vismach model. Then i bring all together. Thats why the model is in 90 angles..
Do you find wrong stuff in the ini or hal???
  • MaHa
  • MaHa
07 Aug 2026 11:52
Ver 10 NEW install
For autologin you can do this, just after completing installation:
For auto login to Debian open a terminal:
sudo nano /etc/lightdm/lightdm.conf
Uncomment the following and add your user name, be sure to scroll far enough down to get past the comments sections.:
autologin-user=yourusername
autologin-user-timeout=0
  • 5280
  • 5280
07 Aug 2026 11:29
Ver 10 NEW install
Good Day: Adam
"I don't Like it" I just want it to work as prescribed which it does not seem to do when I can not even get past the login screen when i entered the password and user name in the OS install. oh ya I am a old man as U say and still building computers and doing installs from scratch.
have a good day
  • 5280
  • 5280
07 Aug 2026 11:14
Ver 10 NEW install
Cool
Displaying 2041 - 2055 out of 11357 results.
Time to create page: 1.703 seconds
