03 Jan 2025 11:05
Estop all the axes that scroll at low speed, a few hundredths per second
Drive enable MUST be controlled by LinuxCNC.
Since you gave no info on what hardware, there is nothing more to help.
  • my1987toyota
  • my1987toyota's Avatar
03 Jan 2025 11:00
Replied by my1987toyota on topic Some 3D printing advice to start this section
Category: Additive Manufacturing
tommylight  have you built a Voron Trident? I am curious on how the Trident and the 2.4 compare as far as performance.
  • Guytou
  • Guytou
03 Jan 2025 10:41
encoder to change PWM value to VFD was created by Guytou
I have a VFD which speed is controlled by a PWM signal (converted to 0-10Vdc).
PWM generated by a RPI4 on which Linuxcnc is installed (QTDragon)
Now I am willing to use an encoder, such as a KY-040 or EC11 to change the PWM value and so to adjust manually the speed of the VFD.
Has anyone experience with this? How should I modify my HAL file?
Thanks for your inputs.
  • Edi_48
  • Edi_48
03 Jan 2025 10:39
Netzwerk abbruch was created by Edi_48
Netzwerk abbruch
Category: Installing LinuxCNC
Hallo
ich musste meinen Rechner neu installieren
Softwre : Debian 12, Linuxcnc 2.9.3  und ProbeBasic 4.0
Hardware NiPoGi Mini PC Ιntel Alder Lake-N100(bis zu 3.4GHz) AK1PLUS Mini Computer 16GB DDR4/512GB M.2 SSD, WiFi 2.4G/5G,BT4.2, Desktop PC 4K UHD Dual Display/LAN/VESA
Ethnet Rialtek, Mesa 7i76e
Mein Proplem ich starte Linuxcnc  und mache einen Ping 10.10.10.10 bekomme eine verbindung.
Starte ich eine Maschine bekomme ich eine Meldung das kein Netzwerk habe , Ping keine antword.
Wenn ich Netzwerk neu starte habe ich wieder einen Ping.
Was kann Ich tun ?
mfg
Hilton
  • Odiug
  • Odiug
03 Jan 2025 10:37
QtDragon PROBE: understanding popup error message
Category: Qtvcp
I am using QtDragon and wanted to probe a hole. I started the inside hole probe with the probe tip roughly centered above the hole. I got the following popup:
My PROBE settings were:
My questions are: What is "Max travel" referring to? Is that "XY" or "XY TRAVEL" or something else? And where do I find "xy_clearance"?
Where was the source for this PROBE panel located? Maybe, I'll figure it out myself.
Kind regards,
Guido
03 Jan 2025 09:09
Replied by Cant do this anymore bye all on topic LinuxCNC on Raspberry Pi 5
Tom, if you had of set out your goals from the beginning, without having to play 20 questions, you would have had an answer in far far less time.
[rant]
This is what makes me somewhat miffed on the forum, getting information out of people to provide a concise answer is like pulling teeth. It's like everything is a state secret. Have people forgotten the art of asking a question ?
[/rant]
03 Jan 2025 09:01
Replied by Cant do this anymore bye all on topic Arduino IO Expansion
Category: Show Your Stuff
I guess SPI would tie you to an arm platform or trying to bit bang from the host PC.
SPI is not recommended for long distance runs (its only really meant to board comms), even 6 or so inches can be unreliable when approaching MHz speeds. Seen this when experimenting with a Mesa 7c81.
Serial can use differential signals if there is noise, SPI differential signals can play havoc with timing at speeds.
And in reality unless you have a real hardware serial port, the serial comms is USB (at the host PC), doesn't run in realtime......in fact there is no realtime serial driver for Linuxcnc.
  • Ginou
  • Ginou
03 Jan 2025 08:43
Hello everyone. Happy New Year 2025.I was able to get by with pncconfig I have my two XY axes that work super well, I have the Z axis with a little bounce and above all I have the Y axis that scrolls after its movement the X and Z axes are fixed and precise. I have especially after the Estop all the axes that scroll at low speed, a few hundredths per second, I noticed that I had connected 28 V to my 7i77 card instead of 24 V would it not be a little too much for the card my power supply is closer to 400 V than 380 hence this small extra value.Could you help me to finalize my final setting. Thank you for your help. Eugene
  • Ehsan_R
  • Ehsan_R
03 Jan 2025 08:36
Replied by Ehsan_R on topic Arduino IO Expansion
hello
Thanks for your good work
I had a question
Why don't you use spi communication instead of using serial communication?
In my opinion, more reliable performance can be expected using spi connection
  • AnkerFly
  • AnkerFly
03 Jan 2025 07:44 - 03 Jan 2025 07:45
Probe basiс and Cyrillic characters was created by AnkerFly
Category: QtPyVCP
The program cannot work correctly with Cyrillic characters in the text program.
I am attaching a file with Russian characters. I'm asking for help. How can I make probebasic understand Cyrillic?
  • RV3Dtech
  • RV3Dtech
03 Jan 2025 07:30
qtDragon LED Probe und Spindeldrehzahl anzeigen
Category: Deutsch
Danke für den Hinweis.
Hab ich leider so aus der Standard Anleitung nicht verstanden.
  • phillc54
  • phillc54's Avatar
03 Jan 2025 06:57
Replied by phillc54 on topic Cut Recovery Not Consistently Triggering
Category: Plasmac
It appears to have been caused by this commit  in July which seems to affect the HAL Python module.
It only affects locales that use commas instead of periods in floating point numbers.
A workaround until we get a permanent solution would be to edit src/emc/rs274ngc/interp_internal.hh and change the following:
Line 998 from:
~scoped_locale() { setlocale(category, oldlocale.c_str()); }
to:
 ~scoped_locale() { setlocale(category, oldlocale); }
Line 1000 from:
 std::string oldlocale;
to:
const char *oldlocale;
and then recompile.
  • TomAlborough
  • TomAlborough's Avatar
03 Jan 2025 06:20
Replied by TomAlborough on topic LinuxCNC on Raspberry Pi 5
Hi rodw,
SheetCAM looks like it gets the nod. Many thanks.
It does have you start by scanning the plans on a (big) scanner and into an image file (.JPG, etc.). For that, maybe I can buy time on a scanner. I do own the plans and the scan would only be for my use.
On top of buying time on a cutting machine maybe I can get my boat realized (and keeping me busy) without actually having a CNC machine.
To reiterate my very first post: I have a fair amount of *nix/device driver and kernel experience and if a need comes up let me know how I might help.
Thanks,
Tom
  • stirra
  • stirra
03 Jan 2025 04:19
Replied by stirra on topic Missing link in homing LC10E
Category: EtherCAT
That was "a" problem but not "the" problem. I changed HOME_SEQUENCE to 1 and the behavior remains the same. I commented out all the other HOME_* parameters and still no change. There is still something else I'm missing.
The homecomp.comp file talks about joint._.request-custom-homing as selecting the custom homing process, and the joint.0.request-cia402-homing pin is net'ed to the x-home-request in your cia402_homecomp.comp, but does not get set from Home All, even when HOME_SEQUENCE is positive non-zero.
I tried to attach my files to the last post, but they seem to have vanished.  Here is another attempt.
File Name: cia402_202...2-2.comp
File Size:11 KB
File Name: cia402_202...02-2.hal
File Size:2 KB
File Name: cia402_202...02-2.ini
File Size:4 KB
File Name: cia402_hom...2-2.comp
File Size:16 KB
File Name: ethercat-c...02-2.xml
File Size:2 KB
  • yoshimitsuspeed
  • yoshimitsuspeed
03 Jan 2025 04:09
Questions in trying to get my home built machine dialed in with a 7i76E
Okay so I have the basics working and now I want to get my toolsetter doing what I need.
It is hooked up and in QT dragon I have my positions setup so it will go to the toolsetter location. Then I can do the touch plate op and it hits the sensor and backs off properly.
From what I can tell it sets it based on the workpiece height and or tool sensor height parameters in the offsets tab which is not what I want.
I just ordered an ATC spindle so very soon I will be setting it up with multiple tools in toolholders with saved tool offsets so I can set them when I change a tool and then just have it pull the tools with the saved offsets.
For the moment though my first priority is to be able to put in a cutter, set it's offset with the tool setter, zero z to my part. Then if I break a cutter or want a different tool for the next op to be able to change the tool, set height, and have that offset to the new tool is at the right height for the next op.
Then a secondary goal would be to be able to change tools manually in multi tool setups.
So basically wanting something like Gcode calls next tool, machine goes to XYZ where I manually change the tool, then machine goes and touches off the toolsetter. Then goes back to machining the next op.
Is there a good guide for doing this? I searched a bit and didn't find anything that looked super helpful.
Displaying 20836 - 20850 out of 21737 results.
Time to create page: 0.638 seconds
