  • Moutomation
  • Moutomation
26 Aug 2024 09:17 - 26 Aug 2024 09:27
Replied by Moutomation on topic İnstall glade
İnstall glade
Category: Gmoccapy
 I tried many things but I can't change cia402.0.pos-scale
  • TheRoslyak
  • TheRoslyak's Avatar
26 Aug 2024 08:22
Replied by TheRoslyak on topic Amplifier Fault ECT60 Closed Loop
Category: EtherCAT
Well, and I wrote the XML manually.
  • anfänger
  • anfänger's Avatar
26 Aug 2024 08:17
Replied by anfänger on topic Display setup sheet
Display setup sheet
Category: QtPyVCP
I solve the issue by making a custom tab and adapting the code snippets KCJ wrote four jears ago.
  • TheRoslyak
26 Aug 2024 08:12
Category: EtherCAT
Strange. I have this kind of drive, and I didn't have any problems with it, although I didn't run it for long. Actually, when you buy it, it's initially sold as either closed-loop or open-loop, and the seller asked me about it when I purchased it. Well, I immediately chose the closed-loop one.
  • avive
  • avive
26 Aug 2024 08:09
Replied by avive on topic Problems with Lichuan Ethercat servo drive
Category: EtherCAT
I also have this driver.  What are you using to power it?  I thought it might be my power supply.
220V
  • panming
  • panming
26 Aug 2024 07:51
How to compile the RT kernel of a ARM board?
@royka Thank you for your reply. I have carefully read your answer, tried your plan, and finally decided to give up. Forgive me, this rookie, I really can't solve it.
  • phillc54
  • phillc54's Avatar
26 Aug 2024 07:46
Replied by phillc54 on topic #<holes> = 3 - Unexpected behaviour
Category: Plasmac
Could you open halmeter from a terminal and select the pin plasmac.feed-reduction and then do another video. It should change to 60 as it begins each fillet end return to 0 at the end of each fillet.
  • Moutomation
  • Moutomation
26 Aug 2024 07:44
İnstall glade
Category: Gmoccapy
I made a mistake by adding gtktooglebutton instead of hal_toogle, thank you very much.
  • Aciera
  • Aciera's Avatar
26 Aug 2024 07:20 - 26 Aug 2024 07:21
Replied by Aciera on topic İnstall glade
İnstall glade
Category: Gmoccapy
Not sure what you are doing:
  • CFE
  • CFE
26 Aug 2024 07:16
Replied by CFE on topic #<holes> = 3 - Unexpected behaviour
Category: Plasmac
I have attached a short video made with PEEK which shows the velocity increase at the last leg of the contour. Maybe this gives a bit more insight in the issue we're facing.
Cheers, Peter
  • Moutomation
  • Moutomation
26 Aug 2024 07:13 - 26 Aug 2024 07:42
İnstall glade
Category: Gmoccapy
Normal buttons were created, but I copied these buttons from the 6 button examples. That's probably why it works. I think the reason why the toggle buttons are not visible is that I cannot add it to the configuration line you mentioned.
Secondly, I can change the ramps and limits from the gui, but no matter what I did, I could not change the calibration value.
There's probably something wrong somewhere
example:
testpanel3.hal:
net xvl ini.xmax_accelaration <=  testpanel3.hal_xacc-f it's work
net xmul cia402.0.pos-scale <= testpanel3.hal_xmul-f it's doesn't work
net cia402.0.pos-scale <= testpanel3.hal_xmul-f it's doesn't work
setp cia402.0.pos-scale testpanel3.hal_xmul-f it's doesn't work
sets cia402.0.pos-scale testpanel3.hal_xmul-f it's doesn't work
  • Aciera
  • Aciera's Avatar
26 Aug 2024 07:10
Replied by Aciera on topic durchmesser stimmt nicht
Category: Other User Interfaces
Wenn's immernoch nicht läuft bitte die aktuelle config zippen und posten.
  • Aciera
  • Aciera's Avatar
26 Aug 2024 07:08
Replied by Aciera on topic Is software Estop allowed
Category: HAL
I don't have a problem with raising awareness about safety, there are a few post of mine on this forum where I have suggested safer procedures than what was being used. The statement I do not agree with is this one:
Linuxcnc ‘gate keepers’ should warn users that - software estops are not allowed - for safety sake.
It's enough of a struggle to try and keep the existing code base and its documentation even halfway updated with the volunteers we have. If you would like to add information about safety then I would invite you to add to the wiki:
wiki.linuxcnc.org/cgi-bin/wiki.pl
  • CFE
  • CFE
26 Aug 2024 06:33
Category: Plasmac
Thank you Phil, I will have a deeper look here too.
Displaying 23236 - 23250 out of 24330 results.
Time to create page: 0.705 seconds
