  • scda
  • scda's Avatar
12 Aug 2024 18:47
Mesa7i96s + 7i85 + pktv2 firmware for Huanyang VFD
Category: Driver Boards
Hi PCW. Ok thanks for the reply. This was my backup plan, so I will probably go this route then and leave the modbus stuff for another project.
Cheers,
David
  • swepeter
  • swepeter
12 Aug 2024 18:43 - 12 Aug 2024 18:45
Pi4b and Pi5 users - What should go in a 2.9.3 image
Category: Installing LinuxCNC
how do i use a img.xz.sha256 file?
I believe that is the wrong file
  • Ismacr63
  • Ismacr63
12 Aug 2024 18:37
Y axis configuration was created by Ismacr63
Hi, I've been trying to configure my Y axis on a bf20 type milling machine for a few days now.
I've read a lot on the forum, but I'm not able to configure it the way I'd like.
I understand that the Y axis, when the spindle moves away from me (or the table moves towards me) should be positive. That's what my Y axis does
I have an inductive sensor installed as a switch for both limits and home. When I search for home it goes to the negative side and I want it to go to the positive side.
I've tried HOME_SEARCH_VEL = 10.000000 and it goes to the positive side, but after home it always hits the hard limits when I get close.
Another issue is that I'd like to change the direction I move the table on the Y axis with the keys. When I press the up arrow I'd like the table to move away from me.
  • PCW
  • PCW's Avatar
12 Aug 2024 18:36
I would think it would be simpler to use a 0-->10V analog spindle speed control
Also, I'm not sure if the Mesa MODBUS interface would work with the Huantyang
  • AndyDM01
  • AndyDM01
12 Aug 2024 18:27
I have serious questions about some stuff I didn't find an answer for
Category: EtherCAT
I am just overloaded with other jobs at work right now, didn't even get the one I am retrofitting from mach3 (dead Bob... again!) to linuxcnc to move yet... already working overtime just trying to get the normal repairs done in a normal schedule..
  • AndyDM01
  • AndyDM01
12 Aug 2024 18:21
Category: EtherCAT
this is exactly what i told to my boss about this shite pneumatic cilinder doing the up / down torch BS... thx Rodw for pointing this out . when you can have the chance to upgrade a machine, then you should upgrade the machine all the way
  • Krulli_Fräser
  • Krulli_Fräser
12 Aug 2024 18:18
Replied by Krulli_Fräser on topic 7i97t with 7i84d connection problem
I have 24V on the 5 pins to the left of the orange screw terminal.
  • besriworld
  • besriworld
12 Aug 2024 18:12
Replied by besriworld on topic OLD Lathe conversion to a CNC
Category: Turning
Thanks, what size should the ring be?
  • PCW
  • PCW's Avatar
12 Aug 2024 18:03
Replied by PCW on topic 7i97t with 7i84d connection problem
Looks OK, can you verify that you have +24V
on both VFIELDB pins?
  • Carsten
  • Carsten
12 Aug 2024 18:00
Replied by Carsten on topic Probe Basic in QTDragon
Category: Qtvcp
Hi Chris,
I upgraded to 2.9.3 and would appreciate a hint how to use a custom iu file.
Kind regards
Carsten
  • cncproject2024
  • cncproject2024
12 Aug 2024 17:53
Replied by cncproject2024 on topic Wiring limit switches to MESA 7i96s
I have now solved the issue. Thanks for the help
  • Krulli_Fräser
  • Krulli_Fräser
12 Aug 2024 17:48
I contacted the vendor and they advised me to order a replacement card and send the defective one back for review. They also informed me that all boards were tested before shipping and most defects are user error. Now, I only connected what is shown in the pictures for a quick test and the card was not working from the start.
Can someone confirm if I made any errors connecting it? (Not to prove anything to the vendor but to save me from scrapping another card)
  • RotarySMP
  • RotarySMP's Avatar
12 Aug 2024 17:30
Replied by RotarySMP on topic Fehlmann Picomax 100 Retrofit
Category: Milling Machines
"Its alive"!
  • cncproject2024
  • cncproject2024
12 Aug 2024 17:26
I think I've found the correct pins in pncof. But when I select the pin for home z axis and it hits the limit switch. Instead of continuing the homing routine it shuts off the whole system and says j3 hit limit in home state. Is the whole point of the homing routine not that it hits the liit switch and then continues the homing sequence for the other axis (I'm homing x first btw). Do I need to select it as a different function? I thought the home function would surely be the correct one
  • DrDflo
  • DrDflo's Avatar
12 Aug 2024 17:25
Joint Amplifier Fault on Non-Moving Axis
Category: Basic Configuration
Background: I have a 3-axis benchtop milling machine (PM-833TV) that I converted to CNC. I upgraded to DMM servo motors about 3-years ago and everything has worked like a charm until the hard drive in my HP 8300 died last week. I misplaced my most recent backup HAL and INI files, so I had to modify an older version. They are attached below. I also upgraded from 2.8 to 2.9 after installing the new hard drive. I am using the ProbeBasic GUI.
The problem: Approximately every other manual tool change, when the Z-axis retracts the spindle to its max travel, I receive a "joint 1 amplifier fault." This is odd because the Z-axis is joint 2. Joint 1 is the Y-axis, which is not moving. Further, when the DYN4 servo drivers encounter an error their status LED switches to red and the drives have to be power cycled to clear the error. There is no indication of an error on the physical Y-axis drive when I receive the fault on the LinuxCNC GUI. Simply pressing the power button in the GUI allows me to resume control of the mill (but it cancels my current milling operation). Further, this "joint 1 amplifier fault" does not occur during long milling operations the rely heavily on the Y-axis only during manual tool changes.
Any idea what could be causing this? Please let me know if you require any additional information
Displaying 24016 - 24030 out of 24484 results.
Time to create page: 2.320 seconds
