  • rdtsc
  • rdtsc's Avatar
07 Aug 2024 13:04
Replied by rdtsc on topic Help me setting up My LinuxCNC
Category: Basic Configuration
You must identify how the EStop is exposed by the MPG. There is nothing about EStop in the mpg.hal file above. You may have to consult the MPG manual. It may be exposed as a signal you can add to the mpg.hal file, or it may only be exposed as two or four wires (which you must wire as a hardware-EStop.)
Your .hal file also does not have any entries for EStop. You'll need to use the .hal command 'net' to link it. How the 'net' command works: linuxcnc.org/docs/2.5/html/hal/basic_hal...#_net_a_id_sub_net_a
Once you figure out how your EStop button works, it would be best to find a similar setup: duckduckgo.com/?q=linuxcnc+estop+net
07 Aug 2024 12:50
Replied by tommylight on topic Pc reboot / 5i25(6i25) & 7i77
No beta, might have bugs.
Are you using the same power supply for all those boards?
If yes, change the power supply.
  • Moutomation
  • Moutomation
07 Aug 2024 12:45
Replied by Moutomation on topic gmoccapy pins
gmoccapy pins
Category: Gmoccapy
thaks a lot
  • Sami
  • Sami
07 Aug 2024 12:43
Replied by Sami on topic Pc reboot / 5i25(6i25) & 7i77
Thank you for your quick response!
Prime x370x-pro motherboard has bios version 6042 and we can update it to next week. At the moment we have another (newer) motherboard
to test with. Asrock Phantom Gaming 4 B550M and it have bios version 3.40 [2024/1/23] (latest stable version) and with this setup we still have
reboot issue with Lathe software. Should we go with beta 3.41 (Update AMD AM4 AGESA Combo V2 PI 1.2.0.C)?
  • Aciera
  • Aciera's Avatar
07 Aug 2024 11:42
Replied by Aciera on topic gmoccapy pins
gmoccapy pins
Category: Gmoccapy
File path is defined in this line in the python code of the user component above:
file_path = 'file.txt'
eg change to:
file_path = '/home/<user_name>/<your_path>/<your_file>'
  • Moutomation
  • Moutomation
07 Aug 2024 11:32 - 07 Aug 2024 11:40
gmoccapy pins
Category: Gmoccapy
It's very nice, it works very well, thank you very much.
  • Muftijaja
  • Muftijaja
07 Aug 2024 11:00 - 07 Aug 2024 11:07
Replied by Muftijaja on topic Latency Test OK, dennoch Fehlermeldung
Category: Deutsch
Of course:
hanno@cnc2:~$ ip a
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
    inet 127.0.0.1/8 scope host lo
       valid_lft forever preferred_lft forever
    inet6 ::1/128 scope host noprefixroute
2: enp2s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP group default qlen 1000
    link/ether 00:0a:cd:00:00:56 brd ff:ff:ff:ff:ff:ff
    inet 192.168.178.55/24 brd 192.168.178.255 scope global dynamic noprefixroute enp2s0
       valid_lft 855370sec preferred_lft 855370sec
3: eno1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP group default qlen 1000
    link/ether 00:23:24:5b:b4:ac brd ff:ff:ff:ff:ff:ff
    altname enp0s25
hanno@cnc2:~$
Tonight, I thought by myself - maybe it's a stroke of fate, that just one connection in time  is working correctly. I would never surf the internet while running my router. In real operation, I will need internet just for updates, research, nothing really worth. BUt technically, I think that should work, and in your simulation it ran free of problems. So, I would go on...
Thanks for your time!
Hanno
  • onceloved
  • onceloved's Avatar
07 Aug 2024 10:08
Replied by onceloved on topic EtherCAT i/o board for spindle, estop and mpg
Category: EtherCAT
For x86 computers with parallel ports, you can connect the spindle encoder to the parallel port. I have a pcie to dual parallel port card that can provide 34 io
  • onceloved
07 Aug 2024 10:05
Category: EtherCAT
Orange Pi 5 Plus has better performance than Raspberry Pi 5, but its ecosystem is not as good as Raspberry Pi. Ethercat is easy to install. You can check it out forum.linuxcnc.org/18-computer/48079-can...-to-run-lcnc?start=0
07 Aug 2024 10:01
Update the motherboard BIOS.
5600G has integrated graphic and came out later than 5600X, so most boards will not work properly with it without updating the BIOS.
07 Aug 2024 09:59
Replied by Cant do this anymore bye all on topic LinuxCNC-RIO - RealtimeIO for LinuxCNC based on FPGA (ICE40 / ECP5)
F'ing Awesome.
But I'm an uncouth Aussie.
  • meister
  • meister
07 Aug 2024 09:09 - 07 Aug 2024 09:09
ahh, I just saw that Mecanix has 'riocore' on the case
maybe you should think again about the naming !?!?!
originally it was called LinuxCNC-RIO, where RIO stands for Realtime-Input-Output.
riocore was only the name for the repostitory, as I had initially separated it into core and gui for the rewrite (because of the dependencies), but this is now all in riocore.
Does anyone have a better name?
07 Aug 2024 09:03
Looking good guys.
Set up a forum member yesterday with my Spartan6 hardware and a basic riocore config.
  • jpg
  • jpg
07 Aug 2024 08:54 - 07 Aug 2024 09:09
How to Spindle Orientation using forward-reverse PWM signal using parallel port?
Bonjour voici une configuration valide pour un tour , les spécifications pour Orient se trouvent dans "spindle hal " ( il n'y a pas le carrousel)
le lien pour comprendre est ici:
forum.linuxcnc.org/10-advanced-configura...indle-activation-m19
File Name: sauvorient...2022.zip
File Size:10 KB
  • rodw
  • rodw's Avatar
07 Aug 2024 08:50
Category: EtherCAT
My servo driver uses ethercat and my io uses rv901 fpga card. They both work well together on Orange Pi 5 Plus.
I have a small retrofitted machine with Ethercat drives and a Rtelligent I/O module. I added an encoder on the spindle but nothing to connect it to. Swapping it put for one of these would solve that problem. I'd also like to try an Ethercat VFD on it too.
Displaying 24181 - 24195 out of 24520 results.
Time to create page: 0.498 seconds
