  • manfrel
  • manfrel
29 Jul 2024 12:33
Replied by manfrel on topic Mesa 7i96s + DM556T -> Motors not moving
Category: Driver Boards
DIR0+ would be TB1 pin 5 for example
Sorry for my stupid question, I thought I should check it in the software and didn't find the pin in the list.
Anyway I checked the voltage of the pin, and it does change polarity when moving in opposite directions.
The motors are connected bipolar/parallel. It was kind of a mess to find out which cable is A+,A- and so on (the guy who built the machine prolonged cables with with cables of different colors)
Maybe I made a mistake there, but I checked it several times.
  • smc.collins
  • smc.collins
29 Jul 2024 12:24 - 29 Jul 2024 12:29
Replied by smc.collins on topic Interesting Youtube Video
The issue isn't that Linux has some technical superiority, it's that we have silo's if interest from oublic and private sector actors colluding to control our screens, it exists in Android, Firefox, Windows etc, all the same thing. Even the open source guys with their "no bi ary blobs" and excluding closed source qpps from repos are doing the same thing.
One thing I've observed about software developers, many of them are controlling narcissists. When you think about computer programming from a 10,000ft view, it certainly would look appealing to people with average intelligence who have strong verbal iq and Machiavellian tendency's to picn computer program as a trade because they would be scratch that itch for tyrannical control.
You can see it with open source projects ejecting contributors and community participants anytime they question or speak against the opinions of the core operations group.
It would be nice if their was a way to find those people and box them up so that couldn't harm everyone but they're everywhere in the software engineering landscape engaging in social engineering scheme's.closed or open source doesn't matter.
Recently OS News blasted owner thom howlerda "check spelling" blasted byran lunduke for being a nazi, bryan is jewish. He was being blasted because he disagrees with the leftist narrative being pushed everywhere
  • stustev
  • stustev
29 Jul 2024 12:11
Replied by stustev on topic big 5axis mazak horizontal cnc mill
Category: Show Your Stuff
I have thoughts on that (and other matters) but we are changing the point of this thread. If we are going to go deeper we should do it in another thread? :)
  • Aciera
  • Aciera's Avatar
29 Jul 2024 11:43 - 29 Jul 2024 11:44
Replied by Aciera on topic big 5axis mazak horizontal cnc mill
Sounds like LinuxCNC has some catching up to do if anyone wants to use those features.
The inclusion of switchable kinematics has made it possible:
forum.linuxcnc.org/show-your-stuff/49103...-head?start=0#271334
  • MartynT
  • MartynT
29 Jul 2024 11:33
Inch display on Metric machine? was created by MartynT
Although I read a few discussions related to this sort of question I haven't been able to find a definitive answer to my situation (i.e. not a real problem).
So, my machine is set up as metric and if I draw in a particular Inventor project in inches the g-code generated dictates inches through G20. Everything runs fine and the parts are spot on as you would expect. Now, I don't always want to go to the trouble of making a drawing and code for some simple actions where I just jog the mill over an item. This actually still works kind of OK but the display shows MM and I have to convert the inches I'm working to into metric each time, which is a bit of a PITA.
Is there a simple way I can start LCNC up and get an inch or mm display without having to convert all the machine specs (even if that was possible) in the Pncconf wizard? I also have a .hal file for the jog pendant which should be relatively easy to modify for inch movement.
Excuses if this has been answered before. Any input gratefully received.
Regards,
Martyn
  • stustev
  • stustev
29 Jul 2024 10:57
Heh - I have never used or explored G68.x or G53.x. I probably would have if I was the operator on my machine if my machine did not have LinuxCNC controlling it. When I found OpenCNC (in 1997) and then EMC/EMC2 (~2000) I stopped exploring Fanuc (or any other) controls.
  • geostein8888
  • geostein8888
29 Jul 2024 10:12
Replied by geostein8888 on topic Keyboard gets unresponsive from time to time
Hello,
at the end of the dmesg output i get this in red:
[ 131.300428] DMAR: DRHD: handling fault status reg 2
[ 131.300430] DMAR: [DMA Read NO_PASID] Request device [04:00.0] fault addr 0xfff9f000 [fault reason 0x06] PTE Read access is not set
i could not find something helpful here only things about the GPU (i have a standard intel board no nvidia card on it)
Georg
  • Aciera
  • Aciera's Avatar
29 Jul 2024 10:12 - 29 Jul 2024 10:57
You can rotate the head and then machine away like normal.
Exactly. This is why it's so much easier to demonstrate the value of TWP on machines with tool side rotation.
forum.linuxcnc.org/media/kunena/attachme...5994/TWP_example.gif
  • seyad
  • seyad
29 Jul 2024 09:55
Ethercat build from source - full instructions
Category: EtherCAT
When I have different EtherCAT slave devices, like the MADLN05BE drive or an EtherCAT coupler from a different vendor, I face issues where the EtherCAT slaves are not being recognized. What should I do to resolve this?
  • Becksvill
  • Becksvill
29 Jul 2024 09:49
Replied by Becksvill on topic big 5axis mazak horizontal cnc mill
Aceria
I'm very interested I have seen it used on a Heidenhain machine
Really cool
Anyway I'll get the machine cutting and see how I go
  • avive
  • avive
29 Jul 2024 09:40 - 29 Jul 2024 10:20
Potential All-in-One Single Board Computers
I've studied the Banana Pi BPI-F3, it looks very interesting. But what about LinuxCNC and RISC-V processor support? Will it be possible to run EtherCAT and GPIO out of the box? Or will I have to assemble and compile everything myself?
And what do you think about the Banana Pi BPI-M5 Pro with Rockchip RK3576?
banana-pi.org/en/banana-pi-sbcs/177.html
  • rodw
  • rodw's Avatar
29 Jul 2024 08:11
Help installing samba on Debian 12 Bookworm PREEMPT-RT ISO
Nooo, that page says its part of Debian so nothing to do in the apt foders
Can you try
sudo apt update
sudo apt install samba
Displaying 24841 - 24852 out of 24852 results.
Time to create page: 0.538 seconds
