  • daro
  • daro
23 Apr 2026 18:24
NoHAL - Visual editor for LinuxCNC machine configuration
Category: Configuration Tools
HI,
I wanted to share with you a tool I've built to make my life easier and I think it has reached enough maturity to be used as a real tool.
It is be no means perfect and some of it is not as polished as i wish it was, but I thought it'd be nice to have it reach more people.
The project's name is NoHAL and as the same suggests - it's supposed to make you not write HAL anymore.
https://github.com/b0czek/noHAL/blob/main/docs/public/screenshots/editor.png?raw=true
It does that by visualizing HAL network as node editor - with an added benefit of making repetitive parts of your HAL configuration templatable through sheets.
I've built it around what I work with, so it might not match your workflow perfectly but issues/pull requests are open for suggestions.
There is Mesa configuration utility built-in but I've only defined a limited set of boards - only those I have used.
Here's a link to repo with it:
And here's a guide I've written on how to use it:
b0czek.github.io/noHAL/
Please let me know what do you think of it.
  • JT
  • JT's Avatar
23 Apr 2026 18:15 - 23 Apr 2026 18:18
Replied by JT on topic (Solved) FlexGUI - Multiple spindles?
Category: Flex GUI
Yes, Flex has full manual spindle controls for all 8 spindles. I'm working on updating the documents.
Just to prevent any search engine from finding incorrect information I deleted the posts with the incorrect information.
JT
  • mclien
  • mclien
23 Apr 2026 17:48
Replied by mclien on topic retrofitting a Proxon for coin die milling
Category: Milling Machines
Thanks for all the hints.
And because I hate to abandon discussions out of nowhere, let me just say our family was hit with quite a tragedy and I can't say when there will be time and mental energy to get back to this project.
greetings mclien
  • papagno-source
  • papagno-source
23 Apr 2026 17:20
Replied by papagno-source on topic Ethercat random jitter fix
Category: EtherCAT
I will do one last test with an Advantech Aimb 505 card with an i5-6700 processor. I tested the latency with Trixie and under stress it does not exceed 40 microseconds with a maximum delta of 2. I asked the customer if I could do this test and he will give me the machine available. Also because, now the only solution we are waiting for is a new version of Ethercat that is adapting Grandixximo?
  • meister
  • meister
23 Apr 2026 16:49
A little preview of what’s coming soon.
This will soon allow you to create a board from the flow config,
or at least a template.
  • spumco
  • spumco
23 Apr 2026 16:36 - 23 Apr 2026 16:40
Considering a Full Rewire on a Working Schaublin 125 CNC
Category: Turning
Has that bug been reported to the Devs?
Yes.
github.com/LinuxCNC/linuxcnc/issues/3455#issue-3089348330
There's another spindle synchronization bug, possibly related, that I encountered at the same time last year.  @Aciera found a workaround for it, but I don't know if the two are related.
github.com/LinuxCNC/linuxcnc/issues/3556#issue-3398986003
I don't have the skills to really figure out what's causing the two problems, much less contribute to a fix.
EDIT - I somehow messed up pasting the forum links when I first reported the bug, but one can highlight the link and right-click to open the forum thread.
  • COFHAL
  • COFHAL
23 Apr 2026 16:18
Replied by COFHAL on topic Qtvcp GUI and hal pins
Category: Qtvcp
I've tried using qtdragon hal bridge function in every way possible, but it's not working. According to qtdragon documentation, if I understand correctly, if I define HALBRIDGE = hal_bridge
and also define a macro in the MDI_COMMAND_LIST in de INI file, qtdragon creates other pins that I can access through halbrdge , but these never appear in hal Show. I also understand that these pins related to the created macros can be accessed through external buttons, but unfortunately, there's no documentation on how to do this. In my configuration, I control some functions through external buttons connected to halbridge but for other functions, such as activating a macro, I can't, or I don't know how to, do it with halbridge.
  • Surmetall
  • Surmetall's Avatar
23 Apr 2026 15:02 - 23 Apr 2026 15:05
Replied by Surmetall on topic LinuxCNC and Beckhoff AX5000 servo drives
Category: EtherCAT
Hi endian,thank you again. I made a completely clean test now with only the AX5125 connected on the EtherCAT bus, no other slaves connected.
I used your files from the zip exactly for the AX test. The startup initCmds file is your Antrieb-1-AX5-0-initCmds.xml unchanged. I only pointed my machine config to that file.
Current result is much better now:
the AX5125 reaches OP when it is the only slave on the bus.Current ethercat slaves output is:
0 0:0 OP + AX5125-0000-0216 EtherCAT Drive (SoE, 1 Ch.)
The important dmesg lines are these:
EtherCAT WARNING 0-0: Slave does not support changing the PDO mapping!
Currently mapped PDO entries: 0x0086:00/16 0x002F:00/32. Entries to map: 0x0086:01/16 0x002F:01/32 0x0024:01/32 0x0050:01/16 0x81E4:01/32 0x81E5:01/32EtherCAT WARNING 0-0: Slave does not support changing the PDO mapping!
Currently mapped PDO entries: 0x0087:00/16 0x0033:00/32 0x00BD:00/32. Entries to map: 0x0087:01/16 0x0033:01/32 0x00BD:01/32 0x0054:01/16 0x0028:01/32 0x81CC:01/16 0x81CD:01/16EtherCAT 0: Slave states on main device: OP.My currently active AX slave config is:
slave idx 0
type generic
vid 0x00000002
pid 0x14056012
name Antrieb-1-AX5-0
configPdos trueMDT PDO 0018 entries requested by config:
0086:01 16 bit
002F:01 32 bit
0024:01 32 bit
0050:01 16 bit
81E4:01 32 bit
81E5:01 32 bitAT PDO 0010 entries requested by config:
0087:01 16 bit
0033:01 32 bit
00BD:01 32 bit
0054:01 16 bit
0028:01 32 bit
81CC:01 16 bit
81CD:01 16 bitDC config currently used:
assignActivate 730
sync0Cycle 250000
sync0Shift 0
sync1Cycle 750000
sync1Shift 0
So the situation now seems to be:
before, the drive stayed in PREOP plus ERROR with MBX_SOE.
now, with only the AX and your startup file, it reaches OP.
but the drive reports that its current mapped PDOs are still the smaller set with subindex 00, while the config wants the extended subindex 01 mapping.
My main question is:
is this already the expected next step, meaning I should now reduce the config to the fixed PDO set the drive actually reports as mapped, or is there still a missing startup/configuration step that should switch the AX5125 to the full 01 PDO mapping?
In other words: now that the drive reaches OP, what is the correct next step before I put the other slaves back on the bus?
Thanks a lot for your help.
  • Ul
  • Ul
23 Apr 2026 14:45
Tipps für aktuelle LinuxCNC Hardware gesucht
Category: Deutsch
Ich sehe gerade, dass die Chinesen die Aliexpress Anzeige geändert haben und nun zwei verschiedene Karten in der Beschreibung sind. Keine Ahnung was man bekommt, wenn man die bestellt. Ich meine jedenfalls die hier.
  • Ul
  • Ul
23 Apr 2026 14:35
Category: Deutsch
Dieses Fallback Bitfile ist blinkende LED und alle Pins IO. Du brauchst das gar nicht, sondern nur das Bitfile, das zu deiner Maschine passt.
Die ersten drei Zeilen sind nur zum Testen vom neuen Bitfile, weil es in den flüchtigen Bereich geflasht wird. Falls das Bitfile nicht mit der Karte funktioniert, wird beim trennen und neu verbinden der Stromversorgung das ursprüngliche Bitfile geladen und die Karte ist wieder ansprechbar.
Untere drei Zeilen braucht es, damit es nach dem Trennen der Stromversorgung im Speicher bleibt, aber eben nur wenn das Bitfile mit der Karte funktioniert. Sonst braucht man JTAG.
Deine Karte ist keine 7i98 sondern eine chinesische F7i98. Ist wieder eine andere, zu der ich nichts sagen kann. Mit 7i98 meine ich die hier: de.aliexpress.com/item/1005012092221990.html
Deine kann alles Mögliche sein. Ich vermute, die wird ebenfalls nicht mit originalen Bitfiles von Mesa funktionieren. Jetzt weißt du aber wenigstens wie man es testet, ohne dass gleich alles kaputt ist
Die JTAG Pins bei deiner scheinen anders zu sein, als bei anderen Karten. Keine Ahnung was man da macht. Man kann den IC aber auch direkt flashen (dürfte der zwischen Ethernetbuchse und FPGA IC sein).
Ich empfehle jedenfalls entweder die verlinkte 7i98 zu kaufen, oder die oben gezeigte 7i92, falls 34 Pins ausreichend sind und die 7i98 zu teuer ist.
  • Jimnyx
  • Jimnyx
23 Apr 2026 12:12
Category: Deutsch
Vielen Dank für die schnelle Antwort.
  diese Karte aber Vers. 1.1 habe ich gebrickt und warte jetzt auf eine neue.
Sie schickten mir diesmal die Doku + Bitfile vorab und schickten anschliessend die Meldung: "Sehr geehrter Kunde, Bitte beachten Sie, dass die Bedienungsanleitung und die Bit-Datei, die wir zuvor gesendet haben, alte Versionen sind. Die aktualisierten Dokumente werden in Kürze an Ihre E-Mail-Adresse weitergeleitet.Alibaba Translation"
Habe eine neue Doku bekommen, jetzt allerdings ohne das 7i98_fallback.bit File.
Wenn ich das richtig verstehe muss ich doch sowohl den Fallback-Speicher als auch den "Arbeits"Speicher flashen. 1x mit 7i98_fallback.bit mit den ersten 3 Zeilen Deiner Anleitung.
Die Endungen der 3 Zeilen --fallback bewirken das der Fallback-Speicher geflashed wird .
Dann muss noch der Arbeits-Bereich geflashed werden mit z.B. 7i98_5ABOBX3.bit. Wenn am Ende der Zeilen kein --fallback steht, wird der Arbeitsspeicher geflashed.
Irgendetwas muss ich da doch falsch verstanden haben...
Denn wann werden die Speicherbereiche wirklich geschrieben und nicht nur simuliert ?
Grüße !
  • RotarySMP
  • RotarySMP's Avatar
23 Apr 2026 11:53
Category: Turning
  • spumco
  • spumco
23 Apr 2026 10:39
Replied by spumco on topic (Solved) FlexGUI - Multiple spindles?
Category: Flex GUI
@JT -
Thank you for the update and new pins.  I pulled the latest deb and Flex is recognizing the additional spindle connections I put in my test GUI.
This doesn't affect me directly - I have no GUI spindle controls, just displays - but are there similar multi-spindle control pins?  I didn't see any update in the docs about those changing.
  • jetbadger
  • jetbadger
23 Apr 2026 09:17 - 23 Apr 2026 09:18
Replied by jetbadger on topic Lathe C axis homing
Lathe C axis homing
A little update as I've found the issue. It was the spindle-at-speed signal. Connected to encoder feedback it would go off in axis mode and I assume it's Gmoccapy behavior that it halts all motion if that signal is false.
Still took me embarrasingly long to figure that out.
  • papagno-source
  • papagno-source
23 Apr 2026 08:55
Replied by papagno-source on topic Simple G7x Profile editor for Linuxcnc/Axis
Category: AXIS
HI good mornig at all.
The GUI, can running on Debian 10 ?
Displaying 2671 - 2685 out of 13997 results.
Time to create page: 0.774 seconds
