  • spumco
  • spumco
17 Apr 2026 23:23
Replied by spumco on topic MotionMaster Upgrade
I also don't understand from first principles what a reactor does. I think they are inductors to smooth out ripples in the outgoing current from VFD to spindle
If they're upstream of the VFD they're called 'line reactors' and smooth out incoming power ripples.
If they're downstream they're called 'load reactors' and smooth out the power to the motor.  Reduces heating in the motor, especially useful for older motors which aren't rated for VFD use and which are going to be run at speeds lower than nameplate rating.
Grease - you can flush out all the greased components with kerosene, then blow out excess with air, then regrease with whatever flavor you want.  Disconnect each grease circuit and flush each component separately - this will help identify any clogged or broken lines.  When you've cleared all the individual circuits out, flush any manifolds and header lines.
the X-axis is "grinding"
Could be from a number of sources.  Suggest disconnecting the ballscrew nut (or nut mount) from the X-carriage.  This will allow you to move the carriage by hand, as well as rotate the ballscrew in it's bearings, and also the nut on the ballscrew.  Should help you identify the source of crunchiness.
Ball bearings. Should I just put new ones in while I'm at it, or, do they last a lifetime?
Which bearings?  Your machine has quite a few.  Some are cheap, some are not.  Your wallet will determine what you can replace... but if the bearing is easily replaceable and remotely suspect, I'd replace it.  You can usually find NOS name-brand bearings on ebay for decent prices.
  • spumco
  • spumco
17 Apr 2026 23:01
Replied by spumco on topic (Solved) FlexGUI - Multiple spindles?
Category: Flex GUI
Spindles are typically controlled through the NML interface by the GUIs, so if the GUI doesn't support multiple spindles you might have to use MDI to turn on and off the auxilliary spindles.
THat said, flexgui is mane to be flexible, so maybe there is suopport?
I haven't used it yet.
Thanks Andy.  I'm trying it out for the first time now.
All machine functions are already handled with hardware controls; I just want displays for all three spindles.  The only on-screen control which could cause machine movement of any type will be an MDI 'run' button.
I'm guessing FlexGUI is new enough that @JT hasn't had anyone bugging him about outlier configurations much.
  • rodw
  • rodw's Avatar
17 Apr 2026 21:32
retrofitting a Proxon for coin die milling
Category: Milling Machines
See if you can add isolcpus=3 to your kernel boot file. I have done it on a pi but can't remember how
It should improve latency.
  • fer662
  • fer662
17 Apr 2026 21:14 - 17 Apr 2026 21:15
Sanitycheck my plan: ethercat + stepperonline A6
Category: EtherCAT
I hit buy on the servos this morning! My order was at the weight limit so i couldn't even add couplings to it and i'll have to place another for the extras, but i can use the us store for that and reship as well. Regarding the cables, of which i need at least 2 longer ones than they come with the motors, i'm guessing i can't chain them and i just have to replace with the longer version, right? Also, is the one for the servo with the break completely different?
  • 0x2102
  • 0x2102's Avatar
17 Apr 2026 20:43
Replied by 0x2102 on topic spindle-at-speed
spindle-at-speed
Category: Deutsch
Der VFD scheint in P02.10 nur eine feste Frequenz zu unterstuertzen. Damit koenne man wohl pruefen ob er z.B. eine Mindestdrehzahl hat. Z.B. 100Hz oder 6000UpM. Aber er kann wohl nicht vergleichen, ob die Vorgabe durch Spannung erreicht ist und dann erst schalten.
Wenn du ganz viel Langeweile hast, kannst du dir auch die ModBus Implementierung anschauen:
github.com/xsnoopy/LinuxCNC-Yalang-yl620...d?tab=readme-ov-file
Der RS485 Anschluss scheint stoeranfaellig zu sein. Ich wuerde das maximal zur Rueckmeldung der Drehzahl nutzen, nicht aber um die Spindel an und auszuschalten.
Falls du ModBus mal testen willst, nimm bitte einen USB / Serial zu RS485 Adapter mit A/B und GND (Masse). 120Ohm Widerstand am Ende der Verbindung nicht vergessen.
  • andypugh
  • andypugh's Avatar
17 Apr 2026 20:36
  • andypugh
  • andypugh's Avatar
17 Apr 2026 20:32
Considering a Full Rewire on a Working Schaublin 125 CNC
Category: Turning
The trick to freeze the VFD PID when not on the limits might be to set maxerror to a very small number (actually = 0 means "no limit") using a mux component.
  • andypugh
  • andypugh's Avatar
17 Apr 2026 20:27
Category: Turning
If I was trying to retrofit the Schaublin I think I would take an approach like this:
1) Use one PID to operate the variator, Use this as the main speed control.
2) Use a second PID to control the VFD, but have this set up to default to 50 (or 60) Hz when disabled. The pid component appears to set the output to zero when disabled, so you might have to use sum2 to add on 50Hz / 3000rpm / whatever to the output.
Then the idea would be to use the variator for speeds inside it's operable range, but then enable the VFD PID to extend that range when the variator is on the end-stops.
Incidentally, the PID gains are full HAL pins. The "lincurve" compoinent was written to allow for dynamic gains to be fed into the PID, if you did need to tune differently for different gears.
  • andypugh
  • andypugh's Avatar
17 Apr 2026 20:09
Replied by andypugh on topic retrofitting a Proxon for coin die milling
Pi5 might work better. But given that you have a 7i96 the Pi4 should work fine with the latency shown. (Just don't watch YouTube while milling)
17 Apr 2026 19:44
  • andypugh
  • andypugh's Avatar
17 Apr 2026 19:42
Replied by andypugh on topic lcnc-suite — web UI for LinuxCNC
Category: Other User Interfaces
Looks impressive.
  • andypugh
  • andypugh's Avatar
17 Apr 2026 19:27
Replied by andypugh on topic (Solved) FlexGUI - Multiple spindles?
Category: Flex GUI
  • mclien
  • mclien
17 Apr 2026 19:23
Replied by mclien on topic retrofitting a Proxon for coin die milling
Here are the 2 screenshots of the Pi. One whithout anything but the Desktop running, one with glxgears running (window resized to about the double).
  • andypugh
  • andypugh's Avatar
17 Apr 2026 19:06
Replied by andypugh on topic REMAP: gang lathe tool orientation
You might have problems with tool radius compensation if you use the orientation, but only if you are doing compensation in the control rather than in the CAM.
So, basically, as a purely graphical fix, it will probably work.
You will need to have different orientations in the CAM tool table and the control tool table, but there is no auto-synching anyway, so that's not a problem.
  • Sandro
  • Sandro
17 Apr 2026 19:01
lcnc-suite — web UI for LinuxCNC was created by Sandro
Hello everyone
I've been working on a web UI for LinuxCNC for my own use and thought I'd share it in case anyone finds it useful. Note that I'm not a professional programmer and this was largely AI-assisted, so take it for what it is.
Greetings
github.com/bildobodo/lcnc-suite.git
Displaying 2881 - 2895 out of 13998 results.
Time to create page: 0.323 seconds
