  • --Matt--
  • --Matt--
06 Apr 2026 22:42
Replied by --Matt-- on topic Surfacemap Z compensation with Probe Basic
Category: QtPyVCP
I'd given up on this for a while and only just noticed the replies here, thanks!
After updating linuxcnc and probe basic I was then able to get the user tab working very quickly. I should be able to have a go at some PCBs now.
Thanks all for your help.
  • PCW
  • PCW's Avatar
06 Apr 2026 21:55 - 06 Apr 2026 22:05
Spindle encoder configuration (with G76 threading command and Mesa 7i96s)
Category: HAL
is spindle.0.at-speed  true?
Also does the index work?
Test by (either in halshow or with halcmd -kf)
sets spindle-index-enable true
watch  spindle-index-enable in halshow
it should go high with the sets command and then low when you rotate
the spindle past the index position.
  • slowpoke
  • slowpoke
06 Apr 2026 21:38 - 06 Apr 2026 21:40
Category: HAL
I made a new configuration using pncconf and compared the spindle & encoder 0 section.
I don't see anything that's different, other than naming conventions (see attached)
I have a quadrature spindle encoder connected encoder (0) input. A & B
I now also have a 1PPR signal, connected to the encoder.0. index pin.
In Halshow
- spindle.0.revs counts up as expected when the spindle is rotated forward
- spindle.0.speed-in appears correct
- spindle.0.index-enable shows disabled
In my SM-10.hal file I have:
net spindle-index-enable <=> spindle.0.index-enable
IF I comment out this line, I can then enable spindle.0.index-enable manually in Halshow, that makes no difference when trying to open the file below (same error)
Regardless when I try to open the following 2 line G76 program I get the following error: "Chosen spindle(0) not turning in G76"
Program:
G0 X0.45
G76 P0.0625 Z-0.5 I -0.005 J 0.008 K 0.0503
What does the error message actually mean and/or what is Linux missing that it needs?
It has the quadrature encoder signals and it has the index pulse, that I can see toggle as the magnet passes the sensor once per rev,
The revs counter is counting up 1 per rev.
  • jetbadger
  • jetbadger
06 Apr 2026 19:30
Replied by jetbadger on topic Lathe C axis homing
Lathe C axis homing
Oh whichever is easiest for you, I don't have a parting slide and C axis at this moment is all I'm trying to do. I'm immensely grateful anyway :)
  • COFHAL
  • COFHAL
06 Apr 2026 19:15
Replied by COFHAL on topic Help with Lichuan drives
Category: EtherCAT
You can try these examples that I have working with some of those ETHERCAT servos
File Name: EC-Axis-C.rar
File Size:45 KB
File Name: EC-position.rar
File Size:20 KB
File Name: EC-position-vel.rar
File Size:21 KB
File Name: EC-Spindle.rar
File Size:44 KB
  • ewlsey
  • ewlsey
06 Apr 2026 17:51
Replied by ewlsey on topic Cubic Interpolator
Cubic Interpolator
OK. I'm having a really hard time understanding the code base. The files don't seem to have any comments explaining what they actually do, what leads to them, or where they lead to.
If the cubic.c is only for non-trivial kinematics, how does the interpolation work for normal cartesian machines?
I was assuming that every servo period it pulls a target position and velocity from the trajectory planner creating 1ms stair steps of constant velocity, but I really can't tell.
  • Dudelbert
  • Dudelbert
06 Apr 2026 17:51
Considering a Full Rewire on a Working Schaublin 125 CNC
Category: Turning
Good to hear that you managed to get your toolchanger working.
I would hope that the PID settings can be constant. I did think that the error term can be scaled.
We know the state of the backgear and the output (spindle encoder). With the analog output, we can have at least a good estimate of the motor RPM. So back-calculating the ratio of the variator should be possible, at least to a degree.
If we scale the error term with the overall transmission ratio and tune the PID at that state, it should give reasonably good behavior over the whole range, wouldn’t it? I am not sure of this. Doing this would give a wonky error at startup (estimating the variator would take a few rotations, I think), but it should be fine before the spindle is fully started up, I think.
But I may have an error in my thinking. Control theory is not my strong suit.
  • andypugh
  • andypugh's Avatar
06 Apr 2026 17:32
Replied by andypugh on topic RRW Lab SPI with raspberry pi 5
Category: Driver Boards
Might be worth asking in the Remora thread.
  • RotarySMP
  • RotarySMP's Avatar
06 Apr 2026 17:27
Category: Turning
I am working on a similar solution, but want to do it as a comp, since I got my comp for the turret working this weekend.
Gear ratio can be inferred from spindle speed / commanded voltage, corrected to frequency, corrected to RPM. (You are a step ahead of me there, with your vfd frequency out put).
I expect we will need a constantly changing set of PID settings, as the inertia varies over the entire speed range.
I always wondered whether the back gear can change gear with the spindle running, but it would be pretty pointless, given the huge 6.5:1 spindle speed change, so I will only trigger it stationary.
Cheers,
Mark
  • andypugh
  • andypugh's Avatar
06 Apr 2026 17:19
Replied by andypugh on topic W axis machine config
And you see the pin iocontrol.0.emc-enable-in toggling high?
Maybe something odd with the amp-fault pin for the W-axis?
joint.N.amp-fault-in
  • RotarySMP
06 Apr 2026 17:15
Replied by RotarySMP on topic Can't find M1 - optional stop switch
Category: Gmoccapy
Yeah, I would also happily sacrifice full screen for M1.
  • andypugh
  • andypugh's Avatar
06 Apr 2026 17:15
Replied by andypugh on topic xhc-hb04 does not communicate
There have been recent updates to the driver. Which LinuxCNC version are you using?
  • spumco
  • spumco
06 Apr 2026 17:08
Replied by spumco on topic Pico Systems Servo Controller
Category: User Exchange
@Andypugh
If you want me to subsidize the shipping cost as a contribution to the project, just let me know.  Once you get an address to @jschulze and a shipping cost is determined, I can paypal either you or @jschulze directly.
  • PCW
  • PCW's Avatar
06 Apr 2026 17:03
Category: HAL
If you have the index connected to the 7I96S index input, then a standard
pncconf or MesaCT created hal file will have the correct connections.
  • spumco
  • spumco
06 Apr 2026 17:02
Replied by spumco on topic Lathe C axis homing
Lathe C axis homing
From what I gather, logic.s0free should be an AND device, so with personality=0x105? Maybe there are other essential things there? I assume SPIN0-xx  signals are distributed in another file?
Yes, logic.s0free is 0x105
There are probably other essential ingredients missing from that hal file.  Best bet is for me to post my whole config...  You've got two options:
  • I can give you a slightly out-of-date version right this second.  It has all the spindle/c-axis stuff in it, OR
  • Wait until tonight and I'll give you the latest version
    • Includes a switchkins component for my separate parting slide, plus some changes that don't affect C-axis stuff
Keep in mind that either config is quite complicated, and there are still a number of functions/features I haven't finished:
- Collet closer position sensor logic/interlocks for both main and sub-spindles
- GUI view rotation for sub/main spindle work
- Other stuff yet to be discovered
Your pick.
Displaying 3286 - 3300 out of 14000 results.
Time to create page: 0.244 seconds
