  • PCW
  • PCW's Avatar
30 Mar 2026 17:24
Replied by PCW on topic Bitfile for rcservo - MESA 7i95t
Category: Driver Boards
I could add 2 RCPWMs to replace one Step/dir channel
Not sure what you mean about the sserial channel on P1
The 7I95T typically has 2 sserial channels on TB4
  • djdelorie
  • djdelorie
30 Mar 2026 16:56
Replied by djdelorie on topic new probe
new probe
I recently got a new probe, and discovered that if I wired it *correctly* it did not work.  I had to wire it backwards, because the small current used to make the light go on when it "hit" was also enough to drive the 7i76E pin, so the probe was always "not hit".  So even if you follow the directions, sometimes it takes more debugging :-P
Always check the voltage at the pin!
  • Lcvette
  • Lcvette's Avatar
30 Mar 2026 16:39
30 Second timeout before opening and E-Stop button not clicking...
Category: QtPyVCP
if the sim opens and works (ie.. press estop, press power, press ref all and it works) its not an installation issue. the problem would be pointing to your machine (milling machine) configuration problem, maybe post your configuration to github and share the link here so we can have a look and maybe help get you sorted out. having the configuration on github is nice because you will always have quick access to it for reference or troubleshooting even when not at your machine pc.
  • grossm5000
  • grossm5000
30 Mar 2026 16:29
Replied by grossm5000 on topic Differential encoder hard crashes the PC MESA7i77
Well, I found a pile of old Dell Optiplex machines for cheap. Im just gonna try a new computer.
I really wish i could have found a way to make the Asus A520M work. Looks like a tough board good for machining environments.
Ill keep everyone posted if the new computer(s) work out :/
  • endian
  • endian's Avatar
30 Mar 2026 16:09 - 30 Mar 2026 17:59
Replied by endian on topic LinuxCNC S-Curve Accelerations
Yes Rod .. it is solution but it is creating constant delay between control position -> DFIR -> current position of tool ....
It will not add any delay as it should be applied as the acceleration is calculated or read per servo cycle. Just not sure how you need to use it.
the size of the buffer is configurable.
Any other published moving average solution wanted to use loops which are a source of delay so I devised this..
One of the cleverest algorithms I have ever coded...
I think the best way to apply that... its consulate with Luca or Yang Yang if they are allready not using something like that now...  I'm not that familiar with their code till now ... it toooo way complicated for me
my next observation is - high value of G64 tolerance around 0.1(650us spikes) is spiking more than 0.001(250us spikes)
best setup till now ... most influential spiking thingy is the
OPTIMIZATION_DEPTH... this creates real mess
ARC_BLEND_ENABLE = 1
ARC_BLEND_FALLBACK_ENABLE = 1
ARC_BLEND_OPTIMIZATION_DEPTH = 8
ARC_BLEND_RAMP_FREQ = 64
ARC_BLEND_GAP_CYCLES = 64
TC_QUEUE_SIZE = 200
  • RotarySMP
  • RotarySMP's Avatar
30 Mar 2026 16:09
Replied by RotarySMP on topic Schaublin 125-CNC retrofit.
Category: Turning
Hi Andy,
I got the Schaublin updated to Trixie and 2.9.8.
I really like the update you did to the look and button layout of Lathe macros. Thanks.
I was trying to work out how to address not having any feedback on the turret arriving in position. Because I am a shit programmer, I tried Chat GPT yesterday.
This is the set of requirements I gave:
The AI summary is rather accurate.
After a couple of back and forth, adding requirements, and accepting some AI suggestions, the result is the attached files.
Scary good how fast and efficient this is for a small project with very limited requirements, and how well it documents and explains the code. It would have taken me a few evening to get to this level, and my code would have been a mess of half-arsed work-around to avoid the gaping holes in my programming knowledge.
It failed to compile yesterday, due to some unknown character. I suspect the apple text editor has added some hidden ascii code. The attached files I cut paste into a different text editor. Off to test them now.
Cheers,
Mark
  • RotarySMP
30 Mar 2026 16:03
Category: Turning
Hi Andy,
Cheers,
Mark
  • spumco
  • spumco
30 Mar 2026 15:43
Replied by spumco on topic CSS/G96 for other than X-axis?
@Aciera - thank you.
right after I posted the question I found an explanation from Andy & RodW that (sort-of) cleared up my confusion:
forum.linuxcnc.org/24-hal-components/327...again?start=40#93573
That was an 'Ahh-ha!' moment:  I don't know anything about C (or any other programming language) so that stuff all looks like gibberish to me.
  • mh300
  • mh300
30 Mar 2026 15:29
Replied by mh300 on topic new probe
new probe
I have the same probe, but I haven’t tested it yet. Based on the documentation I read, this probe switches on the negative (–) instead of the positive (+). So this is probably an electrical issue, and you need to change the wiring.
  • Aciera
  • Aciera's Avatar
30 Mar 2026 15:09 - 30 Mar 2026 15:10
Replied by Aciera on topic CSS/G96 for other than X-axis?
For a more comprehensive switchable kinematics example see:
sim/axis/vismach/5axis/table-dual-rotary
which uses:
github.com/LinuxCNC/linuxcnc/blob/master.../xyzab_tdr_kins.comp
You can download a detailed html documentation on how the kinematic component above was derived:
forum.linuxcnc.org/10-advanced-configura...mill?start=80#263694
For an example using four kinematic models see:
github.com/Sigma1912/LinuxCNC_Demo_Confi...egrex_200y_kins.comp
  • Aciera
  • Aciera's Avatar
30 Mar 2026 14:52 - 30 Mar 2026 14:58
Why does X has a 'tran' and V doesn't?
I cannot give you a totally clear answer but that is basically just the way the data structure is setup:
pos->tran.x, pos->tran.y and pos->tran.z are the 'translational' parts of the cartesian axis pose (ie X,Y,Z axes)
The other axes elements are just called pos->a, pos->b, pos->c, pos->u, pos->v and pos->w
Is this the part of the component/programming that changes the position of the joints?:
The lines with 'pos->* = j[*]' are part of the 'Forward' kinematic model (ie the section you have on your last post). This is used to calculate the AXIS position after the respective joint has been homed. In your particular case the axis is set the same as the joint.
The lines with ' j[* = pos->*]' are part of the 'Inverse' kinematic model . This is used to calculate that particular JOINT position according to the requested AXIS position. In your particular case the joint is set the same as the axis.
Note that in your CASE 1 the joints/axes mapping is actually trivial just like 'trivkins' and the only thing you do in CASE 2 it to swap the joints/axes
So each 'CASE n' in the forward model needs to have a matching reciprocal 'CASE n' in the inverse model. In other words, if you run a joint position value through the forward kinematic and you run the resulting axis position value through the inverse model you should get the exact joint position value you started out with. If the models do not match upyou will get unstable results (eg runaway values).
More specifically, when the kinematics switch is made is the above what causes the X and V axes DRO's to switch?
The switch is made using a case structure in the forward and the inverse kinematic:
switch (switchkins_type) {
        case 0:
        case 1:
Each case represents a kinematic model. In millturn.comp we have two but you can have as many as you like.
The 'switchkins_type' value is changed using an analog motion pin which is connected to a dedicated hal pin (see [HAL] section of the millturn sim config):
HALCMD = net :kinstype-select <= motion.analog-out-03 => motion.switchkins-type
  • jefsaro
  • jefsaro's Avatar
30 Mar 2026 14:39
new probe was created by jefsaro
new probe
Bonjour a tous ,
 je viens d'acheter une nouvelle sonde 3d,je l 'ai brancher  a la place de l 'ancienne , mais j 'ai maintenant une erreur , j 'utilise linux 2.8.1, cela fonctionnait tres bien avec l 'ancienne, je pense qu il y a un parametre a changer , mais je ne trouve pas, pouvez vous m 'aider?dans le panneau de configuration de hal , j 'ai le signal.
merci
  • n_ne
  • n_ne
30 Mar 2026 14:14
RRW Lab SPI with raspberry pi 5 was created by n_ne
Hi, I’m new to linuxcnc and I am trying to get the rrw lab board to work. I’m trying to use the SPI sd card firmware with an STM32 Blackpill. The blackpill led is flashing, but there’s no connection. I can’t seem to find anything online about setting up SPI with a pi5. Any help would be appreciated.
Thanks.
  • susan-parker
  • susan-parker
30 Mar 2026 13:25
Category: QtPyVCP
No, sadly not!
I tried various other things too, but nope.
I am going back to do a completely new install from scratch of Linux, etc. which requires a SSD shuffle between computers.
  • andypugh
  • andypugh's Avatar
30 Mar 2026 12:57
Replied by andypugh on topic Schaublin 125-CNC retrofit.
Category: Turning
I think it might be more effective to create a dedicated component, rather than force carousel to fit.
But I think that Carousel will probably just keep the "motor-fwd" bit set high until the carousel is in the correct position, so the trick is to find a way to release the pressure and lower the carousel once the actuating cylinder hits end-of-stroke.
Is there a sensor for that?
The crude way to make this work might be to use motor-fwd to enable a siggen component that sends a suitably-timed series of pulses.
Displaying 3586 - 3600 out of 13970 results.
Time to create page: 0.435 seconds
