  • Spezidrohne
  • Spezidrohne
28 Mar 2026 20:58
Replied by Spezidrohne on topic Ethercat Setup help needed for beginner
Category: EtherCAT
In seriousness though, I find its less about beginner vs expert in CNC stuff, and more about if you are well versed in linux usage. Most of my troubles setting up were because the instructions just assume you know everything about linux already and leave a lot of critical details out.
Exactly. And i dont rallye have any prior knowledge to this in linux.
  • MaHa
  • MaHa
28 Mar 2026 20:34
Replied by MaHa on topic G64 and G20/G21 handling
In axis i get this:
G20 G64 P0.05
G21 G64 P0.05
  • dbtayl
  • dbtayl
28 Mar 2026 19:53 - 28 Mar 2026 19:59
G64 and G20/G21 handling was created by dbtayl
How is G64 P- handled internally with G20/G21? Is the P value just a straight number that's interpreted according to whatever units are currently active? I don't see any mention of units at all in the docs.
FreeCAD is changing up its postprocessors, and I'm trying to figure out if
G20
G64 P0.01
G21
is the same as
G21
G64 P0.01
Thanks!
ETA- Now that I look at it, the order is still the same as the old FreeCAD postprocessors, but I'd still like to know. It seems weird to me to see G64 before either G20/G21 appears, but if it's literally just setting a number that has zero unit awareness, it's not actually a problem.
  • smc.collins
  • smc.collins
28 Mar 2026 19:10
Replied by smc.collins on topic Schaublin 125-CNC retrofit.
Category: Turning
Mark, this is the solution you end up with, you need execution blocking for the tool changer hal component. here is my program, if you need my email address let me know.
  • smc.collins
  • smc.collins
28 Mar 2026 19:08
Replied by smc.collins on topic Toolchanger HAL Component project
Category: HAL Examples
Hey Mark, i kinda parked this because the problem i ran into, no contributors and i have other project going, that said, you just set g28 for parking during transitions and add it to the postprocessor configuration.
I can attach both or have attached the post processor for fusion360 somewhere in the forums under my username, here is my tool changer program from my lathe.
  • spumco
  • spumco
28 Mar 2026 18:41 - 28 Mar 2026 18:45
CSS/G96 for other than X-axis? was created by spumco
I have a part-off slide mounted to my lathe spindle 90 degrees to X-axis.  It's defined as "V" axis as that seemd to match the basic cartesian configuration best; it's not a Y axis as all the tools mounted on X can't move in Y.
I'm working on a custom M-code to run the part-off process.  I'd like to accomplish the following:
  • Program part-off in diameter, just like programming an X-mounted tool in diameter mode
    • In progress, I think I just have to cut the joint movement scale in half, and fiddle with the homing so "V0" is tool tip at center of rotation
  • Program feed per rev (G95)
    • Seems pretty straight-forward
  • Use CSS (G96)
    • How?
Question... can CSS be used on any axis other than X?  i.e. is G96 hard-coded to X?
If I re-define the parting slide a "U" axis instead of "V", will that work since "U" is considered as co-linear with X?
If CSS is hard-coded to X, any ideas how I can accomplish CSS on a non-X axis?
I don't need/want to move the X-axis while the parting slide is moving since the subspindle is mounted to X-axis slide and will (hopefully) be clamped on to the part.  But swapping the X and V (or U) joint/axis before a part-off and then switching back seems... complicated.  And likely to cause lots of following error issues.
I'm all ears if anyone's got suggestions.
  • TAKUYA
  • TAKUYA
28 Mar 2026 18:07
Replied by TAKUYA on topic Ethercat random jitter fix
Category: EtherCAT
I can yea. what bothers me, is that the DRO was "filled" with the encoder position right away previously. Now, it rarely does but most of the time, takes 5-10 seconds to fully fill in with machine positions. If you enable it before that, you get amplifier errors or a loud axis clunk.
I dont know of anything that changed other than weather :D
  • Hakan
  • Hakan
28 Mar 2026 17:47
Replied by Hakan on topic Ethercat random jitter fix
Category: EtherCAT
Can you plot pll-err? Sounds like you have quite a bit of "normal" jitter.
That can be seen in pll-err.
dc-phased is just the condition that pll-err is below 10% of your servo cycle time.
  • grossm5000
  • grossm5000
28 Mar 2026 16:53
Replied by grossm5000 on topic Differential encoder hard crashes the PC MESA7i77
Category: Driver Boards
No, I was just setting up. I have a couple toggle switches working on gpio but that’s it. I was just getting excited I could see it talking through halshow. No servo/spindle drivers yet.
I figured the MPGs should have been the next easiest thing to do
  • dredivan
  • dredivan
28 Mar 2026 16:30
Replied by dredivan on topic Simple G7x Profile editor for Linuxcnc/Axis
Category: AXIS
Hi, great tool — thanks for sharing it!
I ran into two issues with the generated G-code on a standard LinuxCNC setup (not PathPilot), both easy to fix:
**1. D and I parameters are swapped in the G71/G72 line**
The generator outputs:
G71 Q#### D{stock_allow} I{doc} R... F...
But LinuxCNC G71 expects `D` = depth of cut per pass and `I` = finish stock allowance — the opposite of what is currently generated. With the values swapped, the cycle runs with a 0.2 mm DOC and a 2 mm finish allowance instead of the other way around.
**2. X and Z arguments on the G71/G72 line cause the machine to stall**
The generator adds `X{start_x} Z{start_z}` directly on the G71 line:
G71 Q#### X30.000 Z2.000 D... I... R... F...
LinuxCNC does not accept X/Z on the canned cycle line itself — the approach is already handled by the preceding `G0`. With these arguments present the spindle starts but the machine does not move.
**Fix** — patch profiler.py (4 occurrences):
```bash
sed -i 's/X{start_x:.3f} Z{start_z:.3f} D{p.stock_allow:.3f} I{p.doc:.3f}/D{p.doc:.3f} I{p.stock_allow:.3f}/g' profiler.py
After the fix the output looks like:
G0 X30.000 Z2.000
G71 Q#### D0.500 I0.200 R1.000 F100.0
G70 Q#### F50.0
Which runs correctly on LinuxCNC 2.10 with AXIS.
Hope this helps, and thanks again for the project!
  • TAKUYA
  • TAKUYA
28 Mar 2026 16:27
Category: EtherCAT
I did, unfortunately with SyncToRefclock set to false, the dc-phased pin starts flickering.
the reset counter doesnt go up either.
with it set to true, the rest counter goes to 1 or 2 per lcnc launch.
what ive also found, without every driver being ready, the dc-phased pin is already HIGH. Is that supposed to happen?
  • PCW
  • PCW's Avatar
28 Mar 2026 16:13
Was this a fully working system before you added the MPG?
  • grossm5000
  • grossm5000
28 Mar 2026 15:54 - 28 Mar 2026 16:03
moved to a different PCI slot, no change in behavior
moved to enable breakout power (W1, W2 up) no change in behavior
tried lspci -vv, didnt find the board. Sucessfully enabled board with setpci, then lspci confirmed board was not disabled.
...tried mesaflash, and mesaflash still returns no 5i25 board found.
did not mess with W3 on the 6i25
EDIT: i have completely removed the encoders from the 7i77 and later removed the 7i77 from the 6i25 in an effort to at least see if the 6i25 could be found.
I would also like to point out that if I connect the 7i77 i am in fact getting 5v from the 6i25 (if enabled breakout power) ...i probed with a multimeter (on the 7i77) the encoder TB and also probed on TB1. So I would say the 5v power seems to be there...
I am beginning to think i have a problem. I do have an ethernet port. should i consider a 7i97? Or i might be money ahead trying a whole new PC at this point.
  • PCW
  • PCW's Avatar
28 Mar 2026 15:50
The whole encoder thing suggests a  5V power issue.
(short or mis-connection)
The hard crash may only happen when LinuxCNC fully starts meaning the correct firmware is installed
W3 sets the I/O pin 5V tolerance option, it should be left on the defauly "UP" position
  • grossm5000
  • grossm5000
28 Mar 2026 15:23
To be clear, i am not hard crashing anymore after installing a new 6i25 that i got last week. I am not sure what firmware is on either board.
I could try another motherboard...just a ton of work. what does the w3 jumper do on the 6i25?
i may try going back to breakout power enabled on the 6i25. It didnt like the differential encoders when I did that, but at least i was getting things through the 7i77.
Displaying 3616 - 3630 out of 14010 results.
Time to create page: 0.282 seconds
