  • rodw
  • rodw's Avatar
26 Mar 2026 11:58
Leave enabled pin active when leaving linuxcnc
Category: Basic Configuration
you could try a shutdown.hal file that setp's it to what you want. You may have to unlink the pin as well
  • rodw
  • rodw's Avatar
26 Mar 2026 11:56
too long hm2_7i97.0.read.tmax or something else?
Category: Driver Boards
Looking at your first post, its not network related. Note those previous settings do not persist. Running out of ideas. As PCW mentioned ensure the NIC interrupt is pinned to isolated core 5
You mentioned graphics so you probably have an Intel i915 GPU which hangs on my PC. Add these to grub to lock it downi915.enable_dc=0 i915.enable_fbc=0 i915.enable_psr=0
  • mooser
  • mooser
26 Mar 2026 11:29
I've got a SSR in the latching loop of my spindle contactor being controlled by one of the outputs from the 7i76
net machine-is-enabled hm2_5i25.0.7i76.0.0.output-07
Short of re-wiring, is there a way to temporarily leave that output turned ON when linuxcnc is being closed and re-started to pick up new config changes as I mess around inside the HAL and ini files setting up my new VFD and gear selection code? I can't help but think having the 220v power ripped out from the vfd over and over again isn't doing it any good :)
M
  • spumco
  • spumco
26 Mar 2026 10:43
Replied by spumco on topic Toolchanger HAL Component project
Category: HAL Examples
I am not sure what to do about motion to a tool change position. Given the excessive size of my carousel, relative to the lathe envelope, and wide variety of tool geometries, tail stock etc I suspect it is safer to not automatically move to a tool change position. Do you have thoughts on that?
Cheers
Mark
The capstain turret lathes I've seen move to a safe location - generally max X & max Z - before tool changes (Hardinge, Haas CL1) but none of those have tailstocks.
Do you have a tailstock detector in the carriage?  If so, you could make a toolchange macro conditional so you aren't right up against the tailstock, potentially swinging a long drill in to the tailstock snout.
If not, you might think about installing such a detector.
  • m0602232
  • m0602232
26 Mar 2026 10:13
00:1f.6 Ethernet controller: Intel Corporation Ethernet Connection (7) I219-V (rev 10)
DeviceName: Onboard - Ethernet
Subsystem: Lenovo Ethernet Connection (7) I219-V
Flags: bus master, fast devsel, latency 0, IRQ 120
Memory at b1000000 (32-bit, non-prefetchable) [size=128K]
Capabilities: <access denied>
Kernel driver in use: e1000e
Kernel modules: e1000e
eee was already off, not sure about gro, lro or tso but I will try with them disabled also.
  • rodw
  • rodw's Avatar
26 Mar 2026 09:45
thanks, 6 core PC with one isolated = 5 available so that's right. i5 should be fine
What network card? is it Realtek?
I've been researching this today. Here are a few more obscure settings that may help where eno1 is the NOC name from ip a
sudo sysctl -w net.core.busy_read=50
sudo sysctl -w net.core.busy_poll=50
sudo sysctl -w kernel.sched_rt_runtime_us=-1
sudo ethtool --set-eee en01 eee off
sudo ethtool -K eno1 gro off lro off tso off
  • rodw
  • rodw's Avatar
26 Mar 2026 09:30
THC not getting active even when "all seemingly needed" requirements are met
Category: Plasmac
Its an odd looking voltage plot.
I would look at the time after arc ok the THC is activated. To me it looks like it needs to be 2 seconds. I just can't see the setting I'm looking for.
Early activation could be disabled by the big fluctuations in voltage.
  • Aciera
  • Aciera's Avatar
26 Mar 2026 09:17
Replied by Aciera on topic Where is discussion for my new comp
Use the 'Add a comment' box at the end of the 'Conversation' tab in the PR page:
github.com/LinuxCNC/linuxcnc/pull/3877
  • rodw
  • rodw's Avatar
26 Mar 2026 09:11 - 26 Mar 2026 09:12
Replied by rodw on topic Where is discussion for my new comp
The discussion should occur on the PR. its up to the dev team, not forum users so you neet to convince the gatekeepers. Personally 80 files in one commit is too much to clearly understand and debug build errors.  Perhaps the component is in one PR and the sim in another.
  • Plasmanfm
  • Plasmanfm
26 Mar 2026 09:01 - 26 Mar 2026 09:03
  • RotarySMP
  • RotarySMP's Avatar
26 Mar 2026 08:35
Replied by RotarySMP on topic Toolchanger HAL Component project
What aspects of Andy's carousel.comp have you identified as needing improvment, and/or what other features/funtions are you adding with this comp?
Do you have a github repository, or just keeping the current version of code uploaded to the initial post in this thread?
My Schaublin tool changer is extremely simple, with just a single input to open the tool change pneumatic valve, for a fixed duration, and then checking the next feedback pin went high. Cycling through until the target position is reached. I don't need much of the code like tool unlock, tool lock as that is all pneumatically sequenced.
Cheers
Mark
  • m0602232
  • m0602232
26 Mar 2026 08:16
PCW: Thanks for that, I'll consider changing kernel, or maybe trying with another pc.
rodw: processor: Intel(R) Core(TM) i5-8400T CPU @ 1.70GHz, echo $(nproc) prints 5.
  • Hakan
  • Hakan
26 Mar 2026 07:50 - 26 Mar 2026 07:54
Replied by Hakan on topic El5101 Config
El5101 Config
Category: EtherCAT
pos is of course the number of rotations since zeroing on index. This is the main driver for
the synchronized move, the z-axis is being forced to follow pos.
Rotational speed isn't mandatory, but convenient to have.
You use rotational speed for the at-speed pin and is displayed in the gui.
I guess enc-frequency-scale should be set to 1/2000, so 0.0005, for rps.
For rpm 1/(2000*60) = 8.333333e-6.
  • tom3p
  • tom3p
26 Mar 2026 07:42
Hello,
Is the Forum where discussion of new hal comp takes place?
On Github, on my fork there is a Discussion button
On Github in LinuxCNC.linuxcnc there is no button.
Google said the Forum was the main location for discussion.
Where is proper place to discuss?
My case is
  problems with package creation and a new comp.
 My comp builds and runs fine locally,
but a PR fails during package creation.
I hope a new push will fix the packahe creation error.
  • rodw
  • rodw's Avatar
26 Mar 2026 07:27
Replied by rodw on topic El5101 Config
El5101 Config
Category: EtherCAT
I'm not sure on that. pos = position so it implies reading a linear scale when you have a spindle, you want to measure RPM or RPS which a frequency resolves to with appropriate scaling.
Displaying 3736 - 3750 out of 14012 results.
Time to create page: 0.343 seconds
