15 Oct 2026 00:14
Replied by tommylight on topic Barnworks shop update
Category: Show Your Stuff
Picture with the benches, the ceiling looks burnt ?
Great to see your still kicking, hard! :)
15 Oct 2026 00:09
Axis interface and "useful" conversational scripts in python
Category: AXIS
Thank you for this, i remember a long while back the "grill" saved me a lot of time as i needed to do a 2X1 meter grill with nearly 1000 holes.
Did not use them since then, but it is very nice to know they still work, if i ever need them.
14 Oct 2026 23:54
Replied by tommylight on topic Usefull Open Source software, vibe coded in Rust
There seems to be another version out, but much more limited than this.
From what little info i gathered, this works fine, but of course might have issues, like picture rendering might now always be the exact same as in the paid version.
14 Oct 2026 23:52
Replied by tommylight on topic I think the forum needs some TLC
Category: Forum
Last two days it's been much better, thank you SGD.
14 Oct 2026 23:51
Replied by tommylight on topic Lathe Chuck Table
Lathe Chuck Table
Category: QtPyVCP
That is a loooong post, thank you.
14 Oct 2026 23:42
Replied by tommylight on topic Hermle auswahl Mesa Karten
Category: Deutsch
Sind die servos analog oder step/dir ?
Wen geld kein problem ist, nem das von Mesa:
7i96S - 5 step/dir venig IO, spindle mit encoder
7i83 - analog ausgange fuhr analog +-10V servos - nur wen diene servos analog eingang habben
7i85 - 4 encoder eingange und 4 sserial
wen mehr IO braughs
7i70 - 48 eingange uber sserial
7i71 - 48 ausgange uber sserial
oder nur
7i84 - 32 eingange und 16 ausgange
das ist die beste combo fuhr ale moglihkeiten, und kan finden im Deutchland sein beim www.welectron.com
Normaleweise wen finden an, die 7i95T ist ales beim eine platte fuhr step/dir und encoder, und die 7i97T ist AIO fuhr die analog servo und encoder.
14 Oct 2026 23:33
following error: use bus value instead of internal calculation
Category: EtherCAT
Moved to "EtherCAT" section.
From what i read here, EtherCAT has issues with position feedback to the point i was convinced it is useless, but i might be wrong or something might have improved by now.
Since i have no experience with it, i will retreat, for now.
14 Oct 2026 23:30
Replied by tommylight on topic JMC Servo Drive Bricked!
Does the diagnostic software still communicate with the drive?
14 Oct 2026 23:28
Tornos deco 2000/20 ROBOBAR SSF 226 how to progam barfeeder?
Category: CNC Machines
Any luck with this?
And you do not mention if it is running LinuxCNC, from your writing it seems it is not.
14 Oct 2026 23:26
Replied by tommylight on topic general setup question - standard cnc process
Category: Basic Configuration
What exact errors are you getting?
Attach the pictures/logs here so we can have a look.
14 Oct 2026 23:24
Replied by tommylight on topic Z-axis doesn’t move
Z-axis doesn’t move
Category: Flex GUI
Attach the hal and ini files here so we can have a look.
14 Oct 2026 20:08
Replied by tommylight on topic stepper motor does not move
@geebee
Make a new config, start over.
  • bassti
  • bassti
14 Oct 2026 16:55
Replied by bassti on topic Hermle auswahl Mesa Karten
Category: Deutsch
Welche servodrives hast du genau ?
Gruß bassti
Displaying 391 - 405 out of 11392 results.
Time to create page: 0.492 seconds
