25 Feb 2026 23:24
[AUTOMATIC] [XML] [HAL] [INI] [GENERATORS] [ETHERCAT] [LICHUAN]
Category: EtherCAT
Thank you.
Should we make this "sticky"?
We would appreciate feedback on this.
25 Feb 2026 23:21
Replied by tommylight on topic Simple G7x Profile editor for Linuxcnc/Axis
Category: AXIS
Looks nice, thank you.
25 Feb 2026 23:19
Replied by tommylight on topic Ethercat A6 Servo Homing problem
Category: EtherCAT
I want to use torque homing ....
Is that where the motor moves till it hits a hard stop to home?
Sorry i can not help more, but no experience with EtherCAT, yet.
25 Feb 2026 23:17
Replied by tommylight on topic DMM DYN 4 spindle servo tuning tip
Thank you.
If anyone thinks this belongs somewhere else on the forum, please do let us know.
Leaving it here for now.
25 Feb 2026 23:14
Replied by tommylight on topic Maho MH-400 Retofit
Maho MH-400 Retofit
Category: Deutsch
There was a topic with something similar, but i can not find it (google has become useless), it was quite some time ago, but if i bump into it i will report back.
25 Feb 2026 23:12
Replied by tommylight on topic Postprocessor for oscillating tangential knife
Category: Post Processors
Thank you.
I would also like to build one such machine, but i have a pretty long waiting list, building a laser and a router now, want to build a small but sturdy mill, a wire EDC, a bigger styrofoam cutter, a rugbot, a normal tangential knife, ... oh well.
25 Feb 2026 23:06
Replied by tommylight on topic 7i96S Labels
7i96S Labels
Category: Show Your Stuff
Thank you.
BTW, i can not check on this PC as i have no office suite installed.
25 Feb 2026 23:05
Replied by tommylight on topic Jog speed
Jog speed
Category: pyVCP
Did you set the scaling properly?
25 Feb 2026 22:51
Replied by tommylight on topic M codes for a second spindle?
You are welcomed, always, and thank you for reporting back.
25 Feb 2026 22:50
25 Feb 2026 22:49
Replied by tommylight on topic mesambccc init feature question
Category: Driver Boards
Moved to "driver boards"
  • jtrantow
  • jtrantow
25 Feb 2026 21:48
mesambccc init feature question was created by jtrantow
I have my 7i96 working with a CommanderSK VFD over RS485 with hm2_modbus. (See attached)I write two registers using the init section but I haven't figured out the syntax to read registers in this section. Could anyone provide an example of reading registers during init? I'd like to only read the rated rpm, amps, etc once and I need the values in hal.I would also appreciate an example showing how to set the HAL_FLOAT scale factors. (in the .mbccs) I am currently using
setp hm2_modbus.0.vfd.ref-coarse-00.scale 10.0
It seems like this belongs within the .mbccs definition.
  • PCW
  • PCW's Avatar
25 Feb 2026 20:54
hm2_modbus pktuart, probably a firmware request?
The physical PKTUART pins are assigned in the firmware source (the PIN_XXXXX.vhd file that was included in the zip file)
 (If that's what you meant)
  • jtrantow
  • jtrantow
25 Feb 2026 20:08
That should work!
Do you need to assign the pktuart pins when you build the firmware?
If yes, the Mill with 7i92 has open connectors on the 7i85S TB1 TX6, TX7 SRX0, STX0 and all the odd I/O on the 7i75.
The Router with 7i92T supports a spindle, laser, and bunch of pins reserved for plasma.
P1 and P2 are both configured as G540 but P1 is actually connected to 7i75 card.
The pins I have unassigned are P1 gpio.029, .031, and 0.033.
The router is working fine and won't gain any functionality so an update is much lower priority. Really just a wiring cleanup so let's wait before putting new firmware in that.
I will try to get the  7i96d_7i85p_pktv3 installed today, otherwise it may be a week before I get back to it.
Thanks!
  • liutas4x4
  • liutas4x4
25 Feb 2026 19:44
Replied by liutas4x4 on topic M codes for a second spindle?
It is working. Thanks to you and @dm17ry -- it runs easyli.
Displaying 4906 - 4920 out of 14029 results.
Time to create page: 3.403 seconds
