  • cmorley
  • cmorley
25 Feb 2026 19:24 - 04 Mar 2026 00:06
qtDragon: Auto Return to Manual Mode After an MDI Command so MPG works
Category: Qtvcp
If this is a common complaint, I could add this as an checkbox option in master branch.
As far as other wanted/annoying behaviors - feedback welcome.
I won't guarantee you always get what you want but usually can at least help with customizations
Chris
  • HansU
  • HansU's Avatar
25 Feb 2026 19:23
Replied by HansU on topic Sheetcam v8
Sheetcam v8
Category: CAD CAM
I think it's a bit of a shame that they rather create a new version to have a reason to raise the price instead of fixing the bugs in version 7.
  • Mbrand1901
  • Mbrand1901
25 Feb 2026 19:22
Replied by Mbrand1901 on topic Retrofitting Deckel FP4ATC
Category: Milling Machines
Hahahaha thats defenetly the case with 4 m/min.
I will propably leave it as it is.
Originaly it has also 4 m/min.
  • 3404gerber
  • 3404gerber
25 Feb 2026 19:10
Replied by 3404gerber on topic CiA 402 Folder Missing
Category: EtherCAT
I have no experience with CiA homecomp, but if I have a look at the comp source code here , I see that it creates a "joint.%d.request-custom-homing", jno" pin. Could the name be your problem?
Cheers,
Luca
25 Feb 2026 19:02
Replied by tommylight on topic Add Buttons in Probe Basic
Category: QtPyVCP
Attached picture of the latency shows a Preempt-Dynamic kernel, not the required Preempt-RT kernel, so that will not work.
Try installing the RT kernel, if this works:
sudo apt install linux-image-rt
  • RotarySMP
  • RotarySMP's Avatar
25 Feb 2026 18:54
Replied by RotarySMP on topic Retrofitting Deckel FP4ATC
My Maho was originally only 1,5m/min with the Phillips 432. I have it set to rapid at 2,5m/min, and it is fast enough to crash before I react.
  • RotarySMP
25 Feb 2026 18:53
Replied by RotarySMP on topic Schaublin 125-CNC retrofit.
Category: Turning
Yeah, that behaviour threw me.
  • nicklego
  • nicklego's Avatar
25 Feb 2026 18:52
Replied by nicklego on topic Maxnc15CL Motor timing help
Thank you, I will try starting with slow accelerations, max velocities, and longer step timings until I find a safe limit for it. I'm 100% sure there are no electrical issues because when I first got the machine, it came with a standalone controller that could run programs, but I am unable to run the ancient software to load programs onto it. The jogging feature on the standalone controller worked perfectly and was able to move all axes easily
  • Finngineering
  • Finngineering
25 Feb 2026 18:35
Replied by Finngineering on topic Schaublin 125-CNC retrofit.
Category: Turning
That is quite interesting behavior by the VFD. If you have a "single ended" output (say 0...10V -> 0...70Hz), you would think that with the wires reversed, it would go to minimum allowed frequency or just refuse to start.
Anyway, glad you got it working.
  • Mbrand1901
  • Mbrand1901
25 Feb 2026 18:32
Thank you!
I have already tried a bigger LATCH numer but it would just miss the index. Currently I usind 1.
Mabey I just leave it like that.
And what speeds would you recommend to cap the machine? I currently use 4 m/min. Is it recommended to go higher?
  • jtrantow
  • jtrantow
25 Feb 2026 18:29
hm2_modbus pktuart, probably a firmware request?
Category: Driver Boards
That should work!
Do you need to assign the pktuart pins when you build the firmware?
If yes, the Mill with 7i92 has open connectors on the 7i85S TB1 TX6, TX7 SRX0, STX0 and all the odd I/O on the 7i75.
The Router with 7i92T supports a spindle, laser, and bunch of pins reserved for plasma.
P1 and P2 are both configured as G540 but P1 is actually connected to 7i75 card.
The pins I have unassigned are P1 gpio.029, .031, and 0.033.
The router is working fine and won't gain any functionality so an update is much lower priority. Really just a wiring cleanup so let's wait before putting new firmware in that.
I will try to get the  7i96d_7i85p_pktv3  installed today, otherwise it may be a week before I get back to it.
Thanks!
  • RotarySMP
25 Feb 2026 18:01 - 25 Feb 2026 18:09
Category: Turning
Thanks. I fixed it. I think it was a combination of sometimes doing M3 without an Sxx first on start up, then pressing the button (which defaults to S200) and then trying S100 M3 in the MDI.
Turns out I got the Analog 0-10V and GND wires reversed when I rewired the VFD.
The weird thing was with those wire reversed, it would not start the spindle below S175, but would only run the VFD at the max frequency with any S speed above that. So switch on, type M3 nothing, push button (= S200 worked but always at 70 Hz),  then I had been typing S100 M3, and it would not start.
Switched the polarity, and now it is all back to normal.
I'll upload the latest HAL and Ini to the first posts a bit later, as it is good to have a back up here.
  • RotarySMP
25 Feb 2026 17:57 - 25 Feb 2026 17:58
Really a cool milestone to make the first parts. Congratulations.
On my Maho I have:
HOME_SEARCH_VEL = 0
HOME_LATCH_VEL = 10
HOME_FINAL_VEL =15
  • RotarySMP
25 Feb 2026 17:51
Considering a Full Rewire on a Working Schaublin 125 CNC
Category: Turning
Try a HAL with just this header in it... this works on my set of Mesa cards. You will probably need to change the IP address.
loadrt [KINS]KINEMATICS
loadrt hostmot2
loadrt hm2_eth board_ip="10.10.10.10" config=" num_encoders=5 num_pwmgens=0 num_stepgens=0 sserial_port_0=0000000"
setp   hm2_7i92.0.watchdog.timeout_ns 5000000
loadrt pid names=pid.x,pid.z,pid.s
loadrt debounce cfg=3
loadrt matrix_kb config=8x8
addf hm2_7i92.0.read          servo-thread
addf motion-command-handler   servo-thread
addf motion-controller        servo-thread
addf pid.x.do-pid-calcs       servo-thread
addf pid.z.do-pid-calcs       servo-thread
addf pid.s.do-pid-calcs       servo-thread
addf hm2_7i92.0.write         servo-thread
setp hm2_7i92.0.dpll.01.timer-us -50
addf debounce.0               servo-thread
setp debounce.0.delay         5
addf matrix_kb.0              servo-thread
  • Mbrand1901
  • Mbrand1901
25 Feb 2026 17:50 - 25 Feb 2026 17:56
Hello!
Finally the wiring for the EXE and Mesa that worked for me:
I also dont need a extern  12V supply.
Mesa name  /   EXE Pin and colour
1 QA0         /     9  braun
2 /QA0        /     14 grün
3 GND        /      3 grün-weis
4 QB0         /     1 grau
5 /QB0        /     4 rosa
6 +5V          /     2, 6, 10 grün/braun
7 IDX0        /     7 rot
8 /IDX0       /     15 schwarz
And finally the references work! I only can drive the joints very slowly to find the index. Is there a way to drive faster? The index is only 0.001mm wide. sometimes it wont pick up.
I also milled the first pices! It works great!
I have already recived the 7i74 und the 7i84U´s for the extentions.
On the weekend i will hook up these so i can use the diffrent gear for the spindle.
Displaying 4921 - 4935 out of 14029 results.
Time to create page: 7.080 seconds
