  • Lcvette
  • Lcvette's Avatar
14 Feb 2026 01:41
Replied by Lcvette on topic Some problems with probe basic lathe
Category: QtPyVCP
What is your screen resolution?
  • MRx
  • MRx
13 Feb 2026 23:32 - 14 Feb 2026 03:58
Replied by MRx on topic Mitsubishi SSCNET
Mitsubishi SSCNET
Category: Installing LinuxCNC
I also ordered some Ethercat boards to play around with it, for now I just use regular Ethernet. I will suspend working on it until after chinese new year since I need connectors.
I also hope I can get hands on more Mitsubishi/possibly other machinery in Taiwan.
Chaining up multiple boards with Ethercat seems to be interesting, especially for the peripheral part.
The Zynq is definitely super powerful, I was able to get away with a microcontroller and accurate timings.
But the MDS-B series only needs 3.55ms framing, not 0.222, jitter is around 20ns (while the measured jitter on the Meldas M65 controller is 40-60 ns .. of course all relatively due to my non certified measurement equipment).
My plan is to make it pretty much modular with Ethercat chaining up various modules for certain tasks.
I want to mix my system with different motors than Mitsubishi for 5 axis support.
I have an old DE2 FPGA board (with ethernet), and a couple of LatticeSemi LFE3/5 boards (also with Ethernet) here which I almost wanted to use for it. I think I will just stick with various microcontrollers and small FPGAs if needed to keep it simple in the future.
  • NWE
  • NWE's Avatar
13 Feb 2026 22:45
Ursviken Pullmax Optima 130 press brake retrofit with 4 axis backgage
Category: Show Your Stuff
Finally, got to test drive the pullmax_optima component with closed loop PID, only p set to 5. Left and right side sync nicely, but with loud groaning noise. This machine runs smooth and quiet when I run it open loop. I think what I'm seeing in halscope is a combination of untuned PID and non-linear hydraulics.
chan. 1 pwmgen.04.value = controls left ram servo valve (driven by j3.vel_pid.output)
chan. 2 pwmgen.05.value = controls right ram servo valve (driven by j4.vel_pid.output)
chan. 3 pwmgen.06.value = controls tonnage proportional valve; ultimately comes from a slider on my test gui.
chan. 4,5,6,9 are the discrete spool valve coil power outputs (cr-200 to cr-203)
chan. 7 j3-motor-pos-cmd ultimately comes from a slider on my test gui. This is the input to the pos_pid.command
chan. 8 j3-motor-vel-cmd is signal connecting pos_pid.output => vel_pid.command
I was hoping velocity PID will allow me to skip the low frequency dither these valves like; but now I'm thinking my lack of that dither is what is fighting my PID. I will try lowering the p value first in case 5 is actually too high, next step is adding that low frequency dither, probably via siggen or a custom component.
  • PCW
  • PCW's Avatar
13 Feb 2026 21:46 - 13 Feb 2026 21:47
7i80HD+7i48+7i42TA+7i84 Mesa firmware request (morbidelli author 503 retrofit)
Category: Driver Boards
It should be possible with hm2_modbus,
(as long as the devices sharing a link have the same baud rate)
mesa-modbus only supports one device (per host UART)
  • PCW
  • PCW's Avatar
13 Feb 2026 21:44
Retrofit 7 ton HOMAG with Rexroth motors and drives - mesa 7i97t
No, if you set all PID values to 0 in the .ini file, run linuxcnc
and set LinuxCNC into the machine-on state, all PWM values will be 0
and the PWM enables should all be true (at least for the joints enabled in the hal file)
  • Nkbhvid
  • Nkbhvid
13 Feb 2026 21:35
“Also insure the all PWM enables are true, and all PWM values are 0”
Should I define this in HAL?
  • freemoore
  • freemoore
13 Feb 2026 21:31
Great, that's got the sserial and pktuart ports appearing and working, thank you for the quick response.
We have 3x identical modbus cards to communicate with. Using mb2hal it was possible to address each one but I can't see how to do that using mesa_modbus - is there a way to talk to different addresses over a single pktuart port? This may be a question for Andy Pugh...
Is this possible in hm2-modbus?
  • PCW
  • PCW's Avatar
13 Feb 2026 20:45
OK that looks good.
The next test is to set all PID pins to 0 (P,I,D,FF0,FF1,FF2) in the ini file
and start LinuxCNC, then enable motion, at this point, PWM should be enabled on all axis
but the PWM value should be 0 on all axis. Again measure all the Analog outputs.
 (test done with nothing connected to the 7I97T except 5V power and Ethernet)
  • Hakan
  • Hakan
13 Feb 2026 20:19
IndraDrive + LinuxCNC – PDO configuration problems
Category: EtherCAT
Have a look in syslog "sudo dmesg" and if you find the word EoE that is a problem.
Typically that interferes with the linuxcnc lcec component, which can not handle EoE.
There is a way to read out the eeprom content from the drive, flip a bit and write the eeprom content back.
However, it is much better to compile the ethercat master yourself with eoe disabled.
It has been recommended before in the forum, please search (I don't have it readily available).
See how far that takes you.
  • Nkbhvid
  • Nkbhvid
13 Feb 2026 20:11
Axis0 11mv
Axis1 9mv
Axis2 10mv
Axis3 9mv
Axis4 10mv
Axis5 9mv
13 Feb 2026 20:06
Replied by tommylight on topic QtPyVCP Mill Touch Screen
Category: QtPyVCP
@Kell,
Do not send reports asking for help, you will be banned for doing that again.
From your error report:
Can't execute DISPLAY program qtpyvcp
So did you install QtPyVCP as per the howto on their github?
13 Feb 2026 20:03
Replied by tommylight on topic Joint following error all axis
You are welcomed, always.
13 Feb 2026 19:58
  • Nkbhvid
  • Nkbhvid
Displaying 5446 - 5460 out of 14028 results.
Time to create page: 0.293 seconds
