  • BIBIGUL
  • BIBIGUL
08 Feb 2026 13:06 - 08 Feb 2026 13:10
Replied by BIBIGUL on topic socket raw Eth.
socket raw Eth.
Hello everyone. Who has ever worked with socket raw on linux cnc? raw socket requires a set cap, does it break Linux Cnc? I wrote a test driver, on raw socket, receiving data via mmap. As a controller, I use STM32F7 (4 PWM encoders). Maybe I'm doing something wrong, I don't understand the specifics of Mesa, but the first tests show some kind of prohibitive bandwidth, the jitter is lower than on mesa.
  • Looby
  • Looby
08 Feb 2026 11:58
Lenovo T14 Gen2 AMD - CRAZY High Latency - Am I screwed?
Ill try the other release and see how it shakes out. Its killing me because I see the T470/T480 in use in that thread and this is just the newer version of that laptop. Also I figured I was safe because this one can be bought from Lenovo with Debian preinstalled.
Sorry to clarify the bios is not password locked its just extremely limited by the manufacturer. Locked down in terms of restricted to basics.
  • Nkbhvid
  • Nkbhvid
08 Feb 2026 11:47 - 08 Feb 2026 13:48
Replied by Nkbhvid on topic Linuxcnc 2.9.4 and Mesa 7i97T
Category: Installing LinuxCNC
ip a:
File Name: ipareturn.txt
File Size:1 KB
  • Nkbhvid
  • Nkbhvid
08 Feb 2026 11:45
It seems that the connection is ok
mesact finds and recognizes board
ip a return
BROADCAST, MULTICAST, UP, LOWER_UP at 10.10.10.10
  • Mr1576
  • Mr1576
08 Feb 2026 11:12
Replied by Mr1576 on topic HAL Edits for RS485 / VFD Spindle Control
Category: HAL
@andypugh I relocated the net commands after the motmod .......
IT WORKS!
I cannot tell you how grateful I am -- I've been going round in circles for so long and now cannot stop smiling.
  • andrax
  • andrax's Avatar
08 Feb 2026 10:06
Technical questions about CIA402 and homecomp.comp on A6
Category: EtherCAT
I have some technical questions about CIA402 and homecomp.comp
First of all, which version of homecomp.comp is currently recommended for the A6?
Since I don't understand the source code of homecomp.comp and CIA402, I would like to know how the basic servo homing process works.
Are all servos put into homing mode and checked to see if they are ready before the sequence starts?
I'm trying to understand how the process works, as I keep getting sporadic errors during homing, even though everything else is running smoothly.
  • RotarySMP
  • RotarySMP's Avatar
08 Feb 2026 10:05
Replied by RotarySMP on topic Maho mh800w retrofit
Category: Milling Machines
Does the drive run away if the input from the Mesa is disconnected? Do you have the manual for the drives? On my Indramat, you are supposed to turn the drives using a simple power supply, before connecting them to the controller. Sorry I am no help on this, as the PID tuning I suck at.
Cheers,
Mark
  • Ozcnc
  • Ozcnc
08 Feb 2026 09:56
Replied by Ozcnc on topic Mesa 6i25 - Mesa 7i76U - Omron MX2 wiring
Category: Basic Configuration
Ok thank you I'm happy to use the RS-485 mode,
  • 3404gerber
  • 3404gerber
08 Feb 2026 09:44
Linuxcnc erste Schritte und erste Probleme, NVEM und Remora
Category: Deutsch
Hallo Mario,
Es freut mich zu hören das Du ein Schritt weiter gekommen bist. Gut hast Du Geduld und mehrmals versucht die Firmware zu flashen!
Ich komme selber auch von GRBL; die Software ist zwar genial, aber irgendwann war ich begrentzt mit TMC5160 Treiber. Ich habe dann ein Komponent für LinuxCNC geschrieben (bin nicht mal ein Hobbyprogrammier) und es funktioniert nicht so schlecht. Es ist krass was es auf LinuxCNC alles gibt und möglich ist, im Vergleich zu GRBL. Aber die Komponenten die nicht mit der Standardinstallation kommen sind halt auch nicht unbedingt häufig verwendet. Remora ist zwar eher gut dokumentiert, es ist aber nicht vergleichbar mit Kommerziellen Produkte wie Mesa Karten zum Beispiel. Mir ging es so, und ich kann mir vorstellen das ich nicht der einzige bin: ich habe mir ein Komponent geschrieben und eigesetzt, auf github geladen und bin dann zum nächsten Projekt gegangen, obwohl der Komponent weit von perfekt war und kaum dokumentiert ist.
Allerdings lernt man viel dabei und so lange Du weiter kommst und auch hier Hilfe findest wenn es nötig wird, bin ich überzeugt das Du viel Spass haben wirst mit LinuxCNC.
Gruss,
Luca
  • andrax
  • andrax's Avatar
08 Feb 2026 09:44
Replied by andrax on topic StepperOnline A6 Servo
Category: EtherCAT
anhand deiner Hal denke ich, du sprichst deutsch.
Zunächst: Welche Vorlage hast du für die Konfiguration genommen?
In der ini sehe ich folgendes
1. Für die Verwendung des Handrades musst du noch die Makro buttons mit rein nehmen (müssen nicht belegt sein), sonst gibt es Fehler.
In die hal muss dann folgendes rein: loadusr -W xhc-whb04b-6 -HsfB
2. Es gibt keinen CIA402_HOMING_METHOD=-4
Schau in die Dokumentation vom A6, da werden alle möglichen Homing Methoden aufgeführt.
Es gibt hier auch keinen Drehmomentbasierten Homing Modus. Du kannst aber einen Endschalter + Z-Impuls nutzen.
Der Endschalter muss aber dann am Driver angeschlossen werden (Di1;Di2)
Wäre zum Beispiel -1 oder -2 je nach Verfahrrichtung.
In der ethercat-conf.xml ist es empfehlenswert sync0Shift="0" zu setzen
  • djdock99
  • djdock99
08 Feb 2026 09:41
Replied by djdock99 on topic Maho mh800w retrofit
On my machine when 19k1 is latched it fires the coil on 7k1
Then this allows 24v to the rf pins on the indramat drives.
E1 and E2 which are +10v -10v inputs are connected to Aout0 and gnd on the 7i97t with the shield connected to the gnd as well
Bb and bb also have not been touched as they are controlled by 7k7s coil
In tommylights servo wiring and tuning how to guide he talks about wiring the drive enables on the mesa card but I think I should touch the original maho logic???? But would love to hear what you think
I spent some time going through the manual and making sure the encoder calculations are correct in the ini
I’ve done something wrong somewhere and I don’t know where?  thanks for your time paul
  • RotarySMP
08 Feb 2026 09:37
Considering a Full Rewire on a Working Schaublin 125 CNC
Category: Turning
Good weather for welding :) Nice progress.
  • RotarySMP
08 Feb 2026 09:35
Retrofitting a 1986 Maho MH400E
Hi Daniel,
Shame this forum has no DM function. I think you need to be logged into YT to see the email address on the main page. Otherwise I have the same user name on Zerspannungbude, which has a DM function.
I put all I learnt about the gearbox here.
github.com/jin-eld/mh400e-linuxcnc/wiki
This Github has the Comp my mate wrote to control it.
Yes, the comp rounds the commanded speed to the nearest lower gearbox ratio. It reacts automatic to the "S" code in gcode. Of course, speed change is inhibited with the spindle turning.
I added a G4 P5 pause to my post processor at every speed change, as it can take that long for the gearbox to finish changing ratio.
Cheers,
Mark
  • BIBIGUL
  • BIBIGUL
08 Feb 2026 09:21
socket raw Eth. was created by BIBIGUL
socket raw Eth.
Hello. Who has worked with ETH raw socket on Linux cnc? I'm writing an application running on raw socket, after compiling I run - sudo setcap cap_net_raw+ep NAME.so - Since raw socket requires root, I need to run setcap. Does this break Linux cnc?
  • 3404gerber
  • 3404gerber
08 Feb 2026 09:13
I'm happy to help if I can. I'm ot familiar with the STM32 controllers and I don't really understand the ldscript files, but from what I understand you'll need a ldscript and some adjustment in the platformio.ini file. Can you share your platformio.ini file?
Displaying 5701 - 5715 out of 14030 results.
Time to create page: 1.612 seconds
