  • Finngineering
  • Finngineering
01 Feb 2026 12:52
Replied by Finngineering on topic Strange preview for circular arc (G2/G3)
Category: G&M Codes
Maybe the result depends on the starting position, or some other unknown factor(?)
As such, this is okay for me. I was thinking that maybe a have some strange more or similar enabled. But it appears the preview may require a linear move before arcs.
So maybe a bug in the preview code...
  • amanker
  • amanker
01 Feb 2026 11:48
Replied by amanker on topic Problem with estop_latch
Category: Basic Configuration
They are talking about user-request-enable pin behaviour.
But I noticed that even after all conditions met for estop_latch.ok-out, this output never becomes true.
  • meister
  • meister
  • Wischi
  • Wischi
01 Feb 2026 10:16 - 01 Feb 2026 10:17
Sinker EDM machine based on diy pulse generator
Thank you tjtr33 for the good explanation of the spark process. In the last weeks (or months) i had done some experiments with a mosfet and a 60 V power supply, max 8 A. The mosfet was switched with a variable pwm signal from a esp32. A simple z axis was build from an old 3d printer. I used a hall sensor to measure the current in the gap and control the stepper motor based on a max current threshold. If a shot circuit occurs the electrode will lift up. The dielelectric fluid was distilled water. But because of the low voltage these weren't edm sparks and instead were short circuit sparks. Much more violent, loud and high wear on the electrode. See the test piece for the surface finish, it's bad. Next step would be to get a 100 V - 120 V DC power supply and close the loop with monitoring the spark gap, just as tjtr33 described it. The pwm doesn't care if a spark is good or not. But right now i don't have the time to continue this project (so another dead edm thread on the internet).
Part of the circuit i got from Peter Hofbauer, who has an excellent build log (in german) on his website:
www.hcp-hofbauer.de/indexerodierv2s4.htm
  • Dudelbert
  • Dudelbert
01 Feb 2026 09:45
Considering a Full Rewire on a Working Schaublin 125 CNC
Category: Turning
Slower than I would like to. The workshop is really uncomfortably cold right now. But the control panel is almost done, and the “packaging,” or what goes where, is almost done as well. I will make a few photos when I am in the shop the next time and post here again.
  • Stephan@work
  • Stephan@work
01 Feb 2026 09:14
Configure Mesa 7i96s and pktuart with Omron MX2 (wj200)
I removed
setp     wj200-vfd.00.update-hz               0.1
from .hal
Linuxcnc starts without any error, but still no Temperature from VDF (my indicator that it should work).
But if click the Spindle CW Button , my Vdf switched immediately into some E 12.1 Error Code (image):
If I click the ccw button, Linux CNC will close suddenly and create some error log about weird Modbus data. (modbus_error.png).
Itś hard to debug, my Workshop is 75m long walk, it is currently -5°C inside, so i bought a 75m ethernet cable to extend my Wifi for RemoteDesktop.
But i have to reset my Vdf by Hand every  E12.1 Error ( good excercise :D )
  • Marcos DC
  • Marcos DC's Avatar
01 Feb 2026 08:55
PLC + LinuxCNC for industrial machine with simple HMI (non-G-code operators)
Thanks for the detailed context — that is actually very helpful.
The original EMC separation via NML is interesting and reinforces that LinuxCNC was architecturally designed with separation between the core and the user interface in mind.
From an industrial controls perspective, this also highlights the exact challenge we are running into today: while LinuxCNC has powerful internal mechanisms (HAL, NML), there is currently no stable, supported, PLC-friendly external API that allows LinuxCNC to act cleanly as a subordinate motion controller under a PLC that owns machine state, sequencing, and safety.
Concepts like REST or MQTT could theoretically bridge that gap, but as you noted, defining a robust, long-term API would be a significant effort requiring careful planning, standardization, and maintenance commitment.
Until such an interface exists, PLC + LinuxCNC architectures will likely continue to rely on discrete I/O or tightly-coupled custom integrations, which explains why this model is relatively rare in production despite being conceptually attractive.
This discussion has been very useful in clarifying the current state of LinuxCNC in this regard and helps set realistic expectations for industrial deployments.
Thanks again for the insight.
  • rodw
  • rodw's Avatar
01 Feb 2026 06:16
The original EMC (pre LinuxCNC) design allowed separation of the HMI from the machine itself and communicated via the network and NML.
NML docs: linuxcnc.org/docs/html/code/nml-messages...sec:nml-msg:operator
In one of the config files, there are seperate IP addresses for these two pieces. I can't remember the file to look at and have no idea how much of that is still functional.
I've suggested a few times recently that The missing piece is a modern API for Linuxcnc using restful type calls or even MQTT. It would be a massive body of work that requires a lot of planning. (even picking the API method) I don't think any of our developers are familiar with the API space to even think about it.
Possibly MQTT might map pretty well to NML messaging.
  • Tchefter
  • Tchefter's Avatar
01 Feb 2026 05:52
Mitutoyo Glasmaßstäbe und Lichtschranken mit Mesa 7i96s in LinuxCNC auswerten
Category: Deutsch
Hi David,
ich bin zwar auch nicht der Pro aber wenn Du die Materialien schon alle hast,
würde ich persönlich alles daran setzen diese auch zu nutzen.
Wird sicherlich Zeit in Anspruch nehmen, hier und da Schweiß laufen und evtl.
Frust geben aber wenn es dann läuft, kannst stolz sein und hast eine wunderbare Maschine,
was sie ja eh schon ist! Das nur so als Motivation!
Die Indus, kannst Du im "Worst Case" dann immer noch verbauen!
Viel Erfolg und Durchhalten!
Gruß Fritz
  • Marcos DC
01 Feb 2026 04:30 - 01 Feb 2026 04:30
@NWE
Thanks for the explanation. In our case, the PLC cannot be a “drive-by-wire” remote control for LinuxCNC. The PLC must be the authority of machine state, sequencing, and safety, independent of the PC. LinuxCNC is treated as a subordinate motion controller, similar to how a PLC supervises an industrial robot controller.
That is the key architectural requirement we are trying to address.
  • cmorley
  • cmorley
01 Feb 2026 04:23 - 01 Feb 2026 04:24
LatheEasyStep – experimental QtVCP macro for step-by-step lathe programming
Category: Qtvcp
I tried loading this in master and came up with an error message.
[QTvcp.QTVCP.QT_MAKEGUI][ERROR] Easystep: Trouble looking for handlers in 'lathe_easystep_handler': (qt_makegui.py:469)
File "/home/chris/emc/lib/python/qtvcp/qt_makegui.py", line 446, in _load_handlers
objlist = h(halcomp, widgets, self.PATHS) # this sets the handler class signature
File "/home/chris/emc/configs/sim/qtdragon_lathe/easy_lathe/qtvcp/panels/lathe_easystep/lathe_easystep_handler.py", line 7101, in get_handlers
return [HandlerClass(halcomp, widgets, paths)]
File "/home/chris/emc/configs/sim/qtdragon_lathe/easy_lathe/qtvcp/panels/lathe_easystep/lathe_easystep_handler.py", line 3038, in __init__
self._connect_signals()
File "/home/chris/emc/configs/sim/qtdragon_lathe/easy_lathe/qtvcp/panels/lathe_easystep/lathe_easystep_handler.py", line 4468, in _connect_signals
self.list_ops.currentRowChanged.connect(self._handle_selection_change)
AttributeError: 'QWidget' object has no attribute 'currentRowChanged'
I didn't look into why.
I did switch to 2.9 and it seems to work, but I haven't figured out how to use it yet :)
  • Marcos DC
01 Feb 2026 03:35
@rodw
Thanks for the clarification. I think we may be talking about slightly different problem spaces, so I’d like to address your point more directly.
I fully agree that LinuxCNC + HAL + custom C components is extremely powerful, and technically capable of replacing much of what a PLC would do. That is not in dispute.
In our case, however, the decision to use a real PLC is not driven by capability, but by industrial lifecycle and responsibility separation. The PLC is used as a dedicated machine/cell controller that:
• maintains machine state and sequencing independently of the PC
• handles safety interlocks and operator workflow
• is maintainable by technicians familiar with IEC 61131 environments
• remains in a known, deterministic state even if the LinuxCNC PC is rebooted or serviced
While writing HAL components in C is a perfectly valid solution, it assumes long-term availability of developers comfortable with Linux internals, HAL, and custom code. In many industrial environments, that is not a realistic maintenance model.
LinuxCNC remains responsible for what it does best: motion planning, interpolation, and trajectory execution. The PLC acts as the machine controller. This separation is very common in industrial CNC machines and robotic cells.
So the question is not whether LinuxCNC can do everything, but how others have implemented clean responsibility boundaries between a real PLC and LinuxCNC in production machines.
If you’re aware of real-world deployments following this model, those examples would be particularly valuable to the discussion.
  • Marcos DC
01 Feb 2026 03:23
I’d like to clarify a few points for readers, as I think some replies are unintentionally mixing different problem domains.
First, regarding PLCs and “ladder-only” assumptions:
Modern industrial PLCs are not limited to ladder logic. Under IEC 61131-3, ladder is only one option. In real industrial machines, Structured Text (ST) is very commonly used for state machines, sequencing, recipe handling, diagnostics, and supervisory motion logic.
In addition, several PLC platforms support compiled C/C++ modules or libraries (for example Beckhoff, B&R, Codesys-based systems, etc.). So PLCs are not inherently low-level or limited to ladder logic.
Second, regarding Beremiz:
Beremiz is an interesting IEC 61131 runtime, but it still runs on the same PC and operating system. In our use case, that does not meet the requirement. One of our core goals is that the machine controller remains independent of the LinuxCNC PC, maintaining machine state and safety even if the PC or LinuxCNC software needs to be restarted or serviced. A soft-PLC running on the same machine does not provide that separation.
Third, regarding remote operation via Wi-Fi or mobile devices:
While this may be acceptable in experimental or supervised environments, it is generally not acceptable in industrial machinery. In an industrial context, machine start/stop authority, mode selection, and operator interaction must be mediated by a certified PLC and physical HMI, with clear local/remote modes, access control, and hardwired safety circuits.
Allowing machines to be started or stopped directly from phones or ad-hoc web interfaces raises significant safety, liability, and maintenance concerns in real production environments.
To clarify our intent: this discussion is not about whether LinuxCNC can do everything. LinuxCNC is excellent at motion planning, interpolation, and trajectory execution, which is exactly why we want it handling motion. The PLC is used as the machine controller, responsible for sequencing, safety, operator workflow, and maintaining a known, safe state independently of the PC.
This is a very common architecture in industrial CNC machines and robotic cells, where a PLC handles cell logic and operator interaction, and a dedicated motion controller executes paths.
We are specifically interested in practical examples of this kind of PLC-driven cell logic combined with LinuxCNC (or otherwise)) as a motion controller, rather than PC-centric or soft-PLC-only architectures.
  • rodw
  • rodw's Avatar
01 Feb 2026 00:06
Problems with Lichuan Ethercat servo drive
Category: EtherCAT
looks great. I'll have a play.
Does my homecomp you link to work for you without any changes?
github.com/rodw-au/cia402_homecomp
I never had hardware in the end to test it properly.
  • nicklego
  • nicklego's Avatar
31 Jan 2026 21:27 - 01 Feb 2026 18:45
Maxnc15CL Motor timing help was created by nicklego
Hi, I'm very new to CNC, and I have a Maxnc15CL from around the year 2000 and am using a Raspberry Pi 5 to communicate with it using LinuxCNC. The Pi 5 has a parallel port hat from Byte 2 Bot, and I'm able to control the spindle, detect the limit switches, enable the motor encoder feedback loop, and make the motors make noise when I tell the axis to move. I suspect that the motor timing is off, but im not too sure if when I change the values, if it's getting closer or further away from actually moving. If anyone has any ideas on how to make this work, I would greatly appreciate it, and im leaving my hal file and .ini file below. Thank you
File Name: V3Maxnc_20...1-31.hal
File Size:9 KB
File Name: V3Maxnc_20...1-31.ini
File Size:3 KB
Displaying 6061 - 6075 out of 14034 results.
Time to create page: 0.598 seconds
