  • PCW
  • PCW's Avatar
15 Jan 2026 18:03 - 15 Jan 2026 18:04
MAC address not retrieved (after 2 years stop)
Category: Driver Boards
The host address of 10.10.10.11 is fine, it must be different than the FPGA card
(but in the same subnet)
A failed HM2 registration usually means dropped packets, so there is something marginal
with the Ethernet connection.
What does:
sudo chrt 99 ping -i .001 -c 60000 -q 10.10.10.10
report?
(it will run 1 minute before printing statistics)
  • cnbbom
  • cnbbom
15 Jan 2026 18:02
Replied by cnbbom on topic New and Working RTAI debs for 2.9
Category: Installing LinuxCNC
tommylight post=341431 userid=17274
[EMCMOT]
EMCMOT = motmod
COMM_TIMEOUT = 1.0
BASE_PERIOD = 46872
SERVO_PERIOD = 1000000
Your base period is set at 46872, strange for sure, but i am pretty sure LinuxCNC will round it to something divisible from 1000000. Set it to 50000.
Será que estou inserindo valores incorretos para o Jitter Máximo do Período Base ao configurar uma máquina no Assistente de Configuração do Motor de Passo?
  • Surmetall
  • Surmetall's Avatar
15 Jan 2026 17:56
WEMAS MT 32 CNC Lathe -> LinuxCNC - Mesa or EtherCAT?
Category: Turning
Does nobody have an idea or suggestion regarding the problems with my plans?
Lathes are probably rebuilt far less often than milling machines, unfortunately.
Well, in the meantime I continued working on the control cabinet. I had already planned the layout in CAD, and the effort put into that really pays off here.
First, I printed and attached a template, center-punched the holes and cut the threads, then cut the cable ducts and DIN rails to length and mounted them. A very pleasant, almost calming kind of work.
After that, I pre-wired everything and installed it in the cabinet. I also equipped the lid with a gas spring, and added a cable duct underneath the control cabinet.
  • Jocman
  • Jocman
15 Jan 2026 17:50
did you turn on power to the Mesa card before starting linuxcnc?
yep, first thing I tried (a lot of times I got an error then I realized I forgot to switch on the machine)
Whats does the command:
ip a
report?
What happens if you:
ping 10.10.10.10
This is what I get with "ip a" and giving a ping:
joccnc@JocCnc:~$ ip a
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1
    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
    inet 127.0.0.1/8 scope host lo
       valid_lft forever preferred_lft forever
    inet6 ::1/128 scope host
2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
    link/ether e8:4e:06:84:dc:c9 brd ff:ff:ff:ff:ff:ff
    inet 192.168.1.245/24 brd 192.168.1.255 scope global dynamic eth0
       valid_lft 863950sec preferred_lft 863950sec
    inet6 fd59:b8bd:be6f:0:6bdd:2ca7:6e73:aa7b/64 scope global noprefixroute dynamic
       valid_lft 7152sec preferred_lft 3552sec
    inet6 fe80::6ed6:c856:a0cb:2db8/64 scope link
3: eth1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
    link/ether 70:85:c2:6a:f0:3d brd ff:ff:ff:ff:ff:ff
    inet 10.10.10.11/8 brd 10.255.255.255 scope global eth1
    inet6 fe80::8ede:25a1:ff4d:99b4/64 scope link
joccnc@JocCnc:~$ ping 10.10.10.10
PING 10.10.10.10 (10.10.10.10): 56 data bytes
64 bytes from 10.10.10.10: icmp_seq=0 ttl=64 time=0.779 ms
64 bytes from 10.10.10.10: icmp_seq=1 ttl=64 time=0.418 ms
64 bytes from 10.10.10.10: icmp_seq=2 ttl=64 time=0.402 ms
64 bytes from 10.10.10.10: icmp_seq=3 ttl=64 time=0.424 ms
64 bytes from 10.10.10.10: icmp_seq=4 ttl=64 time=0.365 ms
eth0 is my second network card, I use it to reach my NAS, my LAN and the WEB
eth1 is the integrated network card, used by Mesa
giving the ping 10.10.10.10 I get response from Mesa
I just don't understand why eth1 report IP 10.10.10.11, when my hal file is set 10.10.10.10, and ping to 10.10.10.10 works.
BTW, after these tests I tried to start LinuxCNC, I get again an error message, but this time no mention about the MAC (is correctly reported), now the error is about HM2 registration:
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.7.14
Machine configuration directory is '/home/joccnc/linuxcnc/configs/Prova01'
Machine configuration file is 'Prova01.ini'
INIFILE=/home/joccnc/linuxcnc/configs/Prova01/Prova01.ini
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=halui
DISPLAY=axis
Starting LinuxCNC...
Found file(REL): ./Prova01.hal
hm2_eth: loading Mesa AnyIO HostMot2 ethernet driver version 0.2
hm2_eth: 10.10.10.10: Hardware address: 00:60:1b:10:45:59
hm2_eth: discovered 7I76E-16
hm2/hm2_7i76e.0: Smart Serial Firmware Version 43
Board hm2_7i76e.0.7i76.0.0 Hardware Mode 0 = standard
Board hm2_7i76e.0.7i76.0.0 Software Mode 0 = io_spin
Board hm2_7i76e.0.7i76.0.0 Software Mode 1 = io_ana_spin
Board hm2_7i76e.0.7i76.0.0 Software Mode 2 = io_enc_ana_spin_fv
board fails HM2 registration
Running HAL shutdown script
Killing task linuxcncsvr, PID=1208
hm2: unloading
15 Jan 2026 16:00
Replied by tommylight on topic LAser Engraving GRid Speed/Power
Category: Deutsch
Sorry aber English gehts schneller:
You can search the web for the gcode file, or you can download trial version of LightBurn and generate the code, then use LinuxCNC to test with it.
Most LightBurn code will run on LinuxCNC, and if it does not at least it complains about it so editing and removing offending lines should always work.
15 Jan 2026 15:58
Replied by tommylight on topic New and Working RTAI debs for 2.9
[EMCMOT]
EMCMOT = motmod
COMM_TIMEOUT = 1.0
BASE_PERIOD = 46872
Still i do not think that is the main issue, it seems your PC has some strange and huge excursions in latency, so, did you disable in BIOS:
turbo
speed step
power saving options
TPM if any
PCI-E aggressive power saving (no idea what name is used in some boards)
C states
etc.
Be as it may, for that PC and since you need RTAI, use the Wheezy ISO as is, granted you do not need any missing features from it.
You can download and test Wheezy without installing it, see how that works out.
  • prokopcio
  • prokopcio's Avatar
15 Jan 2026 15:54 - 15 Jan 2026 16:01
Laser Head Height Sensor – Looking for a Beta Tester
Category: Plasma & Laser
Sorry I’ve been quiet for a while — I had to put the project on hold for some time, but I’ve just come back to it and I’m now moving it into production. It should be available within about two weeks.A new operating mode has been added, and in my case it works extremely well (I have my own CNC controller, so I can do whatever I want). It doesn’t require any data processing, because it receives the ready-to-use height directly from the sensor. This option might be useful for others in the future as well.The only drawback is that the output is a universal open-collector type, which isn’t a standard interface. However, I designed a simple circuit that converts the open-collector signal into a standard RS-485 signal. I calculated it, built it, tested it, and measured it — and it works perfectly. Over several hours of operation, not a single bit was lost on an unshielded cable (just a regular twisted-pair Ethernet cable) over a distance of more than 300 meters in an industrial environment. That exceeded my expectations.
CONVERTER SIMULATION
  • PCW
  • PCW's Avatar
15 Jan 2026 15:52 - 15 Jan 2026 15:53
Replied by PCW on topic MESA 6i24 + 7i36
MESA 6i24 + 7i36
Category: PnCConf Wizard
3 changes should be done in the hal file:
1. Set the PWM rate to 48 KHz
2. Set offset mode true for all PWM channels:
setp hm2_5i24s.0.pwmgen.0N.offset-mode true
Where "N" is the channel number
This is critical or the analog output will be wrong
3. Set dither mode true for all PWM channels:
hm2_5i24.0.pwmgen.0N.dither true
 This will increase the Analog resolution from 12 bits full scale to 15 bits full scale
Note that this requires firmware with PWMGen version 1 if the 5I24 firmware
does not have version 1 PWMGens, I will update it.
Note that you may need to change the PWM scale so you have the desired
negative feedback (control) rather than positive feedback (runaway)
  • cnbbom
  • cnbbom
15 Jan 2026 14:48
I hope I got it right this time.
  • Lopez
  • Lopez
15 Jan 2026 14:11
I have a Chinese parallel port board and I can't get the Y1 axis to be a slave t
Thank you so much for your reply, friend. I'd like to know if you have any contacts I could reach if I need help. I'm from Paraguay, and your help would be invaluable. Thanks again, friend.
# Generado por stepconf 1.1 en Thu Jan 15 10:49:41 2026
# Si realiza cambios en este archivo, serán
# sobrescrito cuando ejecuta stepconf nuevamente
loadrt [KINS]KINEMATICS
loadrt [EMCMOT]EMCMOT base_period_nsec=[EMCMOT]BASE_PERIOD servo_period_nsec=[EMCMOT]SERVO_PERIOD num_joints=[KINS]JOINTS num_spindles=[TRAJ]SPINDLES
loadrt hal_parport cfg="0 out"
setp parport.0.reset-time 5000
loadrt stepgen step_type=0,0,0,0
loadrt plasmac
addf plasmac servo-thread
addf stepgen.update-freq servo-thread
# ---PLASMA INPUT DEBOUNCE---
loadrt dbounce names=db_breakaway,db_float,db_ohmic,db_arc-ok
addf db_float servo-thread
addf db_ohmic servo-thread
addf db_breakaway servo-thread
addf db_arc-ok servo-thread
# ---JOINT ASSOCIATED WITH THE Z AXIS---
net plasmac:axis-position joint.2.pos-fb => plasmac.axis-z-position
# ---PLASMA INPUTS---
# ---all modes---
net plasmac:float-switch => db_float.in
net plasmac:breakaway => db_breakaway.in
net plasmac:ohmic-probe => db_ohmic.in
net plasmac:ohmic-sense-in => plasmac.ohmic-sense-in
# ---modes 0 & 1
net plasmac:arc-voltage-in => plasmac.arc-voltage-in
# ---modes 1 & 2
net plasmac:arc-ok-in => db_arc-ok.in
# ---mode 2
net plasmac:move-up => plasmac.move-up
net plasmac:move-down => plasmac.move-down
# ---PLASMA OUTPUTS---
# ---all modes---
net plasmac:ohmic-enable <= plasmac.ohmic-enable
net plasmac:scribe-arm <= plasmac.scribe-arm
net plasmac:scribe-on <= plasmac.scribe-on
net xstep => parport.0.pin-02-out
setp parport.0.pin-02-out-reset 1
net xdir => parport.0.pin-03-out
net ystep => parport.0.pin-04-out
setp parport.0.pin-04-out-reset 1
net ydir => parport.0.pin-05-out
net zstep => parport.0.pin-06-out
setp parport.0.pin-06-out-reset 1
net zdir => parport.0.pin-07-out
net y2step => parport.0.pin-08-out
setp parport.0.pin-08-out-reset 1
net y2dir => parport.0.pin-09-out
#qtplasmac doesn't use a spindle: net spindle-cw => parport.0.pin-14-out
#qtplasmac doesn't use a spindle: net spindle-pwm => parport.0.pin-16-out
net xenable => parport.0.pin-17-out
net estop-ext <= parport.0.pin-10-in
setp stepgen.0.position-scale [JOINT_0]SCALE
setp stepgen.0.steplen 1
setp stepgen.0.stepspace 0
setp stepgen.0.dirhold 35000
setp stepgen.0.dirsetup 35000
setp stepgen.0.maxaccel [JOINT_0]STEPGEN_MAXACCEL
net xpos-cmd joint.0.motor-pos-cmd => stepgen.0.position-cmd
net xpos-fb stepgen.0.position-fb => joint.0.motor-pos-fb
net xstep <= stepgen.0.step
net xdir <= stepgen.0.dir
net xenable joint.0.amp-enable-out => stepgen.0.enable
setp stepgen.1.position-scale [JOINT_1]SCALE
setp stepgen.1.steplen 1
setp stepgen.1.stepspace 0
setp stepgen.1.dirhold 35000
setp stepgen.1.dirsetup 35000
setp stepgen.1.maxaccel [JOINT_1]STEPGEN_MAXACCEL
net ypos-cmd joint.1.motor-pos-cmd => stepgen.1.position-cmd
net ypos-fb stepgen.1.position-fb => joint.1.motor-pos-fb
net ystep <= stepgen.1.step
net ydir <= stepgen.1.dir
net yenable joint.1.amp-enable-out => stepgen.1.enable
setp stepgen.2.position-scale [JOINT_2]SCALE
setp stepgen.2.steplen 1
setp stepgen.2.stepspace 0
setp stepgen.2.dirhold 35000
setp stepgen.2.dirsetup 35000
setp stepgen.2.maxaccel [JOINT_2]STEPGEN_MAXACCEL
net y2pos-cmd joint.2.motor-pos-cmd => stepgen.2.position-cmd
net y2pos-fb stepgen.2.position-fb => joint.2.motor-pos-fb
net y2step <= stepgen.2.step
net y2dir <= stepgen.2.dir
net y2enable joint.2.amp-enable-out => stepgen.2.enable
setp stepgen.3.position-scale [JOINT_3]SCALE
setp stepgen.3.steplen 1
setp stepgen.3.stepspace 0
setp stepgen.3.dirhold 35000
setp stepgen.3.dirsetup 35000
setp stepgen.3.maxaccel [JOINT_3]STEPGEN_MAXACCEL
net zpos-cmd joint.3.motor-pos-cmd => stepgen.3.position-cmd
net zpos-fb stepgen.3.position-fb => joint.3.motor-pos-fb
net zstep <= stepgen.3.step
net zdir <= stepgen.3.dir
net zenable joint.3.amp-enable-out => stepgen.3.enable
net estop-ext => iocontrol.0.emc-enable-in
net tool-number <= iocontrol.0.tool-prep-number
net tool-change-loopback iocontrol.0.tool-change => iocontrol.0.tool-changed
  • Lopez
  • Lopez
15 Jan 2026 14:03
Publicación de PCW=341375 ID de usuario=481¿Qué puerto paralelo se ha desconectado?
¿Puedes compartir tus jarchivos hal/ini?
File Name: CNCLINUX.txt
File Size:4 KB
File Size:4 KB
  • Avion
  • Avion
15 Jan 2026 13:12
retrofit of an existing CNC - tool sensor and 3d probe
Category: CNC Machines
Dear PCW,
thank you for the answers. Good one!
I will make sure to setup the 7176 in all safe states. I think also maybe to upgrade to two limit switches per axsis instead of just one. Right now it is only one per axis and for the wire cutter i had anyways two per axis planned.
The enable and disable part: Probably I should just leave it then right now and when I encounter a situation where it does add function or value, its easy to upgrade.
So in generally, thanks. I will update with diagrams and images as soon as possible.
  • Mbrand1901
  • Mbrand1901
15 Jan 2026 12:22
Replied by Mbrand1901 on topic Retrofitting Deckel FP4ATC
Category: Milling Machines
Hello,
sadly i already bought such a EXE. It looks quite new. I will give it a try. I am going to use an external 12v power supply.
On monday i will recive my 7i97T. Mabey next week the axis will move.
  • tracer
  • tracer
15 Jan 2026 11:42
LAser Engraving GRid Speed/Power was created by tracer
Category: Deutsch
HAllo zusammen,
ich habe schonmal gesucht aber bisher nichts passendes gefunden. Hat jemand eine .ngc Datei oder eine laufendes Script mit der man ein Laser GRid erstellen kann mit Speed und Power?
Danke vorab.
Bei mir meckert er bei dem bestehnden immer.
Beste GRüße
Christoph
Displaying 6871 - 6885 out of 14046 results.
Time to create page: 0.422 seconds
