  • endian
  • endian's Avatar
07 Jan 2026 06:53
Replied by endian on topic LinuxCNC S-Curve Accelerations
okay, thanks, I understand... just said my observations ... did you check my gcode yet?
  • NWE
  • NWE's Avatar
07 Jan 2026 06:41 - 07 Jan 2026 07:04
Replied by NWE on topic RPi CM5 on Mesa Ethernet 7i95
Checking the datasheets:
The Pi5 and CM5 both use the BCM2712 CPU. The CM5 uses the Broadcom BCM54210PE ethernet phy ic. I'm having a bit of trouble finding concrete info on what the Pi5 has, but I see my Pi 5 datasheet in the photo of the Pi 5 it has a BCM54213PE ethernet phy ic soldered near its ethernet connector. According to a quick look at the datasheets, those two chips appear to be interchangable.
In other words Pi 5 = CM5 as far as network drivers is concerned.
I think you could run in a terminal:
lspci -k
to determine whether the correct drivers loaded. It should report the same modules for the network as it does on your Pi 5.
On the other hand, maybe there is a connection problem between the I/O board and the CM5, is the CM5 seated correctly, and the connections clean? One thing I'd try is carefully disconnecting then re-seating the CM5 on the I/O board, it could make a difference.
  • Mbrand1901
  • Mbrand1901
07 Jan 2026 05:55 - 07 Jan 2026 07:58
Replied by Mbrand1901 on topic Retrofitting Deckel FP4ATC
Category: Milling Machines
Hello!
The idea with the Heidenhein board isn't bad. It's definitely a very solid solution.
I have already asked another company about these small converters. If they are suitable I would like to use them because they are small.
www.hs-imagingsolutions.com/hardware/signalkonverter
@hartwig, you can edit your comment to delete the long link
  • grandixximo
  • grandixximo's Avatar
07 Jan 2026 04:51
Replied by grandixximo on topic LinuxCNC S-Curve Accelerations
It is not a simple change, the look ahead is about velocity not position, it is not something we can easily expose via HAL, it does not exist, we do not have that point ahead of time, we need to calculate it, and you just had us look at performance optimization, this will double the calculations, for cosmetic reason, I don't think you'd want that either.
  • rodw
  • rodw's Avatar
07 Jan 2026 03:33
Replied by rodw on topic 3D touch probe confusion
Category: Basic Configuration
I don't have a surface plate or height gauge (yet). I do have a lathe with a DRO. I made a ring that the tool holder fits into. I chuck the ring up the lathe, Turn the lathe tool post holder around so I have a flat surface that will go up against the ring. Zero out the DRO. Move the tool post away from the ring. Insert the mill tool in the ring then move the lathe tool so it touches the tip of the tool. The DRO now shows the tool length. I enter that value into the tool table.
Very inventive solution :)
  • endian
  • endian's Avatar
07 Jan 2026 03:22 - 07 Jan 2026 03:35
No there is no error observations at parts because regulator in servo doing its job .. its just cosmetic issue of lcnc which I can see when I am comparing lcnc with fo example NC application from TC3...
It just my hint.. many of user are facing this ferror a its difficult to understand for them that this error is not the bug but the feature...
I am just highlighting situation and when you are already in gentlemen.. how much difficult is to create pin position-command-bus or something else which will forever solve this observation please?
Thank you. Your jobs are amazing !
  • PHILCOAST
  • PHILCOAST's Avatar
07 Jan 2026 03:17
RPi CM5 on Mesa Ethernet 7i95 was created by PHILCOAST
Hello, I am testing LinuxCNC 2.9.7 (official Raspberry Pi 4/5 image, Debian Trixie, uspace) on a Raspberry Pi Compute Module 5 (CM5) with a Mesa 7i95 Ethernet card.
The same LinuxCNC version, Mesa card, cable, and network configuration work on another Raspberry Pi platform, but on CM5: • eth0 stays NO-CARRIER • ethtool eth0 shows Link detected: no • Forcing speed/duplex has no effect • RP1 PCIe device is detected in kernel logs Network: • eth0: 10.10.10.1/24 • Mesa: 10.10.10.10
Is CM5 fully supported by the current LinuxCNC Raspberry Pi 4/5 image, or is newer kernel / device-tree support required for RP1 Ethernet on CM5? Thank you.
  • cmorley
  • cmorley
07 Jan 2026 03:02
Replied by cmorley on topic qtdragon_hd updated handler issue
Category: Qtvcp
I see this in master and looking at the code, I see why.
Thanks for details and investigation.
I'll try to push a bug fix soon.
  • leandrocontarini
  • leandrocontarini
07 Jan 2026 02:43 - 07 Jan 2026 02:44
Replied by leandrocontarini on topic Chinese Mesa 7I92 from aliexpress NEW
Category: Driver Boards
Aqui os 3 modelos que testei funcionaram bem.
Mas com .bit chinês
  • JohnnyCNC
  • JohnnyCNC's Avatar
07 Jan 2026 02:27
Replied by JohnnyCNC on topic 3D touch probe confusion
Before I had TTS tool holders I used a touch plate that I had made. It was basically a spring-loaded brass button in a Delrin base. I used to put each OP in a separate G-Code file and touch-off with the touch-plate at each tool change. Now I have an M6 remap that automatically measures my variable length tools like drills and odd endmills that I don't have dedicated toolholders for. It uses that length in the tool table for the tools with dedicated holders.
  • JohnnyCNC
07 Jan 2026 02:17
  • grandixximo
07 Jan 2026 01:52
We use CSP control with Ethercat, I can't really envision benefit of sending next next position, instead of just next position.
What do you actually observe on real finished parts? Any actual quality issues? Or is this a theoretical concern based on watching HAL ferror signals?
  • mooser
  • mooser
07 Jan 2026 01:52
Replied by mooser on topic 7i84u probably toasted
FWIW, I finally got back to working on this with the new 7i84 board and the ferrules I ordered.
I purchased two different ferrules but the one that seems to work best is a 0.14mm2  - 26-28g brown  Digikey PN 288-1656-ND, manu-PN 1163014
These will go in and start over the insulation slightly (maybe where it's been necked down a little during stripping?) but crimps down tightly.
I do think I might all a drop of CA to the plastic end of the ferrule once the wire is in just to move the flex point away from where the bare wire is crimped and up to the insulated part
Back to wiring....
  • mika
  • mika's Avatar
07 Jan 2026 00:53
Replied by mika on topic LinuxCNC S-Curve Accelerations
Hi everyone, I'm 杨阳. I'm currently studying the lookahead optimization code in the motion planner, and we're also exploring some approaches to improve its computational efficiency. If everything goes well, I hope to contribute further optimizations in the future.
  • PCW
  • PCW's Avatar
07 Jan 2026 00:19
Replied by PCW on topic Servos drives directly start turning
The hal file shows independent analog outputs and encoders
Are you sure you have the feedback correct for Y and Y2?
You not only have to get the right (matching) directions but the
proper feedback so you don't get a instant runaway at drive enable.
Might be best to test  this with the linear axis disconnected
Displaying 7186 - 7200 out of 14050 results.
Time to create page: 0.523 seconds
