  • Surmetall
  • Surmetall's Avatar
07 Dec 2025 14:54
Replied by Surmetall on topic Arduino IO Expansion
Category: Show Your Stuff
Hi AlexMagToast,I’ve been following your Arduino IO-Expansion project for a while now and I just wanted to say thank you, really great work! Thanks for sharing!I’m currently planning a control panel for my lathe and your project looks like it could be a good fit even though my setup is a bit different from yours. I won’t need the matrix keyboard because I’m planning to use a StreamDeck for most of the button functions (there’s a tool for LinuxCNC support here: forum.linuxcnc.org/show-your-stuff/52628...for-linuxcnc?start=0 ).
 For the panel itself I would still need some hardware I/Os:
-> 8–10 digital inputs/outputs (joystick, rapid, spindle, LEDs, etc.)
-> 3 analog inputs for potentiometers (feed override, spindle override, handfeed)
-> 2 encoder inputs for handwheelsI wanted to use the Heidenhain ROD450 with 500 lines on the handwheels the lathe came with through Beckhoff EtherCAT hardware, but the 11µA sinus signals are a bit of a nightmare to read out. So I’m now considering a simpler approach with two inexpensive TTL encoders from China, which your Arduino setup should handle much more easily.My questions:
How stable has your Arduino solution been for you so far? Are you still happy with it? Especially on the same USB cable with the StreamDeck.
Which board would you recommend for what I’m trying to do? Uno, Mega, ESP32 or something else? Does someone recommend a different hardware setup?Thanks again for sharing your project. It’s cool to see alternatives to the usual hardware solutions, and I’d appreciate any advice before I start buying components. Greetings Tom
  • andypugh
  • andypugh's Avatar
07 Dec 2025 14:51
Replied by andypugh on topic New and Working RTAI debs for 2.9
Category: Installing LinuxCNC
There are lots of comments here abut running the 5.4.279 kernels, but I don't seem to be able to find them anywhere. Any clues?
The link in the first post of the thread says 5.4.279 but leads to 5.4.290 debs.
  • andrax
  • andrax's Avatar
07 Dec 2025 13:40 - 07 Dec 2025 13:41
Replied by andrax on topic StepperOnline A6 Servo
Category: EtherCAT
That won't work.The Slave is currently unavailable in the current configuration.I will have to set it manually.
  • unknown
  • unknown
07 Dec 2025 11:50 - 07 Dec 2025 13:06
Replied by unknown on topic Upgrade advice for ooold system
Upon reflection, do what thy will.
  • Happppppppy
  • Happppppppy
07 Dec 2025 11:47
I have been tuning some steppers using the stepdir plugin and the quadencoder plugins as feedback. The tuning hasn't been working too well and I'm curious if it is possible to set the Stepgen into velocity mode? Thankyou!
  • Hakan
  • Hakan
07 Dec 2025 10:44 - 07 Dec 2025 10:45
Replied by Hakan on topic StepperOnline A6 Servo
Category: EtherCAT
setp cia402.0.csp-mode 1
sets csp mode.
  • andrax
  • andrax's Avatar
07 Dec 2025 10:36
Category: EtherCAT
No, I haven't changed anything.
Those are the servo's default settings.
I need to see where I can switch the servo from speed to position mode.
  • Hakan
  • Hakan
07 Dec 2025 09:26
Category: EtherCAT
Why do you want to set a speed? Normally you set a position.
  • andrax
  • andrax's Avatar
07 Dec 2025 08:52
Category: EtherCAT
Addendum:
Something is wrong.
In the current configuration of the servos (factory settings), it is not possible to set a speed.
Is anyone else using the 6M60-400H2A1-M17?
  • Aciera
  • Aciera's Avatar
07 Dec 2025 08:39
Replied by Aciera on topic Clearpath HLFB amp.joint.delay
Category: HAL
Does the amplifier actually fault and if so do you actually know why it is faulting?
  • timo
  • timo
07 Dec 2025 07:29 - 07 Dec 2025 07:30
Replied by timo on topic Upgrade advice for ooold system
Sitting in the coffee shop having nothing else to do than posting rubbish half knowledge :-)
I think my problem is usually not the missing updates, but the forgotten details, due to lack of documentation. So maybe just update the documentation is already good.
I never connect my cnc machines to the internet (what for?).
I would leave the existing system completely untouched and create an independent newer backup system. (Takes time pressure away)
The hours you have to invest in the backup system is probably the same as fixing things once it stopped working. (bad wheather? unplug! ) :-)
I bought parallelport cards for cheap, they worked on newer, but still old hardware. (6-7 year old 2nd hand PC)
I would only update if there is a particular function that I want or need.
Never change running system.
  • GiBi77930
  • GiBi77930
07 Dec 2025 07:05
Replied by GiBi77930 on topic GCode particulier a QtDragon
Category: Français
OK, thx, ce mode m'avait échappé.
  • cmorley
  • cmorley
07 Dec 2025 03:30
Replied by cmorley on topic qtdragon mod
qtdragon mod
Category: Qtvcp
you could use a PushButton (under the linuxcnc-HAL heading)
It makes a hal pin.
Don't forget to set the property:
pin_name and pin_type
  • Fastfred
  • Fastfred
07 Dec 2025 03:12
Replied by Fastfred on topic Clearpath HLFB amp.joint.delay
Category: HAL
My Latest config still having issue with joint 0 fail.
File Name: custom_2025-12-06.hal
File Size:1 KB
  • Fastfred
  • Fastfred
06 Dec 2025 22:32
Category: HAL
Do I start from scratch? do you mind giving a example how to configure this . Took me awhile just to try to get this far.
Displaying 8371 - 8385 out of 14061 results.
Time to create page: 0.451 seconds
