  • viesturs.lacis
  • viesturs.lacis
23 Sep 2026 12:19 - 23 Sep 2026 13:18
Replied by viesturs.lacis on topic lcec_conf exited without becoming ready
Category: EtherCAT
please find attached 3 screenshots - left side are all the pins for cia402 component (they did all fit in screen) and right side is list of lcec pins in terminal. do you have any idea, which of these is "enable" pin? lcec.0.state-preop, lcec.0.state-safeop and lcec.0.state-op seem suspicious to me but then I do not understand why would 3 pins be needed. I would appreciate some hints on which pins should I try for enabling the drive and which would be most suitable candidate for making the motor spin. cia402.0.velocity-cmd would seem like most obvious candidate but is there anything else to add (so far in my experience it would have been 2 pins - one sets velocity, the other would be a bit output for "run/stop")
BTW cia402.0.controlword has value 4, which seem to match instructions in manual to set the parameter 50.04 to 4 (which means that reference is speed). does that help in any way? and since the manual says this:"Ensure the drive profile parameter 51.02 is set to CiA402 (0)" I would like to think that it's all good regarding the suspicion about needing different mode rather than cia402.
could you please share some link where I could see some cia402 templates that you mentioned?
  • geebee
  • geebee
23 Sep 2026 11:11
Replied by geebee on topic 7i95t firmware flash
Category: Driver Boards
I just try to set the card to work.
For the beginning, I want it to get a single stepper motor to turn with nothing else connected to it. For this, I need to configure some hal and ini files. I can use mesact but not pncconf for this.Later, I will analyze and try to understand these first files according to linuxcnc docs. What i intend to do is retrofitting a lathe to cnc (two, maybe three axes) , an additional axe for an attached lathe and on for a dividing head and some encoders /DRO This is all I might need in the (far) future.
Right now, I would just be happy to get linuxcnc, mesact ,board and stepper (driver) "Talk to one another".
cheers
geebee
  • PCW
  • PCW's Avatar
23 Sep 2026 11:05
Replied by PCW on topic 7i95t firmware flash
OK so the next question is which Ethernet interface is the 7I95T connected to?
(enp8s0 or eno1)
(quick way to check is unplug the 7I95T RJ45 cable and see which interface shows "NO-CARRIER"
  • geebee
  • geebee
23 Sep 2026 10:54
copy from terminal :
eebee@debian:~$ ip a
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host noprefixroute
2: enp8s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP group default qlen 1000
link/ether 9c:53:22:48:4a:55 brd ff:ff:ff:ff:ff:ff
altname enx9c5322484a55
inet 10.10.10.1/24 brd 10.10.10.255 scope global noprefixroute enp8s0
inet6 2003:ca:745:4b0:8af0:56c3:81dc:59d1/64 scope global dynamic noprefixroute
valid_lft 172796sec preferred_lft 86396sec
inet6 fe80::1f98:abff:6d07:69fe/64 scope link noprefixroute
3: eno1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP group default qlen 1000
link/ether 50:46:5d:6f:50:7c brd ff:ff:ff:ff:ff:ff
altname enp0s25
altname enx50465d6f507c
4: wlp7s0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
link/ether 6a:9d:f2:44:dc:7d brd ff:ff:ff:ff:ff:ff permaddr 64:70:02:18:5d:b8
altname wlx647002185db8
geebee@debian:~$
23 Sep 2026 10:33
Replied by tommylight on topic 7i95t firmware flash
Sorry, i forgot to ask, why would you flash the 7i95T ?
23 Sep 2026 10:31
Replied by tommylight on topic Flex GUI 2.1.0 OpenGL 3.3
Category: Flex GUI
IMHO GUI's should not be included in the main repo except for Axis so as to not drag in a huge amount of dependencies for nothing.
If anyone asked me to decide what way to go, i would be very hard pressed to decide as i see benefits on both sides.
Should i elaborate?
  • muddiver
  • muddiver
23 Sep 2026 10:21 - 23 Sep 2026 10:37
Kommunikation mit Mesa 7i92 sehr instabil, Woran kann es liegen?
Category: Deutsch
Hi FOrum!
i have a Foxconn A74 Mainboard with 4GB DDR3_Ram, AMD Athlon X2 250 3Ghz.
I tried to upgrade to a graphicscard, i bought an Asus Radeon R7 240 with 2GB of DDR3 Vram.
Now my problems.. The latency overall is the same as with the onboardgraphics, bit i have massive spikes, up to 600000..
I tried:
1.  Grub "radeon.dpm=0"
no luck, LinuxCNC greets me with a Readerror.
2. Grub "radeon.si_support=0 amdgpu.si_support=1 amdgpu.dpm=0"
no luck, LinuxCNC greets me with a Readerror. I checked which driver is used, it was amdgpu, but no luck.
As far as i can tell, the version without any kerneltweaks worked the best for me.
I have 1 Core isolated for LinuxCNC, nothing fancy in grub customized.
Is there anything i can try to get the graphicscard to work properly?
Thank in advance, greets, TOm
  • hermann1976
  • hermann1976's Avatar
23 Sep 2026 10:20
Replied by hermann1976 on topic NativeCAM auf Linuxcnc 2.9
Category: Deutsch
Ich freue mich auch sehr darüber das NativCAM eine aktuelle Überarbeitung bekommt und bin allen dankbar die daran arbeiten.
Ich bin jemand der auf einer CNC umgebauten Langlochbohrmaschine Kleinigkeiten bearbeitet. Das was halt so in einer Tischlerei anfällt...
Hierzu ist NativCAM ein top Programm dafür.
So ähnlich wie WoodWop für eine Homag Maschine. Hier wird auch vieles an der Maschine programmiert.
Ich bin mir sicher, das dieses Programm künftig noch viele Möglichkeiten bietet. Ich werde mir mal die neue Version installieren und mich damit intensiver beschäftigen. Die derzeit installierte Version läuft leider etwas labil.
Danke an alle die diese Software am leben erhalten....
23 Sep 2026 10:07
board adress changed to 10.10.10.11 and ping to 10.10.10.10 gives destination host unreachable. Ping to 10.10.10.11 is successful.
Are you changing the board IP or computer IP? Board address is changed using mesaflash, and there is never any reason to do it.
Computers address should be changed depending on the Mesa jumper setting, be it for 192.168.n.n (default) or for 10.n.n.n if you change the jumper as per the manual.
I remember rumours different regions or countries might require specific ip addresses in order for this to work
That is not true, both subnets used by Mesa (10.n.n.n and 192.168.n.n) are non routable IP addresses so they do not go out of the local network, hence have nothing to do with region or localisation.
The procedure you suggest in this thread does not work for me.
It always, always works if you follow it properly, so what does PCW's advice return?
  • PCW
  • PCW's Avatar
23 Sep 2026 09:30
What does the command:
ip a
return?
  • geebee
  • geebee
23 Sep 2026 09:19
thanks, forgot to mention I already tried these hints also.
I repeated them anyway
Netmask for board connection reads 24,( I entered 255.255.255.0 )
I checked " use this connection only for resources on its network" in routes
Nothing shows in this window "Editing ipv4 routes for 7i95t" under Address. Netmask, Gateway and Metric. 7i95t is the name I gave to this connection. I did not add anything here since I have not (yet) been advised to.
For both addresses (10.10.10.10 and 10.10.10.11) mesaflash answers no board found.I am in germany. I remember rumours different regions or countries might require specific ip addresses in order for this to work
Further aid will be appreciated
thx and best regards
geebee
  • tuxcnc
  • tuxcnc
23 Sep 2026 06:36
Amston Lake / Alder Lake-N (Atom x7433RE) with IgH EtherCAT — kernel version exp
Category: EtherCAT
I don't like using backports. Never have used them.
"I don't use it" and "I don't like it" are not substantive arguments.
The problem is that there are newer versions of the libraries in the newer release. First of all, it is about Python, in which the authors constantly change or remove something, so even relatively new programs (from a year or two ago) do not want to run, or some of their functions do not work.
However, backports repositories are optional, you can activate them, install only what you need and then turn them off again.
  • geebee
  • geebee
23 Sep 2026 06:07
7i95t firmware flash was created by geebee
Hi
I do not succeed in flashing any firmware to my 7i95T mesaboard.I can ping it under adress 10.10.10.10. Its debian 13, linuxcnc should be 2.10, I replaced 2.9 to master in etc/apt/sources.list.d. and reinstalled according to post from RodW in this forum. ( I would have to look for the exact thread) Mesact lets me select 7i95t board and ip adress 10.10.10.10 in Machine. Verify board says device found at 10.10.10.10 is not a Mesa Board, not surprisingly Find IP board Results: No ETHER board found.  In terminal mesaflash (version 3.5.11) answers No 7I95T board found . Same behaviour with adress 10.10.10.1. No firmware found, I copied firmware according to instructions in window I/O Map in mesact. Thanks for any assistance
cheers geebee
  • nikitinkyiv
  • nikitinkyiv
23 Sep 2026 05:59
Tornos deco 2000/20 ROBOBAR SSF 226 how to progam barfeeder?
Category: CNC Machines
I'm working with a TORNOS-BECHLER ROBOBAR SSF automatic bar feeder mounted on a Tornos Deco 2000/20. It's a base configuration unit — no DPL/MDI operator console, so I'm limited to the front panel (SA2 mode selector, SB1–SB5 buttons, HL1/HL2 indicator lights).Looking for general input from anyone who's operated, maintained, or programmed one of these:
  • Tips, gotchas, or common issues you've run into with this feeder, the Deco 2000/20 control in general
  • Workarounds for running it without the operator console
  • Anything about parameter setup, calibration, or troubleshooting that isn't obvious from the manual
  • Sources for parts, documentation, or people who know these machines well
I've got the full manual and electrical schematics on hand, so I can share pages or details if it helps narrow things down.If anyone with real hands-on experience wants to help more in depth — a call — I'm happy to pay for the time. Just reach out.
Displaying 841 - 855 out of 11357 results.
Time to create page: 0.209 seconds
