  • Jocman
  • Jocman
21 Jan 2026 07:18
MAC address not retrieved (after 2 years stop)
Category: Driver Boards
sorry for being late in my answer, but job and family demand their time too.....This is what i get : joccnc@JocCnc:~$ sudo chrt 99 ping -i.001 -c 60000 -q 10.10.10.10
[sudo] password for joccnc:
PING 10.10.10.10 (10.10.10.10): 56 data bytes
--- 10.10.10.10 ping statistics ---
60000 packets transmitted, 60000 packets received, 0% packet loss
round-trip min/avg/max/stddev = 0.246/0.395/0.733/0.032 ms
  • TAKUYA
  • TAKUYA
21 Jan 2026 07:12
Replied by TAKUYA on topic StepperOnline A6 Servo
Category: EtherCAT
In the meantime, I was testing around with the HOME_ABSOLUTE_ENCODER = 2 setting in axis SIM. It turns out that there might be a positional accuracy issue when homing. Ive created a github Issue for it already. It seems like its reading the joint position and not the encoder position when setting the new home so on re-home, it shifts the axis location in software by your home-offset value while hardware remains the same.
21 Jan 2026 06:33
Mesa 7i96S step ausgangsignal =5V , Schrittmotortriber eingang 12V was nun?
Category: Deutsch
Der Titel dieses Threads suggeriert aber, dass du eine 7i96 nutzt. Wenn dem gar nicht so ist, bin ich bei euch.
Was soll der titel sein?
  • juliankoenig87
  • juliankoenig87
21 Jan 2026 05:11
Category: Deutsch
Selber Bauen macht meisten mehr Spaß ;-)
21 Jan 2026 04:53
Replied by tommylight on topic How to set current machine position manually?
a) How do they probably do it on my "store bought" milling machine? No need to home it. The beast knows where it is after it is powered on.
Absolute encoders.
b) Can the home position be defined in the center of the machine travel? That would make the request easy. The axis can be homed at the position that was reached and the G54 can be "touched off".
Yes, even with normal encoder or without them, must have home switches.
It will home normally at axis ends, and move to wherever you would like it to be home.
c) Can the machine be homed normally, then after disabling the motors moving it around and keep track of the position? Provided some feedback is available e.g. rotary encoder on the hand wheel, or linear encoders?
(that would allow to use the Linux similar to a normal DRO, when the motors are disabled.)
This kind of tracking without motors might be also interesting to teach a machine.
Yes, all that can be done.
Teaching should also be possible without encoders, jogging the machine to required positions and saving coordinates.
  • timo
  • timo
21 Jan 2026 04:44 - 21 Jan 2026 04:45
Just questions that come to mind (i did not do research on it)
  • my1987toyota
  • my1987toyota's Avatar
21 Jan 2026 04:23
Replied by my1987toyota on topic ARE YOU KIDDING ME YOUTUBE !!!
  The really sad part is that other countries will look at it as a template for how to do things. I have noticed
how little value most governments seem to place on their citizens. Oh they will say one thing, but what
they do is what truly matters. Just another example of George Orwell's AnimalFarm
"All animals are equal, but some animals are more equal than others"
But what do I know.
  • Studi
  • Studi's Avatar
21 Jan 2026 04:16 - 21 Jan 2026 04:17
Category: Deutsch
Danke für eure Nachrichten und Vorschläge,
hab soeben Nachricht von meinem Kumpel bekommen:
„selber bauen mach mehr Freude :-)“
Ok ich wollte nur mit meinen begrenzen Kenntnissen helfen,
bin da wo etwas zu schnell und zu weit vorgeprescht!
Bis hin wurde Schritt- und Richtungs-Signal vom Parallel Port, via selbstgebauter Karte, an die Motortreiberkarten geleitet.
Wir werden diese Schaltung übernehmen, da der Parallelport mindestens 5V ausgegeben hat.
Unschwer zu erkennen unten der Parallel Port, Rechts Analog 0-10V, per Relais Spindel ein und darüber die Referenzschalter.
Links die Anschlüsse für Takt und Richtung.
Ich werde unsere Lösung sobald sie verbaut und getestet ist hochladen. (Wenn ich darf!?)
Danke nochmals an alle Meldungen zu diesem Thema!
  • OHEngineering
  • OHEngineering's Avatar
21 Jan 2026 04:13 - 21 Jan 2026 04:35
Replied by OHEngineering on topic Kuhlmann Engraver/mill retrofit Build log
Category: Show Your Stuff
So it has been slightly more than 2 weeks, more like five or six because of reasons. But I have managed to make some progress over the holidays. The first step was obviously to clean up the entire machine, it might not have seen any serious use in a long time, if ever, but it was still in need of a serious cleaning.I started by removing all the cables and electrical parts from the machine since basically all of those will be replaced anyway.It turned into a neat little pile
After that I started cleaning the machine and even though I hadn’t really planned it I also pulled apart like 90% of the mechanics and cleaned all the parts individually.This was really necessary as I hadn’t been able to get all the plastic chips and old grease of any other way.
This included pulling apart, cleaning and re-greasing both the needle bearings for the ballscrews and the linear carriages.  As far as I can tell all this hardware is still available, the bearings  and what not, so it shouldn’t be an issue to service it if any parts give out in the future.
Just look at that before and after. Some of the balls didn’t circulate at all since the traces were so full of hardened grease, depending on the loading direction. I got all of them running again after first wiping them down with break-clean and then flushing them with penetrating oil to loosen and rinse out all the grease.I didn’t remove any of the supported rails so hopefully I haven’t caused any alignment issue. We’ll see when everything is back together, I will do a proper alignment check then.
It cleaned up real nice so I take that as a confirmation that this is a fairly low-hours machineIt’s mostly back together again and I think the next step is to work on the motor mounts. To that end I took a bunch of measurements when I had it apart to be able to manufacture some adapter plates, I will start to just 3D print them and when I have a design I like i’ll cut them on my old CNC router. It hasn't been used in a while so that will be nice.
I also have the main layout of the electrical system finished, I just have some details left as well as doing the schematics, I am planning on doing a full set of schematics for this machine, I have been wanting to try QElectro tech and I think this is a nice project for that.Cheers
  • grandixximo
  • grandixximo's Avatar
21 Jan 2026 04:09
Replied by grandixximo on topic LinuxCNC S-Curve Accelerations
The arc interpolations need some work, G1 seems pretty good, will work on arcs next, maybe not ready for testing yet...
  • sataran
  • sataran
21 Jan 2026 04:04
Bitfile or help – Mesa 6i25 + 7i74 (BiSS-C) + 8i20 + 7i70/7i87
ps i am reading tommylight post for the conf in hal file, it look promising!
  • cncfreak
  • cncfreak
21 Jan 2026 04:03
Replied by cncfreak on topic asd-a2-e ... lcec driver?
Category: EtherCAT
The *.xml file is not attached. Has 0Kb file size.
  • Mr. Mass
  • Mr. Mass's Avatar
21 Jan 2026 03:49
Replied by Mr. Mass on topic asd-a2-e ... lcec driver?
Category: EtherCAT
I'm trying to figure out how to configure delta a2-e. I did as described in this thread, and the ethercat slave command returns:
0   0:0   PREOP        ASDA-A2-E
But I still get an error and don't understand what to do. Any help would be appreciated.
File Name: ethercat-conf.xml
File Size:0 KB
File Name: linuxcnc_report.txt
File Size:6 KB
  • Hartwig
  • Hartwig
21 Jan 2026 03:46 - 21 Jan 2026 09:56
Replied by Hartwig on topic Retrofitting Deckel FP4ATC
Category: Milling Machines
The 3 axes Exe board which I have needs only 5V supplied by the MESA.. Simple connection.- signal output as required by the MESA.
Best regards
Hartwig
Displaying 8506 - 8520 out of 11472 results.
Time to create page: 2.466 seconds
