02 Dec 2025 06:10
Replied by tommylight on topic User name rpi-first-boot-wizard
Category: Installing LinuxCNC
Thanks Tommy ...
You are absolutely welcomed, always.
02 Dec 2025 06:07
Looking for freelancer to finish retrofit of K2 router
Category: User Exchange
Well, to late, but no need for any of that fuss.
We need as much info as possible for the machine, motors, drives, controllers, whatever else, and a lot of pictures of the wiring and setup.
From you picture it seems like brushed servo motors, but i can not see if they have tachos, if they do that would make them analog servo, if not then most probably position controlled with probably step/dir signals or if older with up/down control or plain quadrature.
See, to much assumptions, so more pictures.
For analog servo, you can use this howto and with a bit of time and effort have the machine tuned pretty fast:
The link above will not work for any other type of control, only analog with Mesa boards, although it works with other controllers also.
02 Dec 2025 05:58
Replied by tommylight on topic Kuhlmann Engraver/mill retrofit Build log
Category: Show Your Stuff
5 phase steppers are tough, i have plenty, i use none.
Get some cheap steppers and some really cheap drives like the TB6600 (that despite the name use TB67S109 chip inside), an old PC with a parallel port or a new-ish PC with a parallel port add on card, wire, install LinuxCNC and start making chips.
Later you can think about getting a Mesa board as it is much, much faster than parallel port, so you can use more microstepping on the drives and subsequently the machine will have less vibrations and move faster, but it is a mill so noise is not important.
02 Dec 2025 05:50
02 Dec 2025 05:46
parport observation in outport out-inverter-1 seems not to work
Category: HAL
What does "erratic behavior" mean, exactly and how does it show up?
  • rodw
  • rodw's Avatar
02 Dec 2025 04:48
Replied by rodw on topic User name rpi-first-boot-wizard
With an older 4B you may need to upgrade the firmware for things to stick when installing the image.. I had this problem.
  • PCW
  • PCW's Avatar
02 Dec 2025 03:32
Remora (SKR 1.4 RPi) – massive SPI noise, “bad payload” communication fails
Ribbon cable with every second conductor a ground terminated at one end only, of course you will need a dedicated return
I would suggest the same with the grounds connected at both ends.
Ground bumping and  ground impedance for external HF currents from external noise sources
is a real issue for high speed single ended signaling, so the more ground connections between
the RPI and the UC, the better...
  • COFHAL
  • COFHAL
02 Dec 2025 01:49
Replied by COFHAL on topic Physical buttons to 7i96s+7i77
Category: HAL
That depends on the resolution of the A/D converter. I believe the ones on the 7i43 board are 1024, regardless of the value being converted; the values ​​will range from 0 to 1024. You can check with HAL and analyze the values ​​that the A/D converters on your card are taking.
  • Z3n
  • Z3n
01 Dec 2025 23:25
Replied by Z3n on topic Red Init & Done Lights on 7i92M
Category: Driver Boards
Honestly I work in technical spaces and I’m lucky to have the means to support companies that do this kind of work, and I’m happy to pay Mesa for their cards, given how much support they offer. I will return cards for RMA, and I don’t mind having spares.
Doing this build has been much more enjoyable than I expected so I figure I’ll probably also build an CNC lathe or convert my plasmacutter to Mesa control at some point.
I appreciate the offer of a parallel card so I could boot my existing board but I’ll be able to check with the new control board that is coming and work is gonna consume me until those cards show up anyways :)
  • Punisher
  • Punisher
01 Dec 2025 22:20 - 05 Dec 2025 02:44
Remora sk1.4 with ethernet? was created by Punisher
I have a skr1.4 turbo board. Would like to use ethernet to connect it to a pc instead of using a Raspberry Pi. Did see the demo of it working. Searched through the threads here and couldn't find how to wire and configure it.
  • Steve303
  • Steve303
01 Dec 2025 22:06
Replied by Steve303 on topic 4th axis scale factor (steps per degree)
Category: PathPilot
I'm looking for a 4th Axis. Any links to a half decent quality 4th axis would be appreciated, I'm using pathpilot on a Novakon Pulsar mill so only light milling..
  • EdWorks
  • EdWorks's Avatar
01 Dec 2025 22:05
Running LinuxCNC on a Raspbery Pi5 using the Byte2Bot daughter board
I recently struggled with getting my Raspberry Pi 5 to accept the estop input. On this forum, I asked the following question.
I would like to know how to connect the GPIO to LinuxCNC’s E-Stop chain.
From this, I received some tips and advice that pointed me in the right direction, but no working answers. I used a YouTube video on installing LinuxCNC on a Raspberry Pi, but the advice was old and no longer valid. My assessment at this time is: If someone were to attempt what I attempted, I don't see a mechanism for them to follow in my footsteps because they would unlikely use the search term "estop" or "GPIO" to search the forum. So I would like to put together what I learned to make this happen.
1. Not many users of this form are using Raspberry Pi computers - they have some limitations
2. The Byte2Bot hat does not create a parallel port. Rather is isolates the GPIO pins on the computer board and brings them out using a DB25 connector that is just like the parallel port on your Mesa card or computer. This allows you to use a parallel port breakout board. While a parallel port dedicates PIN2 to a dataline, with the output from a Raspberry Pi, one needs to refer to what is the GPIO line connected to that pin which is GPIO9 in this example. In your setup, you cannot refer to PIN2; you must only refer to which GPIO line it is. When someone sends you suggestions that look like  "=> hal-gpio.PIN12.out" - it won't help you.
3. There are folks who can help you. The most valuable was the user "unkown". unknown provided this:
Below is a thread that is more or less an index for the Main RPi4/5 thread.
forum.linuxcnc.org/38-general-linuxcnc-q...l-images-only#325007
Has a section regarding GPIO and there is a working config if you follow the links.
They are there, you just have to look.
Just about everything regarding the Rpi4/5 is in this thread
forum.linuxcnc.org/9-installing-linuxcnc...official-images-only
4. The schematic offered by Byte2Bot had some notable omissions that is corrected in the Circuit3.jpg schematic from another user.
5. The eStop button should be NC (Normally Closed) - I did not correct that. The eStop button should be latching - mine is not.
6. The *.hal file has changed significantly since the requirement of using the GPIO nomenclature
7. I have yet to control the spindle speed with the breakout board.
8. The StepConfig package in LinuxCNC is not intended for a Raspberry Pi with a hat. It is designed for a MESA board setup, which this is not. I'm not aware of a reason to use it, but it does create a *.hal and *.ini file for the machine name you select in setup.
9. If you want to search Google about eStop, do not search "Linuxcnc estop". You will fail. However, if you add the word "latch" to your query, you will have success. Don't ask. If you have a ton of experience, it may make sense.
10.  When you submit a topic, hit the submit button and go have lunch. Nothing may happen for a while. I became impatient and hit submit again, and two instances of my topic were submitted. 11. How your question looks in the editor may not be how it looks online.12. I have more to learn.
SO
What do I have to promote the cause? If you use a Raspberry Pi 5 with a Byte2Bot parallel hat (it should be called a DB25 hat) with a parallel breakout board, you may have success with the following wiring and code.
  • OHEngineering
  • OHEngineering's Avatar
01 Dec 2025 21:56
Kuhlmann Engraver/mill retrofit Build log was created by OHEngineering
Hi everyone!
I'm a long time lurker but first time poster.
I've been wanting to do something with LinuxCNC for a while now probalby 8-10 years. I've built/run several 3D printers as well as a Queenbee CNC Gantry router but using GRBL and ESTL controller has been way to simple to get up and running.
Meaning I've both been lazy and haven't really seen the need for using LinuxCNC.
I did plan on replacing the ESTL controller that is running the Queenbee router but it is working way to good for me to mess with it.
However!
An opportunity arose when I found a Kuhlmann mill on auction for next to nothing, probably since the controls where both partly missing and outdated, so i got it for an absolute steal, including service fees and tax it was less than 50 Eur.
So my plan is to retrofit it with LinuxCNC, convert it from steppers to Servos, and run both IO and servos on ethercat.
I figure I will use this a s a build log, I am also planning to film most of it but I have no idea of how quickly I can get any videos out.
It has been some time since I edited any video but I think it would be fun to get back to it again.
I hope to have updates here every other week or so, depending on life.
If you have any suggestions on hardware/config or any pitfalls to avoid, give me a heads up!
The mill as it looked when I picked it up. It looks like is has mostly been used for cutting plastics, based on the debris Iv'e cleaned from it so far.
The  manufacturer as well as the original seller of the machine
The extremely outdated control system, a Berger Lahr KIM500. I have not found much info about it and all the stepper drivers are missing, the shop I got it from had several other Kuhlmann mills so my guess is this one has been scavanged for parts.
Berger Lahr was bought by Schneider Electric ages ago, before the internet was really a thing so there is not much info out there on them at all.
It was set up to use 5 phase stepper motors, and IF i had been able to find any drivers I might have used the orginal motors to save some money but no one seems to supply generic drives for 5 phase steppers.
So wish me luck and we will see when I have any more updates.
  • ArthurG
  • ArthurG
01 Dec 2025 21:27
I hired someone last year to retrofit our K2 (KG5050) router after the K2 control board was fried. The primary goal (besides replacing the control electronics) was for it to be able to run LinuxCNC. After many false starts and wrong decisions made in the components to be used, and many, many hours spent wiring and re-wiring and testing things, it turned out that this project was too much for the young man I hired. He ultimately gave up after he failed to figure out the tuning of the servos/axes.
I have a computer programming background but I know very little about the world of electrical engineering and am hoping to find someone who can finish off the project - which according to the young man I hired, is just the tuning of the motors/axes, but which I suspect might require a bit more.
Ideally, I'd like to find someone local (we're based in Ventura, CA) but the control PC *is* setup with remote desktop access and a webcam on the table, so if you're confident you could do it remotely, with me on hand to E-stop/reset the machine as needed, I'd be okay with that option.
  • Muzzer
  • Muzzer
01 Dec 2025 21:22
Updating from LINUXCNC - 2.8.4-23, Mint 20.3 - gmoccapy lathe structure
Category: Gmoccapy
I have to admit that Linuxcnc is the only application I have that requires Linux. Like Andy, my engineering job requires almost exclusively Windows based programs, as do my family, for whom I appear to be IT manager.
@andypugh - could you suggest why your macros aren't showing up in my gmoccapy GUI? I've got no errors showing but clicking on the "cycles" tab doesn't change from the XZ preview.
File Name: combined_2...2-01.ini
File Size:7 KB
File Name: combined_2...2-01.hal
File Size:10 KB
Displaying 10111 - 10125 out of 12711 results.
Time to create page: 0.675 seconds
