  • Hakan
  • Hakan
23 Nov 2025 17:56
QtPlasmaC make the top row slightly taller?
Category: Plasmac
How can I increase the height of the top row of QtPlasmaC?
There is a bad combination of thick fingers and the touch screen and its frame that makes it quite tricky to touch the top row items.
I have a 1920x1080 monitor and have changed resolution to 1368x717 to make the items as large as possible.
Is there an easy way to make the row say 5 pixels taller? I think that would do, it's not much that's needed.
  • PCW
  • PCW's Avatar
23 Nov 2025 17:49
Replied by PCW on topic MESA to AD5362
MESA to AD5362
Category: Driver Boards
There is an example driver using the BSPI interface to A-D and D-A chips: 7i65.comp
This could be used as a guide to writing a AD5362 driver.
  • Hakan
  • Hakan
23 Nov 2025 17:47
Replied by Hakan on topic First Tests with ethercat
Category: EtherCAT
Unbalanced """s
should be idx="0", not idx=0"
  • Hakan
  • Hakan
23 Nov 2025 17:44
Replied by Hakan on topic StepperOnline A6 Servo
Category: EtherCAT
It's this parameter
setp cia402.0.pos-scale 3600
Normally set it in the hal file.
The  unit is encoder increments/measurement unit.
  • Lpkkk
  • Lpkkk
23 Nov 2025 17:41
Replied by Lpkkk on topic Huanyang FC01 modbus
Based on modbus specification in this inverter manual I wrote a python program to steer vfd. Things so far I did (maybe useful for someone) :
1)connect Huanyang FC01 to 485-usb and then to rpi4 with linuxcnc
2)set jumper 4 to On on vfd to enable communication
3)program vfd:
P00.01 = 2
P00.06 = 8
P00.07 = 1
P00.09 = 0
P14.00 = 1
P14.01 = 3
P14.02 = 0
4)start my vfd_monitor
After those steps I was able to connect successfully and drive my spindle.
Next step will be to integrate it somehow with linuxcnc
  • kor
  • kor
23 Nov 2025 17:30
Replied by kor on topic First Tests with ethercat
Category: EtherCAT
the linebreak was a copy paste error. still same error message
 file information:
Note: Using POSIX realtime
lcec_conf: ERROR: Parse error at line 4: not well-formed (invalid token)
./ethercat.hal:2: waitpid failed lcec_conf lcec_conf
./ethercat.hal:2: lcec_conf exited without becoming ready
9917
Stopping realtime threads
Unloading hal components
  • Aciera
  • Aciera's Avatar
23 Nov 2025 17:27 - 23 Nov 2025 17:28
calling subroutine from G54, G55, G56, but it acts weird
Category: O Codes (subroutines) and NGCGUI
If I touch off X0 Y0 Z0 in G54, and then instead do, as the below program shows, G10 L20 P2 X-30 Y0 Z3, it runs perfectly.
touching off in G54 will actually run 'g10 l20 p1 z0' which will set the z-offset value in G54 such that the axis position is equal to zero. This is the value you would need in the other offset systems as well. Which I guess is 3.
  • jakap
  • jakap
23 Nov 2025 17:19 - 23 Nov 2025 17:41
MESA to AD5362 was created by jakap
MESA to AD5362
Dear all,
I would like to interface custom hardware with AD5362 (8ch DAC), via SPI interface. Would that be possible and what would be the easiest to hook this up?
I see BSPI and SSI interface is available in HM2, but do not understand whether they support custom SPI protocols.
How is this done in 7i77 and can one adapt it for custom hardware?
Thank you!
jakap
  • unknown
  • unknown
23 Nov 2025 16:22
Updating from LINUXCNC - 2.8.4-23, Mint 20.3 - gmoccapy lathe structure
Category: Gmoccapy
On the lower panel one of the icons is search, although it maybe just be an application search, either way it's quite easy to customise, right clicking on a panel allows you to add, delete or modify icons.
  • onceloved
  • onceloved's Avatar
23 Nov 2025 16:11
Replied by onceloved on topic First Tests with ethercat
Category: EtherCAT
# EtherCat
loadusr -W lcec_conf /home/bf20/linuxcnc/configs/sim.axis/ethercat-conf.xml
loadrt lcec
add lcec.read-all servo-thread
add lcec.write-all servo-thread
net mon halui.machine.on lcec.0.EL1014.din-2
net mon halui.machine.off lcec.0.EL1014.din-3
  • NT4Boy
  • NT4Boy
23 Nov 2025 16:02
Replied by NT4Boy on topic HURCO KMB-1 Control Update
Category: Milling Machines
My thought of testing the system with an Orient command, I understand now was very naïve.
From others examples, introducing this ability requires pretty much a total tear up of the whole spindle control setup, and a need to get into the ladder world not just a reroute of the enable signal, and that's a move way too far way from any comfort zone for me.
Ducking this piece of implementation brings me much relief.
Thanks for your effort to help.
  • PCW
  • PCW's Avatar
23 Nov 2025 15:45
Replied by PCW on topic Chinese Mesa 7I92 from aliexpress NEW
Changing the IRQ coalesce settings does improve the ping times noticeably on Intel hardware,
but your 4-5 ms  peak ping time indicates other issues, likely related to power management.
My system with Intel MAC and default IRQ coalesce settings:
PING 10.10.10.10 (10.10.10.10) 56(84) bytes of data.
64 bytes from 10.10.10.10: icmp_seq=1 ttl=64 time=0.316 ms
64 bytes from 10.10.10.10: icmp_seq=2 ttl=64 time=0.250 ms
64 bytes from 10.10.10.10: icmp_seq=3 ttl=64 time=0.251 ms
64 bytes from 10.10.10.10: icmp_seq=4 ttl=64 time=0.250 ms
Same system with IRQ coalecing off:
64 bytes from 10.10.10.10: icmp_seq=1 ttl=64 time=0.116 ms
64 bytes from 10.10.10.10: icmp_seq=2 ttl=64 time=0.106 ms
64 bytes from 10.10.10.10: icmp_seq=3 ttl=64 time=0.107 ms
64 bytes from 10.10.10.10: icmp_seq=4 ttl=64 time=0.106 ms
Have you disabled all power management in the system BIOS and grub?
Have you set isolcpus to the last CPU in the grub file?
Do you have idle=poll in the grub file as well?
(These are basic latency reducing steps for any LinuxCNC host)
linuxcnc.org/docs/html/install/latency-test.html
  • kor
  • kor
23 Nov 2025 15:36
First Tests with ethercat was created by kor
Category: EtherCAT
I finally insalled my ethercat master. and when running "ethercat slaves"
I see my beckhoff devices:
bf20@bf20:~$ ethercat slaves
0  0:0  PREOP  +  EK1100 EtherCAT-Koppler (2A E-Bus)
1  0:1  PREOP  +  EL1014 4K. Dig. Eingang 24V, 10�s
2  0:2  PREOP  +  EL2004 4K. Dig. Ausgang 24V, 0.5A
3  0:3  PREOP  +  EL3102 2K. Ana. Eingang +/-10V, Diff.
So next I created a standard axis-sym conf
I modified the axis.ini by adding a new halfile:
HALFILE = ethercat.hal
This is my ethercat.hal:
# EtherCat
loadrt lcec add lcec.read-all servo-thread
and here is my xml file:
<masters>
    <master idx="0" appTimePeriod="1000000" refClockSyncCycles="1">
        <slave idx=0" type="EK1100" name="EK1100"/>
        <slave idx=1" type="EL1014" name="EL1014"/>
        <slave idx=2" type="EL2004" name="EL2004"/>
        <slave idx=3" type="EL3102" name="EL3102"/>
    </master>
</masters>
when starting linuxcnc I get this error message:
./ethercat.hal:3: waitpid failed lcec_conf lcec_conf
./ethercat.hal:3: lcec_conf exited without becoming ready
6791
which does not really help me to figure out what is wrong. My guess is that I did something wrong in the xml, but I can not figure out what.
Thanks for your help.
  • andrax
  • andrax's Avatar
23 Nov 2025 14:32
Replied by andrax on topic StepperOnline A6 Servo
Category: EtherCAT
I am also working with the A6 servos.
I purchased the Stepperonline 750W sto for testing purposes. I got everything up and running without any problems.
But I have a few questions:
How can I adjust the electronic gear?
Is there a function in the .ini file or do I have to set this in the servo driver?
My axis has a pitch of 50:1 and the gearbox in front of it is 6:1.
Which signals are used in the cia402_homecomp?
Are the home switch and the Z-index of the servo used here, or just the home switch
Displaying 10501 - 10515 out of 12725 results.
Time to create page: 1.532 seconds
