  • jjdege
  • jjdege's Avatar
05 Sep 2026 02:37
Replied by jjdege on topic XML Settings for EC1-57E
Category: EtherCAT
in the XML file you posted, the vendor ID (VID) is 0x00400000, while the EC1-57E manual says 0xAB5 or 00000AB5.
That could be the problem.
Hi
  • ianlowe
  • ianlowe
05 Sep 2026 00:52
  • spumco
  • spumco
04 Sep 2026 23:50
Replied by spumco on topic Clogged spindle cooling curcuit TIP
I would strongly recommend against deionized (DI) water in any cooling system where you don't have the exact specifications of all materials in the loop (i.e. an off-the-shelf spindle cooling system).
DI water can be extremely corrosive to certain metals, plastics, and rubbers, especially at elevated temperatures.  I suspect most of the major components would be unaffected, but you can't verify what the MOC is for everything you can't see:
  • o-rings & seals
  • adhesives
  • solder/braze
  • hose & pump internal materials
  • internal coatings in spindle
My recommendation is to use distilled water, not deionized.  Distilled will achieve the objective of eliminating tap water mineral deposits, but without the risk of some system component you can't see or control being corroded.
(distant) 2nd choice would be reverse osmosis (RO) water.  RO water is corrosive to certain metals, but should be ok (ish) with most polymers.
Don't take my word for it - a simple search for "DI water corrosion" should result in a trove of chemical compatibility charts.
  • rodw
  • rodw's Avatar
04 Sep 2026 21:34
Replied by rodw on topic External ESTOP trouble
Category: Installing LinuxCNC
There are a number of applicable standards. I am no expert on them. Aside from local country specific standards like AS4024 here in Australia, International standards include ISO 13850, IEC 60204-1 and IEC 60947-5-5
on a home machine, often a 2 pole estop button is used. one pole cuts mains power to spindle and stepper motors and the other is low voltage circuit wired to linuxcnc to tell the controller estop has been pressed. But this does not safely bring heavy machines to a stop so it gets more complicated. Also its not helpful if you have the control panel at one end of a plasma table and you want to place an estop at the other end where the console is. One approach might be to run a pull rope right around the table but running mains power to another distant switch clearly adds its own safety risks.
I suspect estop-latch predates the standards but it does allow you to create an estop chain in software. It is somewhat complicated to understand initially and I find its best to draw it on paper as a series of boxes (one for each estop-latch) each of these boxes has an OK-out pin which needs to connect to the reset pin on the next in the chain with the last OK-out connected to iocontrol.emc-enable
Each latch will have either a fault-in or ok-in pin attached to the estop button or door latch or whatever that needs to be safe before the machine will start. Finally, the iocontrol.user-request-enable pin is attached to the reset pin on the very first latch. So when the user requests the machine to be enabled (usually the orange button in axis), a short pulse is sent to the first reset and if all faults are clear, the sigal to start the machine arrives at linuxcnc. The beauty of this approach is that you can just as easily use a momentary push button to act as that reset signal if you wish.
Taking that into the standards says the controller can have no part in the safety circuit, and every sub-circuit and every contactor needs to have  dual redundancy so a fault will not trigger anything and both circuits need to work before something's enabled. Also if there is a power outage, the machine cannot become live again when power is restored. You need to press that reset button. Also every contactor and every relay needs to be a force guided one where a non conducting pin is forced between relay contacts to guard against them welding closed from an arc.. Aside from that the safety circuit or safety relay does the same thing as estop-latch. It won't enable the machine until every component being monitored is safe.
  • trackwhack
  • trackwhack
04 Sep 2026 20:32 - 09 Sep 2026 23:10
Replied by trackwhack on topic Perpetual License CAM
Category: Show Your Stuff
Claude helped a lot. But if you check it out, you would know that it was built by humans for humans.
  • spumco
  • spumco
04 Sep 2026 20:17
(Solved) Probe Basic - HAL pins not being created
Category: QtPyVCP
UPDATE
It wasn't me.
I ran the issue through Claude and the overlord reported back that the sidebar tab .py file had (I think) an indeterminate layout which was conflicting with the main UI file.  No error messages, but wasn't loading.
I've attached a Claude-generated document describing the issue and the suggested fix.  I've tested the fixed .py file and it's working fine.
Lcvette - might want to have a look and see if you're interested in editing PB as suggested.
04 Sep 2026 20:11
Replied by tommylight on topic Perpetual License CAM
How much of it was written with AI?
+1
Personally i do not like whatever this AI thing is called, it is an LLM and should be called as such as it has nothing to do with any kind of intelligence.
But, i do like it for some things, mainly being tired of very, very bad "Software engineers" and "Graphical Designers", and hate it as humans will misuse everything so we are inundated with slop everywhere.
I did use it to do some Python programing, and given the right direction it does produce usable code, but absolutely does not produce "production" level code without being heavily guided, and needs constant monitoring and checking as it messes up a lot.
04 Sep 2026 20:00
Replied by tommylight on topic External ESTOP trouble
# --- ESTOP-OUT ---
net estop-out  =>     hm2_7i96s.0.ssr.00.out-00
setp hm2_7i96s.0.ssr.00.invert-00 true# --- ESTOP-EXT ---
net estop-ext     <=  hm2_7i96s.0.inm.00.input-03#  ---estop signals---
net estop-out     <=  iocontrol.0.user-enable-out
net estop-ext     =>  iocontrol.0.emc-enable-in
Omit the first line by adding # in front of it.
  • Billy Boy
  • Billy Boy
04 Sep 2026 19:33
Replied by Billy Boy on topic External ESTOP trouble
Gosh... I didn't mean to open a can of worms!
Thank you very much tommylight for your suggested fix. Unfortunately when I add this line to my hal file, linuxcnc fails with the following...
"./Bridgeport.hal:313: Pin 'hm2_7i96s.0.ssr.00.out-00' was already linked to signal 'estop-out'"
(aside: line 313 is where I added tommylight's line)
I have been reading up on the HAL interface, and I have to admit that I am still quite confused. about how these things are intended to work? It is clear that they do, and for that I am thankful. It is just very hard for a newbie such as myself to make sense of.
Rod,
I appreciate all of your helpful literature and the videos you have made on various linuxcnc topics.
When you say "Its pretty well described in the man page and there was a hal tutorial about it on the forum." it would be *super* helpful if you would link the articles/threads you are referencing. Otherwise I really have no way of knowing which particular man page or forum thread you are referring to. There are a number of forum threads which seem to fit your description and which also appear to contradict one another?
I wonder if you are referencing the estop-latch man page? If so, I have read it, and I do not feel that the man page does a very good job of describing estop-latch at all! It does not explain estop-latch's purpose, when it should be used and when it should not. Further, it does not provide any usage examples. The man page does describe the options, and I expect it does so completely, but it does not explain any of them. I found it quite cryptic actually. I am still entirely confused about what problem estop-latch is intended to solve.
I understand there is some debate about whether having the hard estop signal run through linuxCNC is "compliant" or not. I must admit that I am completely in the dark as to what standard we are complying with, so I have no opinion. While I do care about safety, compliance is not a issue for me right now in my home shop.
All I am trying to achieve here is to have "hm2_7i96s.0.ssr.00.out-00" go high when "hm2_7i96s.0.inm.00.input-03" goes low.
Seems like it ought to be simple... but there is clearly some piece of the larger picture that I am missing, because it is appears that it is not simple?
Thank you for your help.
Bill
  • snowgoer540
  • snowgoer540's Avatar
04 Sep 2026 16:34
Replied by snowgoer540 on topic Perpetual License CAM
  • Routerworks
  • Routerworks
04 Sep 2026 14:55
Replied by Routerworks on topic Clogged spindle cooling curcuit TIP
Quite right. A 25% antifreeze solution is probably a good approach but I would suspect there is just so much chelating ability for that dilute a solution. Compound that with the likelyhood most people are going to replenish it with tap water, there in lies the big mistake.
Again your quite right. I guess my real focus was to give others a heads up on a possible fix without tearing it appart.
  • Todd Zuercher
  • Todd Zuercher's Avatar
04 Sep 2026 14:18
Replied by Todd Zuercher on topic Clogged spindle cooling curcuit TIP
Most of the spindle manufacturers I've delt with recommend a 25% solution of some kind of antifreeze. Not so much to prevent freezing but for the additives for corrosion inhibition and pump seal lubrication that are included with them. While most don't specify an automotive product, they generally are not much different from standard car antifreeze. (Using straight tap water in most kinds of cooling systems is asking for trouble.)
  • PCW
  • PCW's Avatar
04 Sep 2026 13:39
  • phino
  • phino
04 Sep 2026 12:29
Replied by phino on topic Perpetual License CAM
While I focus on open source software, I'm at least glad to see a one-time payment perpetual license at a reasonable price (no subscriptions!) and linux support (even if it is AppImage..).
Good luck.
  • ianlowe
  • ianlowe
04 Sep 2026 12:19
Custom bit file request: 7i76e + 7i78 (P1) + 7i89 (P2)
Hi Peter / Mesa Support,
I am setting up a machine using a 7i76e and I need a custom bitfile for my expansion board configuration.
My hardware layout is as follows:
  • Motherboard: 7i76e
  • Expansion Port P1: 7i78 (Step/Dir expansion)
  • Expansion Port P2: 7i89 (Multi-channel encoder board)
Could you please generate a pre-built
.bit
file (and corresponding
.pin
file) for this specific configuration?
Thank you for your help!
Displaying 1216 - 1230 out of 11458 results.
Time to create page: 1.150 seconds
