- Nikolaj9
- Nikolaj9
23 Aug 2025 10:15
Replied by Nikolaj9 on topic QtDragon feature request go_to_zero
Category: Qtvcp
I know this thread is a bit old, but I think it’s the right place to ask.
I would like to make a custom MDI button (for example, a "GotoMachZero" button) that changes its outline to green – maybe even shows a green LED – when the button is active, similar to how the MAN, MDI, and AUTO buttons behave when they are selected.
So basically: When I press the "GotoMachZero" button, it should highlight (e.g. green border or LED) and stay like that until the motion is completed.
Is it possible to do this in QtDragon? And if so, how can I implement it?Thanks in advance!
23 Aug 2025 09:36
Replied by andypugh on topic Absoluted Encoder but Move the G53 Origin
Category: Basic Configuration
If you want to make this “stick” through upgrades then note that you can define your own custom homing module. ((This may be what you did)
linuxcnc.org/docs/html/man/man9/homecomp.9.html
- jjdege
23 Aug 2025 08:26
Replied by jjdege on topic Debian Trixie upgrade/install to 2.9.4
Category: Installing LinuxCNC
Thanks Rodw
I use EtherCAT, so I'm worried!
Is there a chance that etherlabmaster will decide not to update the certificates?
If so, what's the best course of action?
- hitchhiker
- hitchhiker
23 Aug 2025 08:24 - 23 Aug 2025 11:02
Replied by hitchhiker on topic Homing with 2 inputs/sensors?
Category: HAL
ahhhhaaaaa...
i think i got the firmware fixed on my table/labor mesa 7i92....
to explain:
I have everytime i configurate a new machine or want to try something a mesa 7i92 for learning on my table...
i load the firmware file for the 7i96 and look into it and found the example where index on a stepgen was attached.
Download:
link to the 7i96 firmware files
then extract and look for:
PIN_7I96_StepIDXD_51.vhd
then i saw in the file:
(StepGenTag, x"C2", ClockLowTag, x"04", StepGenRateAddr&PadT, StepGenNumRegs, x"00", StepGenMPBitMask),
bingo!
i add the stuff to my 7i92 bitfile...
and tada after flash i saw this in my terminal output:
this is how it must look, right?
thanks
to explain:
Download:
bingo!
library IEEE;
use IEEE.std_logic_1164.all; -- defines std_logic types
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
-- Copyright (C) 2007, Peter C. Wallace, Mesa Electronics
-- http://www.mesanet.com
-- This program is is licensed under a disjunctive dual license giving you
-- the choice of one of the two following sets of free software/open source
-- licensing terms:
-- * GNU General Public License (GPL), version 2.0 or later
-- * 3-clause BSD License
-- The GNU GPL License:
-- This program is free software; you can redistribute it and/or modify
-- it under the terms of the GNU General Public License as published by
-- the Free Software Foundation; either version 2 of the License, or
-- (at your option) any later version.
-- This program is distributed in the hope that it will be useful,
-- but WITHOUT ANY WARRANTY; without even the implied warranty of
-- MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
-- GNU General Public License for more details.
-- You should have received a copy of the GNU General Public License
-- along with this program; if not, write to the Free Software
-- Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA
-- The 3-clause BSD License:
-- Redistribution and use in source and binary forms, with or without
-- modification, are permitted provided that the following conditions
-- are met:
-- * Redistributions of source code must retain the above copyright
-- notice, this list of conditions and the following disclaimer.
-- * Redistributions in binary form must reproduce the above
-- copyright notice, this list of conditions and the following
-- disclaimer in the documentation and/or other materials
-- provided with the distribution.
-- * Neither the name of Mesa Electronics nor the names of its
-- contributors may be used to endorse or promote products
-- derived from this software without specific prior written
-- permission.
-- Disclaimer:
-- THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
-- "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
-- LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS
-- FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE
-- COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT,
-- INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING,
-- BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
-- LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER
-- CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
-- LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN
-- ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
-- POSSIBILITY OF SUCH DAMAGE.
use work.IDROMConst.all;
package PIN_VMC100 is
constant ModuleID : ModuleIDType :=(
(HM2DPLLTag, x"00", ClockLowTag, x"01", HM2DPLLBaseRateAddr&PadT, HM2DPLLNumRegs, x"00", HM2DPLLMPBitMask),
(WatchDogTag, x"00", ClockLowTag, x"01", WatchDogTimeAddr&PadT, WatchDogNumRegs, x"00", WatchDogMPBitMask),
(IOPortTag, x"00", ClockLowTag, x"02", PortAddr&PadT, IOPortNumRegs, x"00", IOPortMPBitMask),
(QcountTag, x"02", ClockLowTag, x"01", QcounterAddr&PadT, QCounterNumRegs, x"00", QCounterMPBitMask),
(PWMTag, x"00", ClockHighTag, x"00", PWMValAddr&PadT, PWMNumRegs, x"00", PWMMPBitMask),
(LEDTag, x"00", ClockLowTag, x"01", LEDAddr&PadT, LEDNumRegs, x"00", LEDMPBitMask),
(NullTag, x"00", NullTag, x"00", NullAddr&PadT, x"00", x"00", x"00000000"),
constant PinDesc : PinDescType :=(
-- Base func sec unit sec func sec pin -- 26 HDR -- IDC DB25
IOPortTag & x"00" & StepGenTag & StepGenIndexPin, -- I/O 00 PIN 1 PIN 1 just GPIO
IOPortTag & x"01" & StepGenTag & StepGenIndexPin, -- I/O 01 PIN 2 PIN 14 just GPIO
IOPortTag & x"02" & StepGenTag & StepGenIndexPin, -- I/O 02 PIN 3 PIN 2 just GPIO
IOPortTag & x"00" & NullTag & NullPin, -- I/O 03 PIN 4 PIN 15 just GPIO
IOPortTag & x"00" & NullTag & NullPin, -- I/O 04 PIN 5 PIN 3 just GPIO
IOPortTag & x"00" & NullTag & NullPin, -- I/O 05 PIN 6 PIN 16 just GPIO
IOPortTag & x"00" & NullTag & NullPin, -- I/O 06 PIN 7 PIN 4 just GPIO
IOPortTag & x"00" & NullTag & NullPin, -- I/O 07 PIN 8 PIN 17 just GPIO
IOPortTag & x"00" & NullTag & NullPin, -- I/O 08 PIN 9 PIN 5 just GPIO
IOPortTag & x"00" & NullTag & NullPin, -- I/O 09 PIN 11 PIN 6 just GPIO
IOPortTag & x"00" & NullTag & NullPin, -- I/O 10 PIN 13 PIN 7 just GPIO
IOPortTag & x"00" & NullTag & NullPin, -- I/O 11 PIN 15 PIN 8 just GPIO
IOPortTag & x"00" & NullTag & NullPin, -- I/O 12 PIN 17 PIN 9 just GPIO
IOPortTag & x"00" & NullTag & NullPin, -- I/O 13 PIN 19 PIN 10 just GPIO
IOPortTag & x"00" & NullTag & NullPin, -- I/O 14 PIN 21 PIN 11 just GPIO
IOPortTag & x"00" & NullTag & NullPin, -- I/O 15 PIN 23 PIN 12 just GPIO
IOPortTag & x"00" & NullTag & NullPin, -- I/O 16 PIN 25 PIN 13 just GPIO
IOPortTag & x"00" & NullTag & NullPin, -- I/O 17 PIN 1 PIN 1 just GPIO
IOPortTag & x"00" & NullTag & NullPin, -- I/O 18 PIN 2 PIN 14 just GPIO
IOPortTag & x"00" & StepGenTag & StepGenStepPin, -- I/O 19 PIN 3 PIN 2 X Step
IOPortTag & x"00" & NullTag & NullPin, -- I/O 20 PIN 4 PIN 15 just GPIO
IOPortTag & x"00" & StepGenTag & StepGenDirPin, -- I/O 21 PIN 5 PIN 3 X Dir
IOPortTag & x"00" & NullTag & NullPin, -- I/O 22 PIN 6 PIN 16 just GPIO
IOPortTag & x"01" & StepGenTag & StepGenStepPin, -- I/O 23 PIN 7 PIN 4 Y Step
IOPortTag & x"00" & NullTag & NullPin, -- I/O 24 PIN 8 PIN 17 just GPIO
IOPortTag & x"01" & StepGenTag & StepGenDirPin, -- I/O 25 PIN 9 PIN 5 Y Dir
IOPortTag & x"02" & StepGenTag & StepGenStepPin, -- I/O 26 PIN 11 PIN 6 Z Step
IOPortTag & x"02" & StepGenTag & StepGenDirPin, -- I/O 27 PIN 13 PIN 7 Z Dir
IOPortTag & x"00" & NullTag & NullPin, -- I/O 28 PIN 15 PIN 8 Spindle on/off
IOPortTag & x"03" & StepGenTag & StepGenStepPin, -- I/O 29 PIN 17 PIN 9 Spindle Step
IOPortTag & x"03" & StepGenTag & StepGenDirPin, -- I/O 30 PIN 19 PIN 10 Spindle Dir
IOPortTag & x"00" & QCountTag & QCountIdxPin, -- I/O 31 PIN 21 PIN 11 (Encoder Quad Idx)
IOPortTag & x"00" & QCountTag & QCountQAPin, -- I/O 32 PIN 23 PIN 12 (Encoder Quad A)
IOPortTag & x"00" & QCountTag & QCountQBPin, -- I/O 33 PIN 25 PIN 13 (Encoder Quad B)
emptypin,emptypin,emptypin,emptypin,emptypin,emptypin,emptypin,emptypin, -- added for 34 pin 5I25
emptypin,emptypin,emptypin,emptypin,emptypin,emptypin,emptypin,emptypin, -- added for IDROM v3
emptypin,emptypin,emptypin,emptypin,emptypin,emptypin,emptypin,emptypin);
end package PIN_VMC100;Configuration Name: HOSTMOT2
BoardName : MESA7I92
FPGA Size: 20 KGates
FPGA Pins: 256
Number of IO Ports: 2
Width of one I/O port: 17
Clock Low frequency: 100.0000 MHz
Clock High frequency: 175.0000 MHz
IDROM Type: 3
Instance Stride 0: 4
Instance Stride 1: 64
Register Stride 0: 256
Register Stride 1: 256
Modules in configuration:
Module: DPLL
There are 1 of DPLL in configuration
Version: 0
Registers: 7
BaseAddress: 7000
ClockFrequency: 100.000 MHz
Register Stride: 256 bytes
Instance Stride: 4 bytes
Module: WatchDog
There are 1 of WatchDog in configuration
Version: 0
Registers: 3
BaseAddress: 0C00
Module: IOPort
There are 2 of IOPort in configuration
Version: 0
Registers: 5
BaseAddress: 1000
Module: QCount
There are 1 of QCount in configuration
Version: 2
Registers: 5
BaseAddress: 3000
Module: StepGen
There are 4 of StepGen in configuration
Version: 194
Registers: 10
BaseAddress: 2000
Module: PWM
There are 0 of PWM in configuration
Version: 0
Registers: 5
BaseAddress: 4100
ClockFrequency: 175.000 MHz
Module: LED
There are 1 of LED in configuration
Version: 0
Registers: 1
BaseAddress: 0200
Configuration pin-out:
IO Connections for P2
DB25 pin# I/O Pri. func Sec. func Chan Sec. Pin func Sec. Pin Dir
1 0 IOPort StepGen 0 Index (In)
14 1 IOPort StepGen 1 Index (In)
2 2 IOPort StepGen 2 Index (In)
15 3 IOPort None
3 4 IOPort None
16 5 IOPort None
4 6 IOPort None
17 7 IOPort None
5 8 IOPort None
6 9 IOPort None
7 10 IOPort None
8 11 IOPort None
9 12 IOPort None
10 13 IOPort None
11 14 IOPort None
12 15 IOPort None
13 16 IOPort None
IO Connections for P1
1 17 IOPort None
14 18 IOPort None
2 19 IOPort StepGen 0 Step/Table1 (Out)
15 20 IOPort None
3 21 IOPort StepGen 0 Dir/Table2 (Out)
16 22 IOPort None
4 23 IOPort StepGen 1 Step/Table1 (Out)
17 24 IOPort None
5 25 IOPort StepGen 1 Dir/Table2 (Out)
6 26 IOPort StepGen 2 Step/Table1 (Out)
7 27 IOPort StepGen 2 Dir/Table2 (Out)
8 28 IOPort None
9 29 IOPort StepGen 3 Step/Table1 (Out)
10 30 IOPort StepGen 3 Dir/Table2 (Out)
11 31 IOPort QCount 0 Quad-IDX (In)
12 32 IOPort QCount 0 Quad-A (In)
13 33 IOPort QCount 0 Quad-B (In)this is how it must look, right?
thanks
23 Aug 2025 07:49
Replied by rodw on topic Debian Trixie upgrade/install to 2.9.4
Great feedback. Nothing to worry about. The etherlabmaster's certificate in their repository only has a life of 2 years. If you are not using ethercat, there is nothing to worry about. It is outside of our control.
- jjdege
23 Aug 2025 07:03
Good morning,
I followed Rodw's instructions (thanks, Rodw), and upgraded from Bookworm to Trixie.
I can say that everything is fine. I only had two problems:
Several packages weren't installing automatically; they were always in the update list.
I installed them manually and solved the problem.
The Network Manager GUI in the top-right panel wouldn't start, and it was impossible to manage the network
with a graphical interface.
I solved the problem by searching online.
The thing that worries me is the warning that appears after I update from the terminal.
What does this warning mean?
- hitchhiker
- hitchhiker
23 Aug 2025 06:56 - 23 Aug 2025 07:16
Category: HAL
Hi
If i understand correct... i must change the firmware on my 7i92?
I need to add encoder to the bitfile.. but only the index? So it must be a index that is coming from the stepgen.. i only know how to add stepgen with step and dir to the bitfile..
I run the stepgen in position mode ..not velocity..
So instead what i try with the gpio i need a index pin in the bitfile which is linked to the stepgen, right?
Sorry i am a little bit confused and doesnt understand it.. i use linuxcnc 2.9 and a mesa 7i92. Changing the bitfile/firmware is not a problem. But i look everytime to existing files and copy from them... and i cant find a documentation about it...
it should be look like:
IOPortTag & x"NN" & StepGenTag & StepGenIndexPin, "
but i never saw something like this...
thanks
thanks
- pippin88
- pippin88
23 Aug 2025 04:28
Replied by pippin88 on topic Set program zero using XY positioning laser
Please post your full config files
- MikkelRS
23 Aug 2025 01:21
Replied by MikkelRS on topic For Those Who Have to Use Windows
Remember that first 64 bit desktop OS... BeOS?
If you ever ran that for a bit, incomplete was its epitaph haha.
23 Aug 2025 01:10
Replied by Todd Zuercher on topic Displaying Active Work Coordinate System
Category: GladeVCP
I had noticed that just after I posted it, but I thought I tried uncommenting it and it I didn't think it seemed to make any difference. (Error messages were still the same and the Label didn't change.)
But I thought I had better test again before posting a reply. I loaded up a 2.7 Wheezy live cd image in a VM and ran a simulation with this GladeVCP files (and that line uncommented, and it works! I don't know maybe I forgot to save after uncommenting that line earlier today. But I'll have to wait until Monday to try it out on the real machine at work.
Thanks alot for your help.
PS any ideas on these other "error" messages that show up in the terminal but with no noticeable effect on functionality.
File "/usr/lib/pymodules/python2.7/gladevcp/hal_actions.py", line 99, in _f
return f(self, *a, **kw)
File "/usr/lib/pymodules/python2.7/gladevcp/hal_actions.py", line 461, in on_activate
ensure_mode(self.stat, self.linuxcnc, linuxcnc.MODE_MDI)
AttributeError: 'EMC_Action_MDI' object has no attribute 'stat'
ensure_mode(self.stat, self.linuxcnc, linuxcnc.MODE_MDI)- tommylight
23 Aug 2025 00:14
Replied by tommylight on topic Türkçe
Türkçe
Category: Other Languages
Sorry for the late reply, but i was waiting for someone else to reply as i am not sure if i can create a new section or not.
In the mean time, start a new topic here in Tyrkqe ? (is that correct) or rename this one and we will move or delete stuff around as needed.
22 Aug 2025 21:57
Replied by cmorley on topic Displaying Active Work Coordinate System
Category: GladeVCP
You have commented out the line that defines self.stat:
class HandlerClass:
def __init__(self, halcomp,builder,useropts):
self.builder = builder
self.halcomp = halcomp
# self.stat = linuxcnc.stat()- PCW
22 Aug 2025 19:47
Replied by PCW on topic Stop feed when spindle rpm lower
Category: AXIS
That's simpler than my solution using adaptive feed.
22 Aug 2025 19:16 - 22 Aug 2025 19:23
NativeCam has always output gcode in parametric form because it uses subroutines for it's operations (ie the output does not look like what you would expect on a regular 'CAM'). SO there may actually be nothing wrong with that output (except of course that it would need to be formatted properly)
Replied by Aciera on topic Nativecam running on 2.9.4 almost so close
Category: NativeCAM
if I try exporting the project as gcode the .ngc file is mostly composed of stuff that looks like this:NativeCam has always output gcode in parametric form because it uses subroutines for it's operations (ie the output does not look like what you would expect on a regular 'CAM'). SO there may actually be nothing wrong with that output (except of course that it would need to be formatted properly)
- Henk
- Henk
22 Aug 2025 18:56
Replied by Henk on topic Stop feed when spindle rpm lower
Category: AXIS
I always impliment the following on my retrofits.
set up a spindle-at-speed signal in the usual way using encoder feedback and a near component.
invert it using a not component to set up a spindle-not-at-speed signal a d tie it to motion.feed-inhibit.
this will stop all motion when the spindle is not near enough to the commanded speed.
henk
henk
Time to create page: 2.695 seconds
