  • kn612
  • kn612
21 Jul 2025 13:23
Replied by kn612 on topic Servo Driver Plasma Retrofit
Category: Plasmac
Thank you for the help guys.  I am still building the computer/cnc.  Wiring the mesa hardware is all that's left.
With that said I am having issues installing Debian 12.  On install I get a bad mirror error.  Once installed sudo apt update gets a few repository errors.  I believe this is all from not being connected to Internet during the install.  Using a USB Wi-Fi dongle that is missing the driver during install, but once booted into Debian 12 is works.  I will try using Ethernet to connect to Internet on the next install.
With that said, are there any eatx or atx motherboards that work well out of the box with Debian 12?  I am using a dell optiplex 9010 motherboard that I put into an old hypertherm microdedge CNC case.
  • jlennox
  • jlennox
21 Jul 2025 13:16
Replied by jlennox on topic Control panel for Gmoccapy
Category: Gmoccapy
Very neat design you have.
What keycaps are you using and how are you doing the symbols / lettering, laser engraving?
  • krille
  • krille
21 Jul 2025 12:45
Raspberry p15 and linuxcnc 2.9.4 spindle speed
Category: Installing LinuxCNC
Hello I have Raspberry pi 5 and byte 2 bot hat on my mill and it works very fine and now i try to convert it to my lathe with a problem with the spindle speed reading and the index and phase a for cutting thread in the lathe . I have tried to read and understand the Hal mystery with a minor of luck . In Hal Meter i there are a signal at => lowpass.0.in but reading zero at  lowpass.0.out  => abs.0.in pyvcp_options.hal . Can somone helpfull help me with this problem / krister
  • stegrg
  • stegrg
21 Jul 2025 12:22
Hal Config 5i24+7i52+8i20 was created by stegrg
Category: Driver Boards
Hello,
I'm trying to find a simple HAL file to configure Hudson BLDC motors in qhi mode.  I have them running in h mode and qh mode, but I can't seem to get it running in qhi mode.  When I run it in qhi mode, the motor seems to spin only in h mode and doesn't switch to qi mode.  Does anybody have a simplified HAL file test script similar to the ones used in the following link for qhi mode?
forum.linuxcnc.org/forum/39-pncconf/2721...ting-up-5i257i858i20
Regards,
  • JT
  • JT's Avatar
21 Jul 2025 11:43 - 21 Jul 2025 15:58
Spindle Docs was created by JT
Spindle Docs
Category: LinuxCNC Documents
linuxcnc.org/docs/stable/html/getting-st...tion_files_for_2_9_y
Shows 4 configuration options for the ini file that don't limit the spindle rpm in any way, are these for master only?
4.1. Spindle limits in the INIIt is now possible to add settings to the [SPINDLE] section of the INI file
MAX_FORWARD_VELOCITY = 20000 The maximum spindle speed (in rpm)
MIN_FORWARD_VELOCITY = 3000 The minimum spindle speed (in rpm)
MAX_REVERSE_VELOCITY = 20000 This setting will default to MAX_FORWARD_VELOCITY if omitted.
MIN_REVERSE_VELOCITY = 3000` This setting is equivalent to MIN_FORWARD_VELOCITY but for reverse spindle rotation. It will default to the MIN_FORWARD_VELOCITY if omitted.
JT
  • Aciera
  • Aciera's Avatar
21 Jul 2025 11:08
Replied by Aciera on topic (solved) python error on startup
As the error message indicates:
print "change_prolog: Toolchanger soft fault %d" % int(self.params[5601])
Is invalid syntax for python 3. Possibly you imported the 'nc_files' folder from an older version of linuxcnc?
You might want to replace your "nc_files/remap_lib" folder with the one available here:
github.com/LinuxCNC/linuxcnc/tree/2.9/nc_files/remap_lib
  • Todd Zuercher
  • Todd Zuercher's Avatar
21 Jul 2025 11:02
Linuxcnc 2.4.5 with Ubuntu 10.04, Correct file path or structure ?
In the zip file you posted the only "extra" unneeded files I see are all of ones ending in ".halscope". You can safely delete all of those without causing any harm.
As to your issues with booting to live media or reinstalling Linuxcnc. You probably need to turn off those protections in the computer bios, and to do that may require the password to enter the bios editor. If you've forgotten the password, it might be possible to reset this by removing the cmos battery, to return the bios to its default settings.
  • Todd Zuercher
21 Jul 2025 10:30
Replied by Todd Zuercher on topic Axis Modifications
Axis Modifications
Category: AXIS
I've also found the included file browsing/file open ap within Axis to be very limiting to use. The work around we often used was to use the file browser of your choice on your Linux desktop to find the g-code file you want to run, then with a right mouse click use the "axis-remote" command to open to open the g-code file in Axis directly from the file browser. This was especially helpful when wanting to run files saved in network directories that you could not easily find or access using file open in Linuxcnc.
I don't know if this works using other Linuxcnc GUIs or if any of the other GUIs offer an equivalent command to axis-remote that can be used to open a g-code file from another file browser.
  • jochen91
  • jochen91
21 Jul 2025 10:09
Planning to Retrofit a Mazak Integrex200Y Mill-Turn Machine
I got bad news from the spindle repair shop. They gave me an estimated quote of 8-10k€,,, thats a little bit to much. I think I need do it on my own.
Need to watch some Robin Renzetti videos to get in the mood to touch that thing ;)
My plan is to replace the bearings on my own and than search for a service provider, that can regrind the taper on the machine.
  • zzrzzr
  • zzrzzr
21 Jul 2025 09:53
Replied by zzrzzr on topic PlasmaC Voltage Divider
Category: Plasmac
Thanks a lot for your replies.
The stahlwerk-plasmacutters look good.
I already have a THCAD10 that I use for my hypertherm powermax 1000g3, but the cut quality on the hyptherm is not the best because there is a thermal dynamics-torch mounted on the machine and it doesn't cut without an angle at 10mm steel (2mm bevel to the other side). I already changed most of the parts exept the starter cartrigde, and if I can't get it to work properly I need to buy another plasma-machine.
So I could change the Plasmacutter and still use the THCAD-10 if I add series resistors.
Maybe you can explain which exact resistor(s) I need and how exactly the resistors should be added to the plasma-cutter ? I
Somewhere I read that the THCAD should not be placed inside the controller-box ? Is that right ? So where should I put the THCAD 10 and the resistors ?
  • ChironFZ16
  • ChironFZ16's Avatar
21 Jul 2025 08:23 - 21 Jul 2025 08:23
Installation 2.9.4 Debian Bookworm Preempt-RT ISO // Probleme
Category: Deutsch
Ich hatte das gleiche Problem und mit sudo dpkg -P raspi-firmware gelöst
  • peterdownunder
  • peterdownunder
21 Jul 2025 07:28 - 21 Jul 2025 07:29
Replied by peterdownunder on topic (solved) python error on startup
Also just realised that when I start with the remap line in the ini file commented out the error still occurs, without the 2 lines after "Python plugin configure() failed, status = -11"
  • G0G53Z148
  • G0G53Z148's Avatar
21 Jul 2025 07:18
Replied by G0G53Z148 on topic Mesa Auswahl für größeres Projekt
Category: Deutsch
ich danke dir für die bestätigung das mit dem smart serial versteh ich zwar noch nicht wenn man´s aber nur wie du schreibst nur einstellen braucht :) wird das schon laufen irgendwie
Ein schönes Projekt ist es auf jedenfall und danke für dein angebot mich an dich wenden zu dürfen :)
  • peterdownunder
  • peterdownunder
21 Jul 2025 07:14 - 21 Jul 2025 07:22
(solved) python error on startup was created by peterdownunder
File Name: change.ngc
File Size:2 KB
Went to startup linuxcnc today and am getting the following error
Found file(REL): ./custom.hal
initialize: module '/home/peter/cnc/taigmesa/python/toplevel.py' init failed:
File "/home/peter/cnc/taigmesa/python/toplevel.py", line 19, in <module>
import remap
File "python/remap.py", line 19, in <module>
from stdglue import *
File "python/stdglue.py", line 59
SyntaxError: invalid syntax
Interp ctor: can't instantiate Python plugin
import remap
Python plugin required for prolog=, but not available: 78:REMAP = M6 modalgroup=6 prolog=change_prolog ngc=change epilog=change_epilog
Python plugin required for epilog=, but not available: 78:REMAP = M6 modalgroup=6 prolog=change_prolog ngc=change epilog=change_epilog
emc/task/emctaskmain.cc 3084: can't initialize interpreter
If I comment out the
REMAP=M6 modalgroup=6 prolog=change_prolog ngc=change epilog=change_epilog
from my ini file all is well, but obviously no tool change.
With it in it eventually starts up after the error above but is unusable.
Chacking against git history show no significant changes that I can see.
Linuxcnc version 2.9.3
UI is Gmoccapy
Python version is 3.7.3
Unsure where to start.
  • Benb
  • Benb's Avatar
21 Jul 2025 04:03
Inverting jogging sense of X Axis on a VistaCNC P1A-S pendant
Category: HAL
I looked at the official site for this pendant and the hal file is similar to yours.
Try this: I just flipped vc-p1as.jog.0.minus and vc-p1as.jog.0.plus
net jog.0.cont-plus       vc-p1as.jog.0.minus           halui.axis.x.plus         halui.joint.0.plus
net jog.0.cont-minus     vc-p1as.jog.0.plus              halui.axis.x.minus     halui.joint.0.minus
I this does not work perhaps you could double check the pendant configuration for errors.
Displaying 13966 - 13980 out of 14620 results.
Time to create page: 1.692 seconds
