  • jor
  • jor's Avatar
21 Jul 2025 01:32
How to install kernel patch? (Moschip 9900)
Category: Installing LinuxCNC
I found how to "enable" the parport without reboot with
echo 1 | sudo tee /sys/bus/pci/devices/0000:03:00.0/enable
which removes the "disabled" from lspci -v
but it doesn't cause the stepper to work again unless I reboot. Also, i was jogging before at low speed. I tried with higher speeds and it still has alot of that "pausing" going on even though latency is now like 4000. Plus, on starting my configuration it still has "error : unexpected realtime delay on task 1... run the latency test..."
  • dunnitagain
  • dunnitagain
21 Jul 2025 01:22
Linuxcnc 2.4.5 with Ubuntu 10.04, Correct file path or structure ?
Tried several times , Bios is correct settings , will not boot with the ISO . The machine will run with the other machines control plugged in . I posted a zip of the backup files. But there seems to be alot of extra files.
  • jor
  • jor's Avatar
21 Jul 2025 01:10
It seems to work better while it works, but it shortly stops and the parallel port becomes disabled, and I have to reboot. The pausing problem stopped and the latency is much better, but it gets disabled pretty quickly
  • tokomak
  • tokomak
21 Jul 2025 00:16
21 Jul 2025 00:09
www.linuxcnc.org/iso/ubuntu-10.04-linuxcnc3-i386.iso
Download, burn to USB, boot from that USB in LIVE mode, open file browser, insert the USB with the backup files, find the .ini file, right click on it and choose "open with", type emc2 or linuxcnc below, hit enter.
Does the machine run properly?
  • dunnitagain
  • dunnitagain
20 Jul 2025 23:50
To be Honest , I don't have the ability ,capability, or the time for a new configure. The system is password protected. I've tried to boot to a USB with the ISO on it . But the protection wont let me. So I cant do a fresh install.
  • Esaber
  • Esaber
20 Jul 2025 23:37
Replied by Esaber on topic Plasmac to Qtplasmac conversion not working
Category: Plasmac
I’m using the latest versiin of linuxcnc. I tried a new config before posting but got an error when launching qtplasmac. I will try again and post the error here. Thanks.
  • PCW
  • PCW's Avatar
20 Jul 2025 23:32
Replied by PCW on topic Mesa Configuration Tool
Category: Configuration Tools
You can also get a list of all enabled hardware pins with:
halcmd show all | grep hm2
When LinuxCNC is running.
  • Cerezas
  • Cerezas
20 Jul 2025 23:32 - 20 Jul 2025 23:44
Inverting jogging sense of X Axis on a VistaCNC P1A-S pendant
Category: HAL
I'm recalling a message where I stated that the problem was solved. It is not. I'm attaching the present state of the relevant .ini and .hal files.
  • Rickstar73
  • Rickstar73
20 Jul 2025 22:49
Replied by Rickstar73 on topic linuxcnc cmake project
How are you?
How are you progressing with this, did you get it to install successfully?
  • PCW
  • PCW's Avatar
20 Jul 2025 21:50 - 20 Jul 2025 21:52
Replied by PCW on topic 7i76EU Hal and Ini File
Category: HAL
If your current hal file is like the older one, enable is
controlled by joint.N.amp-enable-out. This will be true anytime
LinuxCNC is in the run state.
From the older hal file:
net x-enable <= joint.1.amp-enable-out
net x-enable => hm2_7i76.0.stepgen.01.enable
net x-enable => hm2_7i76.0.7i76.0.0.output-01
Didn't you mention that you had DMM drives?
AFAICR, these are disabled when the enable input is powered.
  • scotta
  • scotta's Avatar
20 Jul 2025 21:18
Hi, please share your LinuxCNC hal and ini files. Is the remora ethernet component loaded?
github.com/scottalford75/Remora-RT1052-c...omponents/Remora-eth
  • rocket6delta
  • rocket6delta
20 Jul 2025 20:27
Replied by rocket6delta on topic 7i76EU Hal and Ini File
Category: HAL
A better question I should ask is what kind of response or voltage should I see on the ENA pin when the jog is made? It's looks to be 24V and not changing.
  • rocket6delta
  • rocket6delta
20 Jul 2025 20:18
Category: HAL
i successfully updated to 2.9.4.  My pins are labeled as 7i76e now but i believe that is due to me picking 7i76 instead of 7i76e in pncconf.
However, I'm still not getting the motors to move.  It's changing the DRO and display in Axis.  I see voltage changes in Dir and Step pins but nothing changes.
Any ideas?
  • ZXT
  • ZXT
20 Jul 2025 20:05
Replied by ZXT on topic Touchscreen issues with debian12
Have anyone found a solution? I have the same problem with a Dell S2240T touchscreen, no double click or any clicks in QTdragonHD
Displaying 13981 - 13995 out of 14620 results.
Time to create page: 0.968 seconds
