  • cakeslob
  • cakeslob
03 May 2025 21:26
the documents will be updated to reflect the struggles of you and the other users this last week.
to the 2 other users who posted the quick guides for flashing and setup, i would like to use those in the remora docs, i hope this is ok
  • Spyderbreath
  • Spyderbreath's Avatar
03 May 2025 21:23
Replied by Spyderbreath on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
OK, progress! I put the #end-stops into my .hal file and BANG, I get a limit switch error reported in axis on pins 3, 5, and 7.
THANK YOU to all that have gotten me this far!! I now know that the remora flash took on the nvem and the hardware part is working.
Just the nightmare of figuring out the rest of the .hal file to get everything else working. But as for now, forward is a good direction to be heading. :)
  • cakeslob
  • cakeslob
03 May 2025 21:23 - 03 May 2025 21:24
the first part is what you add to the bottom of your hal file
the second part is a sample of the NVEM config.txt. the config.txt is what configures the remora hardware to the remora software. the hal file is what connects the remora software to the linuxcnc software. i included it to emphasize the relationship between which IO on the board does what in linuxcnc
The ini file is what configures your linuxcnc machine, so speeds of each axis, the travel, where the home switch is, how many axis/joints, the gui, etc
  • Hakan
  • Hakan
03 May 2025 21:08
Replied by Hakan on topic Using POSIX realtime
Category: EtherCAT
Just type the command "ethercat debug 1"
  • IB_CnC
  • IB_CnC
03 May 2025 20:57 - 03 May 2025 22:23
Probe Basic and Carousel ATC with Geneva and Stepper
Category: QtPyVCP
Today I rewired the carousel stepper driver to the MESA hardware stepgen nr4, which was a 5min job.
Consecutively, I spent 4 hours trying to get it running again.
The stepgen in velocity mode is controlled mainly by "velocity-cmd" which takes a float value.
Positive for CW and negative for CCW.
Main problem was setting the float value with the two digital outputs ( motion.digital-out-03 & motion.digital-out-04) that are triggered for CW and CCW carousel rotation.
But in the end I solved it using MUX4: linuxcnc.org/docs/2.4/html/man/man9/mux4.9.html
# --- (Carousel CCW / REV)
net ATC_Motor_CCW mux4.0.sel0 <= motion.digital-out-03
net ATC_Motor_CW mux4.0.sel1 <= motion.digital-out-04
net ATC_Motor_DIR_VEL hm2_7i96s.0.stepgen.04.velocity-cmd mux4.0.out
net ATC_Motor_CCW_SPD mux4.0.in1
sets ATC_Motor_CCW_SPD 5000
net ATC_Motor_CW_SPD mux4.0.in2
sets ATC_Motor_CW_SPD -5000
net ATC_Motor_OFF_SPD mux4.0.in0
sets ATC_Motor_OFF_SPD 0
net ATC_Motor_OFF2_SPD mux4.0.in3
sets ATC_Motor_OFF2_SPD 0
#*******************# ATC Stepgen#*******************
# Step Gen signals/setup
setp hm2_7i96s.0.stepgen.04.steplen 20000       # Step length (nanoseconds) 20 usec
setp hm2_7i96s.0.stepgen.04.stepspace 20000  # Step space (nanoseconds) 20 usec
setp hm2_7i96s.0.stepgen.04.maxaccel 50000    # Maximum acceleration (steps/second^2) so 1/10 second to full speed
setp hm2_7i96s.0.stepgen.04.maxvel 5000         # Maximum velocity (steps/second)
setp hm2_7i96s.0.stepgen.04.step_type 0           # Regular step type
setp hm2_7i96s.0.stepgen.04.dirsetup 50000      # Direction setup time (nanoseconds) 50 usec
setp hm2_7i96s.0.stepgen.04.dirhold 50000        # Direction hold time (nanoseconds) 00 usec
setp hm2_7i96s.0.stepgen.04.control-type 1        # Control type (1 for velocity control)
setp hm2_7i96s.0.stepgen.04.enable True            # Enable the step generator initially
No more delayed response!!!
  • csurimilan
  • csurimilan
03 May 2025 20:47
How to change jog speed using joystick buttons (QtDragon + HAL)?
Category: HAL
Do you have an idea how can i solve this issue?
  • Spyderbreath
03 May 2025 20:36
Correct me if I am wrong, being all new to this, but that first bit of "code" you listed there looks to be from a .hal file and not an .ini file? If so then that gets me even further along and might be enough for me to get dangerous and take a stab at it.
  • meister
  • meister
  • endian
  • endian's Avatar
03 May 2025 20:07
WEMAS MT 32 CNC Lathe -> LinuxCNC - Mesa or EtherCAT?
Category: Turning
What do you mean with "SoE"?
Maybe i try to get a used Beckhoff AX5xx from eBay when thats easyer to use with LCNC.
... the SIEMENS etherCAT pcb is hard to get. it starts to annoying me...
endian post=327010 userid=29161
AX5xxx from beckhoff is SoE and it can be pain to create custom .xml which should be editable out of Sachas own .xml files...
SoE does mean - Sercos over Ethercat ... similar to CoE - CANopen over Ethercat ... You can imagine that ethercat itself is a empty lorry train were many different buses/networks shape members can sit a transport itself where they are need ..but very fast, synchro and with many many diagnostic stuff
I have never creating custom .xml file for them only for CoE stuff I have done it... I think if you are basic user it should be enough for you to use .xml config from saschas shop but ... it has many many very usefull stuff as monitoring the native I/Os ... external encoder - basically for external encoder as linear scales to run velocity loop over them ...
  • cakeslob
  • cakeslob
03 May 2025 19:38
hmm i thought we had a full config somewhere with spindle. I guess its time to make one (aka copy flexihal). Ill try to mash out a regular config based on my setup
  • cakeslob
  • cakeslob
03 May 2025 19:36
yes the config wizards will be less than helpful in most cases. limits are easy, but estop is a case by case basis depending on how you wish to wire/config your estop. tux posted his estop example a few pages back, and there is an estop example in the remora docs hal section.
for the ini file, yes read the manual, but dont start adding a bunch of options that might not apply to remora.
based on my friends rast's config, the endstops might look like this depending if you do a limit or a limit+ home config. it looks like he has included both in his ini file.
# end-stops
#pin IN03
	#net X-max       remora.input.06        =>  joint.0.pos-lim-sw-in
	net both-x       remora.input.06        =>  joint.0.home-sw-in joint.0.pos-lim-sw-in
#pin IN04
	#net X-min       remora.input.07         =>  joint.0.neg-lim-sw-in
#pin IN05
	#net Y-max       remora.input.08         =>  joint.1.pos-lim-sw-in
	net both-y       remora.input.08        =>  joint.1.home-sw-in joint.1.pos-lim-sw-in
#pin IN06
	#net Y-min       remora.input.09         =>  joint.1.neg-lim-sw-in
#pin IN07
	net both-z       remora.input.10         =>  joint.2.pos-lim-sw-in
the important part is making sure your remora.input.xx match the config.txt file. from the nvem config, label IN03 on the cover of the NVEM board is connected top data bit 6, aka remora.input.06
	"Thread": "Servo",
	"Type": "Digital Pin",
		"Comment":			"IN03",
		"Pin":				"P4_21",
		"Mode":				"Input",
		"Data Bit":			6,
		"Invert":			"True"
  • Aciera
  • Aciera's Avatar
03 May 2025 19:31 - 03 May 2025 19:46
Beginner Building a CNC - Questions About EtherCAT with Delta A2 and In
Some ethercat drives offer built in digital IO that can be used. Ideally the VFD used would also have an ethercat interface.
Many VFDs also offer an RS485 (Modbus) interface which can also be connected to linuxcnc via a USB-RS485 adapter.
LPT can certainly work but it can be a bit tricky to find a PC with low enough latency.
Given the isolation of your market you might want to start out by looking for a used PC with an LPT and an ethernet port and see how low you can get the latency. Mind you, I have no idea how easy/cheap it is for you to find used PCs to try but this would give you an idea of what step rates you could get out of an LPT port solution before buying the drives.
[edit]
I think it should be possible to use ethercat for the drives and the LPT port with one of those cheap breakout boards for the digital IO and the VFD.
  • DarkPhoinix
  • DarkPhoinix
03 May 2025 18:41
Replied by DarkPhoinix on topic [SOLVED]linuxcnc Latency test ambiguous results
Old card nvidia
new amd gifted by my friend
4 winodws firefox youtube 4k and rustdesk!
  • Spyderbreath
03 May 2025 18:40
Thanks for that fast reply! OK, so if I am understanding correctly, the EC500.hal is universal for all 3 RT1052 based controllers and I just need to edit the .ini file for my machine?
I have uploaded the nvem-rt1052.txt to the controller, and that seems to of worked well.
Looking at the ini file I am now seeing what my first problem has been, as nothing is there but the config for X Y and Z. No Estop, limit switches, spindle, etc.. So at this point I will need to go and RTFM, (this? linuxcnc.org/docs/2.8/html/config/ini-config.html), on the ini file and try to figure out what I am suppose to put there to get the rest to go.
Given that I am unfortunately a 101% tactile learner, where would be the best place on the forum to ask my questions about what I'm getting wrong as I proceed with this editing attempt?
Thanks again for the info as I have not seen that part explained before. This is a bit of help in the right direction. I'll take it none of the configuration wizards will be of any help in this endeavor?
  • PCW
  • PCW's Avatar
03 May 2025 18:25
None of the axis are moving - using mesa 7i92t with 7i76u
Category: Basic Configuration
Do not wire Enable until you get things working.
Yep, on simple step drives, its a DISABLE input.
Displaying 16261 - 16275 out of 17066 results.
Time to create page: 0.496 seconds
