  • andypugh
  • andypugh's Avatar
21 Apr 2025 17:47
Replied by andypugh on topic ChatGPT LinuxCNC Assistent
Category: Configuration Tools
# Laden der Kinematik und des Benutzermodus-Stepgen
loadusr -W stepgen
loadusr -W remora-eth-3.0
This is just wrong (typical AI error?)
stepgen is realtime, and should be loaded with "loadrt"
I would rather expect that the same is true of remora-eth-3.0 (if that even exists)
linuxcnc.org/docs/stable/html/man/man9/stepgen.9.html
  • andypugh
  • andypugh's Avatar
21 Apr 2025 17:31
Replied by andypugh on topic How to homing the A-axis again with gcode?
Category: AXIS
I can't immediately think of a way to do what you ask.
It would be possible if M5 was re-mappable, but I don't think it is.
If you can use (for example) M15 in place of M5, then that could be remapped to:
wait for spindle stopped
measure the current angle
reset the offset (as described earlier)
rapid to A=0
linuxcnc.org/docs/stable/html/remap/rema...remap:existing-codes
  • andypugh
  • andypugh's Avatar
21 Apr 2025 17:17
Need help making rotary axis behave like second spindle
And also note that you can split the HAL entries between files, too, if you use a common signal name. (eg all main HAL signals are available in the postgui halfile)
  • andypugh
  • andypugh's Avatar
21 Apr 2025 17:12
Replied by andypugh on topic Digital Input
Digital Input
Category: O Codes (subroutines) and NGCGUI
is "mesa-input-pin" just a placeholder?
I don't really understand the question. Are you wanting to not have the HAL entry for some reason?
  • andypugh
  • andypugh's Avatar
21 Apr 2025 17:07
  • andypugh
  • andypugh's Avatar
21 Apr 2025 17:06
Replied by andypugh on topic boxford 160tcl
boxford 160tcl
A multimeter in diode-check mode can identidy the LEDs. (almost certainly black gnd and red power) and then if the other two are wrong, swap them. P should be several pulses per rev, I should be one pulse per rev.
  • bkt
  • bkt's Avatar
21 Apr 2025 16:26
First time to try build my xml for not listed ethercat in-out component
Category: EtherCAT
I made a test in these way .....
<masters>
<master idx="0" appTimePeriod="8000000" refClockSyncCycles="1">
    <slave idx="0" type="generic" vid="0x00000b3d" pid="0x29c9f7b1" name="D1">
      <!--S1-M20-->
      <syncManager idx="0" dir="in"/>
      <syncManager idx="1" dir="out"/>
      <syncManager idx="2" dir="out">
        <pdo idx="1600">
          <!--Output Data-->
          <pdoEntry idx="7000" subIdx="01" bitLen="32" halType="complex">
            <complexEntry bitLen="1" halPin="out-1" halType="bit"/>
            <complexEntry bitLen="1" halPin="out-2" halType="bit"/>
            <complexEntry bitLen="1" halPin="out-3" halType="bit"/>
            <complexEntry bitLen="1" halPin="out-4" halType="bit"/>
            <complexEntry bitLen="1" halPin="out-5" halType="bit"/>
            <complexEntry bitLen="1" halPin="out-6" halType="bit"/>
            <complexEntry bitLen="1" halPin="out-7" halType="bit"/>
            <complexEntry bitLen="1" halPin="out-8" halType="bit"/>
            <complexEntry bitLen="1" halPin="out-9" halType="bit"/>
            <complexEntry bitLen="1" halPin="out-10" halType="bit"/>
            <complexEntry bitLen="1" halPin="out-11" halType="bit"/>
            <complexEntry bitLen="1" halPin="out-12" halType="bit"/>
            <complexEntry bitLen="1" halPin="out-13" halType="bit"/>
            <complexEntry bitLen="1" halPin="out-14" halType="bit"/>
            <complexEntry bitLen="1" halPin="out-15" halType="bit"/>
            <complexEntry bitLen="1" halPin="out-16" halType="bit"/>
          </pdoEntry>
      </pdo>
      </syncManager>
      <syncManager idx="3" dir="in">
        <pdo idx="1a00">
          <!--Input Data-->
          <pdoEntry idx="6000" subIdx="01" bitLen="32" halType="complex">
            <complexEntry bitLen="1" halPin="in-1" halType="bit"/>
            <complexEntry bitLen="1" halPin="in-2" halType="bit"/>
            <complexEntry bitLen="1" halPin="in-3" halType="bit"/>
            <complexEntry bitLen="1" halPin="in-4" halType="bit"/>
            <complexEntry bitLen="1" halPin="in-5" halType="bit"/>
            <complexEntry bitLen="1" halPin="in-6" halType="bit"/>
            <complexEntry bitLen="1" halPin="in-7" halType="bit"/>
            <complexEntry bitLen="1" halPin="in-8" halType="bit"/>
            <complexEntry bitLen="1" halPin="in-9" halType="bit"/>
            <complexEntry bitLen="1" halPin="in-10" halType="bit"/>
            <complexEntry bitLen="1" halPin="in-11" halType="bit"/>
            <complexEntry bitLen="1" halPin="in-12" halType="bit"/>
            <complexEntry bitLen="1" halPin="in-13" halType="bit"/>
            <complexEntry bitLen="1" halPin="in-14" halType="bit"/>
            <complexEntry bitLen="1" halPin="in-15" halType="bit"/>
            <complexEntry bitLen="1" halPin="in-16" halType="bit"/>
          </pdoEntry>
      </pdo>
      </syncManager>
    </slave>
  </master>
</masters>
same result ..... no lcec.0.op-state true....????
  • pgf
  • pgf
21 Apr 2025 15:20
After homing X and Y, can I auto move to a non 0,0 location?
I've now tested my original homing-at-0 config, with HOME=12, and it does indeed home as usual, and then set the current position to 12. So the question asked in the thread title is answered.
I'd still like to home-at-12, instead.
  • Didi
  • Didi
21 Apr 2025 14:33 - 21 Apr 2025 14:39
Replied by Didi on topic Proxxon CU4
Proxxon CU4
In my opinion they are using the "Leadshine DM542EU" stepper motor controllers, but I couldn't identify the BOB. So, thank you for that info.
  • besriworld
  • besriworld
21 Apr 2025 14:10
Replied by besriworld on topic Lathe with C axis
Lathe with C axis
You can add a second servo motor with a gear like HAAS does
I think it's better if the second encoder goes to the mesa card.
  • vre
  • vre
21 Apr 2025 14:07 - 21 Apr 2025 21:31
Digital Input was created by vre
Digital Input
If i have this in hal
#M66 Digital Inputs
net spindle-stoped motion.digital-in-03 mesa_input_pin
and this subroutine code
M66 P3 L3 Q4 ;Check for spindle stopped - wait up to 4 seconds for digital input 3 to turn on
o307 if [#5399 LT 0]
(abort, spindle not stopped)
o307 endif
How can change this code to check if spindle is stopped
if i have not set this pin
In reality spindle is connected to mesa daughter card 7i33
and i want to check from subroutine code if it is stopped.
  • PCW
  • PCW's Avatar
21 Apr 2025 13:59
Replied by PCW on topic Proxxon CU4
Proxxon CU4
Its parallel port compatible (uses the common "Mach 5 Axis BOB" inside)
So would work with a parallel port or Ethernet/SPI/GPIO/etc device that has a
parallel port like interface.
  • vre
  • vre
21 Apr 2025 13:59
Replied by vre on topic spindle with encoder
Category: Basic Configuration
To mechanically adjust the exact same ratio is very difficult
Also with counter chips division maybe can not be integer multiple
so the only real option is to mount and aluminum disk to spindle shaft
and because my spindle shaft from top has the hydraulic cylinder that locks the tool
the only place can put this is only to the downside of spindle shaft.
How many lines must have the disc for rigid tapping ?
Also must have disc with A B and Z signals or only A is enough ?
  • dctrytsman
  • dctrytsman
21 Apr 2025 13:40
Replied by dctrytsman on topic Lathe with C axis
Lathe with C axis
I had a look at it today again and realized I won't be able to make it work. The backlash in the gearbox will not allow me to machine the part accurately. I'm won't be attempting this any further. Unfortunately this machine was not designed to have a c-axis.
  • pgf
  • pgf
21 Apr 2025 13:33
That would be great -- but I'd also be happy with simply max-X and max-Y.
Displaying 16981 - 16995 out of 17102 results.
Time to create page: 0.403 seconds
