  • JetForMe
  • JetForMe's Avatar
11 Mar 2025 00:06
Replied by JetForMe on topic GladeVCP and venv?
GladeVCP and venv?
Category: GladeVCP
Did you figure it out? I want to use a Rust library in my VCP, but I only know how to install it as a package in a virtual environment.
Oh gosh, I can't remember! It's been so long since I worked on that project! I’m definitely using a venv, but I'm not sure I was able to switch the Python interpreter.
  • JTknives
  • JTknives's Avatar
10 Mar 2025 23:51 - 11 Mar 2025 01:09
Replied by JTknives on topic QTplasmaC upgrade now huge latency
I was looking at upgrading my J1900 brix to a brix with an i7-5775 and 16gr of ram. Is this a fool’s errand or will this help future proof my system?
ps I snagged a BRIX with a i7-5775 for a killer deal so it’s on its way.
  • vre
  • vre
10 Mar 2025 23:51 - 11 Mar 2025 00:00
Replied by vre on topic mesa 7i33 7i37
mesa 7i33 7i37
Category: Driver Boards
What do you mean after configuration?
After loading firmware from flash memory?
When you powering fpga the firmware loads almost immediately...
How to enable xilinx weak internal pulldowns?
  • Lcvette
  • Lcvette's Avatar
10 Mar 2025 23:39 - 10 Mar 2025 23:40
Replied by Lcvette on topic Permanent probing parameters
Category: QtPyVCP
Update your subroutines folder and add the var file parameters per the instructions on the splash page. Will fix your issue. Use the sim config folder for reference.
  • JTknives
  • JTknives's Avatar
10 Mar 2025 22:32
Thank you very much. I will look at your guide.
  • FraesPaul
  • FraesPaul
10 Mar 2025 22:20
Installation 2.9.4 Debian Bookworm Preempt-RT ISO // Probleme
Category: Deutsch
3 Probably because QtDragon does not use the same enable pin as GmoccaPy, although if that is the case, i would really insist on fixing that in QtDragon.
Can you upload config files for both GUI's?
hattest Du schon Zeit mal einen Blick auf meine Konfiguration zu werfen ?
Have you had time to take a look at my configuration ?
  • PCW
  • PCW's Avatar
10 Mar 2025 22:02
7i95t pin and firmware files with Stepgens and Inputs 5Axis BoB
To invert a GPIO input, you use the inverted pin, for example:
hm2_7i95.0.gpio.054.in_not
  • Khan
  • Khan
10 Mar 2025 21:40
Replied by Khan on topic Delta VFD-B Modbus with QtDragon_hd
thank you,
you are right, i think there is already a driver available for my vfd, after some googling around i found this,
github.com/araisrobo/linuxcnc/tree/maste.../user_comps/vfdb_vfd
linuxcnc.org/docs/2.7/html/man/man1/vfdb_vfd.1.html
  • PCW
  • PCW's Avatar
10 Mar 2025 21:11
Replied by PCW on topic OLD Lathe conversion to a CNC
Category: Turning
In the lspci command:
lspci | grep -i eth
The | is a vertical bar character (pipe) not an uppercase i
  • besriworld
  • besriworld
10 Mar 2025 20:41
Replied by besriworld on topic OLD Lathe conversion to a CNC
Category: Turning
After the series of errors I decided to update. But I guess I've had this kernel before. During the update the system showed some errors... I'll try to investigate tomorrow.
  • Stran_ge
  • Stran_ge
10 Mar 2025 20:33
Permanent probing parameters was created by Stran_ge
Category: QtPyVCP
Hey,
are the probing parameters supposed to be reset after every pc restart or should they stay in the .var file.
For some reason after a pc restart they always revert to very old settings that i set long time ago.
Bst regards
Nils
10 Mar 2025 20:30
Replied by tommylight on topic LinuxCNC 2.9.4 Released
Category: Installing LinuxCNC
Update the kernel to at least 6.8.n, preferably 6.12.n.
10 Mar 2025 20:26
Replied by tommylight on topic OLD Lathe conversion to a CNC
Category: Turning
I wonder, why was the kernel not updated for the 2.9.4 ISO????
6.1.n kernel has huge latency and networking issues that are frankly getting to damn tiresome to read about them daily for nearly two years.
I have 6.8.n and 6.10.n on laptops without any issues.
  • besriworld
  • besriworld
10 Mar 2025 20:19 - 10 Mar 2025 20:20
Category: Turning
Thanks for joining. Here's what it showed.
moriseiki@debian:~$ sudo chrt -f 99 ping -i .001 -q -c 60000 10.10.10.10
PING 10.10.10.10 (10.10.10.10) 56(84) bytes of data.
--- 10.10.10.10 ping statistics ---
60000 packets transmitted, 60000 received, 0% packet loss, time 59999ms
rtt min/avg/max/mdev = 0.065/0.074/0.241/0.007 ms
moriseiki@debian:~$ lspci I grep -i eth
Usage: lspci [<switches>]
Basic display modes:
-mm        Produce machine-readable output (single -m for an obsolete format)
-t        Show bus tree
Display options:
-v        Be verbose (-vv or -vvv for higher verbosity)
-k        Show kernel drivers handling each device
-x        Show hex-dump of the standard part of the config space
-xxx        Show hex-dump of the whole config space (dangerous; root only)
-xxxx        Show hex-dump of the 4096-byte extended config space (root only)
-b        Bus-centric view (addresses and IRQ's as seen by the bus)
-D        Always show domain numbers
-P        Display bridge path in addition to bus and device number
-PP        Display bus path in addition to bus and device number
Resolving of device ID's to names:
-n        Show numeric ID's
-nn        Show both textual and numeric ID's (names & numbers)
-q        Query the PCI ID database for unknown ID's via DNS
-qq        As above, but re-query locally cached entries
-Q        Query the PCI ID database for all ID's via DNS
Selection of devices:
-s [[<domain>]:]<bus>]:][<slot>][.[<func>    Show only devices in selected slots
-d [<vendor>]:[<device>][:<class>]        Show only devices with specified ID's
Other options:
-i <file>    Use specified ID database instead of eth
-p <file>    Look up kernel modules in a given file instead of default modules.pcimap
-M        Enable `bus mapping' mode (dangerous; root only)
PCI access options:
-A <method>    Use the specified PCI access method (see `-A help' for a list)
-O <par>=<val>    Set PCI access parameter (see `-O help' for a list)
-G        Enable PCI access debugging
-H <mode>    Use direct hardware access (<mode> = 1 or 2)
-F <file>    Read PCI configuration dump from a given file
  • jayyhu
  • jayyhu's Avatar
10 Mar 2025 20:06 - 10 Mar 2025 20:34
External comp driver for custom hostmot2 module
Category: HAL
Hello,
I'm currently in the process of creating a new module for the 7i80 FPGA, and realizing that I also need to add a driver on the LinuxCNC side. Since the module is pretty niche, I'm trying to avoid modifying the entire Hostmot2 driver (and then worry about having to maintain my local copy against master every time there's a version change), so I was wondering if it was possible to write a driver for Hostmot2 as an external comp. I've seen the mesa_7i65.comp and mesa_uart.comp examples, but I'm more interested in the low level register access (eg. how the inmux driver communicates with the inmux module on the FPGA).
Thanks,
James H.
Displaying 17941 - 17955 out of 18523 results.
Time to create page: 4.146 seconds
