  • JB-Motoring
  • JB-Motoring
19 Feb 2025 15:05
Replied by JB-Motoring on topic Mesa 7i97T + 7i84 + 7i78 configuration
Hey JT,
thanks mate! I finally got it "running".
I will try some things tomorrow. What do I have to modify in the HAL to accept the 7i78? Or is it working already? :)
Thanks!!
BR
  • Aciera
  • Aciera's Avatar
19 Feb 2025 14:45
Replied by Aciera on topic scurve trajectory planner
strange thing is that I seem to able to build 'libdogleg' git repo you linked above which also includes 'chmod.h'. Had to install 'mrbuild' though.
  • Aciera
  • Aciera's Avatar
19 Feb 2025 14:13 - 19 Feb 2025 14:14
I have those installed but still complains about missing 'cholmod.h':
  • Grotius
  • Grotius's Avatar
19 Feb 2025 13:39 - 19 Feb 2025 13:47
Replied by Grotius on topic scurve trajectory planner
Hi Arciera,
I installed both off them in a hurry. I think this one :sudo apt-get install libdogleg2
apt-cache search libdogleg -> gives both :  libdogleg-dev  & libdogleg-dev
Ok,
I am a little further.
There is added a test : single_clothoid_fit();
This is a test, given a clothoid start point, end point.
It is a single clothoid, so no clothoid compound.
  • meister
  • meister
19 Feb 2025 13:29 - 19 Feb 2025 13:40
RPi + Sipeed Tang Nano 20 k: new breakout board for LitexCNC
Category: Driver Boards
is it possible to view the circuit diagram somewhere ?
EDIT: and how many Logic-Cells you need for a 3Axis Mill ?
  • gmouer
  • gmouer
19 Feb 2025 13:23
Replied by gmouer on topic development of a qt version of ncam
Category: Qtvcp
Is the work on ncam still ongoing? I loved using it and have not upgraded my lincnc in years because I don't want to loose it.
I recently played with Pathpilot again but it is a bear to work with and adapt to a non tormach machine. My only real reason for exploring Pathpilot is its excellent conversational. Unfortunately the Pathpilot section for this forum is all but dead, virtually no activity in years so a lot is greatly outdated.
I have not seen a Lcnc screenset with decent (any) conversational to date unless I am missing something.
I would sure love to see Ncam brought back to life. Any updates would be greatly appreciated.
  • Aciera
  • Aciera's Avatar
19 Feb 2025 13:13
I get this error when building your repo:
  • Grotius
  • Grotius's Avatar
19 Feb 2025 13:01
@Arciera,
I think this : sudo apt-get install libdogleg-dev
In the mean time, i have seen the params[index], had a flaw. I repaired that. Git is updated.
Now still wrong results. I think the Jacobian setup is incorrect also.
  • Chris54636
  • Chris54636
19 Feb 2025 12:40
Replied by Chris54636 on topic G41 G42 Problem
G41 G42 Problem
Category: G&M Codes
Hmmm, you meen i can change the diameter in the tool table from 4mm to 1mm.
If i also reduce the diameter in the program by 3mm, it is possible to use G41.
Yes, this is a possibility, but not a nice one, where mistakes can easily happen.
I understand that many people want to keep the current function of G41, but what's wrong with a 2nd function that works like all other controllers and doesn't require any tricks?
Best Chris
  • JT
  • JT's Avatar
19 Feb 2025 12:33
The smart serial card does not need firmware. The 7i97t_7i78d.bin firmware is what you want and you can flash it with the Mesa Configuration Tool .
JT
  • Aciera
  • Aciera's Avatar
19 Feb 2025 12:29
How would I add the dogleg dependencies to your cloned repo?
  • unknown
  • unknown
19 Feb 2025 12:08
Replied by unknown on topic The dumification of humanity through internet
Then we have a situation where some people believe what is contrary to science and create rules that do not allow you to question the belief.
  • denhen89
  • denhen89's Avatar
19 Feb 2025 11:27
(LPT) Debian 12 Latency spikes/unexpected real time delay. Looking for solution.
Thanks for that.
I believe that what Rodw wrote is the reason why i could not anymore open the shared folder, but its funny that in short time this stopped working, as well as the internet browser and also OneDrive setup on wheezy.
The solution is to edit the SMB policy on your windows box and it works perfectly.
I am not expecting that you write me a tutrorial how to get it work, but if you have a simple tutorial, please send me a link. If the new radeon vga will not solve the latency problem, but i will know that i can setup samba on wheezy, then i will do it. If not, i buy the mesa 7i92TF or 7i76e.
  • JT
  • JT's Avatar
19 Feb 2025 10:55
Replied by JT on topic Mesa Configuration Tool
Category: Configuration Tools
7i76EU has been added to Mesa CT just now. I've not tested the configuration yet.
JT
  • JB-Motoring
  • JB-Motoring
19 Feb 2025 10:46
Mesa 7i97T + 7i84 + 7i78 configuration was created by JB-Motoring
Hey guys,
it's been a while since my last post. :)
I am currently working on retrofitting a DMG 50 with analog +-10V Simodrives.
The Mesa's for this project are already laying on my desktop.
I am coming from 7i92 + 7i77, so many tutorials for these builds. Now with the 7i97T i am kinda lost when it comes to flashing.
I need a bin file for the combination :
7i97T
7i84 - over TB4 (ethernet)
7i78 - over P2
Can anyone bring some light into this? Or already used this combination?
The 7i78 is "only" for backup if more encoders are needed- so maybe I can start the config without it.
Thanks in advance for any help guys :))
BR Joel
Displaying 18751 - 18765 out of 19187 results.
Time to create page: 0.676 seconds
